POV-Ray : Newsgroups : povray.off-topic : Today's WTF Server Time
7 Jul 2026 17:27:14 EDT (-0400)
  Today's WTF (Message 13 to 22 of 22)
Subject: Re: Today's WTF
Date: 13 Dec 2012 21:18:47
Message: <50ca8c87@news.povray.org>
Le 2012-12-13 17:20, Jim Henderson a écrit :
> On Thu, 13 Dec 2012 15:38:57 -0500, Francois Labreque wrote:
>> That, or they're poorly done *nix ports where you have to run some sort
>> of "Unix shell for Windows" to run all the shell scripts that the
>> application uses.
> would have to be a pretty poor port of the Unix shell to not support long
> filenames.
> Jim
It's not the long file names per se, it's the spaces in the directory
names that causes the issue.
And you can't blame the port to windows, when it also requires that
there be no space in the application installation directory for Solaris,
Linux and HP-UX installations.  Relying on the short file name is just a
means to get around the fact that there's a space in "Program Files" in
Windows, and you can't change that.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 14 Dec 2012 13:42:11
Message: <50cb7303$1@news.povray.org>
>>> sort of "Unix shell for Windows" to run all the shell scripts that the
>>> application uses.
>> long filenames.
>> Jim
Still not a very good port if it can't handle spaces and has to fall back
to 8.3 filenames.
Jim
Date: 14 Dec 2012 15:44:25
Message: <50cb8fa9$1@news.povray.org>
>> I thought "enterprise-grade application" and "legacy 16-bit app" were
>> the same thing? ;-)
> application uses.
Well, it could be worse... At least it doesn't require a physical VT100
in order to operate correctly. ;-)
Date: 17 Dec 2012 10:02:11
Message: <50cf33f3$1@news.povray.org>
>>>> application uses.
>>> long filenames.
>>> Jim
> to 8.3 filenames.
> Jim
One could say that it's a true-to-the-orignal port of a not-very-good
application if the Unix orignal can't handle spaces either. ;)
Date: 17 Dec 2012 10:03:17
Message: <50cf3435$1@news.povray.org>
>>> the same thing? ;-)
>> application uses.
No, but for the longest time it required Motif libraries for the GUI.
Date: 17 Dec 2012 11:56:58
Message: <50cf4eda$1@news.povray.org>
Yeah, but that'd not be a modern app, which is what I assume we're
talking about here - a port of a modern POSIX app that can't handle long
filenames or spaces isn't very "modern".
Jim
Date: 17 Dec 2012 21:51:22
Message: <50cfda2a$1@news.povray.org>
> Jim
The app might have more than 15 years of existence , but the latest
version came out at the end of november.
And it has no problems with long file names under any OS, as long as
that long file name doesn't have spaces in it.
It's much easier to write in the release notes not to put spaces than to
go through the hundread or so shell scripts that the app calls in the
back end and make sure all the "cd $FOO" are properly doublequoted.
In *nix, it's usually is no big deal since there's no space in /opt or
/usr/local, but in Windows, there is one in "Progam Files", so one is
left with either installing in a non-standard place, or forcing
shortnames to work around the space.
Date: 17 Dec 2012 22:00:17
Message: <50cfdc41$1@news.povray.org>
>> long filenames or spaces isn't very "modern".
>> Jim
I've never run across a modern POSIX program that had trouble with
spaces.  But I've only been doing UNIX since 1983 or so (first experience
was in the sixth grade on some old PDP equipment that I'm pretty sure was
running some form of UNIX - I remember it had a bash shell) and Linux
since about 1989.
Seems like a simple thing to address.
Jim
Date: 18 Dec 2012 12:45:46
Message: <50d0abca$1@news.povray.org>
>>> Jim
> since about 1989.
> Jim
Yes, the solution is simple.  Make sure that all shell commands using
filenames are properly double-quoted, and add a little more
argument-verification logic to the shell scripts.
But it requires going through hundreds of scripts (and in the Windows
version, additional batch files that start sh.exe with with the same
command line arguments).
If they didn't bother rewriting those shell scripts for Windows, and
insits on using a Unix-like environment to run the .sh scripts ,
something makes me think they aren't really willing to revisit all those
shell scripts in the first place.
In this cost-cutting world, I can't say I'm really surprised.  I once
opened a ticket asking how we could run the app with a non-Administrator
user ID since getting an admin account with a non-expiring, shared
password is a big security no-no for my employer, and they replied "make
the user ID part of the 'Administrators' group".
Date: 18 Dec 2012 12:46:48
Message: <50d0ac08$1@news.povray.org>
>>> Jim
> since about 1989.
> Jim
Ah, well.. You see, they couldn't figure out how to write a shell script
to check all the shell scripts for the problem, and fix it. lol
