POV-Ray : Newsgroups : povray.off-topic : An even more interesting problem Server Time
27 May 2026 04:47:05 EDT (-0400)
  An even more interesting problem (Message 1 to 8 of 8)
Subject: An even more interesting problem
Date: 24 May 2013 14:20:10
Message: <519faf5a$1@news.povray.org>
Suppose I give you two arbitrary regular expressions. Are they equivalent?
Does there exist an algorithm to determine whether two regexes are
equivalent? What complexity class does this algorithm live in? What does
"equivalent" even mean in this context? What about if one expression
matches a subset of the other? Or a superset? Or in general two
partially-overlapping sets?
Subject: Re: An even more interesting problem
Date: 24 May 2013 14:44:06
Message: <519fb4f6@news.povray.org>
It depends on what you specifically mean by "regular expression", but
probably this problem is PSPACE-complete.  From what I can tell is
generally solved by converting each regexp into a DFA and checking if
they are isomorphic.
There exists a Perl library to do some related computations of this
sort, although it will sometimes fail to detect an equivalence (but I
think never detects a false equivalence).
http://search.cpan.org/~vbar/Regexp-Compare-0.17/lib/Regexp/Compare.pm
Date: 24 May 2013 15:22:21
Message: <519fbded@news.povray.org>
No. Two regular expressions expressing the same "language" (ie. matching
the exact same things) is not a question of isomorphism. Isomorphism is
a much stricter comparison.
For example "a|aa+" and "a+" are equivalent (both match the exact same
things), but not isomorphic (the former has more nodes than the latter.)
The more accurate comparison is the one that says that "every named path
in one graph exists in the other, and vice-versa." I think the term for
this is strong bilinearity. The comparison can be made faster than in
exponential time.
Date: 24 May 2013 16:02:15
Message: <519fc747$1@news.povray.org>
I should have been more explicit: solved by converting each regex into a
*minimal* DFA  and checking if they are isomorphic.
Graph isomorphism is of course GI-complete, but the conversion to a
minimal DFA is in general PSPACE-complete.
Date: 25 May 2013 04:30:31
Message: <51a076a7$1@news.povray.org>
>> equivalent?
Does the situation change if we disallow the Kleene star?
Date: 25 May 2013 04:55:01
Message: <51a07c65@news.povray.org>
> equivalent?
Piece of cake:
if( string RegExp1 == string RegExp2 ){
	printf( "They're equivalent!\n" );
}else{
	printf( "They're not identically equivalent!\n" );
*wink*
Date: 25 May 2013 07:00:33
Message: <51a099d1$1@news.povray.org>
>> equivalent?
> Piece of cake:
> }else{
> *wink*
Oh come on. You could at least parse the string into an AST and compare
the two ASTs. :-P That would at least remove trivial differences like
extra spaces and so on.
Date: 25 May 2013 11:05:05
Message: <51a0d321$1@news.povray.org>
Yes, although not usefully so.  Without the Kleene star it's co-NP complete.
