So, we put an old Maxtor harddrive in a glass measuring beaker, and
stood it in one of our fume cupboards.
We poured nitric acid on it. Nothing.
The guy opened a bottle of sulphuric acid, which was smoking slightly.
Pour some of that in... a tiny amount of fizzing. That's about it.
So we stand at look at it for a moment. And then my college decides to
add a little hydrochloric acid.
Woah... I'm not sure what the chemistry of this is, but now it's foaming
like hell, and there's huge clouds of dark brown smoke coming off it.
Uh, yeah, I think we close the fume hood now...
After a few minutes it eventually stopped fizzing. There's still some
kind of brown vapour issuing from it though. And the black paint is
slowly falling off, revealing the dully silver metal beneath.
It will be interesting to see if there's anything left by Monday. My
college thinks it will have been reduced to sludge by then. I suspect
it'll still be in once piece, just slightly corroded around the outside.
Flashbacks to Breaking Bad.
"Oh no! We're out of code juice!"
"Don't panic. There's beans and filters
in the cabinet."
Le 17/08/2012 16:25, Invisible nous fit lire :
Red alert. Mixing Nitric acid with Sulphuric acid is a cocktail to make
nitroglycerin from glycerine. The smallest part of grease might turn
dangerous once dried.
Great, now the cocktail is a mix of Sulphuric acid and Aqua regia, the
solvent for gold & platinum.
(for gold, the proportion are 2/3 Nitric, 1/3 Chloridric; it goes to 7/9
and 2/9 for platinum, IIRC)
All the water generated by Aqua regia attacking the metal will get
captured by the Sulphuric acid.
Notice that Aqua regia is unstable: it will generate chlorine gaz and
nitric oxyd (Cl2 and NO) with water.
Adding water to Sulphuric acid is exothermic. (it generates heat)
Le 18/08/2012 10:05, Le_Forgeron nous fit lire :
Nah, it's the opposite proportion! More Chlore, less Nitro!
Am 18.08.2012 10:05, schrieb Le_Forgeron:
If the aim is to destroy the drive, nitroglycerine would definitely help
>_<.
Fine, so gold parts won't escape either :-P
Interesting. I thought aqua regia was sulfuric and nitric... oh well!
How about all the metal irons now floating around? Will that affect
anything?
> solvent for gold& platinum.
Well, yeah, we /are/ trying to dissolve metal...
Apparently it also evolves NOCl, which might explain the dark brown fumes.
Yeah, I gathered at least one of them is. Good thing we didn't add any
water, eh? (Might explain the fizzing though... it certainly didn't seem
to remove any metal!)
Well, the results are in:
The drive is now somewhat corroded, and most of the paint is missing.
The circuit board probably won't work again. But other than that, the
drive is more or less completely unharmed. Apparently soaking it in a
vat of acid for 4 days is /not/ sufficient to dissolve the entire thing
down to the platters. :-P
I told you: boiling hydrochloric acid. No fancy mix, just plain Hcl,
enough HCl.
Now, rinse it, dry it and to the boiler...
Or if you have some liquid nitrogen and a hammer... it can be fun too.
> enough HCl.
I don't have any way of heating the acid. Also, we have now run out of acid.
We have a 2 tonne liquid nitrogen tank. However, the nitrogen can only
be withdrawn in gaseous form.
> acid.
"Another one bit the dust", by Queen... time to check if a fall from any
height on a concrete surface would have exploded the drive. We want photo.
"It's a hard life" : after having been the cherished drive on which
everyone relied, it is now persecuted.
"Hammer to fall": at least, do you have some hammer ?
If all else fail, you might get some expanding-foam (in can, urethane)
injected inside the drive: this would preclude any easy restoration.
Yeah, that's what I was thinking.
A solid lump of steel? Yeah, as if any gravitational impact will touch it.
Yeah. It's kind of sad, really.
http://tinyurl.com/bnvgfmj
Yeah, I still think unscrewing the lid and shattering the platters is
the simplest.
Surely you mean "Another one BYTES the dust"?
Great story though!
Dave Downing, Somerset U.K.
No bytes were harmed in the making of this message.
Nitrogen Dioxide. Nasty stuff. Thank goodness for a fume hood :)
Anything else dissolve?
~Mike
> enough HCl.
Hot Conc Sodium Hydroxide.
~Mike
