OK, so just for giggles, I tried to implement monads in C#.
The short version: It appears that I can create a class with forms a
monad, however it appears to be impossible to define the concept of
"being a monad" such that you can write code which polymorphically works
for any monad.
The long version:
It appears that C# generics is too weak to express the necessary type
relationships that describe what a monad is. I suspect C++ templates
probably can do this, but C# can't. This rules out the possibility of
writing an abstract class or an interface which describes all possible
monads, and then writing code against that interface.
On the other hand, it appears to be quite possible to write code that
works on one *specific* monad, decided at development-time.
OK, so let me recap what the heck a monad is. It's so abstract that it's
awkward to put into works, but it's not particularly complicated. If the
class Foo forms a monad, that basically means that an object of type
Foo<int> can somehow "supply" an integer. Now there are several possible
ways it might do that.
The simplest way is if Foo is some kind of data container. For example,
a List<int> can "supply" integers in that it *contains* integers. So
many sorts of container form a monad. Another way is if Foo represents
some kind of "process". For example, Foo<int> might be some kind of
parser object, which reads some text and parses an integer out of it.
Most of these "process monads" have some kind of a Run() method that
actually "executes" the action(s) in question. (The result might not be
a simple int, of course; for example, a parser could return a parse
error rather than an int, depending on the input supplied.)
Stepping back from that, if Foo<int> is simply an object that represents
a supple of integers, then the Foo class forms a monad if we can define
the following functions:
public static Foo<T1> Inject(T1);
public static Foo<T2> Map(Foo<T1>, Func<T1, T2>);
public static Foo<T1> Join(Foo<Foo<T1>>);
public static Foo<T2> Chain(Foo<T1>, Foo<T2>);
public static Foo<T2> Bind(Foo<T1>, Func<T1, Foo<T2>>);
[This isn't quite valid C# syntax, but the meaning should be clear.]
This set is redundant; several of these functions can be defined in
terms of each other. There are two possible minimal subsets:
- Inject() + Map() + Join()
- Inject() + Bind()
So what do all these functions do, then?
Inject() is simple enough. It takes a thing and constructs an object
which produces that thing. For example, if Foo is a parser, then
Inject(5) is a parser which consumes zero characters of input and just
returns 5. It *always* returns 5, regardless of what input you run the
parser on. (Since it ignores input anyway.) If Foo is a data container,
then Inject(5) is just a 1-element container with a 5 in it.
The Map() function is simple enough. It takes a function and applies it
to every element of a collection. Except that a monad isn't necessarily
a collection. For example, I might have some parser that returns a
single digit character, and a function that converts a digit character
into an actual integer. Using Map(), I end up with a parser that returns
integers not characters. (Notice that we still haven't *run* any
parsers, just constructed a more complex parser out of a simpler one.)
If you use Map() to apply a function which produces another Foo, then
clearly you're going to end up with a Foo<Foo<X>>. The Join() function
unwraps a layer of wrapping. How this works depends on what the monad is
(which is why it's definition is crucial). For a container, it's
obvious; think about flattening a list of lists into a flat list. For
parsers, it's taking a parser that produces a parser, and then running
the inner parser to return the result of that. (It sounds more
complicated than it is.)
The Bind() function actually takes a function that produces a Foo, in
the way just described. You can think of it as taking a parser and a
function which consults that parser's output and decides what parser to
run next, returning that parser so that Bind() can run it. From the
previous paragraph, it should be obvious that Bind() = Map() + Join().
It may be less obvious that Map() = Bind() + Inject() and Join() =
Bind() + the identity function. So either can be defined in terms of the
other.
The Chain() function takes two parsers, runs the first one, and then
runs the second one. It discards the output from the first and returns
the output from the second. This is the clue to how to implement it;
it's simply Bind(), given a function which ignores its input and always
returns the same output.
So anyway, we can define Foo<> and then write the above functions, and
then Foo<> can be used as a monad. But can we write an abstract
specification of "monad" and have multiple classes implement it? Sadly
not, as best as I can tell.
One might naively try this:
public static Monad<T1> Inject(T1);
public static Monad<T2> Bind(Monad<T1>, Func<T1, Monad<T2>>)
The first method is fine. But the second doesn't work at all! The
*intent* is that "Monad" should refer to *the same class* at all times.
But that isn't how object-oriented class inheritance works. The Bind()
method is implemented specially for each type of monad. It has to "look
into" the internal structure of both monad objects - which isn't
possible if they aren't actually both of the necessary class.
Trying to use Map() and Join() instead is no better:
public static Monad<T2> Map(Monad<T1>, Func<T1, T2>);
public static Monad<T1> Join(Monad<Monad<T1>>);
Map() isn't too bad - although since its implementation changes for each
sort of monad, this really ought to be an instance method rather than
static. But Join() is again broken. As written, it will accept
List<Parser<int>> and Parser<List<int>>, whereas we want it to accept
only List<List<int>> or Parser<Parser<int>>.
If we refer to a *specific* monad class, these problems go away. But if
we try to be abstract, there's no way to enforce the required
constraints. The only option is run-time dynamic casting - yuck!
Hmm, all those static methods though... that doesn't sound very OO, does
it? Well, Inject() looks very much like a "factory", so perhaps we can
have a FooMonad class that contains a (non-static) Inject(), and the
move Bind() et al to Foo itself?
public sealed class FooMonad
public Foo<T1> Inject<T1>(T1 datum) {...}
public sealed class Foo<T>
public Foo<T2> Map<T2>(Func<T, T2> f) {...}
public Foo<T2> Bind<T2>(Func<T, Foo<T2>> f) {...}
Even here, trying to write a type signature for Join() is problematic.
Basically Join() takes "this" and returns a Foo<T2> - but only if
T=Foo<T2>. How do you say that in a type signature? The only real way
around this is to artificially stuff Join() back into FooMonad.
> for any monad.
<snip>
Not sure I completely understand... The only functional language I've worked
with is LISP, and I only wrote one rather simple program in it, but in the
interest of learning...
Is this something that could be handled with a pure virtual base class which
defines those elements common to ALL monads and requires type-specific
definitions from implementers?
Or perhaps you'd need a mechanism like the STL sort routine which requires you
to pass it a compare function.
Again, I'm not sure I get the concept here...
A.D.B.
Nobody outside of functional programming understands monads. Nobody outside
of functional languages needs monads. What can be deduced from this?
That nobody outside of functional programming realises that that class
they just wrote is actually a slightly buggy implementation of a monad? ;-)
Again, the problem is that we need to write a method which examines TWO
objects which must be of THE SAME class. I haven't yet found a way to
specify that in C# (although I suspect C++ can probably do it).
I don't understand at all what that even means.
Start by explaining (briefly) what "examines" means in this context.
Am 14.03.2013 21:02, schrieb Orchid Win7 v1:
>> outside
... or that that class they just wrote actually does all they'd need
monads for in an OO rather than functional world? :-P
> - Warp
http://stackoverflow.com/questions/2704652/monad-in-plain-english-for-the-oop-programmer-with-no-fp-background/2704795#
2704795
Still trying to wrap my head around it.
A.D.B.
> 2704795
It almost looks like it's describing inheritance. What is
"First, what is an "amplifier of types"? By that I mean some system
which lets you take a type and turn it into a more special type. For
example, in C# consider Nullable<T>. This is an amplifier of types. It
lets you take a type, say int, and add a new capability to that type,
namely, that now it can be null when it couldn't before."
other than inheritance? The next paragraphs also seem to be talking
about inheritance.
Of course the text then proceeds into blabbering about something that's
hard to understand and seems quite inconsequential. Something about
binding (which sounds like dynamic binding in inheritance, but apparently
isn't?)
Consider another example: Let's say you want to do something like
public abstract class Tree
public abstract Tree Union(Tree other);
So we can now write SplayTree, HeapTree, SearchTree, etc as subclasses
of Tree. But the thing is... you can only Union() two trees together if
they are THE SAME TYPE of tree. So you can take the union of two
SplayTrees, or the union of two HeapTrees, but NOT the union of a
SplayTree and a HeapTree.
But the type signature above does not express this constraint. It says
that you can union *any* two objects so long as they are both Trees -
which is wrong.
That's the basic problem with writing a monad interface in C# (or Java,
for that matter). You could do a run-time type check and throw an
exception if the types don't match, of course. But I haven't yet figured
out how to enforce the constraint at compile-time.
(Having asked some questions on stack overflow, it appears it might
actually be possible in C# though... I'll give it a go tomorrow.)
Am 14.03.2013 22:20, schrieb Anthony D. Baye:
> 2704795
I guess this one about wraps it up nicely (emphasis added):
Monads are typically used to solve problems like:
* I need to make new capabilities for this type and still combine
old functions on this type to use the new capabilities.
* I need to capture a bunch of operations on types and represent
those operations as composable objects, building up larger and larger
compositions until I have just the right series of operations
represented, and then I need to start getting results out of the thing
* I NEED TO REPRESENT SIDE-EFFECTING OPERATIONS CLEANLY IN A
LANGUAGE THAT HATES SIDE EFFECTS
(Note that these are basically three ways of saying the same thing.)
With the whole OO concept being /centered/ around operations with
side-effects (namely modifying the object's internal state), this boils
down to saying that monads are NOT NEEDED in an OO language. (Or, in
other words, that monads do something that is already inherent in the OO
concept anyway.)
I think it might also be fair to say that monads are a way to express
certain OO ideas in functional languages.
Am 14.03.2013 23:39, schrieb Orchid Win7 v1:
Well, this can easily be solved by making Union non-abstract and having
it call more primitive abstract functions; e.g (using pseudocode as I
currently don't have C# syntax memorized):
public abstract Tree copy();
public abstract Iterator<Leaf> leaves();
public abstract void addLeaf(Leaf l);
public final Tree Union(Tree other)
Tree newTree = this.copy();
foreach(Leaf i in other.leaves())
newTree.addLeaf(i);
There. Problem solved.
Note that in OO languages it is customary to use non-lazy evaluation
(because objects may change, so lazy evaluation is prone for effects
that OO programmers don't expect), so there's nothing conceptually wrong
with copying the leaves rather than creating some "meta-tree" that
provides tree-like operations on a compound of two tree objects.
> newTree.addLeaf(i);
Note that taking the union of (say) two heap trees is a O(log N)
operation, whereas what you just wrote is O(N).
You can, of course, NOT write an abstract interface, and just write a
concrete Union() method [with a different type signature] for each
concrete Tree class. That works just fine. [But now you can't write code
that works over any Tree type and expect to do unions.]
But anyway. The example illustrates the problem. Taking the Bind() of
two different monads isn't even *defined*. There's no sensible answer.
So until I can find a solution to that...
> for any monad.
It appears I missed the elephant in the room. Apparently C# already
*has* several classes which form monads, and even a special monad
comprehension syntax for dealing with them.
Consider the following Haskell parser:
identifier :: Parser String
identifier = do
leading <- many space
first <- letter
rest <- many alphanum
trailing <- many space
return ([first] ++ rest)
Now consider the following C# LINQ query:
Parser<string> identifier =
from leading in Parse.Whitespace.Many()
from first in Parse.Letter.Once()
from rest in Parse.LetterOrDigit.Many()
from trailing in Parse.Whitespace.Many()
select new string(first.Concat(rest).ToArray());
Notice any similarity?
C# *already* has monads. The designers of LINQ even explicitly mention
Haskell and monads as influencing their design.
So much for "only functional programmers understand monads and only
functional programmers need monads"... :-P Monads are in fact one of the
star features of a highly commercially successful programming platform.
(Although I'll admit LINQ is definitely tailored more towards
*container* monads rather than being a general monad framework.)
I notice in passing that there is no "interface" which describes all the
methods you have to implement to make a monad. (Or to make something
that LINQ will work on.) Rather, it uses a strange system of "extension
methods" - a very un-OO concept, if you look it up. But anyway, LINQ
queries let you easily write monadic expressions without drowning in a
sea of lambda functions.
> about inheritance.
> isn't?)
Still waiting for an answer to this...
>> about inheritance.
>> isn't?)
OK, so now I'm back from London, let's take a stab at this...
The originally quoted answer doesn't make a huge amount of sense to me.
I mean, I see where the guy is trying to go, but it's not a great metaphor.
Let's say you have a Customer type. Using this, you can construct a
List<Customer> type, which extends Customer with the ability to have
multiple values. Similarly, Parser<Customer> extends the Customer type
with the ability to read a customer from a string.
Except that, really, that's a rather odd way of looking at things. I
mean, a list of customers isn't really much like a customer at all -
it's a list! And a parser of customers isn't a customer either; it's a
thing that might produce a customer.
The "binding" refers to binding the result of a parser (or whatever) to
a function. In other words, you run the parser, and pass its result
through a function to generate the final result. Really, a monad is
simply a specific way of chaining operations together; nothing more
complicated than that.
> Really, a monad is
And this is somehow different from just a regular function somehow?
>> Really, a monad is
Well, yeah, that's the crux of the matter.
In a pure language like Haskell, a *function* takes several inputs and
produces an output, and that's all it's allowed to do. If you want to do
something more complicated, you represent it as a monad.
Now, if you're working in an OO language, then you automatically have
access to facilities like I/O, global variables, exception handling and
so on. So you don't need a monad to represent these things.
But now suppose that you want some facility that the OO framework
doesn't natively support. Whether it's non-deterministic computation or
backtracking or partial failure or atomic transactions or whatever... A
monad is one possible way of dealing with these things.
On 28/03/2013 01:04 PM, Orchid Win7 v1 wrote:
> But anyway, LINQ
You'll be unsurprised to learn that I am currently about 40% of the way
through implementing Parsec in C#. It turns out to be reasonably easy,
although there are a few gotchas. (E.g., there is no C# function which
both inserts an element into a list *and* returns the list. Which is
annoying, since it seems you can't call void-functions from LINQ...)
It will be interesting to compare the speed with your original...
For most parsing tasks, speed isn't really an issue. Usually you use
parsers to parse human-written text, which is typically small enough
that the time spent parsing is negligible compared to the time spent on
subsequent processing.
(If you wanted to parse a 3GB XML file, you wouldn't use Parsec. You'd
use one of the various XML-specific libraries which are tuned to do that
specific job very efficiently.)
That said, I'm not tuning my C# code for speed at all, and I don't
expect it to be particularly fast. Then again, Parsec defaults to using
Haskell strings, which are very inefficient... It looks like being a
tortoise race.
I don't know a great deal about parsers (the most I've done is made one
to calculate very simple sums, like (5+4)/2) but AIUI things like POV
first convert the human readable text to binary symbols (removing any
unnecessary formatting) and then parse the binary symbols rather than
the raw text. IDK which part typically takes longer (I guess the first
part as that involves a lot of string searching), but the time POV
spends "parsing" even a medium-sized scene isn't trivial.
Saying that if you're writing something to do single-line equations then
you probably don't need to worry :-) I thought it would just be an
interesting real-world example if you've coded the same algorithm in
both Haskell and C# to see the difference.
> the raw text.
In other words, "lexing" (AKA "tokenising") followed by "parsing".
That's because
1) The "parsing" time includes the time taken to expand macros, because
these work at the token level rather than some higher-level abstraction.
2) The "big" scenes are ones which include huge meshes. These
machine-generated constructs tend to be quite large.
Yeah, why not...
> the raw text.
POV-Ray doesn't convert the SDL file into any internal binary format.
It just parses the text and creates objects as needed.
Fast parsing (regardless of whether you are interpreting as you parse or
whether you are byte-compiling it) is a difficult problem, one I have some
experience with.
The fastest possible way of parsing a text file with human-readable syntax
is to load it into an array in memory (if the file is exceedingly large
you'll have to do it in sections, but that shouldn't slow it down in any
significant way) and then parse it in-place (ie. without pulling out any
parts of it or creating new objects just to parse the thing) in a linear
fashion (ie. you traverse the array from beginning to end, without ever
going back.)
It is possible to do this kind of parsing without any kind of recursion,
but it becomes a bit complicated. Basically you need a state machine (which
has been generated at compile time into your program), and usually this
means generated code. (I suppose you could write a state machine by hand,
but it quickly becomes complicated, especially if the syntax of the thing
you are parsing is complex.)
The easiest way of writing an efficient parser by hand is to implement
a recursive descent parser (which, as said, parses the input in-place
from the array where it has been read to.) A RDP allows parsing any amount
of nested blocks in the input syntax (eg. parentheses or other types of
nested blocks) at any nesting depth, without ever having to go back in the
input (ie. just traversing the input from beginning to end once.)
What you do with the parsed information depends on what you want, but eg.
byte-compiling it into a stack-based bytecode (that can be later interpreted
in a very efficient manner) is very easy with a RDP. You could, of course,
just interpret the input directly.
>> the raw text.
The existence of tokenize.cpp in the source made me think otherwise.
What does this file do then?
> going back.)
Interestingly, if your parser is a monad, then you can never transform
it into a finite state machine. Monads are just "too flexible" to permit
this.
To be concrete: I can write a single Parsec parser which parses a file
consisting of a BNF grammar specification followed by text written in
that grammar. In other words, a parser which dynamically constructs a
new parser and then runs it. Obviously there is no hope of statically
optimising such a thing.
In Haskell we use monads to perform I/O, and for that task this level of
flexibility is exactly what is wanted. We *want* programs to change
their behaviour depending the input they receive. But for the problem of
parsing a fixed grammar, that's actually a little bit *too* flexible.
Sometimes we would like something a bit less powerful, because often
less is more with these things. (In this case, less expressive power
equals more optimisation capabilities.)
The problem with monads is that the bind operation feeds the result of
one step into some arbitrary Turing-complete code block which then
generates the next parser to run. This Turing-completeness is the source
of the trouble; it means you can't statically analyse what the parser is
going to try to do (c.f. Rice's theorem).
There are alternatives, however. In particular, instead of using a monad
to do parsing, you can use something called an "applicative functor".
(No, I'm not kidding. That's what they call it.)
Every monad is also an applicative functor. However, not all applicative
functors are also monads. For the purpose of parsing, it's the ones that
aren't monads which are interesting.
A few definitions. In Haskell terms, a "functor" is basically anything
that has a Map() function. You'll recall that Map() takes a list and a
function, and applies that function to every element of the list,
resulting in a new list. Well, in a slightly mind-binding kind of way,
and I/O operation is *also* a functor, because you can take (say) an I/O
operation that returns a byte, and Map() a function from bytes to
characters over it, resulting in a new I/O operation that returns a
character. And, indeed, *every* monad is also a functor in this way.
So much for functors. If you have something that's a functor, and all
you know about it is "it's a functor", then that lets you Map() it, and
that's all you can do. This isn't terribly interesting on its own.
Now, an *applicative* functor has two additional abilities. One is that
it has a function like Inject(), which puts a value "into" the functor.
The other is a function that I'm going to call Apply(). It's a bit like
Map(). But whereas Map() takes a function and a functor containing a
value [or values], Apply() takes a functor of functions and a functor of
values.
For example, if Parser<X> is a parser that parses an X, then
public Parser<T2> Apply(Parser<Func<T1, T2>> p1, Parser<T1> p2)
First p1 is run, then p2 is run, then the function returned by p1 is
executed with the result from p2 as its argument. Whatever it returns,
the composite parser returns.
My word, that seems mighty complicated. And why would you want a parser
that returns a function anyway?
Well, Map() lets you apply a function to *one* argument. But what if you
have (say) a 4-argument function, and you want to run 4 parsers to
generate each of the inputs? Well, you can do
Map(f, p1)
That partially applies our 4-argument function "f" to the first
argument... But now we've got a parser that returns a 3-argument
function. We're stuck; Map() wants a function, not a parser that returns
a function.
Now if our parser forms a monad, this is where we invoke Bind() to chain
in the next step. But that's actually overkill; all we want is to be
able to take a function from a parser. And that's all Apply() does. So
we can do this:
temp1 = Apply(f, p1);
temp2 = Apply(temp1, p2);
temp3 = Apply(temp2, p3);
temp4 = Apply(temp3, p4);
Now temp4 is a parser that parses 4 things and then applies f to the
results. In Haskell, it's not called Apply(), it's called "<*>", which
is an infix operator, so we can just write
temp4 = pure f <*> p1 <*> p2 <*> p3 <*> f4
which looks almost the same as
result = f v1 v2 v3 v4
but with a bunch of <*> operators inserted between arguments. There's
also a "<*" operator, which allows us to run a parser and skip its output:
parser = pure f <*> arg1_parser <*> arg2_parser <* separator_parser
<*> arg3_parser
This, by itself, doesn't allow us to parse alternatives. (But then,
neither does a monad by itself.) We need extra combinators to handle
that, and a few other things which are specific to parsers.
Using this framework, the parser can be represented not as an opaque
block of Turing-complete code, but as a transparent data structure which
can be operated on by other functions. This means you can do run-time or
compile-time optimisations on it. In particular, you could write a
function that takes a parser and generates a finite state machine from it.
The *other* possibility is to use something called an "arrow", but
that's for another post...
I'm assuming that implementing a recursive descent parser ought to be
relatively simple in Haskell, given how recursive in nature functional
programming is. (Of course this also assumes that it's easy and efficient
in Haskell to have the input as a byte array, and it's efficient to read
said array byte by byte, without much copying things around.)
An interesting thing about this type of parsing, though, is how to parse
things like numeric literals (especially if they are not integers) or
UTF-8 encoded characters.
Most languages have some kind of standard functionality for parsing the
former. The only thing one has to do is to detect when such a literal is
appearing in the input, and then call said function. (The C/C++ standard
libraries in particular offer functions to parse numeric values that are
in ASCII format in-place, without having to first copy them anywhere,
which is a major help when writing such efficient parsers.)
Parsing UTF-8 encoded characters is a bit trickier, especially if the
language does not offer standard utility functions for that purpose.
The most efficient way of doing that is to, basically, write a small
state machine that reads the input byte by byte until a character not
in a valid sequence appears, and returns how many bytes the found name
consists of. (During this parsing, or afterwards, you can then do with
those characters whatever you need to.)
(Remember that we are writing an extremely *efficient* parser here. That
means no copying characters around and parsing them separately. They have
to be parsed in-place, where they appear in the byte array.)
> programming is.
Indeed.
*Reading* from an array is easy. You only need to copy things if they
change, and reading from something doesn't change it.
> former.
The trouble starts when the literals you're trying to parse don't match
the format that the standard function expects. (E.g., some languages
allow "+7" as a valid integer, and others don't.)
Haskell provides a way to read from a file, decoding UTF-8 on the fly.
I'm not sure how it's implemented internally though. You end up with a
packed array of characters which you can iterate over.
You're probably going to struggle to get this level of efficiency from a
programming language that uses garbage collection. Even if all the data
is in a flat array, the array might get copied from place to place
occasionally by the garbage collector.
(Having said that, I'm not sure whether or not Haskell's GC does any
special handling for "large" objects. Some GCs handle these specially,
which usually means storing them in a separate area that doesn't get
scanned as often, so they don't need to be copied as much.)
It does. It takes various steps to try to avoid copying objects larger
than about 4KB.
