POV-Ray : Newsgroups : povray.off-topic : Monitor sizes Server Time
16 Jun 2026 12:10:41 EDT (-0400)
  Monitor sizes (Message 61 to 70 of 70)
Subject: Re: Hardware sizes
Date: 11 Apr 2012 04:17:11
Message: <4f853e07$1@news.povray.org>
On 11/04/2012 02:05 AM, Darren New wrote:
> On 4/10/2012 8:54, Invisible wrote:
>> How about, uh, speed?
> Look at cars where speed above 70MPH actually matters. Like, say, race
> cars. They've gotten much faster.
Pfft. Every time the engineers find a way to make the cars faster, the
FIA finds a way to make them go slower again. :-P
Subject: Re: Monitor sizes
Date: 11 Apr 2012 04:18:01
Message: <4f853e39$1@news.povray.org>
On 11/04/2012 02:07 AM, Darren New wrote:
> On 4/10/2012 7:55, scott wrote:
>> text was all a bit blocky or blurry depending what setting you used.
> 300DPI is still a bit blocky and blurry on paper.
I still think you're insane. :-P
Date: 11 Apr 2012 04:24:12
Message: <4f853fac@news.povray.org>
Another important point when discussing resolution is what the source
data is you are trying to display.  If it's vector based then you can
decide each pixel value perfectly using a simple algorithm, however if
you're trying to scale a bitmap to display (eg from a webpage or camera
data) it's very hard to make it look as good as the vector based data,
no matter what AA algorithm you use.
Date: 11 Apr 2012 04:55:18
Message: <4f8546f6$1@news.povray.org>
http://en.wikipedia.org/wiki/List_of_fastest_production_cars
The problem with top speed is that it depends on the cube root of power,
so you need huge increases of power to get any significant top speed
improvements.
The bigger improvements have been in cornering speeds and braking
ability (both in racing cars and road cars).  If you look at videos of
old F1 races there are many corners where they used to brake and change
gear whereas in today's cars they just run flat out (Eau Rouge at Spa is
the classic one, or 130R at Suzuka).  Tyres, suspension and aerodynamics
have improved vastly to make such things possible.  Even in your road
car braking distances have vastly reduced due to tyre, suspension and
brake design (not ABS, that only really helps if you want to steer and
brake or it's wet).
Date: 11 Apr 2012 05:07:03
Message: <4f8549b2@news.povray.org>
scott <sco### [at] scottcom> wrote:
> The main problem is that Windows doesn't work nicely with higher
> resolutions.
  I think a bigger problem is that the amount of data that needs to be
transferred from the computer to the display becomes prohibitively large
as the resolution grows.
  There is, after all, a physical limit on how many bits of information
per second can be transferred through circuitry and cables.
Date: 11 Apr 2012 05:18:20
Message: <4f854c5c$1@news.povray.org>
On 11/04/2012 10:07 AM, Warp wrote:
>> resolutions.
I think the bigger problem is Windows. If that could be fixed and
resolutions started climbing, eventually what you're talking about would
become the next problem. But I don't think we're currently near that
limit yet.
Date: 11 Apr 2012 05:24:59
Message: <4f854deb$1@news.povray.org>
DisplayPort already allows up to 3840x2160x30bpp @ 60 Hz, so that should
be enough for a few years before they come up with something else (which
they surely will if there is demand for it).
Date: 12 Apr 2012 14:24:38
Message: <4f871de6@news.povray.org>
> improvements.
> have improved vastly to make such things possible. Even in your road car
> braking distances have vastly reduced due to tyre, suspension and brake
> design (not ABS, that only really helps if you want to steer and brake
> or it's wet).
ABS is very often bad. Most are all/nothing affairs taking only one
sample per wheel rotation that can jerk you around and make you loose
controll. In some cases, the brake pedal will shake and hit your foot
real hard, even to the point of causing some injuries...
A real good ABS must be progressive, take MANY samples per rotation,
gradualy reduce the breaking power as needed acording to the breaking
related torque and wheel load. In short, find the limit of adherance and
stay around it untill you stop.
Date: 13 Apr 2012 04:01:11
Message: <4f87dd47$1@news.povray.org>
That won't work, as once you get past the limit of adherence, gradually
reducing the braking power will not stop the wheel locking.  The
friction gets less, so you need less brake power to lock the wheel, it
gets slower so friction gets even less etc. it's in a positive feedback
loop condition.
Once you are past the limit, the best thing to do is to instantly reduce
the brake pressure completely, this will move the wheel back into the
region of higher friction as quickly as possible and you can then
reapply the brake pressure.  It may not seem intuitive though that
totally releasing the brake pressure will make you stop quicker in the
end, but consider that 99.9% of the time is probably spent below the
limit and only 0.1% above the limit with the brake pressure cut.
Of course the faster your system is the less noticeable the "pulsing" is
and the more you can stay around the limit, but a progressive or gradual
system is not the best way to do it, and would be much more expensive.
Date: 13 Apr 2012 04:33:07
Message: <4f87e4c3$1@news.povray.org>
One winter I was driving along. I forget why, but I pulled into a side
street, which turned out to have half an inch of solid ice coating it.
The ABS cut in when I tried to coast to a stop. It sure juddered my foot
around. (But then, it's a cheap car.) The car did stop, however. If only
they could make a way for the steering to also continue working. :-P
The only flaw I noticed was that once the car is moving slowly enough,
the wheels just lock, and won't unlock. (And by "slowly enough", I mean
"slow enough that you could walk up to the car and play curling with it.")
