POV-Ray : Newsgroups : povray.off-topic : Random failure Server Time
29 Jul 2024 08:13:12 EDT (-0400)
  Random failure (Message 1 to 9 of 9)
Subject: Random failure
Date: 14 Mar 2012 10:47:04
Message: <4f60af68$1@news.povray.org>
OK, so here is today's problem.
I've been given a dead laptop. Only thing is, I can't figure out why
it's dead.
When you switch it on, the BIOS runs, and then nothing happens. In other
words, the OS does not boot, nor give any indication for /why/ it can't
boot. All I get is a black screen with a flashing cursor. (The OS is
supposed to be Windows XP.)
Normally I would expect the BIOS to say "cannot load OS, insert system
disk" or similar if it can't find a bootloader - but no. Normally I
would expect NTLDR to report an error - but no. Just... nothing.
I loaded a Linux live CD, and as best as I can tell, the HD is working
perfectly. I can see a small FAT32 partition and a giant NTFS partition.
The latter is marked as bootable and contains all the necessary boot
files, and much else besides. All the data is there, intact. So...??
More to the point, this laptop /was/ working just fine. And then it
suddenly stopped working. This makes me suspicious; computers do not
just /stop working/ for no defined reason. But I'm struggling to think
what a computer-illiterate person could possibly do to make the OS fail
so completely.
I did wonder if some BIOS setting had been changed which alters the
apparent numbering of the drives or something... but no.
Obviously, I tried booting the Windows XP CD to see if I can ask it to
reset the MBR or something... but no, Windows claims that no HD exists.
*sigh* Windows XP has an irritating habit of "not seeing" SATA
controllers. :-P
Does anybody have any intelligent ideas for how I can convince this
laptop to start working again? Failing that, it shouldn't be hard to
copy the necessary files off of it... but I'm baffled as to why it's not
working.
Subject: Re: Random failure
Date: 14 Mar 2012 13:30:00
Message: <web.4f60d4ceeb23c53771cd8e0@news.povray.org>
> controllers. :-P
If it's SATA check if the controller runs in IDE or AHCI mode in the BIOS.
Date: 14 Mar 2012 17:39:01
Message: <4f610ff5$1@news.povray.org>
>> controllers. :-P
Yeah, I did think about that. AFAIK, Windows XP can't handle AHCI mode,
so I was wondering if it was originally set to IDE and somehow got
changed to AHCI... But no, apparently there isn't an option to change it.
Date: 15 Mar 2012 05:25:01
Message: <web.4f61b4bfeb23c53771cd8e0@news.povray.org>
> >> controllers. :-P
Did you try a BIOS reset?
Date: 15 Mar 2012 11:46:09
Message: <4f620ec1$1@news.povray.org>
> it's dead.
> words, the OS does not boot.
OK, so I took a disk image and put it onto a virtual machine. Now the
retarded Windows setup CD can actually access the drive. (The imaging
tool notes that the filesystem appears not to have been unmounted
cleanly. Oh goodie.)
Well, it turns out that if you fire up the recovery console and do
"fixmbr", then when you reboot you get the Windows loading screen...
followed by STOP 0x0000007B and a reboot before you can read the bloody
message. Fortunately, this is a /virtual/ machine. I just have to stab
the Print Screen button at the right moment. ;-)
(The "fixboot" option appears to have no effect at all. Only "fixmbr"
does anything. And it complains about a corrupted or non-standard MBR.
[It would be /really/ useful if it could decide which of those it is!]
The laptop does have two partitions, for reasons unknown. A giant NTFS
partition with the OS on it, and a tiny FAT32 partition also with some
kind of Windows-like files on it...)
Next plan: Install a new copy of Windows, in a few folder on the
existing Windows partition. When I do this, Windows becomes able to
boot. The old copy of Windows still shows in the boot menu, but
selecting it immediately provokes the message "cannot load
%systemroot%\system32\hal.dll - file is missing or corrupt". Which is
kinda serious. Again, it would be /really/ useful to know which it is -
whether it's actually gone, or just corrupted.
I swear to God that Windows NT had an option to replace core OS files
with the copies from the CD if they didn't match... I cannot find this
option anywhere in XP. *sigh*
Date: 15 Mar 2012 12:22:22
Message: <4f62173e@news.povray.org>
Well, the file definitely still exists. And it's about the same size as
the newly-installed copy. (Not /exactly/ the same size or date, but then
the version number on it is different as well...)
Ho hum. At this point, I guess I just grab the files and call it a day...
Date: 15 Mar 2012 19:22:23
Message: <4f6279af@news.povray.org>
On 3/15/2012 8:46, Invisible wrote:
> I swear to God that Windows NT had an option to replace core OS files with
> the copies from the CD if they didn't match... I cannot find this option
That's because they invented Windows Update.
That said, Win8 apparently has this feature.
   People tell me I am the counter-example.
Date: 16 Mar 2012 09:03:22
Message: <4f633a1a$1@news.povray.org>
>> it's dead.
Probably a recovery partition.  Make that one active and try booting off
of it.  You will probably be able to reformat and reinstall XP to its
original state (including out of date bloatware).  You may even be able
to back some of the data from the NTFS partition.
hal.dll?
The 9000 series is the most reliable computer ever made.  No 9000 has
ever made a mistake or distorted information.  We are in fact fool-proof
and incapabable of error.
Because copying an 8 year old file over a system that has probably been
patched every tuesday since then can not result in other problems
elsewhere...
You have access to the directory when you boot from this new copy of
Windows?  try and locate a new copy of this dll in the KB* or DLLCACHE
directories.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 16 Mar 2012 09:40:01
Message: <4f6342b1@news.povray.org>
Yeah, it's got a MININT folder in it with some plausible-looking files.
It's also got a whole bunch of stuff that looks utterly random.
As I say, in the end I just copied it all to a VM, where I can access it
any way I like. (Gotta love how VMware will only mount the /first/
partition on a disk though. Thanks for that, guys...)
> hal.dll?
Being incapable of error is one thing. Being FOOL PROOF is much, much
harder. You have literally no idea how dangerous fools can be. For real.
> elsewhere...
Oh, sure, it usually made the OS a little unstable. But it least it
would /boot/...
As it happens, I don't think that's even what the problem was. I'm still
baffled as to what "really" want wrong, but hey.
