POV-Ray : Newsgroups : povray.off-topic : 1 GHz CPU and it still cannot time things properly. Server Time
1 Nov 2026 04:07:52 EST (-0500)
  1 GHz CPU and it still cannot time things properly. (Message 1 to 19 of 19)
Subject: 1 GHz CPU and it still cannot time things properly.
Date: 29 May 2012 12:19:27
Message: <4fc4f70f$1@news.povray.org>
I found an old wind up watch that I had not used in years. I got it
serviced but it was running slow so I adjusted it. It went from running
150 seconds a day slow to running 21 seconds fast. Not too bad for the
first attempt, I thought.
Now that I know that the adjustment lever has the range, I will be
scientific. So I recorded the tick on my tablet (1 GHz CPU) and analysed
it. I also recorded a quartz watch as a reference. Damned if the wave
form was > 0.6% out. That is nearly 9 minutes out in a day. It looks
like I will have to revert to the old fashioned method of adjust, let it
run for a day and repeat until I get fed up.
Could do better if it tried. :-(
Regards
Subject: Re: 1 GHz CPU and it still cannot time things properly.
Date: 29 May 2012 12:33:27
Message: <4fc4fa56@news.povray.org>
  It actually doesn't surprise me that CPU clocks aren't adjusted to
extreme accuracy because they don't need to. It's not like they have to
precisely sync with anything. This especially so because most modern CPUs
support throttling. (In fact, an error 0.6% sounds pretty small to me.)
Date: 29 May 2012 12:38:36
Message: <4fc4fb8c$1@news.povray.org>
On 29/05/2012 05:19 PM, Stephen wrote:
> It looks
You could try using the atomic emission spectrum of caesium-133 to
adjust the frequency of the quartz oscillator...
For reference, the frequency of photon generated by the transition
between the two hyper-fine ground states of a caesium-133 atom is
*defined as* 9,192,631,770 Hz. As in, that's the current SI definition
of what one second *is*.
Date: 29 May 2012 15:12:05
Message: <4fc51f85$1@news.povray.org>
Well, you are right. I really wasn’t thinking. It was a thought I had
last night before going to sleep and in the morning I went full steam
ahead, at it. Maybe I just miss working for a living.
On some instruments I’ve worked on 2% was considered accurate enough on
others you measured parts per million. When you expect to get a watch
running to +/- 2 seconds a day it is galling to have to do it by iteration.
Regards
Date: 29 May 2012 15:16:02
Message: <4fc52072$1@news.povray.org>
Sh*te! I forgot. I have one of those in the back shed, as well.
*/- a minute a month will do me. Actually twice a day will do if I
forget to wind it up. :-P
Regards
Date: 29 May 2012 16:03:54
Message: <4fc52baa$1@news.povray.org>
0wned.
Date: 29 May 2012 16:27:41
Message: <4fc5313d@news.povray.org>
> 0wned.
And never called me mother!
Regards
Date: 30 May 2012 03:57:16
Message: <4fc5d2dc$1@news.povray.org>
There is no reason for a tablet (or any PC/phone) to have a clock
generator with super accuracy, it's simply wasted expense when an
accuracy of <1% will do for the majority of tasks.  That's why
professional sound cards have an option to use the clock from an
incoming signal (rather than the internal one) to keep everything in sync.
Try playing the same song (or your tick recording) on several different
devices at the same time, you'll find they likely drift apart noticeably
after only a minute or two.
You could try recording the speaking clock as a reference, that is
probably more accurate than your tablet.
Date: 30 May 2012 05:17:34
Message: <4fc5e5ae$1@news.povray.org>
And here I was thinking that even cheap quartz oscillators are quite
accurate...
Date: 30 May 2012 07:01:59
Message: <4fc5fe27$1@news.povray.org>
> accurate...
Even cheap quartz oscillators are too expensive to just throw at a
device like a tablet.  The audio clock is likely derived from elsewhere
with whatever divide-down ratio was cheapest to implement (the frequency
will likely not even be designed to be spot on 44100 if the numbers
don't work out nicely).
Date: 30 May 2012 09:08:29
Message: <4fc61bcd$1@news.povray.org>
It was a NTB (Not Too Bright) idea, a eureka moment where I slipped on
the soap when I jumped out of the bath etc.
It’s not worth the trouble trying to make an escapement analyser when
the software I have will only find the beats to a resolution of 1
millisecond* and I don’t have a proper microphone. So the waveform I get
is very noisy and automatically finding the beats is not very accurate.
I am sure that they would.
I was using the tablet as a recording device. It is the accuracy of that
which is in doubt. Well it is not actually in doubt, it is not up to the
requirements needed.
My quartz watch was for calibrating/adjusting the figures I got after
analysing the wave form. But the time between ticks is not constant. The
recording program and the sound card probably have too low a priority
for accurate recording. Which is also an answer to Andrew saying that
cheap quartz oscillators are quite accurate. That and the compensation
for voltage and temperature won't be high spec.
* An accuracy of about +/- 7 minutes a day.
Regards
Date: 31 May 2012 04:12:05
Message: <4fc727d5@news.povray.org>
>> accurate...
A deviation in playback speed of +0.6% or -0.6% corresponds to a pitch
deviation of about 10 cents. That's audible. I'd be surprised if they
allow it to be quite that large.
(I would have expected the DAC to run at whatever speed is convenient,
and then resample the signal in software... But what do I know?)
Date: 31 May 2012 04:50:01
Message: <4fc730b9$1@news.povray.org>
If you play it back on the same hardware you used to record then there
shouldn't be any pitch change :-)
But even if you played back something recorded elsewhere, do you really
think a normal person would notice a 0.6% higher or lower pitch (without
the correct reference pitch to compare with at the same time).  When
they show films (shot at 24 fps) on PAL (25 fps) doesn't the video and
audio come out 4% faster and higher pitch (or do they resample that)?
If the software knew what the real clock rate was with 100% accuracy
there wouldn't be this discussion in the first place!  Anyway if you
were to resample from (say) 43500 Hz to 44100 Hz you're going to get a
lot of artefacts and use a lot of CPU (battery) - better to just play
your 43500 Hz recording assuming it was at 44100 Hz.
You also have conflicting technical requirements in a device like a
tablet.  For example the audio circuit needs the clock to be as steady
and accurate as possible, whereas other parts of the circuits will
definitely not want a steady clock frequency to avoid EMC/EMI issues.
Guess which requirement will get forgotten when the EMC tests fail or
the bean counters tighten the strings?
Date: 2 Jun 2012 16:19:57
Message: <4fca756d$1@news.povray.org>
They're really not that expensive. I worked for someone who had three or
four. You just have to keep them calibrated.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 2 Jun 2012 16:21:08
Message: <4fca75b4$1@news.povray.org>
I was trying to play harmony with myself at one point, so I recorded the
first track, then played it back on headphones while I recorded the second
track. Within 8 or 10 measures, I was an entire beat off, when I merged them.
Very annoying. :-)
    in the cabinet."
Date: 2 Jun 2012 17:26:14
Message: <4fca84f6$1@news.povray.org>
More expensive than I would buy for one watch.
But not in Andrew's league of hundreds of millions of pounds. ;-)
Regards
Date: 2 Jun 2012 17:28:32
Message: <4fca8580$1@news.povray.org>
On 02/06/2012 9:21 PM, Darren New wrote:
> Very annoying. :-)
That's what I thought. Grrr!
Regards
Date: 3 Jun 2012 04:51:03
Message: <4fcb2577$1@news.povray.org>
> second track. Within 8 or 10 measures, I was an entire beat off, when I
> merged them.
> Very annoying. :-)
Recorded with /what/?
I have a cheap digital 8-track at home, and I do /exactly this/ with it,
and it works perfectly, every single time...
Date: 3 Jun 2012 12:38:14
Message: <4fcb92f6$1@news.povray.org>
This was a little pocket MP3 player thingie. It happened to be the only
convenient play-back device I had handy at the moment.  I'm not surprised in
hindsight it was off that much, but it was surprising enough that I did it
two or three times before I realized it wasn't me messing things up.
    in the cabinet."
