POV-Ray : Newsgroups : povray.off-topic : An ironic development Server Time
17 Oct 2026 00:53:24 EDT (-0400)
  An ironic development (Message 1 to 50 of 60)
Goto Latest 50 Messages Next 10 Messages >>>
Subject: An ironic development
Date: 28 Oct 2012 17:28:40
Message: <508da388$1@news.povray.org>
The Windows registry. Apparently a lot of people hate it. Tom Kyte
refers to it as "the Microsoft copy-protection system" (which is odd,
considering it has absolutely nothing to do with copy-protection...)
Apparently it's a *really* unpopular system.
The Unix way has always been for programs to populate your home
directory with thousands of .rc files, each and every one of them in a
different randomly-designed file format.
But now, there is a new hope for a unified configuration system. They
call it "Gsettings". And the hilarious thing is that it is COMPLETELY
ISOMORPHIC TO... the Windows registry.
It consists of a binary file containing a hierarchical tree of named
folders, containing named keys, which easy have a value of a certain
well-defined type. (Usually "integer" or "string".) Changing one of
these settings has immediate effect on the owning application. And, for
the most part, different application's keys are jumbled up in a random,
haphazard manner.
...EXACTLY like the Windows registry.
Yes, it seems the GNU folks hate the Windows registry SO MUCH that they
went out and added an exact reimplementation of it to their own
software. :-P So much irony!
In fairness, it's not /completely/ identical. The folders are called
"keys" under Windows, whereas Gsettings calls them "schemas". Both
systems store this stuff in a binary file, but Gsettings loads the key
definitions from XML files and "compiles" them into binary. Unlike the
Windows registry, each key has a textual description (which is
frequently very unhelpful), and a default value to which you can reset
the key. Oh, and most keys for selecting options use text strings rather
than weird code numbers. Also, the Windows registry supports storing
stuff in multiple different "hives", whereas Gsettings apparently does not.
But apart from all this... totally identical. :-P
Subject: Re: An ironic development
Date: 28 Oct 2012 17:41:24
Message: <508da684$1@news.povray.org>
> haphazard manner.
Snort.. Actually, the problem with the windows registry are:
1. Can't read the damn thing, without the editor.
2. Things don't always uninstall cleanly.
3. There are no safeguards to stop program X from screwing with a key
for program Y.
This might require some sort of, "mark this key as editable", or
something, since there may be a few cases where you do want to allow
this, for specific things.
4. It doesn't clean itself up.
Which is to say, some things you might want to keep, like program
information for a DVD, or other removable media, but why load in keys,
and settings, for permanently installed applications, which are no
longer on the system, let alone keep the data on them, unless its, say,
just pointers to data, or something that another program, again, maybe
could need/be given access too?
All of these things make it a pain in the ass. Well, that, and the fact
that, due to how some of the stuff like linked together in it, its hard,
and there are no tools for, tracing how all the parts connect, so you
can either kill all related keys, or figure out which one might have
broken, like a file open function, pointing at a loader, which points to
its application, where any one in the chain could be screwed, by they
are all tied together using long chains of hexadecimal IDs. And, that is
one of the simple cases...
Date: 28 Oct 2012 18:04:03
Message: <508dabd3$1@news.povray.org>
Well, see, the idea is that *you* should never have to look at it. The
program in question is supposed to provide a real UI for editing it.
Much like you should never have to look at a JPEG file in a hex editor;
you should use a real image viewer / editor.
Gsettings might plausibly do this better. It looks like you just delete
that program's XML file and then recompile the schemas... but I haven't
tested this.
Under Windows, any program can just add or delete arbitrary keys.
> for program Y.
You realise that the Windows registry has ACLs, right? Exactly like
files do? I'm not sure whether Gsettings does this, come to think of
it... I suspect not. (After all, Unix doesn't have ACLs for files yet.)
That's really more a problem with crappy software than with the registry
itself. It's like, very commonly you uninstall some program, and then
months later realise that some of its files are still sitting on your
harddrive. Is that a problem with filesystems? No, not really; it's a
problem with badly written installers and uninstallers.
Date: 29 Oct 2012 02:38:25
Message: <508e2461$1@news.povray.org>
Why is that a problem? You always need some sort of software to read a
computer file and regedit comes with Windows.
Regards
Date: 29 Oct 2012 08:45:00
Message: <web.508e798622aa54ceebb90cbd0@news.povray.org>
didn't you know that bastard Miguel de Icaza has long been copying and pasting
Microsoft tech into Linux so they can get royalties?
he first developed Gnome and all Grelated stuff and damned mono
Date: 29 Oct 2012 09:28:41
Message: <508e8489$1@news.povray.org>
AIX has had a binary configuration system for eons.
"Unified" for anyone who decides to use it.  It will probably become as
popular as CDE.
Even though it's mostly due to lazy uninstallers, that can be done on
purpose.  For example, trial versions leave install info beihnd on
purpose so that you can't simply reinstall your demo version when the 30
days have expired.  Another reason might be shared keys between multiple
applications of the same family.  If you uninstall app A from vendor X
and it zaps the whole X branch of the registry, then app B from the same
vendor will no longer function properly.  The real problem is that the
Windows registry does not keep track of which applications need which
key, so the uninstaller (or a defrag utility) can't really know which
keys are still valid.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 29 Oct 2012 09:33:08
Message: <508e8594@news.povray.org>
> tested this.
>> for program Y.
These ACLs are based on userID, not app.  So if I run an anti-virus
installer as "Francois", and then click on a bad link, there's nothing
that will prevent BadVirus.exe from messing with the anti-virus
autostart keys with the same user ID.
WAT?
Have you ever typed "ls -l"  ?  Do you know what the "rwxr-x---" mean on
the left hand side.
Date: 29 Oct 2012 09:45:01
Message: <web.508e87de22aa54ceebb90cbd0@news.povray.org>
> WAT?
> the left hand side.
good thing he was hired to work on *nix things ^_^
Date: 29 Oct 2012 18:11:14
Message: <508eff02$1@news.povray.org>
> WAT?
> the left hand side.
No deary. I mean being able to set an *arbitrary* combination of
permissions.
If you have a folder and you want all the people in QA to have read-only
access, the people in Helpdesk to be able to create new files but not
modify existing ones, and the guys in Development to have full
read/write access, you can actually do exactly that with NTFS file
permissions. Good luck trying to do it with umask...
Date: 29 Oct 2012 18:14:39
Message: <508effcf@news.povray.org>
Am 29.10.2012 14:33, schrieb Francois Labreque:
> WAT?
> the left hand side.
And you know that ACL is an acronym for "Access Control LISTS", right?
Full-fledged ACLs do allow you to specify individual access rights for
an arbitrary number of users and/or user groups, not just for the owner,
one user group and the rest of the world.
BTW, some commercial Unixes like HP-UX do provide proper ACLs (they even
use that very term for the feature).
Date: 29 Oct 2012 18:27:56
Message: <508f02ec$1@news.povray.org>
A naive assumption imho. But, then, Windows is based around, "Sorry, but
you can't be trusted to do that." lol Still, even something like,
"Export all keys specific to this application.", would have been nice.
> tested this.
Yep, more or less, though you do sort of contradict yourself later.
>> for program Y.
Meaningless, since, as others have said, it only protect based on user,
not application. A better solution, having thought a bit about it, would
be if there was like a security key, which the installer, uninstaller,
and the application itself (and any sub-apps) had, which let them
manipulate the "non-public" parts of its key list, so that short of
logging in as administrator, and using a tool/hand editing, the keys as
the super user, nothing could make those changes.
Well, yes and no. In principle, just nuking the entire key for that
application should work. The problem is, its often got a dozen keys,
there are assumptions made about other things installed, no way to
double check if, for example, two application use the same extra things,
and only one is being uninstalled, so its safer to just leave the key
for that in there, even if its not being used, etc. Its not just bad
uninstaller design, its just bad design from the stand point of the DB
itself. A better design would be able to inform the application that
something else is using something it wants to uninstall, not have the
uninstaller tell you, "This is known to be sometimes used by a lot of
other things, should I remove it anyway?" 99% of the time, it is in fact
*not* used by anything else. Data is a bit iffier. Some of it you don't
want to nuke, some of it is just settings, temp files, etc., which
bloody well do need to be removed from the disk, not just from the
registry. But.. almost everything leaves bits of that stuff floating around.
Date: 29 Oct 2012 18:29:33
Message: <508f034d$1@news.povray.org>
Uh.. Because the editor sucks, and there are a lot of things you would
like to be able to do, that it can't (like, for example, listing all
related keys, in a filter of some sort, not using notepad, or a pad of
paper to write down keys, while hunting through a dozen extra searches
to find them all).
Date: 29 Oct 2012 23:16:23
Message: <508f4687@news.povray.org>
A lot of developers write magic numbers to the registry so that when
your trial period ends, uninstalling and reinstalling the application
will not reset your trial period.
STOP.
Why not XML?
Okay, but why compile them?  It's not like drive space is a scarce
resource anymore.
That's mostly the uninstaller's fault.  I suppose there's a utility that
allows you to record the registry changes made by an installer, so that
when the utility is uninstalled you can follow up and scrub the registry
completely.
5. All of your eggs are in one basket.  Yes, let's put the settings for
your application, Jack's application, and the drivers for your hardware
devices, all in one big file.  That won't cause any problems, no sir.
John
Date: 30 Oct 2012 04:37:51
Message: <508f91df@news.povray.org>
> STOP.
> Why not XML?
> resource anymore.
Indeed. Considering that the original XML files *still exist*. It seems
when you add a new application, it drops an XML file into a folder, and
you recreate the binary file from everything in that folder. When you
remove an application, it removes it's own XML file, and you rebuild the
binary file from what's left.
I would imagine the reason for this is so that applications can access
the binary file quickly and efficiently, rather than to save disk space.
You don't have to search and parse lots of XML files, checking for
syntax errors and name clashes and whatever at run-time.
Then again, the GNOME 3 shell appears to be written entirely in
JavaScript, so what do I know?
Yep.
It won't as long as the OS itself is the only thing allows to access
that file, and different parts of the file have different access
permissions. In that respect, it's just like the filesystem itself; only
the OS is allowed to touch the Master File Table that says where each
file is, and individual files have different access permissions.
Then again, Gsettings doesn't appear to have access permissions, so...
Date: 30 Oct 2012 04:40:40
Message: <508f9288$1@news.povray.org>
...which leads us back to "you're not supposed to touch this stuff
manually".
Ever tried using e2fstune? Not very intuitive, is it? Then again, how
often do you even need to touch it?
> to find them all).
1. The registry editor is perfectly capable of dumping chunks of the
registry as text. It also has a search function. (Admittedly it's not
very scriptable.)
2. You can write your own application to access the registry. Hell, it's
probably quite easy to throw something together in VB to do a quick
search or two...
Date: 30 Oct 2012 04:46:04
Message: <508f93cc@news.povray.org>
Well, no, that's the way it's *supposed* to work. The fact that a few
crappy applications don't do this is beside the point. (That and a few
low-level OS things that typical users don't need to touch.)
> But, then, Windows is based around, "Sorry, but you can't be trusted to do that."
Well, yes. Just like regular users shouldn't be renaming system DLLs or
whatever. The *average* user is pretty stupid, after all... (Although I
admit it would be nice to have a version of Windows designed for
computer experts!)
What makes you think you can't do that?
> not application.
Well, yeah, if security could be managed per-application, that /would/
certainly be superior. But there we are.
Date: 30 Oct 2012 04:48:30
Message: <508f945e$1@news.povray.org>
Is this method really used? There are programs to record all
reads/writes to the registry, so you really can delete all the keys
created. Or you just restore a backup of the registry to start the trial
again. I suspect they are a bit more cunning than this.
> resource anymore.
Speed? At least on Windows the registry is accessed pretty much
continuously, you want it to be as fast as possible so that means a
binary format.
> completely.
That's dangerous though, because another program might have been
installed since that changes or uses one of the settings the original
program created/changed. If you go down this route (as some large
companies do for custom automatic installer/uninstallers) then you need
to do a lot of checking and testing for each program.
Date: 30 Oct 2012 04:55:59
Message: <508f961f$1@news.povray.org>
We used an expensive commercial web application which only works
properly if you use Internet Explorer and only if you disable all web
caching between you and the server. Because, obviously, the developers
were too stupid to know how to set pages to expire. Some developers are
very stupid.
Most users don't know what the "registry" is. I'm sure the above method
works just fine in the majority of cases. Also, lots of programs require
you to get a temporary "activation code", which won't work the second
time around...
> Speed?
I concur.
>> completely.
I've seen Linux try to do this with text files. Like, when you install
an application, it renames the old config file, and when you uninstall
it, it renames the old one back. Find if you uninstall stuff in LIFO
order. Not so fine otherwise...
Date: 30 Oct 2012 05:17:52
Message: <508f9b40$1@news.povray.org>
> very stupid.
Developers are often just lazy, and they suddenly stop becoming lazy
when it involves whether people pay for their product or not.
Most users will just search for "program X crack", if it was as simple
as installing the trial and changing/deleting a registry key it would be
all over the web.
I'm pretty sure I've tried with a few trial apps (a long time ago) to
find out how they were detecting I'd already run the trial but couldn't
figure it out (after logging registry and file changes). They must be
using something a bit more sophisticated.
Date: 30 Oct 2012 10:49:21
Message: <508fe8f1$1@news.povray.org>
Am 30.10.2012 09:46, schrieb Orchid Win7 v1:
The simple fact that the registry doesn't track which keys are specific
to which application, maybe?
Date: 30 Oct 2012 11:00:39
Message: <508feb97@news.povray.org>
Am 30.10.2012 04:16, schrieb John VanSickle:
> resource anymore.
Faster access, maybe?
> completely.
Except when the installer doesn't know that the application itself does
make additional changes to the registry.
Or when the installer makes a change to parts of the registry that other
installers are also likely to touch, and un-installing isn't done in
reverse order.
 From Orchid's postings, I gather that the Gsettings concept is
different in this respect, by having the applications just add or modify
their own private XML file, and then compile all such XML files into one
blob (for, as I suspect, faster access).
Date: 30 Oct 2012 11:33:22
Message: <508ff342$1@news.povray.org>
>> WAT?
>> the left hand side.
Yes.
I know that too.  But Andy was exagerating slightly (what else is new?).
And recen versions of Novell's NDS are exactly that too.
Date: 30 Oct 2012 11:34:43
Message: <508ff393$1@news.povray.org>
>> WAT?
>> the left hand side.
> permissions.
Then if that's what you mean, say that.  ;)
Date: 30 Oct 2012 12:11:29
Message: <508ffc31@news.povray.org>
This is quite a good idea, because then it's up to the OS to decide how
to handle conflicts (eg if two apps try to set the same thing in their
own XML). Also then when you uninstall you can just delete the XML and
know that any settings from that app no longer have any influence. In
Windows on the other hand it's simply whichever application changed the
value most recently that wins.
However does this mean that every time a program writes to the registry
the OS must recompile everything?
Date: 30 Oct 2012 15:56:14
Message: <509030de$1@news.povray.org>
Compiling just creates the key names and their default values. Actually
reading and writing doesn't require recompilation.
Also, recompiling takes approx 400 ms on my virtual machine...
Let me just repeat again: Settings have default values. And textual
descriptions [which are often less helpful than you'd like].
Under Windows, if you mistype the registry key, it just creates a new
key [which then uselessly does nothing]. Under Gsettings, it whines "no
such schema" or similar.
The *really* annoying part is that Gsettings appears to totally stop
working if X isn't running. It's also maddeningly hard to change another
user's settings...
Date: 30 Oct 2012 19:13:30
Message: <50905f1a$1@news.povray.org>
>> even use that very term for the feature).
Well, Novell's product (actually, NetIQ's product now - since they were
acquired by Attachmate last May and the identity products have mostly
shifted to the NetIQ business unit) is eDirectory, and it doesn't do
filesystem permissions - it manages the identities used in filesystem
permission entries in the directory entry tables in NSS and TFS volumes.
I wonder, though, how difficult it would be to use eDir identities as
part of *nix ACLs - probably not hard, just need the RFC2307 (IIRC)
extensions installed to map uid/gid to the OS, and integrate pam
authentication with the LDAP server. :)
Jim
Date: 30 Oct 2012 23:00:55
Message: <50909467$1@news.povray.org>
It can't. To do that would require exporting "all linked keys". That
means that you search for, say, Explorer, and you don't get get the key
"USER-Explorer-...", you also get the 5-6 hexidecimal keys for its
components, keys in other sections, which relate, etc. You have to know
what all of them are, and either mark them yourself, or export them each
separately, as far as I can tell. And, just searching for what key you
need is a pain in the ass sometimes (especially if it turns out that the
specific thing you are looking for is one of those "hidden" settings,
which is not normally in the registry at all, nor documented any place
obvious, no accessible through any of the user menus).
Date: 30 Oct 2012 23:13:55
Message: <50909773$1@news.povray.org>
> manually".
>> to find them all).
> very scriptable.)
> search or two...
:snark: and how much of what that is supposed to do is "undocumented",
in the same way that, prior to completely changing the system, you
couldn't find any documentation on how the hell ActiveX interfaced with
the scripting system, in their own editor, and Informal Exploder, so you
could move them around on your "form"? :/snark:
That was about when I gave up looking to Microsoft's own documentation
for anything useful. Here is how to add scripting: ... Here is how to
create and use ActiveX controls: ... What, you actually want to, without
creating new wrappers, and all the other BS, use the inbuilt ActiveX
controls, with scripting, and, *Gasp!* go into "design mode" with them,
so you can create custom layouts in your own applications? What, are you
one something!? Yeah.. It would be nice to do that!!!
At the time ***one*** company I could find found a solution to the
problem. There solution turned out to be, "Design controls that act
exactly like the inbuilt ones, but which *we* could switch modes with,
ourselves." The other solution was to leave them active, but wrapper
them in a completely redundant method, which did nothing more than
temporarily make them non-visible, draw a box where they where supposed
to be, and provide drag handles. Redundant because this wasn't necessary
in the original controls, in the compiler suite, they already have that
functionality.
There are hints, all over the place, that its, at least in theory,
possible to tell the OS to switch a specific form to that mode. There is
jack all saying how, what messages to use to do it, etc.
Later, as I said, they, sort of, fixed this, but basically killing the
old ActiveX entirely, and replacing it with something else, which
included more sane methods to talk to, and get information back from,
never mind instance, controls.
But, even the documentation for that is minimalist, and nearly useless.
I have no idea if "design mode" is still something only a hacker, with
detailed understanding of the OS internal messaging, has a clue how to
access.
So, sure.. You can probably write something to access the registry,
but... will it actually do what it claims to?
Date: 30 Oct 2012 23:29:17
Message: <50909b0d$1@news.povray.org>
Yeah, it is. There are very few programs out that track changes though,
and they are usually "security" type things, like one called scoty (or
something like that), which watch dog they thing, so look for odd
changes, like something adding a new startup program some place (it
catches everything doing that, so even legit stuff gives a pop-up, which
can be interesting...) Other cases may be hidden files, in odd places,
etc. One of the kind of interesting ones is a "give away of the day"
thing, which doesn't actually demo, its installer actually registers it,
within the 24 hours of the give away, and flat refuses to install it as
a working application, if the server says "no".
But, in general, adding some sort of flag to the registry, with a date,
or the like, is the simplest solution. So, in principle, if you knew
what changed, you could undo it.
Date: 31 Oct 2012 01:45:26
Message: <5090baf6@news.povray.org>
Am 31.10.2012 04:14, schrieb Patrick Elliott:
>> search or two...
[lots of ranting about ActiveX deleted]
What, exactly, does that have to do with accessing the registry?
The question is not whether it will actually do what it claims to, but
whether you know what you want it to do.
Your list of things you'd like to be able to do includes "listing all
related keys". Guess what - per definition of the registry, regedit does
that already: The only "native" relationship of registry keys is in the
hierarchical tree structure of sections.
Each and every other relationship between registry keys is only by
convention of individual services and applications - such as the Windows
explorer assigning file extensions to file types, and file types to
applications. Or the device manager linking drivers to devices. Or what
the heck.
At the end of the day, you DO need service- or application-specific
knowledge if you want to edit the registry, because it's services and
applications that assign semantics to the raw data they store in there.
Date: 31 Oct 2012 04:22:30
Message: <5090dfc6@news.povray.org>
http://msdn.microsoft.com/en-us/library/windows/desktop/ms724871(v=vs.85).aspx
or for .net languages:
http://msdn.microsoft.com/en-us/library/microsoft.win32.registry(v=vs.100).aspx
If you don't find that useful then I don't know what you are expecting...
Date: 31 Oct 2012 04:42:49
Message: <5090e489$1@news.povray.org>
A quick google for "registry watcher" gives millions of results, and the
WinAPI even has a function RegNotifyChangeKeyValue that you can easily
use to watch the whole registry if you can write a few lines of code. I
just doubt they use this method as I have tried it before and failed,
and if they did there would be simple registry hacks all over the web to
get full versions of software (which there very rarely is).
> etc.
Maybe, but again that is easy to detect if they use standard API calls
(there are plenty of "file watcher" type programs, or you can easily
write your own). Again, if this were the case there would be simple
instructions available online like "delete this file to restart the
trial", but you don't often see that.
Indeed, nowadays it's easy to do if you assume internet access is
available, you just check with the server with some key generated from
the machine (using mac address) and refuse to run if the server says no.
Of course it is the simplest, but does any real software actually use
only that method? IME not, for example try www.bobstrackbuilder.net -
even a low-budget program from a single coder does not use that method,
so I highly doubt more "commercial" programs like PhotoShop etc would
use such an easily hacked method.
Date: 31 Oct 2012 04:51:34
Message: <5090e696$1@news.povray.org>
Grabbing all the keys related to one application is usually easy enough.
Figuring out what all that stuff /means/? Yeah, not so easy. And finding
all the settings that get changed for /other/ programs when you install
the application (e.g., registering COM servers, changing the system
search path, hooking into the Windows Explorer context menus, etc.) is
not easy at all...
Then again, there are tools for monitoring the registry and recording
changes to it. It still won't help you figure out what the changes
/mean/, but it makes it fairly easy to capture them.
(My personal favourite is how changing from the lame "Windows XP" theme
to the sane "classic theme" doesn't just change one registry key that
says "theme name" or something - it actually changes eighty bazillion
keys all over the registry. Consequently, it's absolutely impossible to
script the damned thing!)
Date: 31 Oct 2012 04:54:38
Message: <5090e74e$1@news.povray.org>
Now try finding any shred of useful documentation about the object model
used for GNOME 3 shell extensions. Because I've wasted countless hours
fruitlessly searching the web for anything like that. MS's documentation
is vague at times, but at least you can /find/ it...
Date: 31 Oct 2012 05:14:48
Message: <5090ec08@news.povray.org>
So compiling is only needed when new keys are created or existing ones
deleted?
And how many key-value pairs is that compared to the Windows registry?
:-) (comparing the size of the binary compiled version with the windows
registry might be a rough indication)
Date: 31 Oct 2012 05:25:45
Message: <5090ee99$1@news.povray.org>
How come it's impossible? Compare the registry before and after and
export the changes to a .reg file. Plenty of software available to do
that or write your own in a few lines.
Date: 31 Oct 2012 11:56:19
Message: <50914a23$1@news.povray.org>
Use the Source, Luke!
Date: 31 Oct 2012 12:21:18
Message: <50914ffe$1@news.povray.org>
I am not saying that they don't "sometimes" provide clear documentation.
Just that, the more specific the information, the less likely you will
find something useful on it. The registry is fairly simple, so, its
pretty hard for them to screw up documentation on the API to access it.
Or, maybe they just didn't try hard enough. lol
Date: 31 Oct 2012 12:23:33
Message: <50915085$1@news.povray.org>
True. Sometimes its dang hard to work out how they do manage it, but,
its got to be "someplace" on your machine, and there are a finite number
of things they can do to manage it.
Date: 31 Oct 2012 14:14:59
Message: <50916aa3$1@news.povray.org>
> deleted?
Yes, basically.
Well, considering that only GNOME itself and a tiny few GNOME
applications use this thing so far... yeah, not very big.
Date: 31 Oct 2012 14:16:16
Message: <50916af0$1@news.povray.org>
Yes, but every time you click an icon or open a window hundreds of
registry accesses happen. Trying to isolate just those related to the
theme change is the hard part...
Date: 31 Oct 2012 14:18:12
Message: <50916b64@news.povray.org>
Yeah. One guy said in a forum post "is there really no official list of
[GNOME shell stock icon names]". And somebody replied "there is no such
list, and nor should there be - the source code is the documentation".
Considering that the source code is in JavaScript, and it's nearly
impossible to comprehend without knowing what the intention behind it
was, this is an extremely stupid statement. :-P
Date: 31 Oct 2012 14:51:14
Message: <50917322$1@news.povray.org>
"Compare before and after" is not the same as "track every access".
Jim
Date: 31 Oct 2012 17:12:10
Message: <5091942a@news.povray.org>
OK. But that still doesn't detract from the actual problem: whether you
track every individual access, or just the before and after images, the
problem is that you can't just grab a bunch of registry changes, apply
them to another machine, and expect it to do the same thing. It's not
that simple.
Every time I log onto a new machine, it takes me about 20 minutes to
turn off all the annoying Explorer shell stuff I don't want. (The hiding
of files and file extensions, the retarded Start menu, the tray
auto-hide, etc.) The dream was that I could track down the actual
registry changes that underlie each of these configurations, and write
an automated script that would instantly turn off all the stupid
settings and give me a usable desktop on any machine.
To some extent, I was able to do this. But theming never, ever worked.
There are *far* too many registry keys involved. When you change theme,
there are DLLs literally setting the number of pixels for the thickness
of a window title bar, the number of pixels to allocate for button
corners, and so forth. Way, way too much stuff to script, or even
comprehend. Separating the significant registry changes from the
insignificant ones proved just too hard.
(I still secretly dream that somewhere, there's some COM object you can
invoke which just *does* it all for you... But since I'm no longer using
Windows XP, I guess it doesn't even matter any more.)
Date: 31 Oct 2012 17:33:30
Message: <5091992a$1@news.povray.org>
> that simple.
Perhaps you're unaware that there are software distribution tools that
employ just this sort of mechanism?  I worked for a company where about
6,000 desktops had applications delivered to them using this type of
application management technology, in fact.
It does require testing and knowledge to do right.  It's far from
impossible.
I feel I must repeat something I've said to you over and over and over
and over and OVER again:  Just because YOU can't do something does NOT
mean it is "impossible".
Jim
Date: 31 Oct 2012 17:54:36
Message: <50919e1c$1@news.povray.org>
>> that simple.
> impossible.
6,000 *identical* desktops, I would imagine.
In that case, yeah, it might work. Just like if you have 6,000
*identical* desktops, you can apply the same Ghost image to all of them,
and this actually works correctly.
What *I* was trying to do is construct a script which will work on *any*
Windows XP installation. That is a much harder task.
If you want to split hairs, it is technically "possible" to unscramble
an egg. According to the laws of physics, scrambling an egg ought to be
a completely reversible operation. (Time invariance, and all that.) But
to date, nobody has ever succeeded in actually doing this.
There are things which are truly *impossible*. (E.g., travel faster than
light.) And then there are things which are theoretically possible, but
so absurdly hard that nobody would bother trying. (E.g., unscrambling an
egg.)
Some things are easy, some things are hard. Some things are hard enough
that for all /practical/ purposes, it's impossible. Somebody with access
to insider knowledge about how the Windows Explorer shell works
internally might be able to put together a registry hack that changes
the theme. Somebody with access to thousands of test systems and with
the time and motivation to reverse-engineer this stuff might be able to
figure it out. One lone guy with a registry monitor? Not a chance.
And that is really all I was trying to say.
Date: 31 Oct 2012 18:16:24
Message: <5091a338@news.povray.org>
>> impossible.
You imagine incorrectly.  A few base images to account for different
hardware, but no, given that there were about 25 offices around the
country and systems in different places in their usable life, no, they
were not all identical.
Not really, because application settings are generally not dependent on
the hardware.  The same is true for theming elements.
> egg.)
Yes, there are things that are impossible.  But you tend to take tasks
that you've determined are non-trivial or that you can't figure out and
declare that they're totally "impossible".  Exporting the correct Windows
registry settings for a particular purpose is not "unscrambling an egg".
Again, you are not correct about this.  There are tools that make it
easier, and yes, a lone guy with a registry monitor does stand a chance
at this "impossible" task - because (and I want you to listen very
carefully here):  IT IS NOT IMPOSSIBLE! :)
And what I'm trying to say is that you are simply wrong.
Jim
Date: 1 Nov 2012 04:17:47
Message: <5092302b$1@news.povray.org>
Directly hitting the registry for that is probably not the best way, did
you investigate using control.exe from the command line to do it?
Something like "control.exe desk.cpl desk,@Themes" should get you
started, but you'll need to google a few more parameters to set what you
want.
Date: 1 Nov 2012 04:39:14
Message: <50923532$1@news.povray.org>
> want.
Thinking about it a bit more, you'd be better off making all your
changes by hand once then saving it as a custom theme file. Then google
"set theme command line" - it's easy. No idea if the theme file format
is the same for different versions of windows, you might have to make
one for each version.
Date: 1 Nov 2012 16:13:14
Message: <5092d7da$1@news.povray.org>
> couldn't figure it out (after logging registry and file changes). They
> must be using something a bit more sophisticated.
Some of them actually write something into the gap behind the master
boot record. This works in the case of windows boot loaders which don't
use it. Other boot loaders, for example GRUB, are located in this gap.
Installing one of these trial applications can therefore ruin your
bootloader. Luckily, this never happened to me. (Only report I found
with a quick search: http://superuser.com/a/192082)
