POV-Ray : Newsgroups : povray.off-topic : SPAAAAACCCEEEE Server Time
17 Oct 2026 05:57:27 EDT (-0400)
  SPAAAAACCCEEEE (Message 1 to 17 of 17)
Subject: SPAAAAACCCEEEE
Date: 17 Mar 2012 19:18:51
Message: <4f651bdb$1@news.povray.org>
Not completely off-topic, since it could be used as render-fodder.
http://www.jpl.nasa.gov/spaceimages/details.php?id=PIA15482
Tim Cook
http://empyrean.sjcook.com
http://www.lifemax.net/TimCook
Subject: Re: SPAAAAACCCEEEE
Date: 17 Mar 2012 20:50:14
Message: <4f653146@news.povray.org>
Em 17/03/2012 20:18, Tim Cook escreveu:
a 300MB image, woah. :)
Date: 17 Mar 2012 20:53:48
Message: <4f65321c@news.povray.org>
Am 18.03.2012 00:18, schrieb Tim Cook:
Thanks for sharing the link.
Date: 17 Mar 2012 21:07:25
Message: <4f65354d$1@news.povray.org>
What?  The full-size Blue Marble image of Earth is a few GB, isn't it?
Never did get back to playing with that...not as much point with Google
Earth available to do a lot more, though.
Tim Cook
Date: 17 Mar 2012 21:11:24
Message: <4f65363c@news.povray.org>
Em 17/03/2012 22:07, Tim Cook escreveu:
damn, I'm still living in the 90's... :p
Date: 17 Mar 2012 22:11:03
Message: <4f654437$1@news.povray.org>
Caveat:  the full-size, raw Blue Marble image was split into two
26400x26400(?) parts, one for each hemisphere, but even then most
programs wouldn't load it, even if you had the memory...it's been a few
years since I looked into that, though, and I now have a 64-bit machine
with quite a bit more RAM than I did.
^_^
Tim Cook
Date: 22 Mar 2012 04:07:27
Message: <4f6addbf@news.povray.org>
They use equirectangular projection to map the sphere on a rectangle.
It's probably ok to use map_type 1 of povray to put it back on a sphere.
Notice that they remapped rgb to 3 infrareds: 22, 12 and 3.4 microns.
(Equirectangular is a family: x = lambda.cos(phi_1), y = phi
lambda & phi are longitude & latitude)
plate carrée is usual, with phi_1 as 0, and a picture ratio of 2:1
Indeed, if unstretched, the picture ratio is 2.cos(phi_1), so you can
always get back to a know phi_1 with a simple unidirectional scale.
Date: 22 Mar 2012 04:55:50
Message: <4f6ae916@news.povray.org>
>> >  a 300MB image, woah.:)
Drat! I cannot get onto the jpl.nasa site but I did manage to find it on
the nasa site at a lower resolution.
http://www.nasa.gov/mission_pages/WISE/multimedia/pia15482.html
Also a Mollweide projection (I think)
http://www.nasa.gov/mission_pages/WISE/multimedia/pia15481.html
And an annotated one.
http://wise.ssl.berkeley.edu/gallery_images/WISE2012-003-A-annotated.jpg
Regards
Date: 22 Mar 2012 13:41:10
Message: <4f6b6436@news.povray.org>
Am 22.03.2012 09:55, schrieb Stephen:
They call it Aitoff.
Date: 22 Mar 2012 14:11:17
Message: <4f6b6b45@news.povray.org>
Le 22/03/2012 18:41, clipka nous fit lire :
the difference might be subtle. And is it Aitoff or Hammer-Aitoff ?
(clue: mollweide & hammer-aitoff are equal-area projections)
Download 'leforgeroncamera_aitoff_hammer.png' (286 KB) Download 'leforgeroncamera_mollweide.png' (272 KB)
Preview of image 'leforgeroncamera_aitoff_hammer.png'
Preview of image 'leforgeroncamera_mollweide.png'
Date: 22 Mar 2012 14:58:08
Message: <4f6b7640$1@news.povray.org>
Thanks and I take my ait off to you. :-)
Regards
Date: 23 Mar 2012 12:12:21
Message: <4f6ca0e5$1@news.povray.org>
Am 22.03.2012 19:11, schrieb Le_Forgeron:
They call it Aitoff, so I guess it's Aitoff.
We definitely need custom-projection warps and cameras. You know, with
functions defining the projection.
Date: 23 Mar 2012 12:14:18
Message: <4f6ca15a$1@news.povray.org>
Am 22.03.2012 19:58, schrieb Stephen:
Why? Because I read the text? I had never heard of this Aitoff thing
before myself ;-)
Date: 23 Mar 2012 13:05:45
Message: <4f6cad69$1@news.povray.org>
> before myself ;-)
It was a joke, albeit a poor one.
Regards
Date: 23 Mar 2012 14:22:51
Message: <4f6cbf7b$1@news.povray.org>
Le 23/03/2012 17:12, clipka nous fit lire :
The true formula for Aitoff is painfull to generate a map (camera); at
least, I get confused by sinc-function enhanced formula (see english
wikipedia), as of course to make a camera, we are going from x,y to
spherical coordinate (and of course, that is not provided by the
documentation, and I did not intend to use a solver)
For custom-camera, you would need a way to output 2 vectors (origin,
direction) from the inputs of 4 vectors (location, up, right,
direction), 2 doubles between 0 and 1, and whatever you do with them as
hard-coded/SDL-coded formulas (including other SDL data and hard-coded
values).(you might see it as a function of 2 doubles which must provides
2 3D-vectors)
Some formula are easy in one direction and nightmare/impossible in
opposite (camera vs projection).
Did you say projection warps ? I would have thought about projection
map_type.  (from a 3D point, some others data (assume origin & other ?),
provide a couple of doubles : integer part can be used to isolate the
"once" (0.x,0.y) and the part after the dot is the coordinate on
map/picture (scale to 0 to 1 in both direction)
Date: 23 Mar 2012 21:45:27
Message: <4f6d2737$1@news.povray.org>
Am 23.03.2012 19:22, schrieb Le_Forgeron:
> 2 3D-vectors)
Not really.
The location, up, right & direction vectors just orient the camera;
that's a simple matrix operation that is independent of the projection
formula.
For a truly generic projection we'd need six funcions, each taking two
numbers (X and Y coordinate in resulting image): Ray origin X,Y,Z and
ray direction X,Y,Z.
For any cartographic projection, two functions would suffice: From two
screen coordinates (X,Y) we'd have to compute two spherical coordinates
(phi and theta).
> map_type.  (from a 3D point, some others data (assume origin&  other ?),
Map types can only be used with input images; implementing the stuff as
a custom warp instead would allow to do the same operations on other
patterns as well.
Date: 24 Mar 2012 07:53:11
Message: <4f6db5a7@news.povray.org>
Le 24/03/2012 02:45, clipka nous fit lire :
>> 2 3D-vectors)
> Not really.
> formula.
> (phi and theta).
Unless you are always mapping from below (center of the planet), I
prefer for an absolute custom camera to be able to set the origin and
direction of each ray (well, each pixel ray, as well as AA sub-rays).
It seems more natural to thing of the camera as a flying satellite
(well, rather a parallel set of raster satellites using their own single
"laser beam"). Probably something along a mathematical-function(s) based
"mesh camera" (without a mesh)
[so far, I have no intent to implement that fully custom camera. yet ?]
It could also allow for easy (easier ?) setting for stereographic render
(half left-picture for left eye, half right-part for right eye)
(not sure about naming that stereographic)
Simulating the eye(s ?) of bee or fly could also be done (once someone
found the formula)
> patterns as well.
Oh, nice thought. I would never have added a warp in a pigment/image_map
to change its type. Nor using a classical pattern.
maybe it would be "safer" to drop map_type and push the usage of warp
(doing it one way) for image_map.
About using other pattern, it might be more troublesome, as some are
really 3D and cannot be limited to a plane. (and other are using more
than just the position).
