![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Today, I wrote a parser in C++.
The slightly alarming thing is that it almost works correctly too. (It's
not quite finished yet.)
And no segfaults! It turns out that if you throw enough STL containers
at the problem, you can make it work without any manual pointer
manipulation. (I shudder to think what the performance is like...
Fortunately the input to the parser will always be small.)
It took 4 employees approximately 4 hours to get VisualStudio to
successfully compile and link the code. (There are external
dependencies, and the program is split into two projects which have to
cross-reference each other correctly, and so on.) VS is really very
clunky with C++ code.
It then took me about half an hour to write the parser test cases, and
the rest of today to write the actual parser. Nested subexpression
parsing still isn't working quiet right yet, so I need to go take a look
at that.
I must say, when I signed up for a job as a C# programmer, I didn't
think I'd spend 3 months writing Bash scripts, two weeks writing
VBScript and then a day writing C++ code... :-P
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 13 May 2013 20:09:39 +0200, Orchid Win7 v1 <voi### [at] dev null> wrote:
Sounds exciting ;)
-Nekar Xenos-
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It's the overly-detailed, over-inflated job 'qualifications' requirements :-P
To be a brick-layer these days, the qualifications probably read: "Must be
familiar with silicon/water chemistry on the atomic level, plus five years of
academic training in geometry. Phd in architectural design a plus."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
After having spent a few years with VS and C#, a few months ago I tried
again VS for C++ and agree it's still very clunky in comparison. Not
sure if that's more a limitation of C++ compared to C#, but it's
certainly not as user friendly.
You mean you haven't found an excuse to use POV yet!?! (and then
obviously the newsgroups as well...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> manipulation.
When using the standard containers, one should know how they work and
what they are doing, in terms of efficiency. For example, passing them
by value eg. as function parameters is inefficient, and that should always
be done by reference, if possible.
And also, of course, use the right tool for the job. It makes no sense
to use, for example, std::list for something that std::vector will do.
And if your array is of static size, use std::array instead of std::vector
(especially if it's eg. a smallish array that's a member variable of a
class that gets instantiated a lot.)
You can still index those out-of-bounds, but many compilers, eg. Visual
Studio, will add boundary checks when compiling in debug mode. (The
boundary checks are not used in release mode for efficiency.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, I did use my IRTC entry for some of our test data...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
How about std::string? Presumably it's a bad idea to pass that by value
either...
All this stuff is pretty dynamic. I have no idea how big the expression
I'm parsing will be until after I finish parsing it.
I'm sure if you could see my code, you'd probably have a heart attack
over all the highly inefficient stuff it's doing. Then again, it gets
run once at application start-up, parsing a few dozen strings that are
mostly a dozen characters long each, so...
(Perhaps the biggest inefficiency is having a lot of zero-element
vectors laying around. I have no idea what the space overhead for that
is. But I also have no idea how to avoid it.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
At about 2AM, I rolled over in bed and realised why this is broken.
std::vector<Stuff> current = stack.back();
current.push_back(more_stuff);
Uh, yes... that doesn't do what I meant AT ALL! >_<
Still, I'm impressed I managed to figure out the bug when I don't even
have access to the code...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
But that's nothing compared to how long it took to get VS to produce a
DLL, and then get C# to successfully call this DLL without access
violations... >_<
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> either...
It depends on the implementation.
Since std::string is so ubiquitous, many standard library implementations
have optimizations that make copying them fast (some use short string
optimization, some use lazy copying...), but that's in no way a guarantee.
There's usually no reason to not to use a std::string reference if it
suffices. Only copy when you have to.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
