POV-Ray : Newsgroups : povray.off-topic : Complex numbers Server Time
1 Nov 2026 04:07:50 EST (-0500)
  Complex numbers (Message 1 to 18 of 18)
Subject: Complex numbers
Date: 7 May 2012 17:09:14
Message: <4fa839fa$1@news.povray.org>
Question: Why can't you extend the complex numbers to 3D space?
Answer: Because the hairy ball theorem says so.
Yes, that's right. There really is a theorem called "the hairy ball
theorem". Isn't that wonderful? :-D
Perhaps even more satisfyingly, what this theorem /says/ isn't some
obscure exotic thing that only a mathematician could understand.
Actually, it just says you can't comb the hair on a ball flat. You
always end up with at least one tufty bit. (You /can/ comb the hair flat
on a flat plane, a torus, or a number of other 3D shapes. Just not a
sphere.)
Subject: Re: Complex numbers
Date: 7 May 2012 17:28:10
Message: <4fa83e6a$1@news.povray.org>
Le 07/05/2012 23:09, Orchid Win7 v1 nous fit lire :
> sphere.)
It's even more deeper. The theorem says you cannot comb a sphere of odd
dimension, but that even dimension is ok.
(2D sphere == circle, 4D sphere is left as an exercise)
That's also why, even if complex cannot be extended in 3D, they can in
4D. (look at quaternion...
Notice that there is a meteorological application of the theorem: there
is always on earth at least one place where the horizontal speed of wind
is null.
Date: 7 May 2012 17:33:02
Message: <4fa83f8e@news.povray.org>
Orchid Win7 v1 escreveu:
is it so hairy that numbers got scared to death and complexed? :p
a game sig: http://tinyurl.com/d3rxz9
Date: 7 May 2012 21:53:24
Message: <4fa87c94@news.povray.org>
Someone also figured out that you can do probability with 1D numbers and 2D
numbers, but not any higher dimensions. The speculation is that's why
quantum effects have the same math as waves and not something either "common
sense" or more baroque than they are.
I.e., you can do math on "the probability that X happens given that Y
happens" and deal with "and" and "or" and Bayesian probabilities, using
either real numbers or complex numbers, but not 3D numbers.
I don't understand the proof myself, but so I'm told.
   "Oh no! We're out of code juice!"
   "Don't panic. There's beans and filters
    in the cabinet."
Date: 8 May 2012 03:29:43
Message: <4fa8cb67$1@news.povray.org>
Le 08/05/2012 03:53, Darren New nous fit lire :
> 2D numbers, but not any higher dimensions.
Are you talking about random movement having a non-null (aka about 100%)
probability of returning to your starting point (sort of) ?
In 1D (moving along a line), with whatever balanced distribution, it
seems rather obvious.
In 2D (moving in a plane), it's less obvious but you will cross your
previous path at a moment or another.
but once in 3D, you're lost and would quasi-never cross any points from
your previous path.
Date: 8 May 2012 03:36:20
Message: <4fa8ccf4$1@news.povray.org>
Le 08/05/2012 09:29, Le_Forgeron nous fit lire :
> your previous path.
Oh, I forgot also a difference as dimensions are raised:
1D & 2D: you can evaluate the length/surface of any grid-aligned
line/polygon by counting the number of element of the grid inside the
limit. (you need to count twice: one for grid's nodes fully inside, and
another for grid's node also on the perimeter)
That computation fails once in 3D or more!
Date: 8 May 2012 04:31:47
Message: <4fa8d9f3$1@news.povray.org>
>> sphere.)
Indeed.
> 4D. (look at quaternion...)
No. Quaternions do not form a field. Neither do the hypercomplex
numbers, nor any of the other 4D generalisations.
> is null.
Interesting...
Date: 8 May 2012 10:15:14
Message: <4fa92a72$1@news.povray.org>
That's irreverent to Le_Forgeron's point. The application of the hairy
ball theorem here does not depend on the numbers forming a field.
Date: 8 May 2012 10:26:12
Message: <4fa92d04$1@news.povray.org>
I should clarify, I took the fact that the extension wouldn't be a field
to be implicit in Le_Forgeron's point, since the Hairy ball theorem's
use doesn't depend on the numbers forming a field.  Not saying your
reading was technically incorrect.
Date: 8 May 2012 10:34:02
Message: <4fa92eda$1@news.povray.org>
Do you happen to remember the name of this theorem?  I'm curious how
fierce a devil is in the details.
Date: 8 May 2012 11:23:47
Message: <4fa93a83$1@news.povray.org>
By "extend the complex numbers", I implicitly meant to extend it to make
a larger /field/. Apparently that is impossible. There are of course
several ways you can extend them if you don't mind the result failing to
be a field...
Date: 8 May 2012 11:43:26
Message: <4fa93f1e$1@news.povray.org>
> be a field...
This is certainly true, but your options are more limited in 3d than in
4d.  I was just assuming that Le_Forgeron was already well aware that
quaternions aren't a field.  Operating under this assumption I took his
point to be that your options for extending the complex numbers to 3d
are more limited then when extending them to 4d, even though obviously
neither extension will result in a field.
Your interpretation of Le_Forgeron is of course also consistent with
what he posted.  However I'm confused how you reconcile this "any
extension must be a field" view with your original post.  In the initial
post you say:
"Question: Why can't you extend the complex numbers to 3D space?
Answer: Because the hairy ball theorem says so."
But that seems a pretty weak explanation of why such an extension isn't
possible if you're insisting that the extension be a field.  After all
such an extension isn't possible to 4d, even though the hairy ball
theorem *doesn't* apply in that case.  If you're going to take this view
why bother with the hairy ball theorem at all?  You can prove more by
other means.
If, on the other hand, you allow the extension to not form a field, then
it makes more sense why you'd use the hairy ball theorem, as it helps to
explain why the quaternions are possible in 4d but not 3d.  Not saying
your view is wrong in a technical sense... it just seems a little
hodge-podge to me.  Perhaps I am missing something?
Date: 8 May 2012 13:23:04
Message: <4fa95677@news.povray.org>
  The reason is that it's not possible to make multiplication commutative
for them.
Date: 8 May 2012 14:03:15
Message: <4fa95fe3$1@news.povray.org>
> for them.
The hypercomplex numbers possess commutative multiplication. What they
do /not/ possess is multiplicative inverses. (Not for all elements, anyway.)
In short, you can construct lots of 4D number systems, all of which fail
to be a field in a different way.
Date: 8 May 2012 14:04:35
Message: <4fa96033$1@news.povray.org>
> other means.
OK, point taken.
It's just that the "other means" are usually incomprehensible, whereas
"you can't comb a sphere flat" is a pretty intuitive description of why
you can't do something.
Date: 11 May 2012 12:43:42
Message: <4fad41be@news.povray.org>
> Do you happen to remember the name of this theorem? I'm curious how fierce a
I know where I read about it, I think. I'll try to check if it's actually
named when I find the book. :-)
    in the cabinet."
Date: 11 May 2012 14:07:35
Message: <4fad5567@news.povray.org>
>> fierce a
> actually named when I find the book. :-)
If you have the name of the book and don't feel like looking for it
yourself, that'd probably be enough for me to go on.
Date: 12 May 2012 17:19:25
Message: <4faed3dd@news.povray.org>
It was mentioned somewhere when I was reading about quantum physics, either
wikipedia or Feynman's QED or something. I can't really find it, but it's
basically the complex probability amplitude equations, and a mention that
you don't get the multiplcation/addition of probabilities working out to
(for example) always come out as "1" if you go higher than two dimensions.
    in the cabinet."
