POV-Ray : Newsgroups : povray.off-topic : Mad skillz Server Time
1 Nov 2026 00:47:39 EDT (-0400)
  Mad skillz (Message 1 to 11 of 11)
Subject: Mad skillz
Date: 5 Jul 2013 13:15:18
Message: <51d6ff26$1@news.povray.org>
http://hackertyper.com/
http://hackertyper.net/
The premise is simple: You prod the keyboard at random, and
technical-looking text appears on the screen, as if you're actually
doing something.
Tools like this are fine as far as they go... but I can't help feeling
that they could go a lot further.
First of all, there *must* be an Emacs mode for this. Because, let's
face it, there's an Emacs mode for everything else! :-P
Next, the "text" appears to simply be whatever file the author looked
most cryptic out of the Linux kernel source code. (Some of these tools
let you select some other programming language if you wish.)
Rather than typing at random, I think there should be real keyboard
commands. Because typing randomly *looks* random, whereas if some of the
keys actually do something, you'd type more carefully and it would look
more real.
Clearly there should be commands to make windows appear and disappear -
because if TV has taught me anything, it's that hackers never use the
mouse, and yet are able to operate complex GUI tools using only a keyboard.
(If this sounds absurd, go use FractInt for a few months, and then
imagine something like that, but with a real GUI not just ASCII art.)
There should be a "search" option which makes an actual window appear,
with the data being searched flashing past at great speed - because
that's how powerful computers search for things. Fingerprints, facial
recognition, text searches, all of these work by displaying stuff on the
screen really, really fast, and then freezing as soon as a match is
found. (Sorry, "hit".)
It strikes me that when typing commands, you type from top to bottom,
however when editing source code you usually scroll around all over the
place, inserting text here and deleting text there.
And of course, this isn't 1974. We're not using green-screen dumb
terminals. There should be syntax highlighting, with 8 colours of ugly
terminal text. ;-)
Naturally there should be a button to activate that user interface they
used in Jurassic Park - because apparently that's what "Unix" looks like.
Also we need a button which causes Japanese characters to rain down on
the screen, followed by "follow the White Rabbit, Neo", and then zoom
through the digits, Matrix style...
What other features should a *proper* hacker UI have?
Subject: Re: Mad skillz
Date: 7 Jul 2013 04:36:53
Message: <51d928a5$1@news.povray.org>
Why would there be Emacs mode for a hacker UI? After all, VI is the
editor for hackers.
> more real.
True.
Ohh, that true! One should also be able to turn on/off devices (printers
etc) so that theier physical switches just click themselves.
Agreed. And when the match found, the system should blink multiple
coloured backgrounds behind "HIT" or "MATCH" while beeping simultanously.
> terminal text. ;-)
Green screen <3. Having the default fg color configured as green
shouldn't stop from having syntax highlighting, though.
You.. are aware of SGI Fusion, are you?
http://www.youtube.com/watch?v=zaRHU1XxMJQ
Hmm, I actually have an Octane... :-)
When you save and quit, the editor should start dropping the digits to a
bucket with the correct filename. It could also zoom to the digits and
follow them to the bucket.
Add 256 to one (random) byte of every IPv4 address.
Date: 7 Jul 2013 06:13:57
Message: <51d93f65$1@news.povray.org>
> editor for hackers.
Hehe, depends which university you ask - apparently.
The top-rated comment... is Jurassic Park. ;-)
I did a search, there is a surprising amount of prior art. This one is
particularly pretty:
http://www.youtube.com/watch?v=ph2rAZhWuCU
I know Linux used to have a Matrix screensaver, but it was awful. All
the text was heavily JPEG-compressed so it looked like arse.
It *sounds* trivial to do, but it's actually quite hard to make this
look really nice...
Ooo, that reminds me... My boss found a video clip from some TV drama or
other. One girl asks why she can't access her email. The other says
"have you tried using the IP address?", and proceeds to type four
numbers, none of which is less than 250. (Why the **** have you
memorised an IP address anyway?!)
This gives me an idea... Such a sequence of numbers is a potentially
valid DNS name - assuming there's a TLD called 572. If we could set one
up, that would MESS WITH PEOPLE'S MINDS! (...and probably reveal a bug
or two in the various software for parsing URLs.)
Date: 7 Jul 2013 07:49:18
Message: <51d955be@news.povray.org>
> editor for hackers.
Well, it depends. After all, Emacs was pretty much created by Unix gurus
(which, in a sense, could well be called "hackers") for Unix gurus.
(After all, "hacker" in the most purist sense is someone who is extremely
knowledgeable and skilled about computer systems, how they work and how
they can be used, even in very unusual and unintended ways. For example
a Unix admin who knows the system thoroughly, has a very good understanding
of not only how the system works but also how it has been programmed, and
can even write things like a kernel module in a sitting, can very well be
called a "hacker.")
Emacs was most certainly not written with the average grandmother writing
an email to her grandson in mind.
Many argue that calling Emacs a text editor is a misnomer, really. What
Emacs really is, is an elisp interpreter with an integrated text editor.
If you know elips, you can make Emacs do almost anything (that elisp
supports.)
Date: 7 Jul 2013 08:40:40
Message: <51d961c8$1@news.povray.org>
Le 07/07/2013 13:49, Warp nous fit lire :
rather Lisp gurus. Emacs is an operating system all by itself (or nearly)
Date: 7 Jul 2013 08:56:26
Message: <51d9657a$1@news.povray.org>
Yes, yes it is. I was just thinking the other day that I should watch
the first 2 again, haven't seen them in ages.
If you use them enough, you'll just simply remember them. At my first
real job (which I quitted in 2002) the main DNS server was
194.252.199.200, for example.
Ohh, I do like the idea. But can the domain- or hostnames contain only
numbers? Hostnames ones wasn't allowed to start with one, but AFAIK
that's overruled now.
Date: 7 Jul 2013 08:57:32
Message: <51d965bc$1@news.povray.org>
I clearly should have used a winking smiley, so here you go: ;).
Just to be fair and honest, neither was VI.
Date: 7 Jul 2013 09:52:35
Message: <51d972a3@news.povray.org>
On 07/07/2013 1:57 PM, Eero Ahonen wrote:
> I clearly should have used a winking smiley, so here you go:;).
If I say, hacking to me is a rough, dry cough. Should I use a smiley ;-)
I also use hack as meaning "cope", as in I cannot hack this job.
Regards
Date: 7 Jul 2013 09:59:09
Message: <51d9742d$1@news.povray.org>
Now I'm getting really hacked off :-D
The level of my sarcasm depends upon the level of your stupidity
Date: 7 Jul 2013 11:05:53
Message: <51d983d1@news.povray.org>
Yes the real meaning. :-)
Regards
Date: 7 Jul 2013 12:46:39
Message: <51d99b6f$1@news.povray.org>
IETF RFCs #1034 and #1035 both contain a "preferred name syntax"
(RFC-1034 section 3.5 and RFC-1035 section 2.3.1) which lists the
following grammar:
   <domain> ::= <subdomain> | " "
   <subdomain> ::= <label> | <subdomain> "." <label>
   <label> ::= <letter> [ [ <ldh-str> ] <let-dig> ]
   <ldh-str> ::= <let-dig-hyp> | <let-dig-hyp> <ldh-str>
   <let-dig-hyp> ::= <let-dig> | "-"
   <let-dig> ::= <letter> | <digit>
   <letter> ::= any one of the 52 alphabetic characters A through Z in
   upper case and a through z in lower case
   <digit> ::= any one of the ten digits 0 through 9
   Note that while upper and lower case letters are allowed in domain
   names, no significance is attached to the case.  That is, two names
   with the same spelling but different case are to be treated as if
   identical.
   The labels must follow the rules for ARPANET host names.  They must
   start with a letter, end with a letter or digit, and have as interior
   characters only letters, digits, and hyphen.  There are also some
   restrictions on the length.  Labels must be 63 characters or less.
However, RFC #1123 states (section 2.1):
       The syntax of a legal Internet host name was specified in RFC-952
       [DNS:4].  One aspect of host name syntax is hereby changed: the
       restriction on the first character is relaxed to allow either a
       letter or a digit.  Host software MUST support this more liberal
       syntax.
It also suggests:
            If a dotted-decimal number can be entered without such
            identifying delimiters, then a full syntactic check must be
            made, because a segment of a host domain name is now allowed
            to begin with a digit and could legally be entirely numeric
            (see Section 6.1.2.4).  However, a valid host name can never
            have the dotted-decimal form #.#.#.#, since at least the
            highest-level component label will be alphabetic.
This appears to be saying essentially what I said - there is no TLD
named 572. If there *was*, then DNS names could become ambiguous with IP
addresses...
