POV-Ray : Newsgroups : povray.off-topic : Today's mirth Server Time
16 Jun 2026 02:57:13 EDT (-0400)
  Today's mirth (Message 11 to 20 of 90)
Subject: Re: Today's mirth
Date: 6 Jun 2013 13:17:41
Message: <51b0c435$1@news.povray.org>
On 06/06/2013 02:17 PM, Shay wrote:
> Most Americans wouldn't know what bespoke means.
OK. Now explain "there" instead of "their", and "pacific" instead of
"specific".
The former is a moderately common mistake. The latter is something I've
never seen before in my life. They're two utterly unrelated words!
Date: 6 Jun 2013 14:11:17
Message: <51b0d0c5@news.povray.org>
> "specific".
Thats just you're open yam, man.
Date: 6 Jun 2013 14:35:50
Message: <51b0d686$1@news.povray.org>
> "specific".
It's people who write what they think they hear rather than proper
English.
"Let me axe you somethin'....."
Jim
Date: 6 Jun 2013 15:05:19
Message: <51b0dd6f$1@news.povray.org>
> English.
Heh. And here I was thinking that we educate people so that they know
better...
Date: 6 Jun 2013 15:08:44
Message: <op.wx9t4su2ufxv4h@xena>
On Thu, 06 Jun 2013 19:17:45 +0200, Orchid Win7 v1 <voi### [at] devnull> wrote:
> "specific".
I had a boss once who used pacific instead of specific.... :P
-Nekar Xenos-
Date: 6 Jun 2013 16:20:21
Message: <51b0ef05@news.povray.org>
>>> I've never seen before in my life. They're two utterly unrelated
>>> words!
>> English.
> better...
People have to want to be educated - if they don't have the interest,
they're not going to learn no matter how long they spend in school.
Jim
Date: 6 Jun 2013 18:32:25
Message: <51b10df9@news.povray.org>
James Holsenback <nom### [at] nonecom> wrote:
> The copy was also littered with
> sentences that ended with prepositions.
Why is that bad?
The rule to avoid ending sentences with prepositions in English is
completely artificial, invented by one person (you can even find his
name if you search) for a textbook, which got just blindly copied by
other textbook with no rationale or any kind of linguistics research
behind it. It just became a popular notion that everybody blindly
repeated, without any kind of reasoning behind it.
That in itself wouldn't be a bad thing if it really described how actual
fluent English works. However, it doesn't. There are countless examples
where ending a sentence in a preposition is completely fluent,
understandable and appropriate. There's basically nothing wrong with it.
The rule is completely artificial and has no reason to exist.
Date: 6 Jun 2013 18:36:18
Message: <51b10ee2@news.povray.org>
Some people write "your" when they really mean "you're". This mistake is
kind of understandable.
However, I have seen people consistently write "you're" when they really
mean "your". *That* mistake I have hard time comprehending.
Date: 6 Jun 2013 19:25:47
Message: <51b11a7b@news.povray.org>
>> The copy was also littered with sentences that ended with prepositions.
> Why is that bad?
One might argue that most rules of grammar are completely artificial.
The purpose of any such rule is for writing to be made clear.  So the
problem that James is referring to isn't necessarily "ending sentences
with a preposition", but "the writing is unclear because the sentences
are ended with a preposition." - that is, the problem is that the writing
is unclear.
And a lack of clarity in writing is a *huge* problem.
Prepositions are used to describe the relationship between two things -
and the second thing in the comparison follows the preposition.  The idea
behind not ending sentences with a preposition has to do with the idea
that if you're comparing two objects, you have to have two objects.
But it's /not/ a "rule", because there are obvious cases where rewriting
to avoid ending with a preposition results in a very contrived sentence.
The guideline is that in general, ending sentences with a preposition
tends to be unclear.  If you're describing something that is with
something else, you have to generally state what the object is with.  Or
above, below, beside, etc.
But prepositions also have other uses, which is why it's not a "rule" but
a "guideline".  But those tend to be exceptions.
"The strike came from above." - yes, that's perfectly clear, because
"above", while describing a relationship (and as a preposition), the
context in the sentence makes it clear that the target was below where
the attack came from.
^^^^ And that last sentence, "from" also is clear because of the context.
"The apple was beside." - that's a sentence fragment that ends in a
preposition.  It's completely unclear what the apple was beside.  (And
that last sentence isn't a sentence fragment because the context makes it
clear that the "what" that is beside the apple is the object that is
missing.)
Jim
Date: 6 Jun 2013 19:30:18
Message: <51b11b8a$1@news.povray.org>
Not really.  If you know that "you're" is a contraction of "you are",
it's very easy to see when it's being misused:
"I think your wrong."
"I think *you are* wrong."
The error is clear as day - you're making a contraction and not using the
punctuation that's necessary in a contraction.
The one that is understandable, I think, is "its" - the possessive form
of "it".  There is no possessive form of "it" that has an apostrophe in
it, but most other nouns are made possessive by adding an apostrophe:
"John's truck broke down."
"The flywheel's spring broke."
"Everybody's wrong about this."
"The firefighters' truck drifted around the corner."
(The latter being possessive plural)
But "its" is possessive and "it's" is /only/ ever a contraction of "it
is".
Jim
