Am 14.03.2012 17:07, schrieb Invisible:
>>> You seem to suggest that there's 16 bytes of overhead /per object/. I'm
>>> saying I'm used to there being a fixed number of bytes of overhead,
>>> regardless of the number of objects. That's O(N) vs O(1).
>> That's obviously impossible. The only way to achieve that would be
>> to allocate an array of objects (by value).
>> If you allocate individual objects, the allocator has to know where they
>> are and if those memory blocks are free or not. At least if the allocator
>> ever wants to reuse freed memory blocks.
> If you're using garbage collection, it's quite possible - and, indeed,
> usual. Each time the GC collects the garbage, it also defragments the
> free space. You therefore need only store a pointer to the next free
> byte of memory. To allocate, just increment this pointer by the size of
> the block allocated. Allocation is now O(1) in time and space.
So far, so good. But how does the GC know how long each chunk of
garbage-to-collect is?
The GC engine needs to know quite a bit about the objects it's scanning
- how big they are, where their pointer fields are, etc. It also usually
needs access to each thread's stack, to see what local variables are
pointing to objects. And so on and so forth. There's a /reason/ why it's
usually hard-coded into the language run-time system rather than being
an add-on library.
On 3/14/2012 9:14 AM, clipka wrote:
>> And btw, cyclic references are not the only problematic situation with
>> reference counting. There are cases where objects may be deleted too
>> early,
>> while there's still code using them.
> I can't think of any reason why that could possibly happen, provided
> that the reference counting is implemented in a thread-safe manner.
Imagine you've implemented a tree where each node is an object which has
a "delete" method that removes the node from the tree. If you're not
careful the node could end up removing all references-counted pointers
to itself (since "this" isn't reference counted) and be reclaimed while
still running its own delete method.
Am 14.03.2012 17:29, schrieb Invisible:
> an add-on library.
You didn't quite /exactly/ answer my question :-P
My point here being that without any per-object memory overhead in
addition to the raw data, you can't do any dynamic memory management at
all. Whether that overhead is accounted for in the language run-time or
an added library is quite irrelevant in that respect.
>> an add-on library.
OK. Well typically each object has some overhead that tells you which
class it belongs to. Typically the GC engine is going to go off that
information, so you're arguably not adding any additional cost there.
Typically each object just gets one pointer wider.
Whether a static allocator can match that or not is open to debate. In
particular, I'd imagine a static allocator might have O(N) cost per
/free block/, whereas a typical GC implementation doesn't need to track
free blocks at all...
Exactly how does the GC engine know how large a block of allocated
memory is? Where is this information stored? (You could get close to
this if all objects that the program ever allocated were forced to be
all of the same size. Of course that's unfeasible.)
Also, if objects are transparently movable in memory without breaking
the references pointing to them, that means that in addition to the
reference the actual raw memory address of the object has to also be
stored somewhere. Where is this information stored?
You can't avoid bookkeeping when you are allocating blocks of variable
size.
clipka <ano### [at] anonymous org> wrote:
> Am 14.03.2012 16:52, schrieb Warp:
> > clipka<ano### [at] anonymous org> wrote:
> >> While this is true, it is not a problem specific to reference counting,
> >> but one that is inherent in /any/ attempt at automatic object lifetime
> >> management.
> > It's not a problem for a garbage collector.
> Last time I heard, reference counting /is/ a garbage collection mechanism.
I think you know what I mean.
> > reference counting. There are cases where objects may be deleted too early,
Module A has a reference-counting smart pointer pointing to an object B.
A member function of that object B calls a function of module A. Said
function of A drops the reference to object B. Since it was the only
reference pointing to it, the object B gets deleted. When the function
in A ends, the execution returns to the member function of B, which now
operates on a deleted object. Undefined behavior ensues.
Yes, that *can* happen.
Am 14.03.2012 17:33, schrieb Kevin Wampler:
>>> early,
It is a problem only as long as you tie object destruction to reclaiming
of memory.
If the memory management is designed to /first/ call the destructor of
the "payload object", and only /afterwards/ decrement the reference
counter and release memory, then I don't see anything you'd have to fear
from this scenario.
Problems may arise of course if you try to implement the reference
counter management functionality in the "payload object" itself. Don't
do that - tie the ref counter management to a dedicated pointer type.
Am 14.03.2012 17:44, schrieb Invisible:
If a GC implementation doesn't track free blocks, how is it ever going
to re-allocate them to anything?
Am 14.03.2012 17:57, schrieb Warp:
Hm... you do have a point there.
> of memory.
I think I probably just explained it poorly, the example I was imagining
was pretty much identical to what Warp pointed out.
A naive implementation of that would be:
- Resolve the location of all used objects by looking for references
to those objects in the program data.
- The size of the objects can be resolved from the reference type and/or
a virtual table pointed by the objects themselves.
- Sort the addresses of the objects.
- Compact all the objects by moving them towards the beginning of the
heap so that no free space is left between them.
- Update the "free memory starts from here" pointer to the end of the
last object relocated this way.
(Of course an actual GC is much, much more complicated than that in
order to make it actually efficient.)
Am 14.03.2012 18:07, schrieb clipka:
>>>> early,
Then again, how would any other GC prevent this kind of thing happening?
As soon as A drops the reference to B, the latter isn't referenced
anymore, so if at this moment the GC happens to kick in you're still in
for trouble. Except that now your error is even more sporadic in nature
and therefore even more difficult to hunt down.
I learned it the hard way. Yes, it happened to me in an actual project,
and I didn't know of this problem before that.
Heh, me too. It was quite a perplexing error at first.
A GC keeps track of *all* the references that are pointing to an object,
including the 'this' pointer (or whatever the equivalent is in any given
language).
You could avoid this problem in a reference-counted scenario by
incrementing the reference count in the beginning of the function and
decrementing it when exiting the function, but that's burdensome and
makes member functions less efficient (especially if they are supposed
to be fast).
Am 14.03.2012 18:09, schrieb Warp:
Well, I wasn't actually considering approaches that would be
prohibitively inefficient :-P
Am 14.03.2012 18:16, schrieb Warp:
> language).
> to be fast).
But doesn't the "this-pointer tracking" in a reference-tracking GC
approach incur approximately that very same penalty?
Efficient GC algorithms are extremely complicated and I don't know in
detail how they work, but AFAIK they do not keep track of all references
all the time, but only periodically. That means that when a method is
called, it doesn't necessarily incur any penalty at all in terms of
memory management.
(This means that objects are not destroyed immediately when the last
reference to them disappears. Only when the GC algorithm determines at
some point that no reference exists to an object, will it mark to be
eventually removed.)
Invisible escreveu:
> On 14/03/2012 04:53 AM, clipka wrote:
>> Am 13.03.2012 21:37, schrieb Orchid Win7 v1:
>>> Wait - there are open-source Java libs now?
>>> (Last time I looked at Java, all anyone ever used it for was pointless
>>> Tic-Tac-Toe applets. Nobody ever wrote actual large applications with
>>> it, just small toy examples.)
>> You've never heard of Java enterprise application servers, have you?
> I've heard of them - but I have no idea what the hell they are. Last
> time I checked, "enterprise" refers either to NCC-1701-D, a galaxy-class
> starship of the United Federation of Planets, or to a piece of software
> which is pointlessly over-engineered, over-complex, over-priced, and
> sold by pushy over-paid salesmen in bad suits.
it's everywhere, Andrew. Kinda like electricity: you just notice it
when it goes down (and a huge call stack fills your browser).
a game sig: http://tinyurl.com/d3rxz9
Invisible escreveu:
> Backwards compatibility is pretty evil, eh? ;-)
haskell still to get its own historic warts... :)
That's actually how Haskell's GC works. :-P
(Or rather, it is if you select 1-space. The default is 2-space. In
other words, it allocates twice as much RAM as it actually needs. When
one half fills, it copies everything to the other half. More RAM, but
less processor time...)
Usually the object's class tells you that. You already have a vtable or
similar structure. (At least, you do in languages where /everything/ is
dynamically bound by default.)
Depends on the implementation.
Smalltalk does it by adding a layer of indirection. The address of every
object in the system is held in a giant "object table". All objects are
referred to be object IDs, which are merely indices into this table. To
move an object, merely update its object table entry. (You can also
store auxiliary information here - e.g., if you wanted to /lock/ the
object while it's being moved.)
How Haskell does it is to copy each object from its old location to its
new location, and then overwrite the old copy with a "hey, this is where
I moved this object to" reference. The GC engine then uses that to
update any references in other objects as it finds them.
> size.
Sure. At a minimum, you need to know the size of those blocks.
Realistically, you also need to know what they contain, or you can't
follow pointers. You probably need to know a little other stuff too.
Most of this information is per-class rather than per-object, however.
On 14/03/2012 19:47, nemesis wrote:
> Invisible escreveu:
Sadly, yes.
Although it /does/ have fewer than most languages. Then again, there's
less of it to start with, so I guess it would do.
On 14/03/2012 18:58, nemesis wrote:
> it's everywhere, Andrew. Kinda like electricity: you just notice it when
Do you want to know... what... it... is?
The Matrix is everywhere. It is all around us. Even here, in this very
room. You can... feel it. When you walk across the street. When you go
to church. When you pay your taxes.
(Wait, what were we talking about?)
The difference between enterprise software and other software is that
enterprise software is capable of being managed centrally. You can configure
it and maintain it and check its health while it's running, centrally,
without being there.
Do you get paged when your web server goes down? Can you configure how much
traffic has to dip before you get woken up at night? Can you get a list of
the people who are allowed to see a particular page? Can you track down
which ISP is at fault when the traffic to your site dips 20%? When serving
pages is slow, can you tell which part of the system is causing it? A bad
disk sector? A flakey network card?
People tell me I am the counter-example.
On 3/14/2012 8:03, Invisible wrote:
> Heh, really? Most languages I work with can allocate new objects in O(1)
> time and using O(1) memory for bookkeeping. I'm not used to dynamic
> allocation being anything to worry about.
Yeah, it's the *de*allocation that takes a while.
It's using basically the same kind of information that's already in each
object to point to a vtable. If the first word of each object points to a
vtable, you stick the information once in the vtable about how big it is and
where the pointers are.
This is also important for the "becomes" operator.
In Smalltalk, if you have an array X of size 10 that you now want to be size
20, you can do something essentialy like this:
y := a new array of size 20.
copy first ten elements of x into y.
x becomes y
That last statement swaps the variables x and y, so that all former
references to x now point to y and vice versa. It's how smalltalk does the
equivalent of std::vector without actually having a header object and a
content object.
I've nver seen any other language do that.
And I suspect if your language is sufficiently strongly typed, you could
figure out the classes of non-variant data without having to add information
to the instances.
On 3/14/2012 2:55, Invisible wrote:
> to know whether the libraries eventually settled down and they stopped doing
> crap like this, or... ?
Both those are deprecated now."
> to make it easy for people to write code for your platform and only your
> platform. >:-D
I didn't say they had a generous reason for doing it. But it's exactly that
reason for why 90% of OSS is either targetting programmers or sucks. Usually
both. That which doesn't is paid for by a large company trying to displace
proprietary software.
And your references have to be as big as your address space, approximately.
Smalltalk back in the 64K days used a 5-bit reference count. If you ever had
more than 30 references, it just wouldn't get collected until the mark/sweep
collector ran.
Because real GC engines count references on the stack. The very fact that A
is going to return to a member function of B is enough to keep it live.
On 3/14/2012 10:52, clipka wrote:
> But doesn't the "this-pointer tracking" in a reference-tracking GC approach
No, because it's not counting references. The efficiency of GC over RC is to
a large extent the elimination of updating something every time you assign a
pointer. The GC runs, sees a reference to B on the stack, and avoids
discarding B. C++ programs don't have access to the stack per se, so they
can't do that sort of thing.
On 3/14/2012 8:37, Invisible wrote:
> Um... So how is the pro version actually different from VS Express?
Some of them include a bunch of stuff you don't need if you're only working
by yourself, for example.
...but not as long as figuring out /what/ to deallocate. ;-)
The other fun thing is that few people have built concurrent GC engines.
At least with manual memory management, one thread doesn't usually block
other threads from running.
A concurrent compacting GC sounds to me like a very hard problem.
If the GC moves objects around in RAM, it has to make sure that no code
is modifying the object while the GC is moving it. How does it achieve
that efficiently, I have no idea.
Everybody seems to think they know how it could be done... and yet,
nobody has written the code that does it.
Well, Haskell currently does thinks like have a separate heap for each
processor core. But that doesn't guarantee there are no pointers from
one heap to another, so you still gotta be careful. What you would
probably do is "mark" each object somehow, before you go about moving
it. Trouble is, that adds the overhead of testing whether each object is
marked every single time you want to access any object...
I'm sure it can be implemented somehow. The question is how complicated
it would be, and how much overhead it would add.
Am 15.03.2012 15:42, schrieb Warp:
If the GC was part of the OS, maybe something could be done with page
faulting.
> faulting.
Indeed. Darren found a paper about this very idea a while back. Some
guys patched the Linux kernel to do interesting stuff in this direction.
And of course, if GC was in the OS, then you wouldn't have this
situation of "the GC engine for program X isn't actually using this RAM
right now, but because it's reserved it from the OS, the GC engine for
program Y can't use it"...
On 3/15/2012 2:09, Invisible wrote:
> least with manual memory management, one thread doesn't usually block other
You would be surprised at the number of implementations of malloc() and
free() that assume you're single-threaded and require locks.
Also, in a language that supports threads in the first place (like Erlang),
the heaps are per-thread, so that's OK.
On 3/15/2012 9:20, Invisible wrote:
> And of course, if GC was in the OS, then you wouldn't have this situation of
You also wouldn't need finalizers.
Yes.
You wind up dividing the heap into multiple zones, based on whether you've
scanned the object, compacted the object, or haven't looked at the object.
If someone tries to write to an object you've scanned and assign it a
pointer to an object you haven't scanned, then at that point you move the
object from the unscanned to the scanned region.
If you set it up so writes cause page faults in that situation, you can get
really good performance by just GCing one page worth of objects each time
you hit that fault, which is the paper Andrew refers to.
>> situation of
Yeah you would. The OS doesn't magically "know" that a specific object
is holding a specific external resource.
Care to give an example (in a modern OS)? At least Gnu libc uses locking
malloc() and free() (and it's one of the reasons for their slowness).
Quite many multithreaded programs would break if malloc() and free()
were not thread-safe.
>>> situation of
> Yeah you would. The OS doesn't magically "know" that a specific object is
If your OS is garbage-collected, it's not an "external" resource, now is it?
I think you just answered the question.
Maybe I phrased my statement wrong. Lots of implementations of malloc() and
free() share a heap amongst multiple threads, so either need to lock
internally or need to be used from a single-threaded system. And hence, they
assume you're single threaded within the context of malloc/free because
they've acquired a global lock. I.e., yes, you get contention between
threads with manual memory management.
> >>> situation of
I think that the idea was that RAM is not the only resource that an
object could own, and having to manually free such resource is error-prone
and going back to the days of C programming.
Right. In a GCed operating system, why would you own anything other than
GCed resources? You don't need file handles. You don't need IPC ports. You
don't need window handles. Etc. Look at Smalltalk - nothing had finalizers,
because it had its own OS. Or Hermes. Or Eros. (Eros and Hermes, for
example, treats all your disk space as just one big virtual memory address
space. There's no files. You just store data in your variables, and serve
them over IPC ports.)
About the only thing you'd need is some way of closing a socket when the
connection got GCed, in which case you could have a process that closes the
socket when its local IPC connections all get closed, and you just talk
through that process. That's basically how Erlang manages it.
> GCed resources?
I think you are talking about system resources. A program may use other
resources than simply system resources. If objects are never finalized,
how exactly are you going to free those resources? Manually?
Even then, sometimes even *memory* handling could require finalizers.
The quintessential example would be if you wanted to implement a
copy-on-write mechanism. In this case you need to "retain" and "release"
a reference counter each time an object takes hold of or drops a shared
block of memory. Without finalizers it becomes difficult.
You could have manual "retains" and "release" calls, but then we are
back to square one, ie. manual memory management, which is laborious and
error-prone, and hard to make exception-safe.
Like what?
That hasn't anything to do with finalizers. In advanced systems, that sort
of stuff isn't something you write in the application code, either, any more
than worrying about taking things out of the B-tree is something a SQL
programmer worries about when deleting a row.
And yes, at IBM, when they were working in NIL (the precursor to Hermes),
they ported a large and complex system from a single machine implementation
to run on a distributed hot-failover cluster changing nothing but the
compiler, just like you could with SQL code.
