POV-Ray : Newsgroups : povray.off-topic : Funniest bug ever Server Time
16 Oct 2026 23:51:27 EDT (-0400)
  Funniest bug ever (Message 1 to 49 of 49)
Subject: Funniest bug ever
Date: 23 Feb 2013 06:34:07
Message: <5128a92f$1@news.povray.org>
OK, so as you guys know, I now write computer software for a living. The
installation DVD for this thing used to be hand-crafted, but thanks to
[mostly] my efforts it's now auto-generated by a script. Anyway,
obviously if you completely replace the installation system, you need to
go test it. So we're testing it.
So yesterday the tester is trying out the software on the various
platforms we support it on. And he starts complaining that on one
specific model of laptop, it's not working properly. He claims the
installer gets to 60% of the first step, and then skips the rest of that
step and skips the next step completely and just says "installation
successful".
So I burn a copy of the same DVD and try installing it on another laptop
of the same model. It works perfectly. But the tester is insistent; he
hands me the laptop with the DVD still in the drive. I run the
installer, and it appears to work fine. But then, around about 65%, it
suddenly "completes", just like the guy said. That's odd.
The install disk is a live Linux environment that runs a Bash script to
do the installation. It does some crazy multi-way piping and redirecting
to get the progress display to work. (Most Linux commands helpfully
provide absolutely no feedback whatsoever, which isn't very good for an
operation that takes 10 minutes to complete...) With all this piping
going on, it wouldn't surprise me if some command somewhere is emitting
an error message and it's simply been "lost" somewhere. A bit alarming
that the script still claims that "installation was successful" though...
At this point I'm wondering if maybe the disk has a scratch on it which
prevents it reading past 65% of the image file. So I boot the disk and
do an md5sum of both image files. They're both fine. Hmm. I manually run
the key command that actually does the installation. Initially I'm
getting 150 MB/sec - which is odd, given that the internal SSD device
maxes out at about 40 MB/sec. After a few minutes, the speed drops to
about 10 MB/sec - a more usual number. And then the command simply
/stops/, with no indication as to why. It claims to have completed, but
the amount of data copied is clearly too low.
So I take the DVD out and put in the one I've been testing with. I
notice the DVD I took out has a slightly older version of the image
file. But the installation script is identical, so that shouldn't matter
at this stage.
I run the installer again, and again it fails the same way. I run it
manually, and again it fails the same way. Now I'm wondering if I've
somehow burned out that sector on the SSD or something. (But surely
wear-levelling would... hmm, anyway.) So I look inside the harddrive bay
to see how old the drive is...
At this point, things get WEIRD! I look in the drive bay, and see...
daylight. It turns out there's NOTHING IN THERE. There *is* no harddrive!
This is not /that/ unusual; we do occasionally swap drives around or
take drives out of machines. So somehow our test guy ended up with a
laptop with no drive. That's not especially surprising.
But... so... if there's no drive, WHAT THE HELL IS THE INSTALLER
INSTALLING TO?!? O_O
Why does it sit there for 5 minutes apparently working perfectly when
there's NO DRIVE PRESENT?!
My collegue suggested that maybe someone had left an SD card in the
internal card reader. But no. Man, that would have been fun though!
So I open up the Bash script and start reading. This is one of the few
parts that I didn't write. (It was written early on, when I had hardly
learned how to do Bash, so my boss else wrote it.) The programmers among
you will appreciate this: The script reports an error if the number of
devices connected is GREATER THAN ONE. But the script neglects to check
for the possibility that the number of devices is LESS THAN ONE. (!)
Because, hey, who the hell has a laptop with no harddrive in it?
OK, well that's fine I guess, but next the script checks that the
[assumed to be] one device has sufficient space. Surely a non-existent
device has zero space on it, right? RIGHT?? How in the HELL is this test
passing?
Ah, but wait. You're thinking about this as if you're using a REAL
programming language. Bash is just text-munging. It doesn't compare the
contents of a variable to a number. It compares two bits of text to each
other. And one of those pieces of text is now "error: the device
/dev/sda does not exist", which is more characters than "80000000000",
and hence is reported as being "greater than" the required disk size.
FACEPALM!
So there's no error produced by the script. But how the HELL does it
image a device that DOESN'T SODDING EXIST?!
Ah, but wait. This is Linux, remember? Consider the following command:
   cat Image1.raw.gz | gzip -d | dd of=/dev/sda
Slowly it dawned on my what is happening here. If there *is* a block
device connected, then UDev will generate a special file named /dev/sda
which represents this device, and the above command will overwrite the
contents of that device. HOWEVER... if there is *no* block device
connected, then this file will not exist. In that case, rather than
produce some kind of error, the above command will *create* a regular
file named /dev/sda and try to decompress 20GB of data into it. (!)
Once upon a time, that might not have worked. A DVD is a read-only
device, after all. But in this modern age, you have the DVD, which is
read-only, and you then overlay a read/write filesystem backed by RAM.
In summary, the installer is decompressing a 20GB disk image into RAM,
hence the 150MB/sec transfer speed. (Probably limited by DVD drive speed
and the rate at which the CPU can decompress the data.) After about 5GB,
free RAM has become so fragmented that the transfer rate drops to
10MB/sec as the OS desperately searches for empty pages. And eventually,
once ALL AVAILABLE RAM HAS BEEN EXHAUSTED, the process is summarily
terminated.
If this was written in a real programming language, some sort of
exception would have been thrown, which would have alerted me to the
problem (and prevented the "installation successful" message being
shown). But this is Bash. By default, it completely ignores all errors,
problems and malfunctions, and continues executing the next command as
if everything worked perfectly. So when DD gets terminated, Bash simply
executes the next line of the script - which says "installation successful"!
I told my boss, and he spent literally 15 minutes laughing
uncontrollably. There's always a lot of banter in our office, but it's
unusual for somebody to actually find something so funny that they're
actually unable to speak any more. And for 15 minutes?
Damn, this is probably the most amusing bug I've ever seen.
Fortunately, the fix is very simple. You just need to add a check for
the possibility of there being zero devices. But I love the way that
there are three separate stages where the problem *should* have been
caught, but wasn't. And all because we wrote the thing in Bash...
Also, somebody give that tester a medal. There's no way in hell we would
have thought to actually *test* for such an obscure condition. (Not that
the tester did so intentionally... It was simply a lucky accident. But
you *know* some customer somewhere is going to do this one day, and
saying something succeeded when it didn't is a pretty serious bug!)
Subject: Re: Funniest bug ever
Date: 23 Feb 2013 08:01:33
Message: <5128bdad$1@news.povray.org>
Am 23.02.2013 12:34, schrieb Orchid Win7 v1:
Heh - I once had a work colleague like that: Be it karma, a genetic
disposition, or - as he used to put it - having "shit on his fingers" -
he had a supernatural talent for having things go wrong on him. He
actually took quite some pride in this mysterious gift of his, because
yes, of course, he did work as a tester. I swear this guy was /born/ to
test the holy crap out of things.
Date: 23 Feb 2013 08:40:46
Message: <5128c6de@news.povray.org>
I can do that. If anything can be broken, I can break it. ;-)
Regards
Date: 23 Feb 2013 08:47:59
Message: <5128c88f$1@news.povray.org>
Am 23.02.2013 14:40, schrieb Stephen:
Well, he didn't have to break things. Things broke by themselves at his
merest presence ;-)
Date: 23 Feb 2013 13:00:00
Message: <web.512903399d37e2efc2d977c20@news.povray.org>
That is too funny! The best laugh of the day.
Date: 23 Feb 2013 14:07:09
Message: <5129135d$1@news.povray.org>
Like I said, it had us all rolling around on the floor...
Date: 23 Feb 2013 15:00:01
Message: <web.51291efa9d37e2efbcbf52970@news.povray.org>
fun indeed
I mean, to put a windoze guy on charge of Linux stuff :)
Date: 23 Feb 2013 17:24:23
Message: <51294197$1@news.povray.org>
1. Redirect stderr to a different file.  And check for that file being
more than 0 bytes before claiming the install completed succesfully.
2. Expect the unexpected.  I am currently having issues with a "serious"
IT company over an install script that does not error checking and where
there are multiple error-prone steps between zeroing out the old config
and recreating a new one, which can leave the machine pretty much
brain-dead if Something-Bad(tm) happens in the middle of the upgrade.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 23 Feb 2013 19:06:34
Message: <5129598a@news.povray.org>
All programs should return an error code if an error happens. If a program
ends in error but returns a success code, that program is broken (and can
subsequently break other programs, such as 'make', which relies on programs
returning non-success on error.)
Date: 24 Feb 2013 06:52:27
Message: <5129fefb@news.povray.org>
I agree. However, unfortunately it seems that by default Bash ignores
all such errors and happily proceeds, unless you manually suffix every
single command with an explicit return-code check.
Date: 24 Feb 2013 06:52:57
Message: <5129ff19$1@news.povray.org>
On 23/02/2013 07:56 PM, nemesis wrote:
> fun indeed
I love that everybody else in the room is LPIC-certified, yet I'm the
one doing the crazy Linux stuff. ;-)
Date: 24 Feb 2013 06:53:46
Message: <5129ff4a$1@news.povray.org>
Ooo, here's an interesting question - what is the size of /dev/sda? Is
it the size of the special file, or the device to which it refers?
Date: 24 Feb 2013 07:03:06
Message: <512a017a@news.povray.org>
How is that different from any programming language?
Date: 24 Feb 2013 07:21:43
Message: <512a05d7$1@news.povray.org>
In C#, Java or similar, if you try to open a file and can't, an
exception is thrown, and your program is halted. (Unless you thought of
that eventuality and coded a catch{} block for it.) In Bash, the program
continues to execute as if everything worked just fine, silently
ignoring the error.
Date: 24 Feb 2013 12:00:25
Message: <512a4729@news.povray.org>
Am 24.02.2013 12:52, schrieb Orchid Win7 v1:
>> program
#!/bin/bash -e
Have fun!
Date: 24 Feb 2013 14:47:58
Message: <512a6e6e$1@news.povray.org>
>> fun indeed
Just goes to show that certification doesn't always mean "expert".  As
I've said before, a cert is a measure of the minimally-qualified
candidate. :)
Well done. :)
Jim
Date: 24 Feb 2013 14:49:48
Message: <512a6edc$1@news.povray.org>
> ignoring the error.
The exception handling part is a feature of OO programming languages,
IIRC.  Bash scripting is far from OOP. ;)
Jim
Date: 24 Feb 2013 15:00:56
Message: <512a7178$1@news.povray.org>
> #!/bin/bash -e
> Have fun!
I think you mean "set -e", but anyway...
Date: 24 Feb 2013 15:01:48
Message: <512a71ac$1@news.povray.org>
I think exception handling predates OO. But whatever; Bash is a
_scripting language_. It is meant for writing short, simple scripts, but
building large, complex, mission-critical applications.
Date: 24 Feb 2013 15:50:36
Message: <512a7d1c@news.povray.org>
The first object-oriented programming language was Simula, developed
in 1967. When was exception handling first used?
Date: 24 Feb 2013 16:40:39
Message: <512a88d7$1@news.povray.org>
Well, I'm referring to things like catching exceptions.  That's something
that IIRC came with OOP.
Prior to that, for example, in C, if you opened a file and then tried to
do something with it if the open() call failed, you'd end up segfaulting
unless you checked for an exception.
So I guess, in a way, that is "exception handling", but I'm talking about
things like the Python "try:" method, or hooking failures.  You could
kinda do it in various languages in various ways, but there wasn't a very
standardized way to do it.
I may not be explaining it well. :)
That I absolutely agree with. :)
Jim
Date: 24 Feb 2013 17:38:27
Message: <512a9663@news.povray.org>
Am 24.02.2013 20:49, schrieb Jim Henderson:
>> ignoring the error.
Exception handling is not an OOP feature. And yes, bash /does/ have it:
   set -e
   trap "echo aborted by user || kill -INT $$" INT
   trap "echo aborted by other process || kill -TERM $$" TERM
   trap "echo error reported" EXIT
     ... critical section ...
   set +e
   trap - INT
   trap - TERM
   trap - EXIT
Date: 24 Feb 2013 17:39:30
Message: <512a96a2$1@news.povray.org>
Am 24.02.2013 21:01, schrieb Orchid Win7 v1:
>> #!/bin/bash -e
>> Have fun!
Allegedly the above syntax is supposed to work, too. Provided of course
that it's the very first line of the script.
Date: 25 Feb 2013 03:31:52
Message: <512b2178$1@news.povray.org>
>>> #!/bin/bash -e
>>> Have fun!
According to the manpage I read, it's supposed to work anywhere in the
script, so you can turn the feature on and off at will.
I especially love how set -e turns it ON and set +e turns it OFF. I
think that's really special...
Date: 25 Feb 2013 04:14:25
Message: <512b2b71$1@news.povray.org>
Funny story, interesting that Linux works that way - I wouldn't have
known that (but then it took me almost a week to get my bitTorrent
client write access to an external hard drive under Linux).
I guess you can use this as a lesson to try and dream up some more
possible failure modes (eg something else uses up disk space whilst you
are installing, or ...). It only takes a half hour session and you might
be surprised what other things you can't handle.
Also it would seem to me to make sense to have a "catch all" type check
at the end of the installation (eg count folders/files or file sizes or
md5 on the supposedly installed folder) to really be 100% sure the
installation worked. At least then if it fails for some crazy reason
you'll catch it.
You shouldn't give him a medal then... just saying.
Date: 25 Feb 2013 09:30:28
Message: <512b7584$1@news.povray.org>
It's the size of the special file.  If you want to know the size on the
device, you'll have to parse the output of df.
But that's not what I meant.  You redirect stderr to a file and then you
check that THAT file's size is not zero with [ -s $ErrorLog ]
Come to think of it, you should also test that /dev/sba is a block
device before trying to dd to it using [ -b /dev/sda ]
Date: 25 Feb 2013 11:34:53
Message: <512b92ad@news.povray.org>
>>>>> ignores all such errors and happily proceeds, unless you manually
>>>>> suffix every single command with an explicit return-code check.
>>> of that eventuality and coded a catch{} block for it.) In Bash, the
>>> program continues to execute as if everything worked just fine,
>>> silently ignoring the error.
>    set -e trap "echo aborted by user || kill -INT $$" INT trap "echo
>    aborted by other process || kill -TERM $$" TERM trap "echo error
>    reported" EXIT
>    set +e trap - INT trap - TERM trap - EXIT
Interesting, I didn't know that.  Thanks!
Jim
Date: 25 Feb 2013 13:58:41
Message: <512bb461$1@news.povray.org>
Figures.
Only if the device is *mounted*. ;-)
I believe we used sdisk to do the job.
Yes, that was the solution I chose in the end. It's an easy fix.
Date: 25 Feb 2013 14:00:20
Message: <512bb4c4$1@news.povray.org>
>>     reported" EXIT
It's truly terrifying just how much stuff you /can/ do with Bash.
(At this point I must remind you that just because you /can/ does NOT,
in any way, imply that you /should/!!)
Date: 25 Feb 2013 14:15:02
Message: <512bb836$1@news.povray.org>
Yeah. In the old days of Unix, there was a folder named /dev, and you
used to run a command called mknod ("make node") which makes "files"
which are really just ID numbers that tell the Unix kernel to access
device X on bus Y. When you access, say, /dev/sda, you're really
accessing the harddrive.
Windows does a similar thing, except it uses \\?\PhysicalDisk0 as the
name. And this "file" exists if and only if disk 0 is actually plugged in.
Linux now uses a system called UDev. Instead of the OS installer running
mknod to generate device nodes for every device that could ever be
plugged in, the actual /dev folder is empty. The UDev software then
dynamically creates the appropriate device node when I device is plugged
in, and deletes it when the device is unplugged again. In this way, only
nodes for devices that actually exist show up.
This is all very useful. But file redirection is such that if you
redirect to an existing file, it is overwritten (the behaviour we want
for our disk image), but if the file does /not/ exist, it gets created.
And /dev isn't special; it's just a normal folder. The name /dev/sda is
also not special; it's just a regular file.
All of this makes perfect sense really. It's just that if you tried this
on Windows (i.e., tried to create \\?\PhysicalDisk7, say) it would tell
you to go away and die. Linux, on the other hand, lets you do it just
fine...
Oh I'm *sure* there must be other things that could fail. If the disk
was scratched I'd expect some non-deterministic yet spectacular failure
(not much we can do about that), if the target drive has bad sectors
that'll probably silently fail too, pressing Ctrl+C will probably break
something...
> you'll catch it.
Fortunately, the install happens running under a Linux OS that I built.
There are no other user applications running, and the user shouldn't be
able to start any. (There's only one text terminal open, and you can't
open any others.) But we'll see...
Date: 25 Feb 2013 14:59:22
Message: <512bc299@news.povray.org>
Bah, it doesn't even compare to zsh.
For example zsh's file completion system can be quite awesome sometimes.
For example, suppose there are several files in the current directory,
all of them with +r rights for others, except for one. You start writing
"chmod o+r " and then press tab... and it completes to the only file for
which the command has a changing effect.
Or suppose that there are several files, only one of them is a .pdf, and
you write "acroread " and press tab... and it completes to that .pdf file
(even though there could be many other possibilities.)
Or you are deep inside a directory structure that's version-controlled by
git (the .git directory being far upward in the directory structure).
Among several files in the current directory, there's only one that's not
being tracked by git. You write "git add " and press tab... and you can
guess what happens.
Or you write "mplayer " and press tab, and it lists all possible
completions, including the different protocols that mplayer supports
(such as "cdda://", "dvd://", "http://", "tv://" and so on.)
Or you write "git commit -" and press tab... and it lists all possible
options that could follow.
Well, that's nothing still. You start writing "scp somehost:" and press
tab, zsh will ask for your ssh password for that host, and then will start
completing the remote files...
Date: 25 Feb 2013 15:01:12
Message: <512bc308@news.povray.org>
> start completing the remote files...
tsch does that as well.
Jim
Date: 25 Feb 2013 17:31:13
Message: <512be631$1@news.povray.org>
> guess what happens.
I did this yesterday in Bash. I typed "hg add " and pressed tab. Of all
the dozens of files in the current folder, it immediately completed with
the single (deeply nested) file that I hadn't added.
I have literally no idea how it does that.
Annoyingly, if you type "systemctl restart x" and hit tab, it fails to
notice that xdm.service is the only possible completion...
...none of which has much to do with /scripting/ tasks, but anyway.
Date: 25 Feb 2013 18:41:48
Message: <512bf6bc@news.povray.org>
Am 25.02.2013 20:15, schrieb Orchid Win7 v1:
> something...
You can bet on that.
That's what "trap" is good for.
Question is, which subset of all the existing signals do you need to
trap to be safe...
Date: 25 Feb 2013 20:26:58
Message: <512c0f62$1@news.povray.org>
> Jim
Begun the shell wars have.
Date: 26 Feb 2013 03:16:45
Message: <512c6f6d$1@news.povray.org>
Yes, I use the \\?\{<drive_guid>} syntax to make sure my backups always
get written to the correct drive (with several hard drives and USB
storage devices connected I am never sure if the drive letters will be
repeatable).
I only have one annoyance left with my linux setup, I have the external
USB drive connected most of the time to it and it always appears as
/media/EXTERNAL (EXTERNAL is the drive name). However, if I boot it up
*without* the drive connected once, it will never appear again unless I
manually create the folder /media/EXTERNAL and reboot. I don't know
enough about what goes on behind the scenes to prevent this happening.
Date: 26 Feb 2013 13:27:43
Message: <512cfe9f$1@news.povray.org>
> repeatable).
The GUID is so huge that I'd never use that. (And if you ever reformat
the drive, I believe it'll change.) But *much* more reliable than using
the disk number, drive letter or similar.
When the system starts up, it reads /etc/fstab and mounts everything
listed there (except entries marked as "noauto"). But it only does this
on startup. You can probably do "mount /media/EXTERNAL" to make it to
mount it any time you want...
...alternatively, some fluffy end-user helpy-helper tool is doing this,
in which case all bets are off.
This is the greatest problem with Linux. It's based on Unix, which works
in a defined way, but it's rather unfriendly. So now a mish-mash of
incompatible tools sit on top of it trying to make it user-friendly. And
it works great, most of the time. But when it breaks, suddenly you have
to know all this arcane crap again to figure out what's up.
(Oh, and your helpy-helper tool will NOT have any documentation...)
Date: 27 Feb 2013 03:17:23
Message: <512dc113$1@news.povray.org>
It's 24 hex digits, so yeh a bit long to put in every line. What I do is
do a mountvol to mount the external drive using the GUID to a temp
folder on my C drive, then instruct robocopy to backup to that folder.
It's not ideal (for several reasons) but robocopy doesn't seem to like
paths with the GUID directly.
Yes I've put it in fstab to mount the way I need, which all works fine
so long as I never boot it without the drive connected. If I do, the
entry in fstab stays unchanged (I assume some warning or error is thrown
somewhere), but next time I boot with the drive connected it doesn't
appear as /media/EXTERNAL - I have to manually create that folder and
then reboot (or manually mount it).
I suppose one workaround is to check that folder exists before fstab is
read. You'd also need to check the drive is actually connected though,
and then make that folder. Otherwise I'd end up with the same bug you
had where suddenly /media/EXTERNAL is just a normal folder on the local
storage. I have no idea how to do any of that though.
I miss on the Acorn where you could just reference drives by the name of
the disk in the drive. In windows why can't I rename my external drive
"backup" and then write to "backup:\", it even comes up in the Win7
address bar in explorer...
Date: 27 Feb 2013 12:12:33
Message: <512e3e81@news.povray.org>
Because DOS.
Date: 4 Mar 2013 04:37:04
Message: <51346b40$1@news.povray.org>
> Because DOS.
Maybe that's because on DOS/Windows hard drives came along before
multi-tasking? So you never got the situation where you were swapping
floppies around to do several things at once in a multi-tasking
environment. In that situation it's very useful for the OS/app to know
which disc to use, rather than just which drive to use (otherwise you
end up saving your word processor document to your printer driver disc
and then can't find the latest version the next day).
Date: 5 Mar 2013 09:04:16
Message: <5135fb60$1@news.povray.org>
>> Because DOS.
This sounds like a "been there, done that".
Date: 6 Mar 2013 10:15:43
Message: <51375d9f$1@news.povray.org>
Nope, I never went near a DOS/Windows machine until Windows 95 when hard
drives were standard. When I first got my Acorn it only had 1MB RAM and
no hard drive, so everything (apart from the OS which was in ROM) was on
floppies. If you needed to edit a spreadsheet, create a chart and put it
in a desktop publishing document then print it out (as was quite common
for school homework), you'd need to be using at least 3 or 4 different
discs and then it's important you saved all the stuff on the right disc!
I have no idea how DOS/Windows handled such situations before everyone
had hard drives.
Date: 6 Mar 2013 12:15:06
Message: <5137799a$1@news.povray.org>
> Because DOS.
More like, "Because lazy". You can name drives under DOS, I think you
could even do so with a floppy, but then your application has to
"manually" check to make sure that the name is the same, since they a)
never added a way to reference, as far as I know, the drive name as a
means to write to it, and b) the OS doesn't check if the name changed on
its own, as far as I am aware.
Date: 7 Mar 2013 01:50:04
Message: <5138389c@news.povray.org>
>> Because DOS.
Of course, there is a bloody stupid "DOS" way to do it:
http://stackoverflow.com/questions/47849/refer-to-select-a-drive-based-only-on-its-label-i-e-not-the-drive-letter
Or the "useless" method:
A volume GUID path, for example,
\\?\Volume{26a21bda-a627-11d7-9931-806e6f6e6963}\.
Or.. Maybe a UNC... Hmm. Ah, hah, this would work, with a few
adjustments. The examples given on one page is:
http://compnetworking.about.com/od/windowsnetworking/g/unc-name.htm
"Consider a standard Windows XP computer named teela. In addition to the
built-in admin$ share, say you have also defined a share point called
temp that is located at C:\temp. Using UNC names, you would connect to
folders on teela as follows:
\\teela\admin$ (to reach C:\WINNT)
\\teela\admin$\system32 (to reach C:\WINNT\system32)
\\teela\temp (to reach C:\temp)"
But, its not going to let you "access" it that way normally, since its
only directing you to C: locations. If you make it a mapped network
drive, then, you still sort of can't do it without the drive letter.
**However** if you create an empty folder, called backup, on the C:
drive, then you can "mount" your external drive to that folder, and then
reference the folder as, "\\yournetworkname\backup\", at least, from
what I can tell applying the information on UNC above, with the
information from here:
http://serverfault.com/questions/8832/if-i-refer-to-a-local-external-usb-drive-by-its-network-unc-name-mycomputer
But, its overly damned complicated, given something that should be
simple. But, then, this is Windows... lol
Date: 7 Mar 2013 03:20:02
Message: <51384db2$1@news.povray.org>
That's exactly what I do - mounting the external drive using its GUID so
I'm sure it's always the correct drive. Whilst this works, there are a
few "issues". Firstly I have no idea what will happen if the folder
"backup" already exists and has data in it, will that data be
unavailable whilst the drive is mounted to that folder and then reappear
once the drive is unmounted? Also it seems that you need to run the
command prompt or script as admin to get this to work, whereas if you
write directly to the drive via its drive letter you don't. Thirdly you
have to check errors carefully otherwise you end up physically writing
your entire backup to drive C rather than the external drive.
All in all it would be *way* simpler if I could just write "robocopy ...
EXTERNAL:\Backup /MIR".
Date: 7 Mar 2013 03:26:38
Message: <51384f3e@news.povray.org>
Am 07.03.2013 07:50, schrieb Patrick Elliott:
Interestingly, the top answer has /nothing/ to do with DOS whatsoever.
(Except of course for the raw fact that drive letters and drive labels
are a DOS legacy, and the author chose to call his visual basic script a
"bat file" for apparently nostalgic reasons.)
Date: 7 Mar 2013 09:21:18
Message: <5138a25e$1@news.povray.org>
And the second one returns "Bad command or file name", when run from a
DOS6.1 boot floppy, so it doesn't have much to do with DOS either.  (Not
that I was expecting it to work...)
Date: 8 Mar 2013 02:32:46
Message: <5139941e$1@news.povray.org>
Not sure, but it may just fail if you try to mount to a non-empty
folder. Alternatively, what it might do is create a logical
concatenation of the contents, i.e., what ever is there will stay, but
doing a listing of the directory will give you what is there *and* what
is in the mounted drive. But, yeah, having the contents go unavailable,
if not empty, is one possibility.
That said.. assuming you are running the commands in a script, I suppose
there might be some way to check if the mounted folder has some
attribute that shows it is actually a mount, but.. no clue how you would
do that. :p I just thought the thing was interesting enough, especially
if I needed to do it at some point, to hunt down what, if any, solutions
existed.
Date: 8 Mar 2013 02:35:01
Message: <513994a5$1@news.povray.org>
>>>> changed on
Great.. Might as well just try to run something via windows scripting
host, for all that those "solutions" do any good then. At least with
that you could, in theory, find some way to get around it.
