I was reading a description for a computer algorithm. Get this, the
authors claim that the time-complexity is proportional to the "inverse
Ackermann function".
That's a good thing, right? I mean, the Ackermann function grows
absurdly fast, so its inverse presumably grows absurdly slowly.
(Quite how any algorithm's run-time could ever be proportional to
something as obscure and arbitrarily defined as the inverse of the
Ackermann function, I have no idea... I guess now I've seen everything.)
Union-find structures I assume?
You could of course look a proof and read through it.
Actually, something much more complicated than that.
I saw the proof. It's about 20 pages of dense formulas. Clearly I'd need
to study it very carefully to figure out what the hell is going on...
Intersting, what was it, I'm curious? The only other algorithm with
that complexity I can think of off the top of my head is an MST algorithm.
In that case, however, you may be further interested to know that the
standard union-find algorithm also has inverse Acermann complexity.
Thus there's an even simpler example of something with that "odd"
complexity.
Yeah, that proof does suck a little like that.
> Intersting, what was it, I'm curious? The only other algorithm with that
An optimisation algorithm for logic programming.
> standard union-find algorithm also has inverse Acermann complexity. Thus
> there's an even simpler example of something with that "odd" complexity.
That's really odd. The Ackermann function is an ad hoc function with
arbitrarily-chosen coefficients which was thrown together to prove a
point. Why it should /ever/ occur in real life is beyond me...
Am 06.06.2012 09:57, schrieb Invisible:
If "the Ackermann function" referred to is actually the "Ackermann-Péter
function" (which is probably the case), then I see nothing
"arbitrarily-chosen" in its recursive definition.
Maybe the Ackermann function you know is a different one? According to
Wikipedia, "'the Ackermann function' may refer to any of numerous
variants of the original function", modified "to suit various purposes".
