POV-Ray : Newsgroups : povray.off-topic : The cake is a lie, but... Server Time
14 Aug 2026 05:48:41 EDT (-0400)
  The cake is a lie, but... (Message 1 to 10 of 19)
Subject: The cake is a lie, but...
Date: 10 Dec 2012 09:26:31
Message: <50c5f117$1@news.povray.org>
... the Raspberry Pi is not!
I just got mine, after months of waiting...
First task: Try to communicate with it.
Subject: Re: The cake is a lie, but...
Date: 10 Dec 2012 10:37:53
Message: <50c601d1$1@news.povray.org>
Second task: Port Pov to it.
Regards
Date: 10 Dec 2012 11:00:55
Message: <50c60737$1@news.povray.org>
I'm curiously waiting for official benchmark results.
-Aero
Date: 10 Dec 2012 11:44:17
Message: <50c61161$1@news.povray.org>
> -Aero
Third task:   ;-)
Regards
Date: 10 Dec 2012 12:38:17
Message: <50c61e09@news.povray.org>
Nitpicking but...
There's a difference between "porting" a program to a platform, and
simply "compiling" it for that platform. Porting would require code
modifications, and povray probably doesn't need any for the Raspberry Pi.
Date: 10 Dec 2012 13:28:07
Message: <50c629b7$1@news.povray.org>
Am 10.12.2012 16:37, schrieb Stephen:
Exactly.
Date: 10 Dec 2012 13:34:08
Message: <50c62b20$1@news.povray.org>
Am 10.12.2012 18:38, schrieb Warp:
> Nitpicking but...
Someone already tried the compiling part some months ago, only to find
that although it did compile and even run, the results weren't
satisfactory (as in, the output included artifacts that shouldn't have
been there).
That's when I decided to order one myself.
So yes, it /is/ "porting" this time.
Date: 10 Dec 2012 14:01:36
Message: <50c63190@news.povray.org>
> been there).
Sounds more like bug-fixing rather than porting, unless it really is
something that has to be modified because the platform, for some strange
reason, works differently from all other platforms. Which would sound
really strange given that it runs Linux and BSD...
Date: 10 Dec 2012 15:24:32
Message: <50c64500$1@news.povray.org>
>> been there).
It probably doesn't implement IEEE-754 arithmetic correctly or something
daft like that.
Date: 10 Dec 2012 18:26:55
Message: <50c66fbf$1@news.povray.org>
Am 10.12.2012 20:01, schrieb Warp:
>> been there).
Not so strange if you recall that the porting work for Linux (and
probably also BSD) to run on ARM platforms had been done already.
One possible difference might be the floating point math, which doesn't
seem to be as straightforward as we're used to on x86 machines. I guess
there is /some/ reason why the official reference Linux distro for the
Pi is built to use software-emulated floating point math, rather than
the on-chip floating point hardware.
Even if it turns out that there's nothing else to do, there's still
porting work to be done in the sense of checking whether the
platform-specific header files make sense for the ARM.
