POV-Ray : Newsgroups : povray.off-topic : Finding a good VM Server Time
17 Oct 2026 01:42:26 EDT (-0400)
  Finding a good VM (Message 1 to 37 of 37)
Subject: Finding a good VM
Date: 27 Aug 2012 06:24:05
Message: <503b4ac5@news.povray.org>
OK, so I'm currently looking for some VM software I can run on my home PC.
At work, I use VMware Workstation. Which works vastly better than
anything else I've seen, but it's expensive. Really expensive. I just
looked it up, and it's, like, £170.
There is VMware Player, of course. That's free. But being free it's also
crippled with all sorts of artificial limitations; no linked clones, no
snapshots, no teams. Basically it lets you run another OS, but without
any of the benefits of a VM.
In the past, I've tried BOCHS and QEMU. The interface is CLI-only. You
have to manually manage all the files involved. You end up having to
write elaborate scripts to fire up a VM. It works, but it's extremely
complicated. Plus this stuff runs very, very slowly.
I also tried Virtual Box. This offers a familiar GUI interface. (And I
particularly like the way each VM has its own window, so you can SEE
multiple VMs at the same time. On the other hand, it lacks activity
lights...) However, there are two main problems with it. The first is
that you still have to manually manage disks and VMs separately. But the
big, big problem is IT'S TOTALLY UNRELIABLE! It just will NOT do what
you tell it to. The number of times it's crashed on me, or a particular
VM has become unusable is utterly unacceptable.
Are there any other VM products with investigating? (Clearly there are
other VM products; I'm asking whether any of them are any good.)
Subject: Re: Finding a good VM
Date: 27 Aug 2012 08:23:41
Message: <503b66cd@news.povray.org>
Have you tried VirtualBox?
Date: 27 Aug 2012 10:06:59
Message: <503b7f03$1@news.povray.org>
Am 27.08.2012 14:23, schrieb Warp:
If "VirtualBox" == "Virtual Box" then yes, he did mention it.
Date: 27 Aug 2012 14:37:47
Message: <503bbe7b$1@news.povray.org>
On 8/27/2012 3:24, Orchid Win7 v1 wrote:
> Are there any other VM products with investigating? (Clearly there are other
If you're talking about Windows, Microsoft makes a Virtual PC that comes
with certain versions of Windows that works well.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 27 Aug 2012 15:42:51
Message: <503bcdbb$1@news.povray.org>
FWIW, I use VirtualBox on Linux pretty much daily, never have stability
problems at all.
I'm also not sure what you  mean by "manag[ing] disks and VMs separately"
- the GUI that I use (which is the default GUI AFAIK) doesn't do that.
Jim
Date: 27 Aug 2012 16:52:50
Message: <503bde22$1@news.povray.org>
>> other
I thought that was limited to only running one single instance of
Windows XP for backwards compatibility.
Date: 27 Aug 2012 16:56:24
Message: <503bdef8$1@news.povray.org>
>> comes with certain versions of Windows that works well.
No, you're thinking of "compatibility mode", not Virtual PC.
There's also Hyper-V if you have Windows Server.
Jim
Date: 27 Aug 2012 16:59:09
Message: <503bdf9d$1@news.povray.org>
> problems at all.
You never had it pop up and say "This process has performed an illegal
operation and must be terminated. Do you wish to send an error report"?
(Oh, well, I guess you wouldn't be seeing a Windows-specific error
message on Linux... But you get what I'm saying.)
You never had a VM working perfectly, and then the next day VirtualBox
utterly /refuses/ to start that VM? (Like, you click "start", and either
nothing happens or VirtualBox instantly crashes.)
You never had it refuse to delete a snapshot for no defined reason?
(E.g., you have a VM powered down, you take a snapshot, realise you
wanted to do something first, go to delete the snapshot you just made,
and it says "sorry, I can't do that Dave".)
When you create a VM, it asks to create a virtual disk. (Which isn't
surprising; VMware does this also.) But it seems to want to put all the
VM files in one place, and all the virtual disk files in another place.
And it asks me if I want to reuse one of my existing disk files. (Why
would I *ever* want to do that??) And when I delete a VM, this does
/not/ delete the disk image files with it. I have to manually do that
from the disk management window.
Maybe the GUI is completely different on Linux or something. But on
Windows, you can't even edit a snapshot description while the VM it
belongs to is running. (I can understand, from a technical perspective,
how that could end up not working. What I can't figure out is why the
heck nobody has fixed this. It can't be that damned hard...)
Date: 27 Aug 2012 17:15:53
Message: <503be389$1@news.povray.org>
>> problems at all.
Nope, never.
Nope, never.  I've even had my entire Linux DE crash on me and I've been
able to restart the VM when it came back up.
What version are you running?  Sounds like an old version maybe, or just
that the Windows version is garbage and you should use the Linux
version.  I've had nothing but good luck with the Linux version - enough
so that I stopped using even VMware Player.
Nope, never had it do that, either.
>> separately"
All of my VMs' disk files are with the configuration, but this actually
makes sense on a couple different levels, because you can do 'linked
cloning', in which case deleting the disk file would affect multiple VMs
(ie, it would break them).  But in the Linux GUI, you do have the option
when deleting a VM to also delete the disk files at the same time if
they're not linked/in use by another VM.
That works just fine on Linux.
Jim
Date: 27 Aug 2012 21:43:27
Message: <503c223f@news.povray.org>
On 8/27/2012 13:59, Orchid Win7 v1 wrote:
> asks me if I want to reuse one of my existing disk files. (Why would I
> *ever* want to do that??) And when I delete a VM, this does /not/ delete the
I think you just answered your own question.
    in the cabinet."
Date: 28 Aug 2012 04:32:04
Message: <503c8204$1@news.povray.org>
How so?
If you put the disks from one VM into another VM, then the other VM
*becomes* the first VM. All VMs are essentially identical; the disks are
the only thing that makes them different. Either you want to delete a
VM, or you don't. So deleting the settings file and then still using the
existing disks is a nonsensical thing to do.
Date: 28 Aug 2012 11:18:36
Message: <503ce14c$1@news.povray.org>
> How so?
Not if the disk is a data disk, or is used as something other than the
boot disk.
Or if it's a base for multiple linked clones where you started from a
common base, but the clones are different.  It's not unusual at all, for
example, when testing networked setups of identical OSes to create a
common base image and then customize multiple linked clones.
Jim
Date: 28 Aug 2012 12:03:19
Message: <503cebc7$1@news.povray.org>
> boot disk.
Wouldn't you just clone the disk for something like that? (Otherwise
only one VM can access it at a time.)
Then wouldn't each clone have its own local cloned disk image?
Date: 28 Aug 2012 13:22:55
Message: <503cfe6f$1@news.povray.org>
Am 28.08.2012 18:03, schrieb Orchid Win7 v1:
>> boot disk.
Virtual Box is pretty smart when it comes to saving disk space: When you
clone a disk image, it "freezes" the original disk's state into a save
point, and the clone will actually be a reference to that save point
plus a delta tracking any changes.
Likewise, the original disk will further on be managed as that "frozen"
state plus another delta tracking any changes made by /that/ VM.
(Note that a "frozen" state itself may already be a reference to an
earlier save point plus a delta.)
Date: 28 Aug 2012 13:56:53
Message: <503d0665$1@news.povray.org>
>>> are the only thing that makes them different. Either you want to
>>> delete a VM, or you don't. So deleting the settings file and then
>>> still using the existing disks is a nonsensical thing to do.
>> boot disk.
No, and no.
Linking the clone means that you don't waste the disk space with
duplicate data.
And no, only one VM can *write* to it at a time, but multiple VMs can
*read* from it at the same time.  Changes get written to a secondary file
that contains the differences between the combined images and the base
image - just like a snapshot.
Again, no.  That's not what a linked clone is.
I might be inclined to suggest "RTFM", as the VirtualBox and VMware
documentation both describe what a linked clone is.  Rather than assume
what it is and then make statements based on those assumptions, you could
actually learn what the idea is behind it.
Jim
Date: 29 Aug 2012 03:49:23
Message: <503dc983$1@news.povray.org>
Isn't this how /all/ VM products work?
Date: 29 Aug 2012 03:53:51
Message: <503dca8f$1@news.povray.org>
Oh, so now you're claiming that I don't know how VMware works?
When you create a VM, it starts with one file for the disk image. Each
time you take a snapshot, it stops writing to the current image file,
and creates a new file which is a delta against the previous one. When
you make a "full clone", it copies all the data. When you create a
"linked clone", it creates a new VM, but it's base disk image is just a
delta against the linked VM, just like a snapshot.
I don't know off the top of my head how Virtual Box does it.
I'm still not seeing why you would want to transfer a disk from one VM
to another - except perhaps, as you say, for data transfer (if you can't
get a more sane method to work).
Date: 29 Aug 2012 06:26:42
Message: <503dee62$1@news.povray.org>
Am 29.08.2012 09:49, schrieb Invisible:
Don't know; if that's the case, how come you didn't seem to know about
that concept?
Date: 29 Aug 2012 11:18:23
Message: <503e32bf$1@news.povray.org>
Well there you go. You have a VM on your desktop machine, and now you want
to run it in the colo facility.
    in the cabinet."
Date: 29 Aug 2012 11:19:15
Message: <503e32f3@news.povray.org>
It depends how you configure them. This is additional space overhead, remember.
    in the cabinet."
Date: 29 Aug 2012 11:53:23
Message: <503e3af3$1@news.povray.org>
>> could actually learn what the idea is behind it.
Given that you don't seem to understand how linked clones work or how
they are, I'm suggesting that maybe you should read up on the idea rather
than making wild assumptions about it.
Correct.  And if you delete the base vmdk image, what would you expect to
happen when using a linked clone?
And the VirtualBox documentation does in fact describe this.  But hey, at
least you're saying "I don't know how it does this" rather than making an
incorrect assumption based on no knowledge.  So that's progress. ;)
I'm working with a product right now that actually does this in order to
personalize the image.  The underlying virtualization technology is
XenServer, and the developers opted to create a LiveCD ISO to boot the VM
from that customizes the image (due to a lack of APIs in XenServer to do
this).  They transfer the disk files to a temporary VM that mounts them
after booting the LiveCD image.
One benefit is that this allows them to be hypervisor-agnostic - it's a
technique that works with any hypervisor that can boot from an ISO.
Jim
Date: 30 Aug 2012 03:50:26
Message: <503f1b42$1@news.povray.org>
> Correct.
So my understanding is correct, and this constitutes making "wild
assumptions"?
VMware won't let you do that.
None of which explains why I have to manage disk images and VMs
separately in Virtual Box, when they are nearly synonymous.
Date: 30 Aug 2012 03:50:58
Message: <503f1b62@news.povray.org>
> want to run it in the colo facility.
So... you just move the entire VM. I'm still not seeing why you would
want to move just the disk.
Date: 30 Aug 2012 11:26:01
Message: <503f8609@news.povray.org>
>> rather than making wild assumptions about it.
>> Correct.
> assumptions"?
Your understanding of the mechanics is correct, but your conclusions are
not.
>> And if you delete the base vmdk image, what would you expect to happen
Right, and neither will VBox.
Because they /aren't/.  A disk image can be used by multiple VMs.  You
understand the mechanics, but your conclusion that they're "nearly
synonymous" is faulty.
Jim
Date: 30 Aug 2012 16:31:47
Message: <503fcdb3$1@news.povray.org>
A virtual machine is just a simulation of a computer. You can create and
destroy an unlimited number of them at will. The only thing that
distinguishes one from another is the data it does or does not have on
it - i.e., the disk image(s).
Date: 30 Aug 2012 16:47:29
Message: <503fd161$1@news.povray.org>
Well, no, there's the virtual hardware configuration as well.
But again, when dealing with linked clones, you have a common base and
then things change from VM to VM.  Linked clones use both a common disk
and their own differentiating disk overlays that make them unique.
As such, disks/VMs are not "nearly synonymous".
Jim
Date: 30 Aug 2012 18:14:18
Message: <503fe5ba@news.povray.org>
Am 30.08.2012 22:31, schrieb Orchid Win7 v1:
Think of VMs as mainboards (+ CPU and memory installed), and disk images
as hard drives.
You can disconnect a hard drive from one mainboard and plug it into
another, can't you?
Date: 31 Aug 2012 03:23:30
Message: <50406672$1@news.povray.org>
> as hard drives.
> another, can't you?
Sure, you /can/... but why would you /want/ to?
Date: 31 Aug 2012 11:51:05
Message: <5040dd69@news.povray.org>
>> images as hard drives.
>> another, can't you?
Because you're upgrading the hardware and want to preserve your data?
Jim
Date: 31 Aug 2012 13:53:29
Message: <5040fa19$1@news.povray.org>
Because the colo facility may offer you different numbers of CPUs, RAM,
disk space, NICs, DVD drives, etc...
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 14 Oct 2012 15:16:04
Message: <507b0f74$1@news.povray.org>
OK, so today I bought VMware Workstation. Because, hey, I get paid now. ;-)
At work I had VMware Workstation 6.5.4. However, apparently the latest
version is 9.0.0 - which, as it turns out, looks much more pretty. And
there's a few minor irritations that are now gone. This is much better! :-D
On the other hand, sadly they /still/ haven't added an option to still
show disk indicator lights in fullscreen mode. Nor have they added a CPU
light. There's lights for every other resource, but not CPU. So I
honestly can't tell if my VM has crashed, or is just compute-bound...
Date: 15 Oct 2012 11:22:42
Message: <507c2a42$1@news.povray.org>
What would be the difference to check how much CPU the Vmware
Workstation's process is using?
Date: 15 Oct 2012 13:16:08
Message: <507c44d8$1@news.povray.org>
It's just annoying having to constantly flick between the VMware window
and the Process Explorer window to try to see what the thing is doing.
By contrast, disk and network activity are nicely displayed right there.
(Unless it's in full-screen mode...)
Date: 15 Oct 2012 13:28:45
Message: <507c47cd$1@news.povray.org>
Well yes, that's true. OTOH you could finally buy yourself also a decent
monitor and put those 2 windows side by side ;).
Date: 15 Oct 2012 15:21:40
Message: <507c6244@news.povray.org>
Not unless I also buy myself a bigger desk to put them on, and maybe a
bigger room to fit the bigger desk into. ;-)
Date: 16 Oct 2012 10:22:15
Message: <507d6d97@news.povray.org>
That's not a bad plan. But don't hold your breath, it might take couple
of months ;).
Date: 16 Oct 2012 10:26:22
Message: <507d6e8e$1@news.povray.org>
> of months ;).
You're thinking too small.
Screen / Desk / Room... what about House instead ?
Make your day, buy a city!
