OK, so last week I had a call about a possible job in Oxford. That's a
bit of a long way, but it's shorter than my current commute.
On Friday, I got a call to say that first I have to pass a test. On
VB.Net, of all things. So, uh, yeah... That's totally going to work out
then! :-P
What actually happened was that the agency sent me an email containing a
Word document with several dozen VB questions. I then have 30 minutes to
email back the document with the answers filled in. Now, obviously, I've
never written anything in VB.Net. The closest I've come is that VBA
script that took me 2 hours to write - the one that puts today's date in
a certain cell when you click a button.
In summary, this test boils down to "how much stuff can you Google about
VB.Net in just 30 minutes?"
After I sent that back, I got another test - this time, SQL Server. Now
the job spec says you must have experience of "SQL", but I'm guessing
they actually meant "SQL Server", which is something quite different.
Suffice it to say, I know quite a lot about Oracle, but absolutely
nothing about SQL Server. So, again, how much can you look up on Google
in 30 minutes?
On both tests, the questions range from "what is the name of the
function for X?" to "please describe how you would solve this moderately
complex problem". In both cases, I left the latter sort of question
completely blank. I couldn't actually find all the answers to the former
sort either - not in the time allocated.
At this point, of course, I had just come back from that brilliant
interview, and I thought that job was probably in the bag. I wasn't even
all that interested in this job - especially if it somehow involves VB.
So I didn't try especially hard.
Well, you can see where all this is going; apparently, in spite of my
obviously abysmal performance on the test, the company wants to
interview me. (??!) I can't imagine why. I mean, of all the tens of
thousands of other people who applied, there must surely be a vast
number of them who are way, /way/ better at VB than I am. (It is, after
all, a language specifically aimed at lusers.) And yet they're still
bothering to talk to me? Hmm...
From what I can tell, the company in question sells gas and
electricity, mainly to commercial customers, and they make a big deal
about how green they are. She shall see. I'm not expecting great things
from this interview... then again, I said that about the last one.
Man, I've had 2 interviews in the past 30 years, and now it looks like
I've got 2 interviews within the same year of each other!
So! What is wrong with that?
I've been implementing SAP for 16 years and I use Google all the time.
It is a tool of the trade, now. That and the F1 key.
Good luck with it. :-D
Regards
I believe the purpose of the test was to find out if you *know* VB, not
whether you can Google it really, really fast. ;-)
This makes me sad.
Thanks. Luck is what it'll take...
>>> about VB.Net in just 30 minutes?"
The purpose is to see if the candidate can get the job done.
Learning has in some ways moved on from "memorize/regurgitate" to "can I
find the information I need quickly?".
It's like my former boss once said - if he wants to fix a hole in his
roof, he's not going to take a course on roofing, he's going to search
for a video that shows him just what he needs to know.
The ubiquity of the 'net has shifted how people learn and how people
tackle tasks. Many hiring managers want someone who can take something
and run with it, even if it's something outside their experience. Being
able to effectively research stuff on the 'net (and that usually means
using Google effectively) is a huge skill that's not explicitly asked for.
When I would do technical interviews, I'd ask questions I knew the
candidates couldn't answer, because I wanted to find out how they would
think about something outside their experience and how they'd research
it. I always found good candidates as a result.
Yes, good luck indeed. :)
Jim
That is what you are taught at school.
> not whether you can Google it really, really fast. ;-)
This is RL
And what Jim said.
> This makes me sad.
It makes me sad that makes you sad.
Yes we all need luck.
Regards
> This is RL
> And what Jim said.
Sure. I mean, who needs a solid background understanding of a complex
problem in order to solve parts of it?
No. Some of us are GOOD...
>> This is RL And what Jim said.
The number of that kind of complex problem in today's business world is
relatively small, unless you are into engineering, complex software
development, or a similar field.
As a service economy, though, most "problems" are customer service
problems, and those are relatively easy to resolve.
Being good isn't enough. I'm actually *very* good at the things I do,
but so far all I've found that's a good fit is contract work. But I'm
picky.
Jim
>> This is RL
>> And what Jim said.
You need a solid background and understanding to answer the "please
describe how you would solve this moderately complex problem" type
questions and a B.A. in Googleology won't help for those, but you don't
need to clutter your brain with all the various switches to the grep
command.
As one of my teachers used to say: "You don't need to remember all of
this stuff [he was talking about various heat transfer differential
equations]... You just need to remember in which book you read it!"
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
Sure. But if you don't even know what the hell a differential equation
/is/... Well, maybe you can find the answer in a book. But I would
suggest you won't do very well trying to solve questions that come up in
the real job rather than in a test paper...
I've worked a number of jobs since I took differential calculus, and I've
never had to use it. (Though arguably, I have actually used it, but it
wasn't a necessity - I was curious about the rate that a change was
taking place in, don't even remember what it was now).
Jim
> /is/...
Which was the point I was making in the previous paragraph.
Actually, it turns out it's only 5 miles shorter. On the other hand, I
tried driving over there to see if I could find the place, and even at
3pm almost all of the roads along the route were absolutely wedged
solid. And this isn't even rush hour. It took almost 2 hours to get
there - twice my current commute time. Oh, and once you get there, there
is NO parking anywhere. The ONLY way to park is to use the lame-ass
"park and ride" system.
Clearly I will not be looking at any further jobs in Oxford. The journey
is just insane. I got stuck at one singe junction for 20 minute
straight. This is at 3pm on a Friday afternoon. I hate to imagine what
rush hour is like. (!)
> then! :-P
OK, well, the job spec clearly says they're looking for a VB programmer.
I have never done any VB coding (as a cursory glance at my CV will
readily confirm).
Firstly, this raises the interesting question "why the hell are they
even interviewing me?" Especially given how badly I did with the test
they sent. Presumably the purpose of a test is to weed out the people
who are completely unsuitable, so they can concentrate on the people who
show at least a minimal aptitude for the work.
An equally valid question - and one which I fully expect that they will
ask me - is why the /hell/ I'm applying for a VB job when I know nothing
about VB. (!)
The truthful answer, obviously, is that I went through the jobs list and
applied for almost every single job in sight, without really paying much
attention to the action specification. I took this approach under the
(perfectly reasonable and subsequently confirmed) assumption that almost
nobody I applied to would even bother to reply to me. I applied for this
job thinking "what's the worst that can happen?" It turns out, the worst
that can happen is that you get interviewed for a job you're not really
interested in, and not skilled for.
(If this were C#, I would be interested. I can probably learn that
fairly easily. Hell, I've already started. But VB is just a bit too
crappy for my taste...)
None of this is stuff you want to say in a formal interview. So the
question is... what the heck am I going to tell these guys? They're
offering a job that's almost impossible to commute to, coding in a
language I dislike. So why the heck did I apply?
Sometimes I think maybe I'm not really cut out to be a sentient human
being...
You do the interview and see if perhaps there's something closer to what
you're looking for - that may be why they asked you in anyways - and if
it doesn't look like a good fit, you thank them for their time and leave.
You don't need to say anything beyond that.
Jim
On 9/2/2012 12:52, Orchid Win7 v1 wrote:
> is at 3pm on a Friday afternoon. I hate to imagine what rush hour is like. (!)
Around here, 3PM on a friday afternoon is the most rushing of rush hour. By
5PM, everyone has already left early for the day.
> None of this is stuff you want to say in a formal interview. So the question
> is... what the heck am I going to tell these guys? They're offering a job
> that's almost impossible to commute to, coding in a language I dislike. So
They won't ask you why you applied. If they do, tell them "because I'm
interested in learning new things and I am confident I can do the job." Let
them make an offer before you turn it down.
"Oh no! We're out of code juice!"
"Don't panic. There's beans and filters
in the cabinet."
> readily confirm).
A legitimate question to ask but not in those terms.
Regards
Weirdly, at 9:30 in the morning, it's apparently pretty deserted. How odd...
Consequently, I arrived almost an hour early. (Still, arriving almost an
hour late would be way, way worse!)
Surprisingly, the interview actually seemed to go fairly well - although
I doubt they'll be offering me the job anytime soon. And honestly, would
I really /want/ to continue driving nearly 100 miles per day? Plus
they're talking about working 8am to 6pm (rather than the usual 9 to 5),
plus most weekends. On top of that, it's VB... Really, this job has
quite a number of things against it.
Undeniably the /worst/ part, though, was getting home again.
I made the stupid mistake of trying to actually use the "park and ride"
system that the signs scream about every 200 yards or so. The idea is
that instead of driving into Oxford, where there is NO parking ANYWHERE,
instead you park in a giant field several miles outside Oxford, and then
get the bus into Oxford itself.
This part worked just fine. The problem happens when you try to get the
bus BACK to your car! You see, the trouble is, of all the dozens of bus
stops littered around the place, ZERO of them are for buses that go back
to the car park. There are stops for buses going to Banbury, Witney,
Woodstock, Kiddlington, Islip, but NOTHING going to the ****ing car
park! >_<
Consequently, I had to WALK back to my car. (Google Maps informs me that
this is approximately 3 miles.) Perhaps most frustrating of all, a
God-damned SAW several 300 buses go right past me. I just couldn't find
ANY bus stops where the 300 actually stops. Instead, I trudged on and
on, in unbearable summer heat, wearing my best new suit and my shiny
office shoes that gave me blisters. And all because Oxford city council
can't be ****ing bothered to provide a park and ride service that
****ing works!
I have a damned good mind to demand my money back for my return ticket,
since I was clearly unable to actually GET a return trip. :-P
I do not find it funny that I had to walk down the side of a high-speed
4-lane road, being narrowly missed by thundering juggernauts, because of
their stupidity. Even when I GOT to the car park, there's no way of
actually CROSSING the road short of just playing chicken with the
oncoming heavy goods traffic. I could have been killed!
Possible answer #1: You still did better than any other candidate.
Possible answer #2: The questions you left blank were "traps" to weed
out the BSers (I had a few questions like that when I was interviewing
people). By leaving them blank it showed them you weren't trying to
show off.
Possible answer #3: "Bob, this guy is not qualified for my position,
but he would clearly be a good candidtate for you! You should check him
out" I've done that with many CVs that were sent to me, and have also
received a few people that were initially interviewed by other depts.
Andy needs food. Badly.
(Bonus points if you get the reference)
Am 04.09.2012 15:19, schrieb Orchid Win7 v1:
> ****ing works!
http://www.oxfordbus.co.uk/main.php?page_id=61
http://www.oxfordbus.co.uk/main.php?page_id=62
What? 10 hours (including breaks) a day AND most weekends? What is this?
An 18th century factory job?
>> ****ing works!
Wait - so you can only get ON the bus if you walk 5 miles into the
center of the city first?! WTF?
(The stop I got off at is outside the area shown on the map.)
I have no answer to that.
> odd...
Nope, rush hour is over.
Glad to hear it. :-D
> And honestly, would
No, but I drive 150 miles a day. It is tiring.
And a couple of things going for it too.
It is paid and it looks good stepping from one job to another (while you
look for something more suitable).
If you get the job you ask your co-workers what is the best thing to do.
Personally I think that you did something wrong. :-P
Regards
Welcome to modern Britain. ;-)
The client that I'm working for at the moment (Mercedes HPP) work from
8am to 5:30, nominally. They do a lot of unpaid overtime as well. If it
is a race weekend they work that too.
Regards
Yup, sometimes you just need something to fill the gap. Of course, you
don't tell the prospective employer that.
Jim
In my country, google maps tells you where the bus routes stop.
"They're the 1-800-#-GORILA of the telecom business."
On 9/4/2012 13:31, Stephen wrote:
> The client that I'm working for at the moment (Mercedes HPP) work from 8am
> to 5:30, nominally. They do a lot of unpaid overtime as well. If it is a
I used to do that shit, before I realized I could just say no.
And in Andrew's country too.
Regards
Really? And how do you make it do that?
Besides, the council's own maps claim that the buses stop at South
Parade, despite the fact that I couldn't find any bus stops where the
bus I want stops.
Well there's a surprise - I just got a call telling me they won't be
offering me the job.
You all saw that, right? I called it. :-P
Actually, I guess the surprising thing is the recruiter calling me at
nearly 8pm to tell me this... What the hell are those guys' office
hours?! o_O
Well, I'm not real surprised, and I didn't *really* want to work in
Oxford anyway, so...
I don't know, it just does if you zoom in close enough.
3 zooms back from max you get the icons. Click on an icon and you get
the buses that stop there.
Regards
OK, I just tried zooming in to maximum magnification. It still doesn't
show the bus /routes/, but it does at least mark the bus stops.
Unfortunately, the information Google gives me about which buses stop
where does not match the information physically printed on the bus
stops. I wonder which one is actually correct...
(Hey, Google can only tell you what the bus company told them, right?)
> stops.
Public transit information availability is dependent on location, looks
like it's not in Milton Keynes.
Jim
>> stops.
I was actually looking at Oxford.
>>> stops.
I show the same result at Oxford - public transport not available at this
location.
Jim
