POV-Ray : Newsgroups : povray.off-topic : Current questions Server Time
7 Jul 2026 12:54:09 EDT (-0400)
  Current questions (Message 11 to 15 of 15)
Subject: Re: Current questions
Date: 11 May 2013 18:28:07
Message: <518ec5f7@news.povray.org>
Am 11.05.2013 23:21, schrieb Orchid Win7 v1:
>>> Lots of people try to write Haskell like
>>> data Foobar = Foobar {foo :: Int, bar :: Int, baz :: Int}
>>> data Fizz = Fizz {foo :: Bool, wok :: Int}
>>> This doesn't work at all, due to a namespace collision.
>> A /severe/ design bug, if I'm asked. Nothing I'd expect from a
>> contemporary programming language.
> It's embarrassing, sure. But it's not really an especially severe bug;
> it's just a nuisance having to manually prefix all your field names with
> the name of the type that they belong to (or some abbreviation thereof).
... which is exactly why namespaces were invented in the first place.
Any contemporary programming language that bothers to use namespaces
should avoid such nuisances once and for all.
Date: 12 May 2013 05:03:57
Message: <518f5afd$1@news.povray.org>
Well, the other alternative is to define each record in a separate
compilation unit. That'll do it. But that's also rather inconvenient.
In mitigation, Haskell programs tend not to have quite so many data type
definitions as a typical C program, and they tend to have a lot fewer
fields. That's not to say that name collisions don't happen though.
There have been a couple of solutions suggested. GHC has a mode in which
names are allowed to overlap, and the compiler tries to "guess" what you
meant at compile-time. This mostly works, but many people consider it to
be a deeply evil hack. Then there's Frege, which is basically a very
slightly modified Haskell which compiles to Java source code. In Frege,
every type is its own namespace, and in case of ambiguity you must
prefix the field name with the type name. (Note that C# does this with
enum values.)
Ultimately the problem is type inference. Pascal lets you write
"foo.bar" to access a field - but then, in Pascal the type of "foo" must
be explicitly stated in a type signature. Haskell is trying to let you
write the same expression but still let the compiler automatically
detect the type of "foo" - a much harder problem...
Date: 13 May 2013 03:20:17
Message: <51909431$1@news.povray.org>
> It is NOT typically written as
>    exp(ix) = cos(x) + i sin(x)
> except when written in computer source code.
Isn't that just because in maths the brackets are usually left out with
standard functions if it's obvious what the parameter is? For more
complex parameters brackets are usually used to avoid any ambiguity.
When writing "user defined" functions like f(x) in maths you always use
brackets.
Date: 13 May 2013 03:46:56
Message: <51909a70$1@news.povray.org>
You leave out the brackets unless there's grounds for confusion. Which
is pretty much what Haskell does. (And what most other programming
languages do for everything except subroutine arguments.)
> brackets.
Pro tip: Don't use the word "always" around mathematicians. It tends to
make them find obscure counter-examples. ;-)
(Why, I have a book somewhere which claims that a "function" is actually
a set of 2-tuples...)
Date: 13 May 2013 06:27:48
Message: <5190c024$1@news.povray.org>
A mathematician would not expect any confusion with an expression like
sin 2x, so would leave out the brackets.
