POV-Ray : Newsgroups : povray.off-topic : Math questions Server Time
20 Nov 2026 13:22:03 EST (-0500)
  Math questions (Message 1 to 50 of 90)
Goto Latest 50 Messages Next 40 Messages >>>
Subject: Math questions
Date: 13 Jul 2013 09:50:42
Message: <51e15b32@news.povray.org>
1) Does a unit square contain the same amount of points as a unit line?
(We are talking about real numbers here.)
2) If yes, that means there has to be a 1-to-1 mapping between those
points. Give a function that expresses such a mapping.
3) If the answer to the first question is yes, then it follows that
the amount of points inside a unit cube is also the same as the amount
of points on a unit line. The same for a four-dimensional hypercube,
and so on. Can you give a generic function that gives a 1-to-1 mapping
between a unit line and an n-dimensional unit cube?
4) So the next question is: Does a countably-infinite-dimensional unit
cube contain the same amount of points as a unit line? If yes, can you
give a 1-to-1 mapping between them?
5) And the logical extreme: Does an uncountably-infinite-dimensional
unit cube contain the same amount of points as a unit line? Explain why.
(Also explain how the number of dimensions can be uncountably infinite.
That seems to defy the definition of "dimension".)
Subject: Re: Math questions
Date: 13 Jul 2013 10:29:54
Message: <51e16462$1@news.povray.org>
I would say no. They are different orders of infinity.
I recommend Rudy Rucker's fiction book White Light as a good entry to
thinking about infinity. It is a bit strange but easier to read than
Edwin Abbott Abbott's Flatland.
http://en.wikipedia.org/wiki/White_Light_%28Rudy_Rucker_novel%29
Regards
Date: 13 Jul 2013 10:43:32
Message: <51e16794$1@news.povray.org>
Weirdly, yes.
(As an aside, if the answer were no, the rest of the questions all
become in applicable, which kind of gives the game away...)
Given the 2D coordinates of a point on the unit square, you can
interleave their decimal digits, which always yields a unique point on
the unit line. For example,
   0.3425
   0.2183 -> 0. 32 41 28 53
This amounts to interleaving N sequences of digits rather than just two.
Now I'm lost. I can neither prove nor refute that the cardinalities match.
Date: 13 Jul 2013 12:16:38
Message: <51e17d66$1@news.povray.org>
Le 13/07/2013 15:50, Warp nous fit lire :
Yes. It must be, from Cantor, something bigger than Aleph-0. (and is not
countable)
IIRC, Peano curve would do. Expressing the position of any point using
(x,y) can be replaced with the ratio (between 0 and 1) over the Peano
curve of the length to reach the position over the total length of the
curve (and the precision of the ratio number can be used to infer the
order of the peano curve, or you can use any very big order of Peano
curve as it suits you)
You can also consider Wunderlich curves. Same approach. All real numbers
in [0,1) maps to the points on the unit square.
Be careful, using infinite and common sense might yields some surprise.
A basic approach would be to convert the first two coordinates (both in
[0,1) ) into a single coordinate using either Peano or Wunderlich, and
then repeat.
 X,Y -> a
 X,Y,Z -> a,Z -> b
 X,Y,Z,T -> a,Z,T -> b,T -> c
 C0,C1,C2,... Cn -> (C0,C1)->p0,C2,... Cn
Yes, apply the answer of point 3, once the dimension value has been
mapped (because countably-infinite) to the set of natural number , in
order to have the number of original coordinates.
The mapping (of dimension) is obvious, because it is the definition of
the countably-infinite. ("obvious" as in math, after 10 to 2000 pages of
demonstration and 40 minutes or 500 years of intense thinking)
No.
Dimension can be uncountably infinite if it is not mappable to the set
of natural number. Such case can be the set of real number in [0,1),
(see Cantor's diagonal).
The number of dimension can be uncountably infinite as soon as the
number of dimension is no more restricted to a value mappable to the set
of natural integer. Fractal object have such dimension.
Date: 13 Jul 2013 12:44:11
Message: <51e183db@news.povray.org>
You would have to explain that in more detail.
Remember that, for example, one could easily think that there are "more"
rational numbers than there are integers. Yet that's not correct. There
are equally many. (That's because it's possible to construct a one-to-one
relationship between every rational number and every integer.)
If you can construct a function that gives a one-to-one mapping between
the points on a unit line and the points on a unit square, that means
that both sets have the same size (as unintuitive as that might sound.)
Date: 13 Jul 2013 12:47:09
Message: <51e1848d@news.povray.org>
>    0.3425
That doesn't work because it's not a one-to-one mapping. Ie. the mapping
is not unambiguous.
Date: 13 Jul 2013 12:47:29
Message: <51e184a1@news.povray.org>
Nothing in set theory is intuitive. ;-)
Date: 13 Jul 2013 12:48:26
Message: <51e184da$1@news.povray.org>
>>     0.3425
> is not unambiguous.
That would imply that two distinct 2D points exist which map to the same
1D point. Can you provide such a counter-example?
Date: 13 Jul 2013 12:55:02
Message: <51e18665@news.povray.org>
> No.
Note that this might be a bit of a trick question. It's talking about
an "uncountably-infinite-dimensional *unit cube*". As you say,
dimensionality being uncountably infinite requires non-integral dimensions.
Thus answering the question correctly would first require demonstrating
whether a non-integral-dimensional unit cube can exist. (I think it can't,
because it goes contrary to the definition of "cube".)
Of course for the sake of the question we can loosen up the requirement
of the object being a unit cube and simply say that it's an arbitrary
object of a unit "volume".
Date: 13 Jul 2013 13:07:05
Message: <51e18939@news.povray.org>
> >>     0.3425
> > is not unambiguous.
By using a decimal notation you are equating the set of real numbers
with the set of integers, thus making the assumption that the set of
real numbers is countable. Not all real numbers can be represented with
digits, because digits can only be used to represent a countably infinite
set, which the set of reals isn't.
Date: 13 Jul 2013 13:07:25
Message: <51e1894d$1@news.povray.org>
I got it wrong. It is not multiplying or raising the dimension that
changes the size/order of an infinitive set. It is raising it by itself.
E.g. multiplying the number of real numbers on a line by itself,
itself's times. (Badly explained but I'm sure you can work out what I mean.)
I had a really bad journey yesterday, sitting on a grounded plane at the
wrong airport for four hours. So I am not going to hurt my brain any
more by reading about the perverted going ons of trans-infinities.
(If fractions were good enough for Alfred E Neuman then 11 dimensions,
or is that 10, are good enough for me. :-) )
Regards
Date: 13 Jul 2013 13:27:25
Message: <51e18dfd$1@news.povray.org>
>>>>      0.3425
>>> is not unambiguous.
I was under the impression that if you allow infinitely long decimal
expansions then all reals are representable.
Date: 13 Jul 2013 14:13:18
Message: <51e198be$1@news.povray.org>
Le 13/07/2013 18:55, Warp nous fit lire :
>> No.
Nope, the question is similar to asking: can a white crow swim ?
The answer does not have to prove the existence of a white crow. But
using the properties of such white crow, answer the question of the
capability to swim or not.
Nevertheless, my answer is bit out of scope, regarding the question: it
just asserts that the previously used method of mapping to a single
value cannot be used with a non-integral-dimensional unit-cube. Maybe
there is a different method for mapping even transcendental numbers.
We "just" need to define the notion of distance in
non-integral-dimension, and from that just cut any cube out of such
setting. But that's not the question. (cutting a sphere is easier, but
cube are just sphere too)
If we immerse the non-integral-dimension cube into an integral-dimension
space (of higher dimension), it is obvious that we can map. But then the
question becomes: is there a way to immerse a non-integral-dimension
into an higher-integral dimension. (and then, yes, does such white crow
exists ?)
Date: 13 Jul 2013 16:16:35
Message: <51e1b5a2@news.povray.org>
The question would thus be: Can the set of real numbers be represented
with digits chosen from a finite set?
Or even: Does an infinite amount of digits (chosen from a finite set)
become uncountably infinite? Doesn't that go contrary to the notion of
countable sets?
Date: 13 Jul 2013 16:56:15
Message: <51e1beef$1@news.povray.org>
> countable sets?
No.
Consider for a moment the set of all natural numbers, N. This is (by
definition) a countable set. Yet the set of all possible subsets of N is
*uncountable*. And that's just plain ordinary subsets; the decimal
expansion of a number is not merely a subset of N but an *ordered
sequence* of digits. Intuitively it sounds like there should be *more*
of these. (But, as with many things in set theory, it turns out actually
the cardinalities are the same.)
Wikipedia explicitly mentions this:
http://en.wikipedia.org/wiki/Cardinality_of_the_continuum#Alternative_explanation_for
Date: 13 Jul 2013 18:28:48
Message: <51e1d49f@news.povray.org>
Perhaps the mapping you proposed between the points on a unit line and
the ones in a unit square is indeed valid.
Although proving that it indeed is would be better than by something else
than "can you show me a counter-example?" :)
Date: 14 Jul 2013 03:51:50
Message: <51e25896$1@news.povray.org>
Le 14/07/2013 00:28, Warp nous fit lire :
That's remind me of the old metaphor of the hotel of infinite rooms used
for dealing with infinity.
1. the hotel is empty
2. a bus of infinite capacity (Aleph0 only, countable infinity) arrives.
Each passager get the room number from its place in the bus.
3. a single guy came in. Current customers get moved from room N to room
N+1. The guy get the first room.
4. another bus of same infinite capacity... Current customers get moved
from room N to room 2N, passagers get the room 2s+1, where s is the seat
number in the second bus.
and so on.
Date: 14 Jul 2013 17:42:22
Message: <51e31b3e$1@news.povray.org>
Saying that they have the same number of points is not a meaningful
statement.  However, we can say that they have the same countability.
Consider any ordered pair (u,v) in the unit square.  These two values
can be presented as
0.u_0 u_1 u_2 u_3 u_4 u_5 ...
and
0.v_0 v_1 v_2 v_3 v_4 v_5 ...
Where the different u_n and v_n are digits of whatever radix you care to
select.
 From these two numbers you can construct a third number thusly:
0. u_0 v_0 u_1 v_1 u_2 v_2 u_3 v_3 ...
Essentially you can interleave the digits of u and v to produce a third
number w that falls in the unit line.
Done.
I'm sure you can extrapolate from the above example to any higher dimension.
Yes, as you can see from above.  The unit line, unit square, unit cube,
unit hypercube, etc., all have the same countability.
The hypercube of infinite dimension may have a higher countability than
any finite-dimensioned cube, but it is certainly no lower in countability.
John
Date: 14 Jul 2013 17:48:43
Message: <51e31cbb$1@news.povray.org>
> countable sets?
This is why the reals are considered to have a higher countability than
the integers.  Reals are allowed to have infinite precision (such as pi,
for which any digital representation goes indefinitely without
repeating), but integers are defined to have finite precision.
(Which brings up the question, why this imposition on the integers?)
John
Date: 15 Jul 2013 03:49:45
Message: <51e3a999$1@news.povray.org>
> and so on.
What happens if an infinite number of buses turn up at once?
Date: 15 Jul 2013 05:12:15
Message: <51e3bcef@news.povray.org>
Wouldn't that be the power set of natural numbers, making it a genuinely
larger set? Unless I have once again misunderstood something completely.
Date: 15 Jul 2013 05:16:26
Message: <51e3bdea@news.povray.org>
You demonstrated that an n-dimensional unit cube has the same amount of
points as a unit line. However, that's not what the question is asking.
I'm not sure that answer makes sense...
Date: 15 Jul 2013 05:47:14
Message: <51e3c521@news.povray.org>
>    0.3425
One problem I see with this is that some real numbers can have more than
one decimal representation.
For example 1 and 0.99999... represent the exact same real number, but
their decimal representation is different.
Obviously if you had eg the point (0.5, 0.1), it would make a big difference
how you represent that 0.1. In one case you would get 0.51 while in
the other you get 0.500909090909..., which is obviously not the same value
as 0.51. Thus it wouldn't be a pure bijection.
Date: 15 Jul 2013 06:08:53
Message: <51e3ca35@news.povray.org>
Thinking about it a bit more I came up with this:
People arriving on a bus, give them a bus number, B, from 1 to infinity,
and a seat number, S, from 1 to infinity
People already in the hotel, give them bus number 0, and their seat
number is their existing room number
Everyone then has a unique B and S number.
To map 2D integers to 1D you can use a formula like the cantor pairing
function (had to look up what that was called, but I remember it from
school) 0.5*(B+S)*(B+S+1)+S. This then gives you their new room number
in the hotel.
Date: 15 Jul 2013 13:16:26
Message: <51e42e6a$1@news.povray.org>
Which infinity?
Date: 15 Jul 2013 13:19:42
Message: <51e42f2e$1@news.povray.org>
>>     0.3425
Yes. However, a real has at most two decimal expansions - one ending
with a recurring 9, the other with a recurring 0. If you insert a rule
that the latter is always the one to be chosen, the representation
becomes unique.
This allows you to unambiguously transform any 2D point into a 1D point.
It is unclear to me whether it solves the reverse transformation...
Date: 15 Jul 2013 13:21:21
Message: <51e42f91$1@news.povray.org>
Integers are allowed to have infinite digits before the decimal place.
Reals are allowed them after the decimal place as well. ;-)
Date: 15 Jul 2013 17:54:15
Message: <51e46f87$1@news.povray.org>
Taking "same amount of points" to mean "the two sets of points have the
same cardinality", then yes.
An injective mapping suffices to prove #1 (since the other direction is
trivial), and interleaving the digits achieves this.  A 1-to-1 mapping
is trickier due to annoying edge cases with multiple decimal
representations of the same number.  I don't see a (constructive) way to
do a true 1-to-1 mapping off of the top of my head.
My answer is identical to #2.
Assuming you take the "obvious" definition of an "inifinite dimensional
unit cube" to actually be a unit cube (which I think is natural to do),
then yes.  Again, only an injective mapping is obvious to me.  This can
be done with a triangular interleaving type pattern.
As you've stated it, I believe the answer to this depends on the
continuum hypothesis.
Date: 16 Jul 2013 03:35:30
Message: <51e4f7c2@news.povray.org>
Genuine question then, why isn't the set of real numbers countable,
given that you could represent each one with two integers (one for the
digits before the decimal point, one for the digits after the decimal
point)?
Date: 16 Jul 2013 04:29:55
Message: <51e50483$1@news.povray.org>
> becomes unique.
If you take out all the numbers that could be represented with recurring
0s or 9s from the 2D points, and the corresponding 1D representations of
them, the remaining numbers have a 1-to-1 relation.
So the question comes down to is there a 1-to-1 relation between the 1D
and 2D values you took out from the original sets.
The 2D coordinates taken out will be all possible pairs of numbers from
this list:
0,1,0.1,0.2,0.3,...,0.9,0.01,0.02,0.03,...
The 1D numbers taken out will be the ones generated by interleaving the
digits from all possible pairs of this list:
0.000...
0.999...
1.000...
0.099...
0.100...
0.199...
0.200...
It seems there is then an easy 1-to-1 mapping function for these
remaining numbers, namely that if your 2D coordinate is the i'th and
j'th element from the first list, then you use the i'th and j'th element
from the 2nd list to generate your 1D coordinate.
So (0.3,0.4) is the 5th and 6th element from the first list, so you use
the 5th and 6th from the second list (0.100...,0.199...), which gives
your 1D value of 0.110909090909...
Date: 16 Jul 2013 04:35:14
Message: <51e505c2@news.povray.org>
> point)?
The set of all strings that contain all possible combinations of two
or more digits (in other words, the set of all possible decimal
representations) is uncountable. In other words, it's not possible to
enumerate them all. This might be a bit surprising (it was to me...)
Cantor's diagonal argument is used to demonstrate this. Note, though,
that said argument only proves that there are sets that are uncountable
(ie. cannot be enumerated with integers), not that the set of reals is
uncountable.
Cantor's diagonal argument is a proof by contradiction. It goes something
like this:
Let's assume that it is possible to enumerate every single possible infinite
string of digits. Thus we have a(n infinite) list of numbered strings (its
order doesn't really matter, as long as it contains *all* of them.) For
example like:
1: 1001101110...
2: 0010110111...
3: 1100011110...
4: 0111001101...
If the assumption is true, that means that this list is complete, ie. it
contains every single possible string using those two digits. Which would
mean that it's impossible to construct a string that does not appear in
that list.
However, we can construct such a string: Take the first digit of the first
string and invert it, the second digit of the second string and invert it,
and so on. In other words, with the example above the string would be
0110... etc.
Said string is different from every single one in that list (because it
necessarily differs from each one by at least one of the digits.) This is
a contradiction because the list was supposed to contain *all* of them.
(It doesn't help if you just "add" this new string to the list. You can
then construct another string that's not in the list.)
Because this is a contradiction, the initial premise is necessarily false:
It's *not* possible to enumerate all of those strings. Therefore the set
of all those strings is genuinely larger than the set of integers.
(But as said, AFAIK this only proves that the set of all possible strings
of two digits is larger than the set of integers, it doesn't yet prove
that the set of real numbers is also. However, it's probably getting there,
and may only require a few steps more to prove also that.)
Date: 16 Jul 2013 05:26:49
Message: <51e511d9$1@news.povray.org>
>> point)?
This is surprising to me too, I would have thought that because every
string of digits (without a decimal place) represents an integer then it
would be countable.
> example like:
> 1: 1001101110...
> 2: 0010110111...
> 3: 1100011110...
> 4: 0111001101...
> that list.
> 0110... etc.
I understand that, but don't understand why that proves it is
uncountable. Because you can do a similar thing with a list of all
natural numbers, ie calculate the sum and then you get a new natural
number that wasn;t in the list to start with.
Date: 16 Jul 2013 06:05:45
Message: <51e51af9@news.povray.org>
> >> point)?
> would be countable.
Note that an infinite string of digits does not represent an integer
(because no integer is infinite.) That's probably what causes the
confusion.
("No real number is infinite either." That's correct. But the decimal
representation of a real number can be.)
That's not to say that no set containing infinite decimal representations
is countable. For example the set of rational numbers contains infinitely
many values which decimal representation is infinite, yet this set is
countable. (It just that, obviously, the set of rationals does not
contain *all* possible infinite decimal representations.)
"Decimal representation" in itself might be a problematic thing to rely
on when dealing with infinite sets, because it's not very intuitive.
> > 0110... etc.
> uncountable.
Because there's no way to enumerate them. (More technically, there exists
no bijective function between the two sets.)
You cannot sum all the natural numbers because there's an infinite
amount of them.
Any sum of a finite amount of natural numbers gives a number that was
already in the set.
Date: 16 Jul 2013 09:28:54
Message: <51e54a96@news.povray.org>
> confusion.
True.
That also probably explains why you can't represent every real number
with two integers (one for the fractional part and one for the integral
part).
> amount of them.
I guess the bit I got confused with / didn't understand is that you can
have a set with an infinite number of natural numbers, yet none of the
natural numbers themselves are infinite in size.
Date: 16 Jul 2013 10:32:52
Message: <51e55994$1@news.povray.org>
> point)?
I didn't comment on Orchid's quip since I assume he was joking, but you
are rightly confused because it is completely incorrect.  Real numbers
do indeed have an "integer before the decimal place", but critically
*not* necessarily "after the decimal place".  The reason is that there
may be infinitely many digits after the decimal place, all integers only
have a finite number of digits.
Date: 16 Jul 2013 11:06:17
Message: <51e56169$1@news.povray.org>
How do I better understand that all integers have a finite number of
digits, but there are infinite number of them? That's the bit I'm
struggling with.
The way I see it, the number of positive integers with N or fewer digits
is 10^N, so if N is finite then 10^N has got to be finite too?
Date: 16 Jul 2013 12:14:04
Message: <51e5714c$1@news.povray.org>
> struggling with.
Ahh I see.  This is one of many counter intuitive things which happens
with infinities.  Perhaps the issue here is that there are two different
ways that we tend to think about sizes of things at play here, and it's
not always made clear which one we're talking about:
1) finite vs. infinite
2) bounded vs. unbounded
#1 here refers the the number of elements within a set, for instance the
set {3,7,9} has three elements, the set of integers has infinitely many
elements, and the set of reals has "even more infinitely" many elements
in a certain well defined sense.
#2 instead relates to some notion of the "size" of the different
elements within a set.  This is tricky because depending on what you're
doing you might care about a different definition of what "size" is.
For example with positive integers you might care about the number of
digits, but with real numbers you might care about the magnitude of the
number with relation to the < and > relations (which is certainly *not*
the same as the number of digits in it!).  Often you just figure it out
from context.
So this tells you a little bit about the concepts, but I think that some
examples are useful in getting the mathematical intuitions.  For instance:
* If you have a set of integers, where the number of digits in each
integer is bounded, then there are only finitely many integers in that
set (as you said, at most 10^N).
* If you have a set of integers where the number of digits in each
integer is unbounded, then there are infinitely many integers in that
set.  For although each particular integer has only a finite number of
digits, for any particular number N, you can always "look further" and
find an integer with more than N digits.
I think this last one is probably where your confusion comes from.
There is more that you can say about the relationships between the
concepts of finite/infinite and bounded/unbounded, but hopefully the
small bit I've covered this helps clarify things a little.
You can, by the way, give precise mathematical definitions of these
concepts, but I've decided not to do so since I wasn't sure it would
actually make the issue more clear.
Date: 17 Jul 2013 03:44:35
Message: <51e64b63@news.povray.org>
> doing you might care about a different definition of what "size" is. For
> from context.
I guess the problem is I'm thinking of each "integer" as a set of
digits. This set has a finite yet unbounded number of elements. But then
if you make a set of all possible "integers" you don't get a set with a
finite yet unbounded number of elements, you get a set with an infinite
number of elements.
Date: 19 Jul 2013 12:31:55
Message: <51e969fb@news.povray.org>
> number of elements.
It is a strange concept, and it's not for nothing that some people
reject it entirely.  I don't really have an explanation which will make
it less strange, except to mention that mathematically it might be best
to think of "infinite" as meaning "not finite".
Let me explain a bit more.  If a set S has a finite number of elements,
then there is some integer n such that S has n elements (this is pretty
much the definition of "finite").  Therefore, if you can show that no
matter which number n you pick, S will always have more then n elements,
they s is not finite, and therefore infinite.
You probably already understand this reasoning, if which case I doubt it
did much to make it "feel" like it makes sense.  The real strange thing
that's going on is that you're grouping all the integers into a single
set.  This is sort of the difference between unbounded and infinite in
this case (i.e. with positive integers).  The individual integers in
this set increase without bound, but it's the while set of all of them
that's infinite.  With relation to the above definition of "finite" you
can think that for any particular integer i, there's some n such that i
<= n (obviously), as soon as you consider *all* the integers as a single
thing this stops being true.
I don't know if this ever starts to make sense so much as you just start
to get used to it.
Date: 19 Jul 2013 14:54:48
Message: <op.w0hf5ip8ufxv4h@xena>
I don't know.
Maybe I should start with something simpler.
Infinity + Infinity = ?
Is there any other answer than 2(Infinity)?
If so please explain.
-Unlike Warp I don't know the answer and really want to know :)
-Nekar Xenos-
Date: 19 Jul 2013 15:13:46
Message: <51e98fea@news.povray.org>
Am 19.07.2013 20:54, schrieb Nekar Xenos:
Yes: Infinity + Infinity = Infinity.
I can't. I guess it's just the way infinity is defined.
Note that there's no such thing as infinity in real life, so there's no
"natural" way of dealing with infinity. It's an artificial construct,
and as such is defined in a way that applying the "natural" rules of
arithmetic to it does't yield results too useless for too many
applications too much of the time.
Date: 19 Jul 2013 15:56:15
Message: <op.w0hizxioufxv4h@xena>
This is what I thought, but didn't have any evidence for it.
-Nekar Xenos-
Date: 19 Jul 2013 16:02:15
Message: <51e99b47$1@news.povray.org>
Le 19/07/2013 20:54, Nekar Xenos nous fit lire :
> I don't know.
Well, if anything else, that's never the answer.
You have to be aware that some Infinity are bigger than some other
Infinity. (rahh... not now!)
To ease the understanding, the smallest infinity is called Aleph-0.
(well, that still a controversial subject, linked to the Axiom of Choice)
The natural integer (0, 1, 2, .. and so on) are in the N set, whose
cardinality is indeed Aleph-0.
Imagine one hotel of infinite room, each room numbered uniquely from N
set. And now you build another one next to it, of same size.
You then renumber the room of the first hotel x--> 2x, and of the second
hotel y--> 2y+1. You now have a single hotel-company of the same size as
one of the original.
You can also split it in multiple (finite number) hotels, all of
infinite size... they were already there!
Date: 19 Jul 2013 16:10:02
Message: <51e99d1a$1@news.povray.org>
On 19/07/2013 07:54 PM, Nekar Xenos wrote:
> I don't know.
"Infinity" is rather vague.
Let's talk specifics. Suppose we have the set of all natural numbers
(i.e., all positive whole numbers). There are infinity of these.
This set is commonly denoted by the latter N. I'm going to refer to the
size of this set as being A0.
Now, suppose we compare N, the set of all *positive* integers, to Z, the
set of *all* integers, negative and positive. Clearly there are twice as
many of these. For every item in N, there are two corresponding items in
Z, one negative and one positive. So the size of Z is A0 + A0.
But wait...
I can map every odd number in N to a negative number in Z, and every
even number in N to a positive number in Z. In this way, every element
of N is mapped to *one* element of Z, and every element of Z is mapped
to *one* element of N.
The existence of this mapping _proves_ that the sets N and Z are
ACTUALLY THE SAME SIZE! O_O
In other words, A0 + A0 = A0, exactly unchanged.
This seems utterly bizarre. But it's a consequence of infinitely large
quantities. To understand, try doing the same trick to prove that the
set {1 .. 5} is the same size as the set {-5 .. +5}. If you try this,
you'll discover the following:
   {1 .. 5}   {-5 .. +5}
      1    <->    -1
      2    <->    +1
      3    <->    -2
      4    <->    +2
      5    <->    -3
                  +3
                  -4
   Oh bugger!     +4
                  -5
                  +5
It doesn't work. You can't match them up. Because - AS IS FRIGGING
OBVIOUS - the sets aren't the same size. Basically you run out of
elements of the left set before you've matched up all the elements of
the right set.
The ONLY reason this works with infinite sets is that, because they're
infinite, you will never "run out" of stuff to match up. Because of
this, even "doubling" the size of an infinite set actually leaves its
size unchanged - bizarre as that is!
If adding a set to itself once does nothing, doing this twice also does
nothing. That is,
   A0 + A0 + A0 = A0
In general,
   x * A0 = A0
This is clearly true for any finite x. But what if x ISN'T FINITE? What
happens if we do this:
   A0 * A0 = ???
Remember that A0 is the size of N, the set of all integers. So if we
construct the set of all PAIRS of integers, like this...
    (1, 1)
    (1, 2)
    (1, 3)
   infinity
    (2, 1)
    (2, 2)
    (2, 3)
   infinity
    (3, 1)
    (3, 2)
    (3, 3)
   infinity
Surely, the size of this set is CLEARLY equal to A0 * A0.
But wait...
If I take both numbers, add zeros to pad them out to the same length,
and then interleave their digits, I get this:
   (123, 456) <-> 142536
   (123, 457) <-> 142537
   (123, 458) <-> 142538
Every number on the right matches exactly one pair on the left. Every
pair matches on number on the right. THE SETS HAVE THE SAME SIZE! We
just proved that A0 * A0 = A0.
Just when it's starting to look like A0 is A0 no matter what you do to
it, something interesting happens.
The size of N is A0. If we construct all possible subsets of N, then for
each element of N, a given subset of N either DOES or DOES NOT contain
that element. That's 2 possibilities, independently for each element of
N. So that's a total of 2 ^ A0 possible subsets.
It turns out that (2 ^ A0) > A0.
Yes sir, there are actually DIFFERENT SIZES of infinity. Let us write
   A1 = 2 ^ A0
   A1 > A0
But, by the same algorithm, 2 ^ A1 > A1, so we actually have
   A(n+1) = 2 ^ A(n)
   A(n+1) > A(n)
In summary, infinity comes in different sizes. (Now you see why the
original question "what is infinity plus infinity?" is vague; there's
one than one infinity you may ask about.)
In general,
   A(x) + A(y) = A(y)   iff y >= x
That is, if you add two infinities, the result is the size of whichever
is the largest infinity. (Thus, when you add a particular infinity to
itself, nothing happens.)
Date: 19 Jul 2013 16:34:02
Message: <51e9a2ba$1@news.povray.org>
On 7/19/2013 11:54 AM, Nekar Xenos wrote:
> I don't know.
If you've even hung around people majoring in math in undergrad, you may
have heard stories of a set theory class in which a they actually spend
a day's class proving that 1+1 = 2.  On the face of it this seems like a
huge waste of time, why would you bother to construct a proof of such an
obvious fact?  Well, it's in answering questions such as yours in which
such effort pays off.
There are a few rather subtle points to a simple question like "what is
1+1":
1) What is a number?
2) What is addition?
And in addition, for your question:
3) What do we mean by infinity?
For the most part your answers to these questions don't matter for
ordinary finite numbers, but as soon as you start treating infinity like
a number these subtle points start to matter a great deal.
In terms of your question "Infinity + Infinity = ??" you most commonly
see one of two answers:
a) Infinity * 2   (note: not 2 * Infinity, the order often matters)
b) Infinity
And this entirely glosses over issues that for some answers to questions
1-3 you can get more than one infinite number, at which point it matters
which infinities you were adding!
Sorry I don't have a simpler answer.  But basically the only real way to
answer it is "tell me what you really mean by Infinity, and only then
can I tell you what Infinity+Infinity is".  The answers given by clipka
and Le_Forgeron/Orchid are but two of many possibilities (although they
both get the same result, they are using different interpretations of
"infinity" to do it).
Date: 19 Jul 2013 16:37:48
Message: <op.w0hkw5h0ufxv4h@xena>
On Fri, 19 Jul 2013 22:10:11 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
>> I don't know.
> But wait...
>    {1 .. 5}   {-5 .. +5}
>       1    <->    -1
>       2    <->    +1
>       3    <->    -2
>       4    <->    +2
>       5    <->    -3
>                   +3
>                   -4
>    Oh bugger!     +4
>                   -5
>                   +5
> the right set.
> nothing. That is,
>    A0 + A0 + A0 = A0
> In general,
>    x * A0 = A0
>    A0 * A0 = ???
>     (1, 1)
>     (1, 2)
>     (1, 3)
>    infinity
>     (2, 1)
>     (2, 2)
>     (2, 3)
>    infinity
>     (3, 1)
>     (3, 2)
>     (3, 3)
>    infinity
> But wait...
>    A1 = 2 ^ A0
>    A1 > A0
>    A(n+1) = 2 ^ A(n)
>    A(n+1) > A(n)
> In general,
This is all very interesting. :)
I was thinking of adding any particular infinity to itself.
-Nekar Xenos-
Date: 19 Jul 2013 16:48:58
Message: <op.w0hlfragufxv4h@xena>
On Fri, 19 Jul 2013 22:34:29 +0200, Kevin Wampler <nob### [at] nowherenet>
>> I don't know.
> 1+1":
> b) Infinity
I think I could say the specific infinity I'm thinking of would be the
biggest type of infinity.
What would that be?
Complex Infinity? (if that could be considered)
-Nekar Xenos-
Date: 19 Jul 2013 16:54:30
Message: <51e9a786$1@news.povray.org>
> What would that be?
You will be sorry you asked that. :-P
Regards
Date: 19 Jul 2013 16:56:59
Message: <51e9a81b@news.povray.org>
How about and we may have an infinity of authors spinning in their graves:
The sum of all the odd numbers is infinity.
The sum of all even numbers is infinity.
The sum of all numbers odd and even is infinity.
So by doing ordinary sums:
infinity + infinity = infinity
and
infinity = infinity * 2
Can't be right. And that is because infinity is not a number but an idea.
But if you make a mathematics using infinity as an object it opens a
whole new way for mathematicians to think.
It was at this point that I thought that I would leave it for minds that
want to see things with out drugs.
Give the book that I mentioned at the beginning of this thread "White
Light" a try if you can find it.
Regards
Date: 19 Jul 2013 17:01:36
Message: <51e9a930$1@news.povray.org>
> What would that be?
There are two different ways I'm tempted to interpret your question, but
only one of them makes sense.  I'll try to answer them both anyway:
Q1) "Out of all the different ways you can define Infinity, what's the
biggest?
A1) Because the different definitions of Infinity use different
definitions of what a "number" is, there is no way to compare them at
all to say which is bigger -- they are just completely different things.
  It's like asking "which is bigger, 4 or fish?".
Q2) "You mentioned that for some definitions you get multiple different
types of infinity, what's the biggest of those?"
A2) The answers depends on what particular definition of Infinity you're
talking about, but the most common answers is that there is no biggest
Infinity -- just like there's no biggest finite integer.  Sometimes
people will try to add a "biggest infinity" to things, but you don't
generally allow addition with it anyway.
As I mentioned in (A1), it doesn't make sense to ask if "complex
Infinity" is bigger than another definition of infinity.
As an aside, a notion of "complex Infinity" is actually extremely useful
in some areas mathematics.  Arguably much more useful than "real
Infinity" is.  The standard definition of complex Infinity does not
allow Infinity+Infinity though (it treats it as undefined, much like 1/0
is commonly treated as undefined for the reals).
