POV-Ray : Newsgroups : povray.off-topic : Today's insight Server Time
24 Apr 2026 01:04:35 EDT (-0400)
  Today's insight (Message 1 to 7 of 7)
Subject: Today's insight
Date: 7 Aug 2012 05:37:17
Message: <5020e1cd$1@news.povray.org>
If you try to build a mechanical computer, the main thing stopping you
from running it faster is inertia. Components have to have connecting
rods to transmit mechanical force from one component to another, and the
further apart these components are, the larger and heavier the
connecting rods. So you have to waste power accelerating them, and then
waste power bringing them to a halt again. The faster you want to
compute, the more force you end up needing to use, and the more power
you waste.
Now consider trying to build an electronic computer. Now the problem is
that the long connections from component to component act as tiny
capacitors, each one a low-pass filter trying to filter out your
high-frequency data signals. And the only way to overcome this, it
seems, is to use higher and higher voltages.
Inertia verses capacitance. Mechanical force verses voltage. It's in
interesting parallel...
Subject: Re: Today's insight
Date: 7 Aug 2012 08:25:34
Message: <5021093e$1@news.povray.org>
> you waste.
Not to mention inducing vibrations that can skew results - or even
physically damage the device.
Not to mention inducing harmonics (yes, even with digital signal) that
can skew results - or even worse physically damage the device.
Not only are both signal analysis and vibration dynamics using the same
differential equations, they even use the same symbols for schematics
diagrams (a resistor looks exactly like a spring, a capacitor looks
exactly like a damper or shock absorber)!
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 7 Aug 2012 08:42:42
Message: <50210d42$1@news.povray.org>
Well, I mean, everyone knows that the Fourier series for a square wave
has transfinite extent...
Not any more:
http://en.wikipedia.org/wiki/Resistor
According to the IEC, the symbol for a resistor is now supposed to be a
rectangle, not a zigzag. Personally I think it looks dumb, but hey...
Date: 7 Aug 2012 13:11:31
Message: <50214c43@news.povray.org>
Am 07.08.2012 14:42, schrieb Invisible:
I grew up with the IEC symbol (probably just a DIN symbol back then), so
I think the American symbol looks somewhat ugly, but hey...
Date: 7 Aug 2012 14:32:51
Message: <50215f53$1@news.povray.org>
I grew up with the zig zag symbol and think the rectangle looks bland.
But hey... :-P
Regards
Date: 7 Aug 2012 15:16:49
Message: <502169a1@news.povray.org>
> But hey... :-P
Well MY symbol is gonna kick YOUR symbol in the nuts! :-P
Date: 7 Aug 2012 15:51:45
Message: <502171d1$1@news.povray.org>
No way.
I don't have any. ;-)
Regards
