POV-Ray : Newsgroups : povray.off-topic : I'm in the mood for monads Server Time
23 Jun 2026 00:52:11 EDT (-0400)
  I'm in the mood for monads (Message 24 to 33 of 93)
Subject: Re: Living in a box
Date: 22 Apr 2012 11:49:56
Message: <4f9428a4$1@news.povray.org>
On 22/04/2012 11:59 AM, Warp wrote:
> Orchid Win7 v1<voi### [at] devnull>  wrote:
>> Further, let's pretend that you can create an anonymous function just by
>> writing
>>     int function(int x) {return 2*x;}
>    You can create anonymous functions. The syntax is:
>      [](int x) { return 2*x; }
>    (Of course that alone won't do anything because you can't call it, as
> it has no name. However, you can eg. create a variable that represents
> the function, like: "auto func = [](int x) { return 2*x; };". If you need
> to eg. return that function from another function, you'll have to use the
> std::function wrapper. Likewise if you need to give one as parameter to
> a non-templated or anonymous function.)
Mmm, interesting.
So how do you call such a function? Does it just override the usual
function call notation?
Subject: Re: I'm in the mood for monads
Date: 22 Apr 2012 11:54:37
Message: <4f9429bd$1@news.povray.org>
>> Heh, man... I thought "it inserts user-defined code between each pair of
>> statements" would a pretty simple idea. I guess not... ;-)
> I should have said that I am none the wiser. I still do not know what a
> monad is.
If you have a set of things which can be "added" and "subtracted" in a
certain technical sense, this is called a monoid.
(The technical rules say things like "if you add X and Y, and then
subtract Y, the result has to be X". Stuff like that.)
A monad is a little more complicated, but essentially, if you have
- A "box" type of some sort.
- A "return" function that takes a value and sticks it in a box.
- A "bind" function that takes a box and a function that returns a box,
and calls that function with the thing(s) in the input box.
then that's a monad.
(Once again, there's a bunch of technical rules that make this
mathematically rigorous. Technically the functions have to obey certain
rules - the "monad laws" - such as "bind x id == x". But usually any
sane way of implementing the two functions about will satisfy the
requirements.)
Date: 22 Apr 2012 11:56:52
Message: <4f942a44$1@news.povray.org>
>> 1. You can take a 5-argument function, pass it 2 argument, and get a
>> 3-argument function as the result.
>    Would this be currying in C++?
>      std::function<int(int)>  multiplierFunction(int multiplier)
>          return [multiplier](int value) { return value * multiplier; };
>    The above function returns a function that takes an integral as parameter
> and returns it multiplied by the specified multiplier.
Yeah, I think that would satisfy my idea of "curried function".
The question is, does
   multiplierFunction(3)(4)
or similar yield a 12?
Date: 22 Apr 2012 12:34:40
Message: <4f943320@news.povray.org>
Am 22.04.2012 17:40, schrieb Orchid Win7 v1:
> On 22/04/2012 11:40 AM, Warp wrote:
>> But that's the thing: It sounds so trivial as to defy sense. Why give
>> a particular name to such a trivial thing?
> One could argue that "calling a function" is a pretty trivial idea. But
> it's still useful to have a name for it.
>> But then when one starts asking questions like "so it's like giving
>> default values to function parameters?" or "so it's like writing another
>> function with less parameters that calls the first function by giving it
>> some default values as the rest of the parameters?", the answer is
>> something
>> like "not really".
> Providing default arguments is /kind of/ similar. The difference is that
> usually you /can/ still provide explicit values which override the
> defaults. With a curried function, you /cannot/ change the arguments
> that have already been given. (Or even know if any arguments /have/ been
> give yet. All you can see is what arguments remain.)
> Writing a new function that takes one fewer arguments than an existing
> one is like currying. Except that the idea behind "currying" is that
> this is /automatic/. You don't have to code it yourself. It's
> automatically available for all functions.
Maybe that's what scrambles my mind whenever I read "Haskellists'"
explanations of stuff: They're so proud that Haskell does it
automatically for you, that they tend to deny the obvious parallels.
So yes: Currying *is* like writing a function that takes fewer
arguments, calling the original one and supplying (unchangeable)
defaults for the missing arguments.
And yes, apparently Haskell provides syntactic sugar for that. Wow. Big
deal.
> Finally, like I said, currying works backwards too: If a function call
> happens to return a function as its result, you can just keep appending
> arguments. "head function_list 7" and all that.
Again, nice-to-have syntactic sugar, but nothing conceptually
fascinating (as you noted yourself).
> That said, you could probably design some sort of object that has
> methods for adding arguments, N at a time, and when it gets enough
> arguments, it yields an answer. And that might reasonably be described
> as currying.
No. That might reasonably be described as nothing but bullshit.
Date: 22 Apr 2012 12:41:51
Message: <4f9434cf$1@news.povray.org>
Am 22.04.2012 17:56, schrieb Orchid Win7 v1:
Sure, why not? multiplierFunction(3) returns a valid function, so
invoking its () operator calls the function with the respective
parameter(s).
(You could achieve the same syntax by having multiplierFunction() return
an object with an overridden () operator rather than a function, but of
course that would be cheating.)
Date: 22 Apr 2012 12:51:29
Message: <4f943711@news.povray.org>
  I think that the difference is that the new function is not static,
but it's generated dynamically. (In other words, what you end up is a
new function which fixes some of the parameters of the original function,
but the values to which they are fixed is determined at runtime rather
than at compile time.)
  This means, if I understand correctly, that you could for example create
such functions in a loop (or, as we are talking about functional languages,
in a recursive manner), which is quite difficult to achieve with static,
compile-time functions. (I suppose you could try to emulate this in a
statically typed language with no lambda functions, but you would need
some kind of stack or something where the fixed parameter values are
stored.)
  There are probably even deeper implications.
Date: 22 Apr 2012 12:53:52
Message: <4f94379f@news.povray.org>
  Yes.
Date: 22 Apr 2012 13:03:36
Message: <4f9439e8@news.povray.org>
  That's kind of what the C++ lambda does internally: It puts the captured
variables in some kind of internal struct, which the function then operates
with (similarly to how a class member function operates with the object
using the 'this' pointer). You could achieve a similar behavior by writing
a class, but a lambda achieves this with significantly less effort.
  There is a significant difference to a class, though. In this example
std::function<int(int)> can manage *any* lambda function that takes an
int and returns an int, not just ones that have captured a 'multiplier'
variable and perform a "value * multiplier" on it.
  If you implemented the functionality of the example I wrote with a
class, you would be fixing the "lambda" function to be only and exactly
a multiplier function that has to be used with exactly your class and
nothing else. std::function<int(int)> has no such limitation. Any function
(be it a static function or a lambda) that takes an int and returns one
will do.
  This can make a difference especially with non-templated functions that
take a std::function as parameter. (One advantage of std::function over a
generic functor is that the former does not require for the code that uses
it to be templated and thus doesn't suffer form the few limitations that
templated code has.)
Date: 22 Apr 2012 13:15:46
Message: <4f943cc2@news.povray.org>
> Mmm, interesting.
  A variable that points to such an anonymous function works like any
function pointer, which means you can call it like a regular function.
Thus if you have, for example:
then you can simply call it like
    func(5);
  Templates taking a functor as parameter work the same way. You could
have something like:
    template<typename T, typename Comparator>
    bool compare(const T& value1, const T& value2,
                 const Comparator& comparatorFunction)
        return comparatorFunction(value1, value2);
  In the above example any comparator function will do (a comparator
function is something that behaves like a function taking two parameters
and returns a boolean). This can be a regular function, a functor (a class
that behaves like a function), a lambda, or an object of type std::function.
Thus you can call it eg. like:
    compare(1, 3, [](int v1, int v2) { return v1 < v2; })
Date: 22 Apr 2012 13:44:28
Message: <4f94437c$1@news.povray.org>
On 04/22/2012 09:06 AM, Stephen wrote:
> On 22/04/2012 1:38 PM, James Holsenback wrote:
>>> monad is.
>> Oh that's easy ... it's just the singular form of gonad ... THUD ...
>> couldn't resist ;-)
> That calls for a kick in both monads. :-P
hmmmm ... nonads (well that's self explanatory) better yet faux-nads ...
someone who thinks that gotta pair. OK I'll stop now ;-)
