POV-Ray : Newsgroups : povray.off-topic : Trouble with large directory in Linux Server Time
17 Oct 2026 05:53:17 EDT (-0400)
  Trouble with large directory in Linux (Message 1 to 14 of 14)
Subject: Trouble with large directory in Linux
Date: 28 Feb 2012 13:49:22
Message: <4f4d21b2@news.povray.org>
I have a directory which (I think) has many many small files in it.  I'd
like to remove these files, however every attempt I've tried fails.  For
example:
cd <dir>; rm *
rm -r <dir>
ls <dir>
find <dir>
All quickly consume my 8GB of memory and grind to an apparent halt.  I
haven't been able to even determine the name of a single file within
that directory, let alone delete anything.  Does anyone have any ideas?
Notes:
1) I'm assuming the problem is a large number of files, but as I can't
get any info about the contents of the directory I don't know for sure
if this is the case or it's some other problem.
1) This is on NFS, in case that matters.
2) I don't have root privileges.
Subject: Re: Trouble with large directory in Linux
Date: 28 Feb 2012 14:38:27
Message: <4f4d2d33$1@news.povray.org>
Le 28/02/2012 19:49, Kevin Wampler nous fit lire :
> example:
> cd <dir>; rm *
> rm -r <dir>
> ls <dir>
> find <dir>
do not have the shell expand * ;
> Notes:
What is the output of : ls -ld <dir>
(notice the d), in particular the size attribute
many many many files in a directory would lead to huge size.
Check also the rights on directory.
Also possible: drive is full, check the output of "df <dir>"
(rules of thumb: 5% of partition is reserved to root, unless tuned
otherwise explicitly with ext2/3/4. )
Yes, it means we cannot use the lovely unlink.
Of course not, root does not traverse NFS. (unless serving system is
changed (and you do not want that))
I wonder about :
 $ find <dir> -type f -exec rm {} \;
 $ rm -rf <dir>
(notice the f)
How is the network load when you tried to access that directory ?
Date: 28 Feb 2012 14:47:33
Message: <4f4d2f55@news.povray.org>
> example:
> cd <dir>; rm *
> rm -r <dir>
> ls <dir>
> find <dir>
  A webpage suggests this:
find <dir> -exec rm {} \;
  (I think that the idea is that this executes the 'rm' command individually
on each file as it traverses the directory, rather than first gathering all
the file names into RAM and then trying to do something to them.)
Date: 28 Feb 2012 15:01:12
Message: <4f4d3288$1@news.povray.org>
Alas (but thankfully) I just managed to delete all the files by
remembering the existence of and SSHing into a machine with 64GB of ram
before I read your reply.  I'll still try to respond to your questions
for curiosity's sake.
There was, however, some odd behavior that I'm curious about, even if
I've successfully deleted the files now.  On the 64GB ram machine I was
able to run 'find . -name "*.txt" | wc', which listed around 350K files.
  After running 'find . -name "*.txt" -delete' successfully, another run
of 'find . -name "*.txt" | wc' have 150K files (all *.txt files too!).
Repeating the process, the number of remaining files fluctuated up and
down a number of times before everything finally seemed to be removed.
This seems to be somewhat strange behavior to me.
> What is the output of : ls -ld<dir>
I obviously can't run this now, but if I remember the output of previous
df commands I think the dir was somewhere in the ballpark of 10GB.  Due
to the odd behavior mentioned above I'm not sure how many files ended up
being in the directory, except that it was probably between 350K and 1000K.
> Also possible: drive is full, check the output of "df<dir>"
This is one thing I did try, there was plenty of free space (about 50%
capacity).
> I wonder about :
>   $ find<dir>  -type f -exec rm {} \;
>   $ rm -rf<dir>
> (notice the f)
On the 8GB ram machine I tried a similar variant to the above find
command (using the -delete option), which ate through all my memory like
everything else.  I didn't try rm -rf though, since I figured it
wouldn't run faster than rm -r... perhaps I should have though.
Unfortunately this is one I can't answer.
Thanks for your help!  I will remember everything you suggested in case
something like this comes up again.
Date: 28 Feb 2012 15:01:25
Message: <4f4d3295$1@news.povray.org>
It's probably shell expansion of the wildcard, as others have indicated.
Break it down into smaller deletions.  For example:
rm a*
rm b*
rm c*
etc.
Or use one of the other suggested ideas.
Jim
Date: 28 Feb 2012 15:04:29
Message: <4f4d334d$1@news.povray.org>
> find<dir>  -exec rm {} \;
I saw that too, and tried some pretty similar things.  For whatever
reason I wasn't able to get find to do anything successful, and all
attempts met the same fate as other approaches.  Fortunately I
remembered that I had access to a machine with enough ram to actually
run find, and something like your suggestion did work.  I appreciate you
taking the time to look for an answer though.
Date: 28 Feb 2012 15:06:38
Message: <4f4d33ce$1@news.povray.org>
Also, I still don't know how I could have deleted things without SSHing
to the bigger machine, so if you have some ideas there I'd still be very
interested in hearing them.
Date: 28 Feb 2012 21:53:22
Message: <4f4d9322@news.povray.org>
For the future, just try "find <dir>" and see what you get. That should
print all the file names to the screen without having to actually load them
into memory. (The shell and ls both try to sort the list of files before
printing/using them, so that's part of your problem.)
Also, be aware that once the directory is empty, it may take several minutes
to rmdir it, because (depending on the underlying file system) it has to
read the entire directory before it will ack that the directory is
sufficiently empty to delete.
   People tell me I am the counter-example.
Date: 28 Feb 2012 22:30:38
Message: <4f4d9bde@news.povray.org>
> them into memory. (The shell and ls both try to sort the list of files
> before printing/using them, so that's part of your problem.)
I did try exactly this actually, it printed "." and nothing else before
it used up 8GB of ram, 15.5GB of swap, and ground to a halt.  It worked
on the 64GB ram computer though, which is basically how I managed to
delete the files.  If I did "find ." in the superdirectory by the way,
it successfully printed files as normal until it got the the problematic
subdirectory, at which point it ground to a halt just as before.
Date: 2 Mar 2012 00:42:10
Message: <4f505db2$1@news.povray.org>
Hmmm. There's a flag you can pass to find to turn off the optimization of
counting the number of links on "." and not recursing afterwards, or
something. I wonder if that would have helped. I wasn't aware find tried
loading things into memory, but maybe you wound up with a hard link to
itself in the directory (other than ".") or some such. I suspect file system
corruption.
Date: 2 Mar 2012 13:42:34
Message: <4f51149a$1@news.povray.org>
Le 02/03/2012 06:42, Darren New nous fit lire :
> of counting the number of links on "." and not recursing afterwards, or
> system corruption.
I'm more thinking about it: by default, it (ls) will try to sort the
filenames in alphabetical order... find the switch to disable that!
Date: 2 Mar 2012 22:10:40
Message: <4f518bb0$1@news.povray.org>
This is an excellent point, although I did at least check that find
wasn't trying to sort things when I ran it (it wasn't).  Totally forgot
that ls would do that though.
Date: 2 Mar 2012 22:12:57
Message: <4f518c39$1@news.povray.org>
> I suspect file system corruption.
This has been a worry of mine too, although everything else seems to be
fine, and deleting the files did eventually work.  I also am starting to
wonder if there's something with the particular Linux distro I was
using, since the more I think about it the more I feel that it ran a
little *too* well on the big machine, I'll poke around a bit more when I
get back from vacation and see if i can figure out anything else.
Date: 2 Mar 2012 23:50:24
Message: <4f51a310$1@news.povray.org>
That's why I sugested just "find . -print". "find" doesn't try to sort the
output. (glob sorts the output also.)
