POV-Ray : Newsgroups : povray.off-topic : Urk.. This is why I hate complex math... Server Time
4 Jul 2026 08:12:11 EDT (-0400)
  Urk.. This is why I hate complex math... (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Urk.. This is why I hate complex math...
Date: 5 Sep 2012 15:17:24
Message: <5047a544$1@news.povray.org>
On 9/5/2012 1:59 AM, scott wrote:
> On Mon 27/08/12 23:01, Patrick Elliott wrote:
>> Changes in forward motion, such as slowing down and speeding up, won't
>> have an effect, in principle.
> Won't speeding up and slowing down make the train swing out more or
> less? (Like going round a corner in a car, if you speed up it rolls more).
> In a rotating reference frame you'd be essentially turning even when on
> a straight piece of track, so I would not say that changes in forward
> motion won't have any effect.
Yes, to an extent, this is true. But, since the only angle its changing
at is side to side, forward motion isn't going to have an affect
*except* when making turns. If it was computing for motion in all
directions, then it would be different.
Date: 6 Sep 2012 06:00:24
Message: <50487438$1@news.povray.org>
>> more).
But as I said, in a rotating reference frame the train will be "making
turns" all the time, even when on a straight track. So any forward/back
acceleration will, in general, affect the side to side swinging.
You can easily see this by imagining a straight piece of track rotating
and plotting out the course the train will take as it goes along the
track - it will be a curve, so some sideways forces must be involved.
Date: 6 Sep 2012 06:10:17
Message: <50487689$1@news.povray.org>
>> In that case why not just model it as a point mass at B connected by a
>> suitably stiff spring to point A? Keep track of the position and
>> velocity of B and you can use normal numerical integration to update B
>> (there will be a gravity force and a spring force towards A). In your
>> graphics you can use the angle between the vertical and the line A-->B
>> to draw your train.
>> It may not be 100% physically accurate but much simpler than trying to
>> work through all the maths related to dynamics in a rotating reference
>> frame...
> Uh, yeah, so how do you do that? lol Seriously, the closest I have come
> to differentials is a book promising to take you from basic math up to
> basic calculus, and I got lost like 3/4 of the way through it. :p But,
> yeah, it sounds good...
This is a good guide, there's some other good articles on his site too.
http://gafferongames.com/game-physics/integration-basics/
I don't know how much you've done already on this kind of stuff, but
even after 4-5 years of learning calculus the rotating reference stuff
was scary hard. From what I remember, mainly because your unit vectors
are no longer constant, so no longer disappear when you differentiate
them...
This is the demo we had in one of our lectures:
http://www.youtube.com/watch?v=kc88SrMG5fA
Fun to watch, but try to prove the physics :-)
Date: 6 Sep 2012 11:30:01
Message: <web.5048c064af4d86e69726a3c10@news.povray.org>
> So.. guess I am trying to work this out myself after all. lol
My apologies.  Real life conspired to take from me all but about five hours of
sleep for a while.
If I understand what you are trying to do, I think you can boil it all down to
figuring the "swing angle" (theta) of the car.  I'm assuming a rigid connection
(a "bar" with length L) between the center of mass (m) of the car and the track.
 The position of the track-end of the bar is given at any point in time, and
from this you can figure the car's velocity and acceleration in the direction
tangent to the track.
You have five "forces" acting on the car.
 * Gravity pulls it downward.
   |F_g| = m*g
 * Centrifugal force pulls it away from the center of the disc.
   |F_disc| = m*r_disc*omega_disc^2
 * Centrifugal force pulls it away from the center of curvature of the track.
   |F_track| = m*|v|^2/r_track
 * Centrifugal force pulls it away from the track-end of the bar as it swings.
 * The bar pulls it toward the track.
This can be further simplified, since the bar will counteract all force
components EXCEPT the component that can cause the car to swing from
side-to-side.  This component is tangent to the swinging arc at the car's
current position.  So, figure out the component of F_g, F_disc, and F_track that
is in this direction.  (You can use trig or direction vector dot products for
this, whichever you prefer.)
Now that you have the total tangential force (F_tan), calculate the tangential
acceleration (a_tan) it would cause from F_tan = m*a_tan.  Then, figure the
angular acceleration (alpha = a_tan/L).  Integrate over time to get the angular
velocity (omega), and again to get the angular position (theta).
Don't forget to calculate and then add the tangential velocity (v_tan) vector to
the total velocity (v) vector when computing F_track.  You will also probably
want to include some kind of frictional force (angular velocity damping) so the
car does not keep swinging forever.
I hope this helps.
http://en.wikipedia.org/wiki/Centripetal_force
http://en.wikipedia.org/wiki/Angular_acceleration
P.S. Your intuition that "forces" don't exist as such is a good one, especially
at the macro scale of everyday life.  They are, however, extremely useful
abstractions.
Date: 6 Sep 2012 12:00:02
Message: <web.5048c87baf4d86e69726a3c10@news.povray.org>
I forgot to mention that I usually make *lots* of mistakes as I work through a
problem, and this looks like one of them.  The component of the side-to-side
swinging velocity in the direction of the track should be zero, so forget about
this.
Date: 6 Sep 2012 12:05:23
Message: <5048c9c3$1@news.povray.org>
>     |F_g| = m*g
Do you need the coriolis force in there too?
Date: 6 Sep 2012 12:30:00
Message: <web.5048cedfaf4d86e69726a3c10@news.povray.org>
Good catch.  It looks like it could be significant for this problem.  As usual,
the Wikipedia page has a useful formula.
http://en.wikipedia.org/wiki/Coriolis_effect#Formula
(If I ever manage to make a real income from math, I plan to send them a
donation for having been an invaluable mathematics reference for years.)
Date: 6 Sep 2012 23:06:01
Message: <50496499$1@news.povray.org>
>>> to draw your train.
>>> frame...
> them...
I have done.. almost nothing. Like I said, never took calculus at all,
and the book I read through derailed about where the equations got into
integration and differentials. I did pick up a few interesting trick
about raising to powers and negative powers that I had no idea was
possible, but otherwise.. confusing as hell. I need to sit down one of
these days and actually try to work out what they are doing.
O.o
Ok, yeah, that is.. not something I would have predicted. lol
Date: 6 Sep 2012 23:12:45
Message: <5049662d$1@news.povray.org>
Hmm. Ok. All that should get me a start. Wouldn't have had a clue what
all to look for without help. Just need the time to actually write a
script, test and debug. Unfortunately, no idea when that is going to be. :p
Date: 6 Sep 2012 23:19:27
Message: <504967bf$1@news.povray.org>
>>> more).
Ok, true. Maybe I am phrasing wrong then. What I meant is that, since
the reference is going to be, in principle, constant, what ever forces
it is applying are not going to have the same effect as say,
acceleration or deceleration of the train **on** the track, if the
direction is directly parallel to the existing force being applied by
the reference. The result will, thus, only matter when the resulting
vectors actually change, with respect to the angle it can swing in. I.e.
Possible angle = <0,1,0>
Forces = <4,2,1>
Result = <0,2,0>
This is not the case, obviously, when the track is not directly parallel
to the force, or if the possible rotations where <1,1,0> (i.e., both X
and Y, not just Y).
