POV-Ray : Newsgroups : povray.off-topic : Urk.. This is why I hate complex math... Server Time
1 Nov 2026 01:34:30 EST (-0500)
  Urk.. This is why I hate complex math... (Message 1 to 21 of 21)
Subject: Urk.. This is why I hate complex math...
Date: 26 Aug 2012 16:53:15
Message: <503a8cbb$1@news.povray.org>
I am looking at a situation in the future where I plan to simulate an
entire area that is rotating, like a big drum. This will be done by
simply having the wall texture on the entire outer surface drift, as
though its spinning. But, I also want to place a suspended rail tram in
there, and have it react (sadly, due to the limits of the system, only
with one angle, since I can't have more than one pivot point), as though
its being effected by the rotation, as well as its changes in momentum.
I am presuming that the math for this has to be:
http://www.myphysicslab.com/pendulum_cart.html#navsite
But.. then I run into a problem... Basically, I am not sure what the
frak is going on there...
Biggest issue is, there is a lot of stuff in it that won't help me.
Friction.. Well, no, the cart isn't going to be controlled via "forces",
its running a plotted course, so half the stuff in the "force of the
cart" part is just flat out meaningless. Then there is the fact that my
force calculations need to be only the force that its being applied "at
that moment" in one direction, two 3D vectors. That one is going to give
me issues, as it is. But, maybe I can direct substitute it in as F, or
something. Do I assume the cart mass itself is 0? Why can't there ever
be a simple, "Someone did this once, for a very similar situation, so
here is the math, and all you need to do in integrate the other rotation
thing you are doing." You know, instead of googling, and getting page
after page of descriptions, without math, of the things, or articles on
control systems, without math, for them, or just about anything other
than an explanation of how the frak it works in a real world, 3D
situation. lol
At the very least, some idea what I can/should do to cut extraneous data
out of the equations I do have, would be helpful. I am just real glad
the "pendulum" is going to be "one directional" just like the example,
and not with two axis of rotation, like.. a lot of them have.
Subject: Re: Urk.. This is why I hate complex math...
Date: 26 Aug 2012 21:20:01
Message: <web.503aca99af4d86e69726a3c10@news.povray.org>
It looks to me like you might have a modelling problem to figure out first. Are
you talking about something like the following, with the track attached to the
inside of a rotating drum instead of the surface of the earth? Is there any
actual gravity?
http://www.nycsubway.org/wiki/Wuppertal,_Germany
The important thing here is whether the tram swings in the direction of its
motion (as in your link), or whether it only swings significantly from
side-to-side (as in the link I posted).
If I have managed to get the gist of what what you're modelling, you might be
able to reduce your system to a single degree of freedom, vastly simplifying the
math. (Sort of, you would only need to solve for one unknown.)
> situation. lol
I'm completely with you here. I do whacky math for a living, and it is
tremendously difficult to find out if someone else has solved a problem I'm
doing. Not only would I like to check my work, I also need to properly cite the
original author if I end up publishing something about it.
If I'm on the right track here, I personally wouldn't use either of the
approaches in the link you posted. What makes your problem quite different from
what thousands of mathmaticians, physicists, and engineers have solved countless
times over the years is the rotating coordinate system inside the drum. Plus,
the local coordinate system of the tram is varying along its (rotating) path.
However, I'm still not certain if I'm thinking about the same problem you are.
Are you trying to come up with an exact symbolic solution, perhaps so you can
design a control system? Or, do you just need a reasonable numerical
approximation, perhaps just for animation?
Date: 27 Aug 2012 06:26:06
Message: <503b4b3e$1@news.povray.org>
I quite enjoyed complex math - you know, once I wrapped my head around
the whole "i = sqrt(-1)" thing...
Date: 27 Aug 2012 08:06:44
Message: <503b62d3@news.povray.org>
Trying to visualize in your head how spacetime works around a massive
object according to general relativity, and why objects moving at
different speeds traverse through the trajectories as they do, and
finally getting a grasp of it, is quite enlightening.
Date: 27 Aug 2012 12:55:01
Message: <web.503ba5e4af4d86e69726a3c10@news.povray.org>
If you like complex math, you might love the multicomplex algebras I've been
working with lately.
http://russell.ae.utexas.edu/FinalPublications/ConferencePapers/2010Feb_SanDiego_AAS-10-218_mulicomplex.pdf
Date: 27 Aug 2012 18:01:46
Message: <503bee4a$1@news.povray.org>
Hmm. First, its for simulation. I want to create the illusion that a
large underground complex was built, and by large I mean "really large",
and it is rotating around a center, and someone built a tram system in
it. So, no, this isn't real world, its entirely simulated, and won't
even be using real phsyics (hell if it was, I wouldn't need to compute
all this myself.. They don't even have a "curve" based movement system,
you can feed in the "rotation" and "location" data now, to define where
something should be at each point, but you have to "precompute" the
results. Hell, I have an experimental system that does that already,
using a curve that "fits" the control points, it just uses more script
resources to do it, so causes more lag in the simulator. Apparently,
basic curve math is either too confusing for them, or they actually
think it makes sense to waste script memory storing 500 data points, and
the needed rotations, instead of computing them for you. Though, I
admit, the one hickup I have been still trying to work out why my
version is taking the last point, and the next, and figuring out what
the proper change in rotation needed to be. I don't remember if I ever
actually figured that one out...
To clarify how the thing needs to work though, lets set this up. Imagine
a huge "platform", say 250 meters each direction. This platform is
rotating around its center. The "track" is set up on this rotating
platform. The tram itself is suspended from a single rail, and due to
the limitations of the kinematics in the system I am using, it ***can't
have*** more than one direction of movement, or at least not if its like
the image you linked, which is an actual car design. If it was set up
as, say, a two seated thing, this would be different, since there would
only be one point of suspension. For my case, I have two attachment
points, and since I can't hinge any other points, its limited to side to
side movement, as you describe.
So, what I am looking for is the angle that the pendulum has swung to,
depending on the "external" motion of the platform, as it applies to the
side to side motion, and the motion induced by turns taken by the tram.
Changes in forward motion, such as slowing down and speeding up, won't
have an effect, in principle. In fact, I don't think it has an effect at
all, since the only thing it could do is counter the motion of the
centrifugal forces, or increase them, in the forward direction, and
since there is no rotation in that direction...
Now.. Functions available -
I have vectors, so all the "math" can be handled without having to
monkey too much with non-matrix math, unless I have to. Its also easier
to leave things as they are, since its using quaternions.
I can get the location of the tram, at that time, its rotation, as well
as computing:
Rotation to Axis: VectorNormal(a.x,a.y,a.z) * (1 | -(a.s <0))
Rotation to Angle: ACos(Abs(a.s)) / Sqrt(a.x^2 + a.y^2 + a.z^2 + a.s^2)) * 2
Axis Angle to Rotation: axis = VectorNormal(axis) * Sin( angle / 2)
{returns- axis & Cos(angle/2)
Rotation to Left: VectorNormal(<0, 1, 0> * q)
Rotation to Forward: VectorNormal(<1, 0, 0> * q)
Rotation to Up: VectorNormal(<0, 0, 1> * q)
Vector Normal
Angle Between: 2 * ACos((a.x * b.x + a.y * b.y + a.z * b.z + a.s * b.s)
/ Sqrt((a.x * a.x + a.y * a.y + a.z * a.z + a.s * a.s) * (b.x * b.x +
b.y * b.y + b.z * b.z + b.s * b.s)))
Rotation Between: Umm. Complication and not a single equation. It also
bugs out, if the rotations are nearly opposite of each other.
It might be nice to also have the math for something that actually can
wobble in more than one axis, on the off chance a short "point to point"
zip line like thing was needed some place, but that isn't something I
had planned for, and I could live without it.
Date: 2 Sep 2012 20:30:51
Message: <5043fa3b@news.povray.org>
So.. guess I am trying to work this out myself after all. lol
Date: 5 Sep 2012 04:49:35
Message: <5047121f$1@news.povray.org>
So what you're saying is the following are known:
Position and velocity of the top of the train over time (following a
pre-determined track at a pre-determined speed), call this point A.
Angular speed of the platform (but that will be taken into account in
point A, as presumably the whole track and train are rotating with the
platform)
And you want to find out how much the train swings sideways as point A
goes around this track?
I assume you're doing this at discrete time steps and just want a
solution to the current time step based on the data from the previous step?
In that case why not just model it as a point mass at B connected by a
suitably stiff spring to point A? Keep track of the position and
velocity of B and you can use normal numerical integration to update B
(there will be a gravity force and a spring force towards A). In your
graphics you can use the angle between the vertical and the line A-->B
to draw your train.
It may not be 100% physically accurate but much simpler than trying to
work through all the maths related to dynamics in a rotating reference
frame...
Date: 5 Sep 2012 04:59:58
Message: <5047148e$1@news.povray.org>
Won't speeding up and slowing down make the train swing out more or
less? (Like going round a corner in a car, if you speed up it rolls more).
In a rotating reference frame you'd be essentially turning even when on
a straight piece of track, so I would not say that changes in forward
motion won't have any effect.
Date: 5 Sep 2012 15:14:52
Message: <5047a4ac$1@news.povray.org>
> platform)
> to draw your train.
> frame...
Uh, yeah, so how do you do that? lol Seriously, the closest I have come
to differentials is a book promising to take you from basic math up to
basic calculus, and I got lost like 3/4 of the way through it. :p But,
yeah, it sounds good...
Date: 5 Sep 2012 15:17:24
Message: <5047a544$1@news.povray.org>
Yes, to an extent, this is true. But, since the only angle its changing
at is side to side, forward motion isn't going to have an affect
*except* when making turns. If it was computing for motion in all
directions, then it would be different.
Date: 6 Sep 2012 06:00:24
Message: <50487438$1@news.povray.org>
>> more).
But as I said, in a rotating reference frame the train will be "making
turns" all the time, even when on a straight track. So any forward/back
acceleration will, in general, affect the side to side swinging.
You can easily see this by imagining a straight piece of track rotating
and plotting out the course the train will take as it goes along the
track - it will be a curve, so some sideways forces must be involved.
Date: 6 Sep 2012 06:10:17
Message: <50487689$1@news.povray.org>
>> to draw your train.
>> frame...
This is a good guide, there's some other good articles on his site too.
http://gafferongames.com/game-physics/integration-basics/
I don't know how much you've done already on this kind of stuff, but
even after 4-5 years of learning calculus the rotating reference stuff
was scary hard. From what I remember, mainly because your unit vectors
are no longer constant, so no longer disappear when you differentiate
them...
This is the demo we had in one of our lectures:
http://www.youtube.com/watch?v=kc88SrMG5fA
Fun to watch, but try to prove the physics :-)
Date: 6 Sep 2012 11:30:01
Message: <web.5048c064af4d86e69726a3c10@news.povray.org>
My apologies.  Real life conspired to take from me all but about five hours of
sleep for a while.
If I understand what you are trying to do, I think you can boil it all down to
figuring the "swing angle" (theta) of the car.  I'm assuming a rigid connection
(a "bar" with length L) between the center of mass (m) of the car and the track.
 The position of the track-end of the bar is given at any point in time, and
from this you can figure the car's velocity and acceleration in the direction
tangent to the track.
You have five "forces" acting on the car.
 * Gravity pulls it downward.
   |F_g| = m*g
 * Centrifugal force pulls it away from the center of the disc.
   |F_disc| = m*r_disc*omega_disc^2
 * Centrifugal force pulls it away from the center of curvature of the track.
   |F_track| = m*|v|^2/r_track
 * Centrifugal force pulls it away from the track-end of the bar as it swings.
 * The bar pulls it toward the track.
This can be further simplified, since the bar will counteract all force
components EXCEPT the component that can cause the car to swing from
side-to-side.  This component is tangent to the swinging arc at the car's
current position.  So, figure out the component of F_g, F_disc, and F_track that
is in this direction.  (You can use trig or direction vector dot products for
this, whichever you prefer.)
Now that you have the total tangential force (F_tan), calculate the tangential
acceleration (a_tan) it would cause from F_tan = m*a_tan.  Then, figure the
angular acceleration (alpha = a_tan/L).  Integrate over time to get the angular
velocity (omega), and again to get the angular position (theta).
Don't forget to calculate and then add the tangential velocity (v_tan) vector to
the total velocity (v) vector when computing F_track.  You will also probably
want to include some kind of frictional force (angular velocity damping) so the
car does not keep swinging forever.
I hope this helps.
http://en.wikipedia.org/wiki/Centripetal_force
http://en.wikipedia.org/wiki/Angular_acceleration
P.S. Your intuition that "forces" don't exist as such is a good one, especially
at the macro scale of everyday life.  They are, however, extremely useful
abstractions.
Date: 6 Sep 2012 12:00:02
Message: <web.5048c87baf4d86e69726a3c10@news.povray.org>
I forgot to mention that I usually make *lots* of mistakes as I work through a
problem, and this looks like one of them.  The component of the side-to-side
swinging velocity in the direction of the track should be zero, so forget about
this.
Date: 6 Sep 2012 12:05:23
Message: <5048c9c3$1@news.povray.org>
>     |F_g| = m*g
Do you need the coriolis force in there too?
Date: 6 Sep 2012 12:30:00
Message: <web.5048cedfaf4d86e69726a3c10@news.povray.org>
Good catch.  It looks like it could be significant for this problem.  As usual,
the Wikipedia page has a useful formula.
http://en.wikipedia.org/wiki/Coriolis_effect#Formula
(If I ever manage to make a real income from math, I plan to send them a
donation for having been an invaluable mathematics reference for years.)
Date: 6 Sep 2012 23:06:01
Message: <50496499$1@news.povray.org>
>>> to draw your train.
>>> frame...
> them...
I have done.. almost nothing. Like I said, never took calculus at all,
and the book I read through derailed about where the equations got into
integration and differentials. I did pick up a few interesting trick
about raising to powers and negative powers that I had no idea was
possible, but otherwise.. confusing as hell. I need to sit down one of
these days and actually try to work out what they are doing.
O.o
Ok, yeah, that is.. not something I would have predicted. lol
Date: 6 Sep 2012 23:12:45
Message: <5049662d$1@news.povray.org>
Hmm. Ok. All that should get me a start. Wouldn't have had a clue what
all to look for without help. Just need the time to actually write a
script, test and debug. Unfortunately, no idea when that is going to be. :p
Date: 6 Sep 2012 23:19:27
Message: <504967bf$1@news.povray.org>
>>> more).
Ok, true. Maybe I am phrasing wrong then. What I meant is that, since
the reference is going to be, in principle, constant, what ever forces
it is applying are not going to have the same effect as say,
acceleration or deceleration of the train **on** the track, if the
direction is directly parallel to the existing force being applied by
the reference. The result will, thus, only matter when the resulting
vectors actually change, with respect to the angle it can swing in. I.e.
Possible angle = <0,1,0>
Forces = <4,2,1>
Result = <0,2,0>
This is not the case, obviously, when the track is not directly parallel
to the force, or if the possible rotations where <1,1,0> (i.e., both X
and Y, not just Y).
Date: 6 Sep 2012 23:22:03
Message: <5049685b$1@news.povray.org>
> this.
That's OK. I might actually do a gondola style thing too, maybe, so, in
that case, the force wouldn't be 0 in the track direction as well. But,
for the design I intended, yeah, I already figured that. lol
