POV-Ray : Newsgroups : povray.off-topic : Basic arithmetic Server Time
28 Jul 2026 08:26:26 EDT (-0400)
  Basic arithmetic (Message 31 to 39 of 39)
Subject: Re: Basic arithmetic
Date: 14 Mar 2013 15:57:18
Message: <51422b9e$1@news.povray.org>
On 14/03/2013 01:54 PM, scott wrote:
> The exam would be a more realistic and useful test then if it simply
> gave you a real linux prompt and timed how long it took you to get the
> correct answers to do what it wants. The pass rate would then be on how
> long it took you to get all the answers.
Don't forget that it's not just about being able to /write/ commands to
do stuff; you probably need to be able to /read/ this stuff as well. ;-)
> Knowing where and how to find
> stuff efficiently is far more important than actually knowing it
> (because you could never hope to know even a tiny fraction of all the
> information you have access to). As stated already the stuff you use
> frequently you will remember anyway.
Indeed.
Date: 14 Mar 2013 15:59:01
Message: <51422c05$1@news.povray.org>
On 14/03/2013 04:07 PM, Jim Henderson wrote:
> On Thu, 14 Mar 2013 08:59:14 +0000, Orchid Win7 v1 wrote:
>> Unix commands and their switches follow no reason or rhyme
> Sometimes it certainly appears that way.  In this instance, I think it's
> a case of "-r" and "-R" were already used as a secondary option for the
> query parameter, and 'e' is the next letter in "remove".  -U was already
> used for "upgrade".
Like I said, half the text-processing commands let you specify how many
bytes to process using -b, and half call it -c. No reason, they just do.
But then again, we're not talking about a coherently designed system,
we're talking about a random collection of tools and utilities
independently developed by unrelated individuals over the course of 70+
years. Add in a few layers of backwards compatibility and YUCK! >_<
Date: 14 Mar 2013 16:31:42
Message: <514233ae@news.povray.org>
>> it's a case of "-r" and "-R" were already used as a secondary option
>> for the query parameter, and 'e' is the next letter in "remove".  -U
>> was already used for "upgrade".
"b" = Bytes
"c" - Characters
Developer's choice/prerogative. :)
Try about 50 years.  UNIX came about in 1969.  Some of the development
work obviously would've been before it was released.
Jim
Date: 14 Mar 2013 18:42:35
Message: <5142525b$1@news.povray.org>
> "b" = Bytes
> "c" - Characters
Nice choice of "-" and "=" there. :-P
But yes, that's why the names. Because, obviously 1 character = 1 byte.
Oh, wait...
And hey, even if that were true, it's *still* an inconsistent naming of
command switches. Some commands expect -c and some expect -b, and you
just have to memorise which is which. (A tiny few commands accept BOTH,
and actually do the correct thing with multi-byte characters... But not
very many!)
>> years. Add in a few layers of backwards compatibility and YUCK!>_<
That's a bit before my time. But the main point still stands - it's a
collection of tools independently developed by mostly unrelated
individuals over a period of several decades. There never was any
overarching design plan.
Date: 14 Mar 2013 23:01:08
Message: <51428ef4@news.povray.org>
Typo. ;)
> Oh, wait...
When you're dealing with ASCII (and EBCDIC, IIRC), that is most certainly
true.
> very many!)
Like I said, programmer's prerogative.
>>> 70+ years. Add in a few layers of backwards compatibility and YUCK!>_<
There was for the underlying architecture, but yes, developers who wrote
different tools didn't coordinate.  You sound surprised by that for some
reason.
Jim
Date: 16 Mar 2013 16:01:31
Message: <5144cf9b$1@news.povray.org>
Le 2013-03-14 09:54, scott a écrit :
>> Formulas can sometimes be derived from first principles if necessary.
>> (Provided you remember enough background around them.) Unix commands and
>> their switches follow no reason or rhyme. Much like the spelling of the
>> English language, the only solution is to memorise large chunks of data
>> and be able to recall it later. It's not so easy to do that for parts of
>> the syllabus that you don't actually need to use regularly...
> long it took you to get all the answers. Knowing where and how to find
Just like the CCIE lab test.
Day 1: Here's a pile of network gear*.  Here's a Visio diagram of a
corporate network (with missing info, of course).  All the cables and
all the manuals are over there on the shelf.  You have 8 hours.
Day 2: Guys, there, was a major incident on your network last night, the
CIO has been screaming at your boss for the last half hour.  Fix it.
You have 8 hours.
*Including some that's DOA, or whose firmware has been erased.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 17 Mar 2013 00:03:21
Message: <51454089$1@news.povray.org>
> CIO has been screaming at your boss for the last half hour.  Fix it. You
> have 8 hours.
Which is a very good exam - one of the best in the IT industry, if not
the best.
But it's also not something you'd do on an entry-level exam.  It's a
fairly expensive exam to take, to administer, and requires a fair amount
of setup to pull off.  If you fail, Cisco will charge you to review the
results (you get the review fee back if the scoring was incorrect,
however).
IT certification exams fall into two categories, generally:  Introductory
and Advanced.
Introductory exams are almost /never/ practical exams (RedHat is the only
exception to this that I'm aware of - and the guy who's in charge of
their exam and certification programs has no interest in doing anything
other than performance-based testing.  I've met him and he and I talked
at length about it).  The LPIC-1 is an introductory exam.  The purpose of
an exam at this level is to define a minimally-qualified entry level
candidate - a first level admin, or similar.  Those certifications tend
to be marketing fodder for the exam sponsors (Cisco, SUSE, RedHat, etc).
They have to measure a valid candidate in order to have some validity,
but the purpose is to build a large following of candidates who have
familiarity with the product(s) the exams are about.
The benefit shifts when you get to more advanced exams.  Those exams are
targeted at a smaller audience - and if (IMHO) the sponsor is doing their
breakdown properly, the advanced exams are /not/ revenue-generating.  At
best, they should break even.  (If you're making an "advanced" mass-
market certification exam, you don't understand the economics of
certification programs, again IMHO).  The purpose of an advanced
certification program is to have a small number of people (relatively
speaking) who have advanced skills and knowledge - the "creme de la
creme" of the mass-market certification audience are the ones who will
take it, and they should be difficult to pass (like the CCIE).
The benefit to the candidate of a properly defined advanced certification
is significant - demonstrably higher pay, higher regard/recognition, and
higher demand for their skills.
Jim
Date: 18 Mar 2013 09:12:49
Message: <514712d1@news.povray.org>
Unless I'm mistaken, the CCNA (Introductory Cisco Cert) has some amount
of simulated hands-on, now.  When I took it, it was just multiple choice
answers, inlcuding sections where you had a list of 100 commands, and
you needed to pick the one that applied to each of the 20 questions in
that section, but that was before the days of Flash and Java, so
simulators were not that common.
Agreed. their as much a sales pitch as a technical certification.  A kid
just out of school who got her MiCkey mouSE certification will probably
not recommend Solaris as her new employer's server platform.
They may not be revenue-generating, but they are also expense-cutting.
For example, if a company has a certain number of CCIEs on staff (I
think it's 4), they get a huge deal on maintenance contracts, because
Cisco assumes they won't be calling TAC twice a week for silly stuff.
Date: 18 Mar 2013 12:08:35
Message: <51473c03$1@news.povray.org>
>> only exception to this that I'm aware of - and the guy who's in charge
>> of their exam and certification programs has no interest in doing
>> anything other than performance-based testing.  I've met him and he and
>> I talked at length about it).  The LPIC-1 is an introductory exam.  The
>> purpose of an exam at this level is to define a minimally-qualified
>> entry level candidate - a first level admin, or similar.  Those
>> certifications tend to be marketing fodder for the exam sponsors
Simulation was up-and-coming, I know there's a company in China that does
a lot of the simulation construction for Citrix, and the test drivers
used in testing centers are better able to handle that type of hands-on
because there are limited possibilities.
The way that's actually done is interesting, because the test developers
actively seek out unqualified candidates during development to determine
possible answers that someone who doesn't know the material might try.
I was thinking along the lines of being able to say "we've got x
certified individuals", but yes, it is something used to build customer
loyalty as well, for customers who invest in the courses and exams -
there's a training investment, so the customer wants to get a positive
return out of that investment.  The interesting thing is that that's
something that can actually be measured (in broad terms) by the exam
sponsor, and some sponsors do make claims like "you'll recoup the
training expense in 3 months" with a fair degree of certainty.
It requires a fair amount of course eval data to be able to do so - and
not just an eval at the end of the course, but a follow-up eval 6 months
after the course.
>> are targeted at a smaller audience - and if (IMHO) the sponsor is doing
>> their breakdown properly, the advanced exams are /not/
>> revenue-generating.
Oh, yes, absolutely.  The first IT certification exam - the Certified
NetWare Engineer - was originally only going to be granted to a fixed
number of candidates who worked for partners - the purpose was to allow
the partners to be an extension of the product support organization, and
too many certified candidates would have diluted that pool to the point
that nobody made any money (actually, there's a similar problem in IT
training centers today - many organizations have too many training
partners to meet the demand, and the end result is that classes get
canceled not because there isn't demand, but because there isn't demand
to fill the course - say - the 6 times a week it's being held at
different training centers in an area.  Well, that and the face of
training has changed to the point that most people won't sit a 5-day
class any more).
Jim
