POV-Ray : Newsgroups : povray.off-topic : Teach yourself C++ in 21 days Server Time
4 Jul 2026 09:41:27 EDT (-0400)
  Teach yourself C++ in 21 days (Message 49 to 58 of 168)
Subject: Re: Teach yourself C++ in 21 strange malfunctions
Date: 18 Apr 2012 04:04:14
Message: <4f8e757e@news.povray.org>
On 17/04/2012 08:51 PM, Warp wrote:
> Invisible<voi### [at] devnull>  wrote:
>> I'm still a bit baffled that this is a valid thing to do, however...
>    There's some baggage from C that would have better been dropped, but
> as you may know, backwards compatibility can be a real b***h sometimes...
Don't we all know it. ;-)
(Haskell isn't as ancient as C, so fortunately it has much less of this.
It /does/ have it, however...)
>    It can be argued using the same logic as with uninitialized variables,
> though: There are situations where execution never reaches the end of the
> function, and hence having a 'return' statement there would be useless.
Sure. But like I said, the Java compiler seems to detect this. If
doesn't just look at a function and say "does it contain a return
statement somewhere?" It actually statically analyses every possible
flow of control, and checks that every individual one ends with a return
(or throws an exception, which is also a valid way to terminate a function).
Of course, it's not perfect. Plausibly you could have if branches such
that a particular sequence of branches is impossible due to the
conditions in those branches, but the compiler wouldn't "see" that and
would still insist that you have a branch that doesn't terminate
properly. But I haven't seen that happen yet.
Subject: Re: Day 6
Date: 18 Apr 2012 04:06:37
Message: <4f8e760d@news.povray.org>
On 18/04/2012 07:24 AM, Le_Forgeron wrote:
> Le 17/04/2012 14:13, Invisible a écrit :
>> Obviously this /isn't/ what's so special about classes. The /actual/
>> benefits don't appear to be mentioned.
> The benefit of class over a simple struct/collection is in the
> private/protected parts, and the mandatory centralisation of the
> prototypes of all related functions.
Indeed. Anybody who knows any OO theory will understand this. But,
unfortunately, anyone who reads this book will have no idea.
Hey Warp, you ever think about writing a book? I bet you could do a
better job than this idiot...
Date: 18 Apr 2012 05:36:14
Message: <4f8e8b0e@news.povray.org>
> IDEs are only really useful for OO languages.
I do not agree.
> You know, you have a
> variable holding an instance of a class, then you type "." and get a
> list of methods available... no such thing in functional programming
> where the order is reversed: you have a function and want to apply
> arguments to it. You may list arguments that match that function
> definition and you may even know their types (assuming "intellisense"
> got type inference), but most likely you're not directly applying those
> arguments to the function, but applying some other function to it first.
> It sounds too much of hassle to use "intellisense" in those situations...
Did you know that there's a program called Djinn which can take any
Haskell type signature and generate Haskell source code for it, if it's
possible to write it without recursion?
Of course, there's usually more than one possible expression for a given
type signature. So the code you get may well not be the code you
actually wanted. But still, it's interesting that just a type signature
is sometimes enough to generate useful, runnable code. (Try doing /that/
in a normal programming language...)
> I fear IDEs are really only useful at getting away with lesser
> languages' weaknesses
> so, all that would seem to rest of usefulness for an IDE is project
> management.
I do not agree.
Consider the things that a typical IDE does:
- Syntax highlighting. Bracket pairing.
- Generate parts of an expression as you type. (E.g., generate the
matching close bracket, generate the "then" and "else" keywords when you
type "if".)
- Highlight any syntax errors, mismatched brackets, unused variables.
- Allow you to compile the whole project with one keypress.
- Highlight the line of source code that the compiler is complaining about.
- Display a summary of what entities are defined in each file, what
their types are, whether they're public or private, etc.
- Let you navigate to each entity in the list.
- Run the document extraction tool.
- Take you to the documentation for a given entity (regardless of
whether its in your project or an installed 3rd party library).
- Easily launch your application.
- Run your test suite and log the results.
- Integrate with your source control system. Show interactive diffs.
Show the history tree. Manage commits and reverts and branches.
- Integrate with the debugger. Let you single-step through your code.
Let you create watches, inspect variables in scope, drill down through
complex data structures.
Tell me, how do any of these things stop being useful if your
programming language isn't object-oriented?
Date: 18 Apr 2012 07:13:35
Message: <4f8ea1df@news.povray.org>
  But the C++ compiler cannot break the standard by making the situation
an error. It can only issue a warning.
  (And besides, any kind of detection of this cannot be 100% accurate,
as the problem "will this line of code ever be reached?" is unsolvable
in the general case.)
Subject: Re: Day 6
Date: 18 Apr 2012 07:15:14
Message: <4f8ea241@news.povray.org>
> prototypes of all related functions (until you start playing with
> friend, but that's another story).
  Well, classes also support inheritance and dynamic binding, which
is sometimes useful.
Subject: Re: Day 6
Date: 18 Apr 2012 07:17:42
Message: <4f8ea2d6@news.povray.org>
  There already exist good books.
  If you want to read something actually useful about C++, try the
"Effective" book series by Scott Meyers (or at the very least "Effective
C++" and "More Effective C++"). They actually contain some competent and
easy to understand information.
  "Effetive STL" is probably also good.
Date: 18 Apr 2012 08:04:12
Message: <4f8eadbc@news.povray.org>
Sure. I understand that. The problem is that the standard requires this
to be permissible. I was just pointing out that "because it's impossible
to detect" is not a valid reason for the standard being written this
way. (Backwards compatibility is, of course.)
Sure.
Subject: Re: Day 6
Date: 18 Apr 2012 08:06:05
Message: <4f8eae2d@news.povray.org>
Well, I guess.
Noted.
(Basically the only reason I'm persisting with this poorly written and
probably outdated text is that we've already bought it. But I'm thinking
it might be better to just save myself the trouble and go read a real
explanation...)
Date: 18 Apr 2012 18:18:41
Message: <4f8f3dc1$1@news.povray.org>
Invisible escreveu:
> I do not agree.
AFAIK, the hindley-milner type system is turing complete, so it's not
surprising at all.  So, if you want you may indeed just provide
mind-boggling complex types and let djinn extract the program behaviour
from that, just as a C++ programmer can go overkill and write with
templates a compile-time lisp interpreter and run factorial 100 on it
and just output
93326215443944152681699238856266700490715968264381621468592963895217599993229915608941463976156518286253697920827223758251185210916864000000000000000000000000
at run-time.
It's all feasible, just not very useful.
>> management.
> I do not agree.
> type "if".)
all common features of the most featureless text editors out there
besides scumbag notepad.
that requires a bit more working, specially unused variables.
Mismatched brackets is a (mis)feature of languages that are not lisp. ;)
that's only useful for languages still in the old edit-compile-test
cycle... ;)
in any case, even humble C can do that, provided a Makefile is ready.
heck, Makefiles are language-agnostic even...
emacs and vim both allow that kind of integration with external tools
such as compilers... I'm sure other featureful text editors too.
For C/C++ that's as easy as simply taking a look at each header file. :)
ever heard of exhuberant C-tags?  I'm sure it got support for haskell
too, and is such a tool that generates for a codebase a tags file and
lets you navigate through source code using those tags.  Support for it
in both emacs and vim at least.
what's wrong with man? ;)
like ./out ?
like ./test > log.txt ?
well, I'm stopping now.  It's clear you're just a button masher who
enjoys mashing buttons than simply harnessing from an integrated textual
development environment.
you are not even talking like a haskeller anymore!  Is there such a
haskell debugger?  Last time I heard, debugging and lazy evaluation were
at odds...
They are all very useful and none requiring a bloated and costly IDE.
Intellisense is the only really thing useful in such IDEs, and, like I
said, it's only really useful for OO languages.
Date: 19 Apr 2012 04:17:25
Message: <4f8fca15$1@news.povray.org>
>> it's possible to write it without recursion?
> surprising at all.
Basic Hindley-Milner isn't Turing-complete, no. Add a few extensions and
it can be /made/ Turing-complete, however.
Not really.
Suppose I have two Maybe values, and I want a utility function to pick
the first one which has a value in it. I run Djinn and say
   select ? Maybe x -> Maybe x -> Maybe x
It immediately replies
   select a b =
     case a of
       Nothing -> b
       Just c  -> Just c
which is the correct way to do this. (Although ever so slightly more
verbose than necessary.)
Now actually there are /several/ possible functions with this type
signature, and in a sense it's just a fluke that Djinn happens to have
picked the one I wanted. However, this is not exactly a "mind-boggling
complex type". Actually it's a pretty damned /simple/ type. :-P
So far I've fed all sorts of stuff into Djinn, and mostly it produces
the code I wanted. The killer limitation is that it can't handle
recursion. You can't have recursive types, you can't generate recursive
code. That's a pretty big limitation. But for simple boilerplate that
just involves lots of type conversions, it works great!
> cycle... ;)
Compiling a program is a useful way to check for errors, even if you
don't intend to actually /run/ it. (Well, it is if you aren't coding in
C anyway...)
Makefiles only work on Unix. :-P But hey, you can write a simple script
to build your project under Windows.
The /real/ problem, of course, is that you have to open a command
window, CD to the right folder, and type in "make program1" or whatever.
This takes significantly longer than pressing F7 (or whatever).
Heck, KDevelop lets you have the terminal window embedded right there in
the text editor, and it /still/ takes longer switching back and forth
between windows than it would to just jab a key.
...and skipping over all the preprocessor directives, comments, inline
functions, and other cruft. :-P
What are "tags"?
Oh Jesus, where do I even *start* with that??
> like ./out ?
Sure, once you take your hands off the keyboard and onto the mouse to
switch from the text editor window to the command prompt window. :-P
...that's not what it looks like from here. ;-)
> haskell debugger?
Yes, there is. OK, it doesn't actually /frigging work properly/, but it
exists. And has a horrifyingly bad UI, BTW. Mainly because trying to do
interactive program exploration using a CLI is really unintuitive.
Bloated I'll give you. But costly? Do you have any idea how many free
IDEs there are?
Basically, what you've just said is "you can recreate some of the
features of an /integrated/ development environment by manually linking
tools together yourself". Sure, you can, it's just harder.
For the most part, I use a non-integrated development environment when
I'm coding Haskell. That doesn't mean I don't see the value in something
like Leksah.
An IDE is way, way more than just code completion.
