POV-Ray : Newsgroups : povray.off-topic : A new site Server Time
5 Mar 2026 11:06:17 EST (-0500)
  A new site (Message 1 to 1 of 1)
Subject: A new site
Date: 4 Apr 2013 13:41:43
Message: <515dbb57$1@news.povray.org>
The other day I visited haskell.org, and was astonished to discover that
there are now some news items dated this year. :-P
The item in question refers to a company I've never heard of - FP
Complete. Naturally, I went over there and had a nose around. Reading
their blog was... interesting. Consider this entry, for example:
https://www.fpcomplete.com/blog/2012/03/onamission
Or how about this:
http://tinyurl.com/cwn8eq4
Now, to be clear, I am a Haskell enthusiast. I think Haskell is
brilliant, and that everybody should be using it. But reading that first
post, even to me it sounds like... every over-hyped product I've ever
read about. It talks about how "Developers who use Haskell often report
2x  or higher productivity improvements, even as their bug count is
significantly reduced.", but without a single shred of substance. You
could take the word "Haskell" and replace it with any other programming
language on Earth, and the sentence would be equally vacuous.
It reads like one of those pamphlets that Dell were so fond of sending
me. You know the ones, where they tell you how Dell products "reduce
total cost of ownership" and how Dell provide "end-to-end solutions",
but without one single shred of technical detail. In other words, the
kind of crap written for the Pointy Haired Boss, not for me!
Likewise, some of these blog posts sound almost hysterical in their over
optimism. Don't get me wrong, I think Haskell is fantastic. But I've
long since given up hope of anybody ever actually using it. (And even if
somebody did use it, nobody will ever take it seriously in public.)
One *real* contribution which is interesting is a framework for running
Haskell on their website. There's already a site that does this:
http://tryhaskell.org/
It even has a little Haskell tutorial built into it. (Last time I
checked, it's fairly incomplete.) So how does this new offering compare?
Well, tryhaskell.org gives you a Haskell REPL. This new site appears to
be some kind of Wiki where you can embed Haskell fragments, with a
button to execute them. This means that rather than entering single
expressions, you end type in a lengthy chunk of code and then execute
it, with is a feature. On the other hand, the time required to compile
the code and display the result seems quite length, with is a drawback.
(There's been an IRC bot which provides a sort-of Haskell REPL for
years. But it's only fairly recently that tryhaskell.org appeared, to
allow casual users to experiment with Haskell without needing to install
an IRC client and join a special IRC server - or worse, attempt to
compile the IRC bot themselves! It's bit-rotted like crazy over the
years...)
Making a website where you can run Haskell interactively *sounds* like
such a simple task... When you sit down to try and actually *do* it, you
suddenly realise that all sorts of petty practical concerns make this
way harder than you'd imagine. For example, a simple typo can an
infinite loop; you don't want to hang the entire web server if a user
makes a mistake! And hey, what about security? We don't want some user
to issue a Haskell command to format the harddrive. Then there's the
mechanics of turning a lone Haskell expression into a full module which
can be compiled... It's all a lot more fiddly than you'd think.
It's nice to see a few people managing to do this now. In fact, I've
often thought it's a bit of a pity we don't have a small Haskell
interpreter written in Haskell, so it could be embedded into other
things. (We *have* an interpreter, but it is *not* small or simple!)
