POV-Ray : Newsgroups : povray.off-topic : Ancient history Server Time
17 Oct 2026 05:55:56 EDT (-0400)
  Ancient history (Message 1 to 28 of 28)
Subject: Ancient history
Date: 5 Mar 2012 06:26:39
Message: <4f54a2ef$1@news.povray.org>
Ooo, check this out:
http://tinyurl.com/67c4p8
Intel Pentium II? IBM harddisks? And a wiring job that looks like
something I'd have in my bedroom? Heh. How far they have come...
Subject: Re: Ancient history
Date: 5 Mar 2012 06:56:29
Message: <4f54a9ed$1@news.povray.org>
Cases are for <insert typical minority group here>, look at the
motherboards bending under the weight of the pair of hard disks.
No cases, flying motherboards everywhere, running threads and flying
nude switches and yet enough money to get a HP networking rack on top.
One hand looks very professional and clean solution, the other hand is
so DIY.
I guess it's like putting a home-made top case on a racing car, F1
style. With fancy stickers of flower on it.
Date: 5 Mar 2012 07:28:38
Message: <4f54b176$1@news.povray.org>
Uh, yeah. Last time I checked, HP equipment isn't cheap...
Date: 5 Mar 2012 13:47:41
Message: <4f550a4d@news.povray.org>
> Cases are for<insert typical minority group here>, look at the
> so DIY.
Who said only pairs of HDs? For all we know, and see, there could be 4
of them on each motherboards...
I agree, rack mounting normal motherboards is not the brightest idea.
Date: 5 Mar 2012 14:42:34
Message: <4f55172a$1@news.povray.org>
OTOH, it seems that any equipment that says "rack mountable" on it is
instantly 5x the price, for no apparent reason...
Date: 5 Mar 2012 15:34:42
Message: <4f552362@news.povray.org>
Le 05/03/2012 19:47, Alain nous fit lire :
Pay attention to the image. There is 2 motherboards per layer (visible,
back to back), each with its Pentium II, and a PCI Ethernet card (1
slot). Above the motherboards, there is 2 disks, one for each motherboard.
Now, given the number of switchs & leds, I wonder if there is not a
deeper set of motherboards (for a total of 4 or 5 per layer), or that
just some small powerunits.
There is only 2 memory slots filled out of the 3 available. The hard
disks are on the mezzanine on top of them. (well, it's a bit of
wood/cardboard
Date: 5 Mar 2012 19:53:44
Message: <4f556018$1@news.povray.org>
Of course, the engineering that goes in designing the special connectors
to power and manage these boards, as well as keep them ventilated comes
free of charge, in your world...
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 5 Mar 2012 21:48:22
Message: <4f557af6$1@news.povray.org>
Along with hot-pluggable redundancy in power supplies and in some cases
even the controllers plugged into the system (hot-plug PCI anyone?).
Jim
Date: 5 Mar 2012 22:17:11
Message: <4f5581b7@news.povray.org>
"Imagine a college freshman made out of gigabytes. This would be his dorm room."
   People tell me I am the counter-example.
Date: 6 Mar 2012 04:11:49
Message: <4f55d4d5$1@news.povray.org>
What "special connectors"?
Buy a UPS that sits under your desk. That's £50. Buy a UPS that is rack
mountable. That's £800, minimum. Sure, they probably don't sell rack UPS
with capacities as low as they do for the desktop. But 16x the price?
Really? For a battery and an inverter?
Buy a 12-port desktop switch. £30, maybe? Now buy a rack mountable one.
That'll be £200 please. Sure, it's physically bigger. There's more metal
in it. Metal costs money. But does it cost /that/ much money?
(Before anyone asks - no, just because it can be rack mounted, that does
/not/ mean it has management features. When I joined the company, we had
a whole rack full of switches, all rack mounted, none of them managed.
And all about £400 each.)
Redundant power supplies cost extra. RAID controllers cost extra.
Hot-swap drive bays cost extra. And yet, a server that has these costs
nowhere near as much as a rack-mount server. Now sure, making something
like a server actually small enough to be rack mounted is nontrivial.
There's a reason laptops cost 5x the price of a similar desktop. I
understand that. But for goodness' sake, if you make a /wire clamp/
that's rack mountable, suddenly it goes from being £2 to £80. It's like
it's a license to print money...
Date: 6 Mar 2012 08:48:15
Message: <4f56159f$1@news.povray.org>
I was talking more about "blade servers", since the original topic was
the Google servers, where each blade gets its power, remote management
and network connections from a central backplane.
but even if we are talking about a "desktop" PC case vs. a
rack-mountable server with a similar CPU.  The rackmountable server will
have a lot more consideration put into its ventilation and heat
disspation since it is made to be in a closed space full of other
heat-generating devices.  Secondly, rack-mounted servers usually come
with a lot of extra feautres not usually found on classical desktop
hardware, such as hot-swappable disks, power supplies, and in some
cases, memory and CPUs.
You need to realise that these things also contribute to the price of a
rack-mountable server.
It depends on the battery.  And besides, you are comparing apples and
bulldozers.
Maybe besides size there are other factors to consider...  Let's compare
a "home" unit, vs. a rackmountable unit of the same power rating and
same supplier.
"Home" UPS
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BE750G&total_watts=200
Output capacity: 450W/750VA.
Run time @400W: 3 min.
Run time @100W: 40 min.
Recharge time: 16 hrs.
Alarms: power/on battery/replace battery led display.
Management: N/A
Price: ~100$
"Rackmountable" UPS
Output capacity: 480W/750VA.
Run time @400W: 8 min.
Run time @100W: 50 min.
Recharge time: 4 hrs.
Alarms: Audible alarms when on battery/low battery/Replace battery
Management: vis DB-9, RS-232, SmartSlot or USB.  Network management card
optional.
Price: ~500$
So the rackmountable unit recharges 4x faster and has much better
management capabilities - I mean what good does a LED display do you in
an unattended server room? - for 5x the price.  Seems reasonable to me.
The "entry-level" rackmountable unit has a lot more to offer than the
"top-of-the-line" standalone unit, besides mounting brackets.
What's the MTBF of your 30$ desktop switch?   Does it have remote
management capabilities?  What about problem diagnostics?  How many
packets per second can it process?  Does it support vlans?  QoS?  PPPoE?
  802.1x authentication?  Etc...
Not manageABLE or simply not managed? Also [citation needed] brand and
model?
[citation needed] Brand and model?
Then make one and sell it for only £50 and drive the £80-clamp guy out
of business, if it's that easy.
Date: 6 Mar 2012 10:23:17
Message: <4f562be5$1@news.povray.org>
Oh, right.
Yes, those really /are/ expensive. If nothing else, each manufacturer's
blades only fit in their own blade centre. So once you have their blade
centre, they are the only people who can sell you blades. So they can
charge any arbitrary price they want.
When I joined the company, we had floor-standing servers with hot-swap
drives, dual redundant power supplies, a floor-standing UPS, and all the
rest. It still didn't cost anywhere near what a rack-mountable setup
would cost.
My original point was, /anything/ sold as rack mountable seems to
suddenly jump drastically in price, regardless of whether it's anything
special beyond having the necessary mounting points.
Heck, a USB keyboard costs, what, £2 maybe? Oh, but if you want a
keyboard draw for a rack? Suddenly it isn't £2 any more. More like £200.
Sure, the draw runners clearly cost money. Do they cost £198? I don't
think so.
> same supplier.
> "Home" UPS
> Management: N/A
> Price: ~100$
> "Rackmountable" UPS
> optional.
> Price: ~500$
I don't see why management facilities should cost 5x extra. If somebody
can make something as complex as a mobile phone and sell it for £10,
building something which closes a connection when a voltage goes below a
threshold can't be that damned expensive.
I don't know why there's such a massive difference in recharge time.
Since I don't know what's different about the second unit which allows
it to recharge so much faster, I can't say whether or not that justifies
the price difference.
Isn't MTBF an arbitrarily-chosen marketing number?
> Does it have remote management capabilities?
Unlikely. (Although not impossible, believe it or not.) But then, for
£200 your rack mount unit probably won't either.
Same statements as per management.
> model?
No management features. You just plug them in, turn them on, and they
work. (Once they finished learning MAC addresses, anyway...)
I don't recall the exact model off the top of my head. They were
definitely SMC "EZ switch", but I can't remember the precise model
numbers. A mixture of 12-port and 24-port units.
A cursory inspection of the nearest product catalogue indicates that the
starting price for a HP server is about £200, while the cheapest
possible rack-mountable unit is £400. Which, actually, isn't nearly as
bad as I'd expected. (I was thinking nearer £2,000. It /is/ HP, after all.)
It just seems that being rack-mountable is one of those "premium"
features that makes manufacturers instantly put the price up, just
because they can.
It's like printers with network cards. A network card costs, what,
£0.0016? And yet, a printer without one is £30 or something, but one
with it is £150. Presumably because they figure that your average home
user doesn't give a fig whether there's a network card, they just want
the cheapest one in the shop, but your average business user cannot
afford to do without one, and won't think twice about splashing a few
hundred pounds for something they actually need...
Date: 6 Mar 2012 11:45:00
Message: <web.4f563df0dde0759e3771cd8e0@news.povray.org>
You do know that a network card for a printer is actually a print server, right?
Regards
Aydan
Date: 6 Mar 2012 11:50:09
Message: <4f564041@news.povray.org>
You do know that a laser printer already has an entire computing
environment inside it running an embedded PostScript engine, right?
Adding an embedded TCP/IP stack can't be /that/ damned hard.
Also, explain this:
   Replacement network card for our printer £250.
   Replacement printer: £200.
How can the entire printer be /cheaper/ than just the network card?!
That makes no logical sense!
Date: 6 Mar 2012 12:20:00
Message: <web.4f56472edde0759e3771cd8e0@news.povray.org>
You were talking about a 30GBP printer.
You don't get a laser printer for 30 pounds.
Even if you do it's unlikely that the printer supports PostScript.
The cheapest postscript capable printer I could find on short notice is a
Lexmark E260 for 169 Euros.
Date: 6 Mar 2012 14:38:28
Message: <4f5667b4@news.povray.org>
Also, don't forget that most rack mountable components are hot swapable.
That account for some price increase.
Want to change that board holding those 4 old single core CPUs with one
holding 6 8 cores CPUs of the last generation? Disable the board, pull
it out, push in the new one, fire it and you are good to go.
Date: 6 Mar 2012 14:46:23
Message: <4f56698f@news.povray.org>
>> connectors to power and manage these boards, as well as keep them
>> ventilated comes free of charge, in your world...
Most server-class hardware also comes with a support contract with fast
turnaround.  Service is like insurance - expensive, and you hope you
never need to use it.
Jim
Date: 6 Mar 2012 16:10:26
Message: <4f567d42$1@news.povray.org>
> turnaround.
Yes, but you can perfectly well get tower servers with that too. So
comparing that to a rack-mount server would seem to nullify this point.
Yep - usually because when you /do/ need it, you find out it isn't very
good. ;-)
Date: 6 Mar 2012 16:18:46
Message: <4f567f36@news.povray.org>
>> turnaround.
I've never seen a tower server with hot-pluggable power supplies or hot-
pluggable PCI.  (Doesn't mean they don't exist, but I've yet to see one).
>> Service is like insurance - expensive, and you hope you never need to
>> use it.
> good. ;-)
That's also usually true. :)
Jim
Date: 6 Mar 2012 16:46:22
Message: <4f5685ae$1@news.povray.org>
>>> turnaround.
Our old server towers had hot-swap PSUs. In fact, one of the tests in
the disaster recovery plan verification procedure that I wrote was to
physically unplug one and make sure the server doesn't die. ;-)
No hot-swap PCI though; IIRC, it had ISA, not PCI.
>>> use it.
>> good. ;-)
Ah, you too have bitter experience, I see. :-)
Date: 6 Mar 2012 16:53:11
Message: <4f568747@news.povray.org>
>>>> fast turnaround.
>>> point.
>> hot- pluggable PCI.  (Doesn't mean they don't exist, but I've yet to
>> see one).
I'd buy that.
I had some of the first Proliant 6500 servers to come off the assembly
line - the hot plug PCI was a nice feature, but we never actually needed
to use it.
>>>> use it.
>>> very good. ;-)
Well, right now I don't have health coverage at all because I'm just
doing contract work.
But yeah, I've had situations where insurance coverage really didn't help
much.
I've also had experiences where support was less than stellar on hardware
and/or software. :)
Hard to work in this industry and not have that happen, sadly.
Jim
Date: 6 Mar 2012 17:00:42
Message: <4f56890a$1@news.povray.org>
>>>>> use it.
>>>> very good. ;-)
> much.
> and/or software. :)
Forget /this/ industry; just "industry". Tried getting warranty support
on your car? It doesn't fare much better.
It still amuses me that I just bought a new phone for £80 and they
offered to charge me £6/week for insurance. Or I could... just buy a new
phone? For a fraction of the cost? And no danger of the insurance not
covering it? Gee, let me think about that for a moment... :-P
Date: 6 Mar 2012 17:28:30
Message: <4f568f8e$1@news.povray.org>
>>>>>> to use it.
>>>>> very good. ;-)
>> help much.
>> hardware and/or software. :)
I've had good experience with my car - even now that the manufacturer
(Saturn) has gone belly-up.  Of course, the car is out of warranty now
(as a '99 model), but when it was under warranty, I never had a problem -
which is one reason why I bought two cars from them in succession.
The guys who do the work on it now used to run the dealer's service
center, so I still get the same level of service.  I'm really pleased
with that. :)
Yeah, that kind of 'extended warranty' is nothing but a scam.  I have
only once bought it, and it was as much a waste of money as I thought it
would be (I was buying a router to put alternative router firmware on and
thought I might brick it, so having the warranty seemed like a good
idea.  It wasn't - the reason I bought the router in question was because
it was very difficult to brick....)
Jim
Date: 7 Mar 2012 15:16:00
Message: <4f57c200$1@news.povray.org>
> Oh, right.
> would cost.
Of the same brand and model?  Last time I looked at server costs (over
10 years ago), the price difference between a Compaq Proliant 2500 with
feet and a compaq Proliant with mounting brackets was the price of the
mounting brackets.
> think so.
Are.
They.
The.
Same.
Brand.
And.
Model?
If not, your comparison is useless.
>> same supplier.
>> "Home" UPS
>> Management: N/A
>> Price: ~100$
>> "Rackmountable" UPS
>> optional.
>> Price: ~500$
Are you being willfully dense?  You don't understand why two different
types of batteries might be responsible for the price difference?
No.
Why not?  My $99 dollar Linksys router has remote management.
Same answer as above.
>> model?
They are probably not the exact same model as what you had, but the
SMC8505T is currently listed both on the standalone and the
rack-mountable sections of the SMC website.  Unless it's an error, I
suspect the price will be very similar...
On the other hand, the "smallest" SMC switch that actually looks like a
rackmountable is the SMCGS16, whic DOES have a lot of extra features
besides drill holes for mounting brackets.
Is the £200 server THE SAME as the £400 one, apart from the mounting
brackets?  If not, your comparison is flawed.
> because they can.
It couldn't possibly because the USB printer at £30 prints only 6 pages
per minute at 300dpi, while the networkable printer does twice as much
at twice the resolution, has two paper trays and does automatic
two-sided printing, can it?  No... It HAS to be because of the built-in nic.
Date: 8 Mar 2012 04:22:48
Message: <4f587a68$1@news.povray.org>
>> would cost.
No.
Generally manufacturers will make one model that's floor-standing, and
another, different model which is rack-mount. That makes it quite hard
to compare the same model in both configurations.
> Last time I looked at server costs (over 10
> mounting brackets.
And if that were the case, I'd have no complaints. My point is that this
seems emphatically /not/ to be the case. It seems more like rack
mounting is a "premium feature", and you have to pay a serious amount of
money for it.
That said, for a /server/ there is at least some justification; it's not
easy to fit all that stuff into such a small space. For other devices,
there's really no way to justify it.
>> think so.
> Are.
> They.
> The.
> Same.
> Brand.
> And.
> Model?
Since when do keyboards have "models"?
I'm saying, not knowing how the batteries are different, I can't say
whether or not that justifies the price difference. It might do, I don't
know.
Interesting... I haven't seen too many cheap devices that support this.
I would imagine these switches are long obsolete now. A few Google
searches turn up results such as
"The EZ Switches 10/100 (SMCFS1601/ SMCFS2401) are unmanaged,
rack-mountable 16-/24-port Fast Ethernet switches for workgroup and
small office environment."
which is probably what we had. Good luck figuring out what the original
sale price was.
>> all.)
No. The rack-mount is higher spec - that the difference is probably
enough to account for the difference in price.
Which would seem to suggest that the difference is that they don't
bother offering rack-mount for cheap hardware.
>> because they can.
Actually, the printer I'm thinking of prints at a /lower/ resolution
than most other inkjets. And it only has one tray and no duplex. I will
grant you, however, that it most certainly /does/ print very, very fast
for an inkjet.
Date: 8 Mar 2012 08:26:02
Message: <4f58b36a$1@news.povray.org>
Am 08.03.2012 10:22, schrieb Invisible:
>>> would cost.
> No.
>> mounting brackets.
> money for it.
And guess what - there happens to be a reason for this ;-)
You know, people who rack-mount things usually demand some features
(besides mounting brackets) the non-rack-mounting people just don't care
about. So why spend even $0.01 per unit in design and manufactoring
costs on optional rack-mounting capability for some piece of equipment
with a margin of less than $10.00 if this increases your sales by less
than 0.1%?
> know.
Obviously they're different in how fast you can charge them, no?
Exactly that. The added design and manufacturing costs - however low
they may be - simply don't pay off.
Date: 8 Mar 2012 09:01:42
Message: <4f58bbc6$1@news.povray.org>
>> money for it.
That's kind of what I'm asking about.
> about.
I fail to see why putting a £2 keyboard with some of its keys missing
into a slidy draw makes it worth £200, but OK.
>> know.
I meant what's physically different about the batteries that makes them
perform better.
If they work better because the electrodes are made of solid gold, then
yeah, that'll be why they're more expensive. :-P (Although... damn...
according to my chemistry, that shouldn't work AT ALL!) If they charge
faster because the charge management chip is different, then... there's
really no reason for a price hike.
Date: 9 Mar 2012 09:37:15
Message: <4f5a159b$1@news.povray.org>
>>> money for it.
>> about.
>>> know.
> perform better.
If only there was a way to get that information from the website I
linked in the previous post...
Replacement battery pack for the home unit:
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=RBC17
Replacement battery pack for the rackmountable unit:
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=RBC34L
The RBC34L is about 3 times as heavy than the RBC17 that should be your
first clue...  3 times the number of batteries = 3 times the price, no?
Secondly, the RBC34L is hot-swappable, that means additional circuitry,
and design that could very well account for the rest of the price
difference.
You also need to understand that they probably sell fewer rackmountable
units than they sell home units, therefore the production fixed costs
have to be recouped on a smaller number of units sold, also contributing
to higher prices.
It's possible that APC is screwing their corporate customers, but there
are quite a few perfectly valid reasons besides price-gouging to justify
the higher prices.
