POV-Ray : Newsgroups : povray.off-topic : The trouble with XSLT Server Time
17 Oct 2026 05:55:28 EDT (-0400)
  The trouble with XSLT (Message 1 to 50 of 84)
Goto Latest 50 Messages Next 34 Messages >>>
Subject: The trouble with XSLT
Date: 20 Feb 2012 11:21:03
Message: <4f4272ef@news.povray.org>
OK, so I've written a program that generates a bunch of XML as output.
If you open that in a web browser, it shows up as a simple parse tree.
Which is OK, but a little verbose.
Fortunately, using the wonders of XSL (specifically, XSLT) you can have
the browser transform the raw XML into a pretty-looking XHTML document.
But *only* if you edit the original XML file to mention the XSLT file
that you want to apply.
Now, it ought to be simple to write a 3-line file that says "take this
XML file and that XSLT file, and display the result". But after over a
week searching the Internet and even consulting Stack Overflow, I cannot
find any way of doing this. I literally cannot *believe* that something
so trivially simple is also so utterly impossible.
If there /is/ a way of doing this, every single XSL tutorial in
Christendom fails to mention it. No XSL FAQs mention it either - it's
not even that they say it can't be done, it's that none of them even
contain a question about this topic. This raises the alarming
possibility that what I'm trying to do might actually be impossible
after all. (Which is slightly daft, given that it's the entire point of
XSL existing in the first place...)
To be clear: It seems to be perfectly possible to apply any XSL to any
XML if you use an external 3rd-party tool. You just can't do it with a
*web browser*. You know, those programs that know about XML and XSL and
are installed on every computer in the world. No, you have to select and
download a special CLI utility if you want to perform such advanced
wizardry. *sigh*
My first thought: XSL lets you include one stylesheet inside another, so
maybe you can include one source document inside... erm, no. No you can't.
It looks like it /might/ be plausible to do something with the XSL
document() function - but I haven't figured out exactly how yet.
Apparently XML itself has a general include feature called XInclude.
According to Wikipedia, "Browser support: None". *facepalm* OK, so
that's really going to help then.
About the closest thing I've found is a website that says that if you
copy and paste a few miles of convoluted JavaScript code, you can make a
web page that runs the script which then loads the required XML in the
background, lots the XSL, applies one to the other, and inserts the
result into a specific position in the DOM of the current document. In
particular, it cannot /replace/ the current document, it can only be
/inserted into/ it. So if your XSL generates an entire XHTML document...
forget it.
(I presume it goes without saying that the first thing this code snippet
has to do is test whether it's running on Internet Explorer or a
standards compliant browser. :-P Some things never change...)
So it looks like I'm going to have to sit down and write a special tool
to take an XML file and copy it, inserting the correct XSL reference
into the header. How pathetic...
Subject: Re: The trouble with XSLT
Date: 20 Feb 2012 11:58:12
Message: <4f427ba4$1@news.povray.org>
Oh dear God...
https://bugzilla.mozilla.org/show_bug.cgi?id=98168
Short story: Using the xsl:text disable-output-escaping='yes' setting
doesn't work. It's supposed to allow you to output arbitrary text, and
it works with IE, but not with Firefox. And it appears they're trying to
claim it's IE that's broken, not Firefox. >_<
Date: 20 Feb 2012 12:13:54
Message: <4f427f52$1@news.povray.org>
Le 20/02/2012 17:21, Invisible nous fit lire :
XML failed to have include.
That's merely a shell-script:
1. find the closing of the first <?xml tag
2. insert your xsl tokens
3. copy verbatim the remaining document
4.
5. Profit.
Notice: some browser (including firefox), would:
 a. process differently a document from a http:// URL than a file:// URL
 b. not take into account XSL (as well as XSD and CSS, IIRC) not from
the same server as the original document (arguing about security!)
Date: 20 Feb 2012 12:43:44
Message: <4f428650@news.povray.org>
  I don't understand. This in an XML file seems to work just fine (at
least with Firefox):
<?xml version="1.0" encoding="UTF-8"?>
<?xml-stylesheet type='text/xsl' href='test.xsl'?>
(and then obviously you need a separate test.xsl file.)
  What exactly is the problem you are having?
  I don't know if it matters, but that test xsl file starts with:
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output method="html" indent="no"
  doctype-public="-//W3C//DTD HTML 4.01//EN"
  doctype-system="http://www.w3.org/TR/REC-html40/strict.dtd"
(if it makes any difference.)
Date: 20 Feb 2012 16:10:11
Message: <4f42b6b3$1@news.povray.org>
Le 20/02/2012 18:43, Warp nous fit lire :
I think I understand Invisible (ouch!):
Assume a file a.xml and another file showme_pretty.xsl
To have the browser display a.xml using showme_pretty.xsl, the a.xml
must contains the reference of showme_pretty.xsl;
There is no way to create a file a_in_pretty.xml that would
automatically combine a.xml & showme_pretty.xsl; a.xml must be copied
inside a_in_pretty.xml
Now imagine there is not ONE a.xml, but hundreds of them... Bummer!
Date: 21 Feb 2012 04:11:31
Message: <4f435fc3$1@news.povray.org>
> 1. find the closing of the first<?xml tag
> 4.
> 5. Profit.
How the heck do you do that from a shell script?
...oh, wait. You probably meant a /real/ shell, not CMD.EXE, right?
Date: 21 Feb 2012 04:16:55
Message: <4f436107$1@news.povray.org>
Sure, that works. But now suppose I have /more than one/ XSL file. In
order to select which one I want applied, I have to actually edit the
XML file.
I'd prefer to have the link between XML and XSL in a file external to
the XML file - but apparently that is impossible. (Unless you use an
external 3rd party XSL tool.)
Date: 21 Feb 2012 04:26:08
Message: <4f436330$1@news.povray.org>
Am 20.02.2012 17:58, schrieb Invisible:
> Oh dear God...
Actually both are standards compliant:
"An XSLT processor will only be able to disable output escaping if it
controls how the result tree is output. This may not always be the case.
For example, the result tree may be used as the source tree for another
XSLT transformation instead of being output. An XSLT processor is not
required to support disabling output escaping. If an xsl:value-of or
xsl:text specifies that output escaping should be disabled and the XSLT
processor does not support this, the XSLT processor may signal an error;
if it does not signal an error, it must recover by not disabling output
escaping."
IE behaves as mandated for a combo of an XSLT processor and an HTML
rendering engine.
Firefox behaves as expected (by the spec authors) for a combo of an XSLT
processor and a DOM tree rendering engine.
The spec concludes that "Since disabling output escaping may not work
with all XSLT processors and can result in XML that is not well-formed,
it should be used only when there is no alternative."
Date: 21 Feb 2012 04:36:42
Message: <4f4365aa$1@news.povray.org>
Am 20.02.2012 17:21, schrieb Invisible:
Why does this come as such a surprise to you?
Remember that the same thing is common practice for HTML and CSS as
well: If you want the HTML to be rendered using a particular style
sheet, you'll usually specify that in the HTML header.
I'm not sure whether all modern browsers support client-supplied CSS,
but I wouldn't be surprised if there were still some out there that
don't. For instance I have no idea how to choose a custom CSS in
Firefox; you can disable all CSS, or choose which of multiple
server-supplied CSS to use, but that seems to be about it.
Date: 21 Feb 2012 05:09:34
Message: <4f436d5e$1@news.povray.org>
>> Oh dear God...
Ah. So in fact, the W3C specification is broken, since /clearly/ a
system should not be specified to suddenly produce completely incorrect
output if an optional feature is not implemented.
*sigh*
Meanwhile, it looks like my only options are either to start memorising
Unicode code points by ID, or to save my XSL file as UTF-8 and watch the
encoding get screwed up every time I touch the file...
(Let's not even get into the question of why the standard character
names /only/ work in HTML, and not all SGML file types...)
Date: 21 Feb 2012 05:26:20
Message: <4f43714c@news.povray.org>
Well, what you say is of course true.
Then again, CSS just applies a few font settings to an HTML file. XSL
transforms one file into a totally different one. If every single time
you open that file you're always going to apply the same transformation,
you might as well just not bother keeping the original file, and only
store the transformed version. It completely defeats the whole purpose
of XSL.
Actually, no, that's not /completely/ true. If several files all use the
same XSL, then changing that one XSL file immediately changes /all/ of
the files that use it.
Even so, XSL is clearly crying out for the ability to apply more than
one XSL file to the same source file. And indeed you can trivially do
that - just not with a web browser, unfortunately.
I only recently discovered that Firefox even has a UI for changing the
CSS. ;-) (Or turning it off, for that matter.) I have no idea whether
you can supply your own CSS; isn't that an optional feature of the spec?
There's probably a way to do it, but there might not be a UI. (E.g.,
there may be something hidden in about:config somewhere.)
Date: 21 Feb 2012 08:44:05
Message: <4f439fa5$1@news.povray.org>
>> 4.
>> 5. Profit.
1. write the program that will do it using your favorite language
(*cough*Haskell*cough*) and name it BAR.EXE
2. FOR %FOO in (*.xml) DO TYPE %FOO | BAR > new%FOO
Assuming BAR.EXE reads from stdin and output to stdout, this will run it
against all the .xml files in the directory and create a second set
called new*.xml
Alternately, find Win32 versions of awk, sed, perl, or something like that.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 21 Feb 2012 08:58:22
Message: <4f43a2fe$1@news.povray.org>
and positioning, and size, and background image, and whether the object
shows up at all on a particular media, etc... but let's not let that get
in the way of a good argument.
> XSL
> of XSL.
You can override server-side CSS in Firefox by putting stuff in [your
profiledir]\Chrome\userContent.css.
Date: 21 Feb 2012 12:14:07
Message: <4f43d0df@news.povray.org>
> XML file.
  What do you expect? For the XML file to read your mind?
Date: 21 Feb 2012 14:25:28
Message: <4f43efa8@news.povray.org>
>> XML file.
No, I wanted to put that information into a separate file, that's all.
It's not a complex idea.
Date: 21 Feb 2012 15:40:07
Message: <4f440127@news.povray.org>
> >> XML file.
  Create an xml file that includes (using XInclude) the other XML file
you want as well as the xsl file?
Date: 21 Feb 2012 21:55:35
Message: <4f445927$1@news.povray.org>
Am 21.02.2012 11:09, schrieb Invisible:
That's why they warn about this possible difference, so that the user
can decide whether to (a) make sure that the XSLT file is only used with
an XSLT processor that supports the feature, or (b) make sure that the
output is not *completely* incorrect if the feature is unavailable.
That's not broken spec, that's just perfectly normal optional features.
Ah, so your /real/ problem is a crappy text editor.
Because they're a HTML-specific invention?
Date: 22 Feb 2012 04:04:13
Message: <4f44af8d$1@news.povray.org>
>>>> XML file.
That's a great idea. Except that apparently no browser supports XInclude
yet. As I pointed out in my original post.
Date: 22 Feb 2012 04:07:53
Message: <4f44b069@news.povray.org>
It's a broken spec, in that it provides no way to design a transform so
that if DEO is not implemented, the output still looks sane. There isn't
even a way to say "sorry, the required feature is not available".
Instead, it just prints random gibberish without telling you or giving
you any chance to correct it.
The /real/ problem is that there is no way of knowing what encoding a
given text file has. So it's not safe to use non-ASCII characters in a
text file. Which is why character entities were invented in the first
place...
Um, why?
It's not like only HTML could possibly need non-ASCII characters.
Date: 22 Feb 2012 15:42:12
Message: <4f455324@news.povray.org>
Am 22.02.2012 10:07, schrieb Invisible:
> place...
Use an editor that places a BOM at the start of UFT-8 files and bob's
your uncle.
Date: 22 Feb 2012 16:28:49
Message: <4f455e11$1@news.povray.org>
>> place...
> your uncle.
In other words, "there is this informal undocumented /convention/ that
if a file starts with a BOM [even though UTF-8 does not require such a
mark, since there /is/ no byte order], then it is presumed to contain
UTF-8".
I wonder how widely implemented this undocumented feature is?
Date: 22 Feb 2012 16:47:21
Message: <4f456269$1@news.povray.org>
Am 22.02.2012 22:28, schrieb Orchid Win7 v1:
>> your uncle.
> UTF-8".
Most likely more widespread than you think.
As an alternative, forget UTF-8 and go for UTF-16.
Date: 23 Feb 2012 04:11:08
Message: <4f4602ac$1@news.povray.org>
I got the distinct impression that this is a Windows-specific
convention. (Doesn't Linux do something strange with using environment
variables to define the "system locale"?)
Or that, I suppose.
This still leaves me with the problem of how to generate unusual
characters in the first place. Typing → is pretty simple. Figuring
out how to actually generate the arrow character is not.
Date: 23 Feb 2012 04:39:02
Message: <4f460936$1@news.povray.org>
You just need the right documentation.
Either you search it each time on the web (like "utf-8 chartable"... )
or you call it correctly, and ask for unicode (utf-8 is one
presentation, unicode is what you really want), and get to print the
parts that you need often.
See http://unicode.org/charts/
And soon you will discover that there is no single font to display all
possible unicode glyphs.
You also need a unicode-compatible editor...
Date: 23 Feb 2012 05:57:34
Message: <4f461b9e$1@news.povray.org>
>> characters in the first place. Typing→ is pretty simple. Figuring
Remembering to type → is much harder than remembering to type
→. It's also far less readable. Working out how to generate the
actual character so you can copy and paste it into your document is far
slower than just typing some stuff with your keyboard. (It involves
moving your hand to the mouse, for one thing...)
> and get to print the parts that you need often.
Well, yeah, I guess that's what it comes down to. Sadly.
Yeah, but nobody /needs/ all possible Unicode glyphs. I'm never going to
write stuff in Linear B or Ogham. I just hand a small handful of
non-ASCII characters - most of which /are/ widely supported in many fonts.
I've got that. The problem isn't the editor handling Unicode, it's
figuring out which encoding an arbitrary text file happens to use. It
seems as soon as you use any encoding other than the Windows default
(whatever the hell that is), things get messy, rapidly.
Date: 23 Feb 2012 06:53:15
Message: <4f4628ab$1@news.povray.org>
Le 23/02/2012 11:57, Invisible a écrit :
> It seems as soon as you use any encoding other than the Windows default
On Windows, yes. Even two Windows can be messy out of their natural
country (around Redmond I believe). (e.g. at work we have some English
windows and some french ones... they default to a different code page
(that's a thing back from DOS, a time where printers had micro-switchs
to provide different mapping not only to the 127-255 range but also
inside the 33-126 range... none of which usually maps exactly to the
local code page either)
Windows choose the UTF-16 way at a time (hence the wchar in API)... but
that's double the file's size of ascii... and yet, the integration is
far from done (many code still expect char of 8 bits..)
Maybe you can have some forked resources to tag the file as being a
given encoding (forked resources for a file are its filename followed by
colon and another text... it's usually invisible and yet remain
associated with the file (yet another kludge from the West of america...
the text names the resource, the value is in the associated "file"))
Maybe you can search the web about that ?
(and find a program which allow you to handle forked resources...)
As long as the file is in a NTFS filesystem, it's safe.
Date: 23 Feb 2012 06:55:55
Message: <4f46294b$1@news.povray.org>
Am 23.02.2012 10:11, schrieb Invisible:
 From the current XML spec:
"Entities encoded in UTF-16 MUST and entities encoded in UTF-8 MAY begin
with the Byte Order Mark described by Annex H of [ISO/IEC 10646:2000],
section 16.8 of [Unicode] (the ZERO WIDTH NO-BREAK SPACE character,
#xFEFF)."
As for this being supported by editors, there are two possible cases:
(1) The editor treats UTF-8 with a leading BOM as a special encoding; in
that case, it will strip the BOM from the character stream upon reading,
and prepend it upon writing, so you're perfectly safe here.
(2) The editor does not expect a leading BOM in UTF-8; in that case, it
/must/ treat it according to the Unicode standard, which explicitly
states that the BOM is actually a perfectly valid normal character,
which just happens to be one of the many space characters, non-breaking
in this case, with zero width; so you're perfectly safe here as well,
unless you accidently strip it from the very beginning of the file.
Date: 23 Feb 2012 07:13:03
Message: <4f462d4f$1@news.povray.org>
Am 23.02.2012 11:57, schrieb Invisible:
That's because figuring out the encoding of an extended-ASCII text file
is, in fact, virtually impossible (unless you know details about the
contents, e.g. you can recognize the encoding if you know that it's an
HTML file), due to the fact that none of them has a standardized file
signature. With the sole exception of UTF-8 with leading BOM, where the
BOM character can double-feature as such a signature.
A leading BOM in UTF-8 files can cause problems with files such as shell
scripts or C/C++ source code (because it is indeed a part of the
character stream rather than a mere file signature; strictly speaking
the same is actually true for UTF-16 as well); but at the beginning of
XML files it is explicitly allowed.
Date: 23 Feb 2012 07:23:42
Message: <4f462fce$1@news.povray.org>
Am 23.02.2012 12:53, schrieb Le_Forgeron:
Huh? I'd have expected French Windows to use Latin-1 as well. Wouldn't
be surprised about problems with the keyboard mapping though.
Unless you're talking about the command prompt, which may indeed still
use those old IBM codepages. (But the US-American IBM codepage and
Latin-1 differ as well, so the only advantage the Redmondians have over
you in this matter is that their native language doesn't need more than
95 printable characters in the first place.)
Date: 23 Feb 2012 08:54:15
Message: <4f464507@news.povray.org>
  Does that mean that xFEFF is the zero-width nbsp in both UTF-16 and UTF-8?
  Also: If the byte order happened to be the reverse of what the editor
expects (assuming the editor does not support the BOM), wouldn't the
multi-byte characters be garbage then?
Date: 23 Feb 2012 10:11:01
Message: <4f465705$1@news.povray.org>
Tsss... no cake for you.
0xFEFF is the UTF-16 encoding of BOM (Byte order mark). It is used to
signal endianess with UTF-16 (because 0xFFFE is not a valid utf-16,
indeed U+FFFE will never be a valid glyph).
Encoding U+FEFF in utf-8:
 * has no purpose, there is no endianess to detect for utf-8 encoding
(but it is legit to have a BOM in utf-8)
 * would be done as 3 bytes: 0xEF 0xBB 0xBF
BOM can also be useful when using UTF-32. (and other esoteric encoding
of unicode, such as utf-7, or utf-ebcdic, utf-1 (misnamed, IMHO), ... )
Notice that U+FEFF is deprecated as zero-width non breaking space.
You should use U+2060 (word joiner, zero width space non breaking),
and/or U+200B (zero width space, but breaking). At least in unicode 6.1
That's the reason utf-16/32 need a BOM for automatic detection.
Date: 23 Feb 2012 11:49:39
Message: <4f466e23$1@news.povray.org>
Am 23.02.2012 14:54, schrieb Warp:
If you're talking about codepoint, then obviously yes.
If you're talking about encoded byte sequence, then no; in UTF-16, it
would be encoded as xFE xFF or xFF xFE respectively, while in UTF-8 it
would always be encoded as xEF xBB xBF.
I would be surprised to find an editor supporting UTF-16 but not the
BOM. As for UTF-8, the byte order for multi-byte characters (i.e.
codepoints x0100 and above) is unambiguously defined by the standard
(using a big-endian-ish encoding); as UTF-8 requires bit shifting
anyway, a byte-reversed encoding would provide no benefit for
little-endian machines and therefore doesn't exist.
Date: 23 Feb 2012 11:55:51
Message: <4f466f97$1@news.povray.org>
Am 23.02.2012 17:49, schrieb clipka:
Strike "x0100", replace with "x0080".
Date: 23 Feb 2012 12:35:03
Message: <4f4678c5@news.povray.org>
  UTF-16 is more compact if the text consists mostly of non-ascii
characters, especially if it contains eg. kanji symbols, hiragana, etc.
(The vast majority of Japanese kanji can be expressed with 2 bytes using
UTF-16 but require 3 bytes with UTF-8.)
  However, if the text consists mostly of ascii characters, such as
English usually does, then UTF-8 is more compact than UTF-16 (which will
basically double the size of the file).
  Support for UTF-16 is still relatively poor (although getting better).
Most modern browsers should handle it ok, though, but it requires for the
server to send the proper http header to tell the browser the encoding,
and configuring the server to do this might not be trivial. (A html file
encoded in UTF-16 will look like garbage.)
Subject: Re: The trouble with XML
Date: 23 Feb 2012 13:04:28
Message: <4f467fac@news.povray.org>
The trouble with the whole xml thing is that it's just another
enterprisey BS to grind CPUs idle times.  You need an xml document, an
xml document describing the structure of the previous document, yet
another xml document to describe how to style the original document
itens, perhaps a xml document describing how to transform your xml
document into another xml document.  It's an insanely verbose and
homogeneous pile of human and machine barely readable crap.
People resented it and thus insist on saner formats, such as CSS, JSON
and real programming languages rather than a shitload of xml abstraction
layers, tools and java frameworks.
Date: 23 Feb 2012 13:19:50
Message: <4f468346$1@news.povray.org>
Am 23.02.2012 18:35, schrieb Warp:
I guess a factor 2 in text stream size is not a serious problem with
today's internet bandwidths.
It didn't sound like Andy would want to retrieve the XML file from a web
server, but rather directly from the local file system. Otherwise he
could simply go for server-side XSLT processing.
Date: 23 Feb 2012 13:37:20
Message: <4f468760$1@news.povray.org>
Am 23.02.2012 19:04, schrieb nemesis:
Businesses do use it quite a lot for data exchange.
But yes, XML as a mere replacement for HTML is a rather silly thing
(except in its incarnation as XHTML); its legitimate ecologic niche on
the web is on the server side (if anywhere), and its native habitat is
actually totally somewhere else.
In some sense, XML is today's CSV: A generic file or data stream format
a human /can/ create, read and/or modify with an ASCII text editor, but
that still follows certain clear-cut rules that it can also be evaluated
by software; and actually just a meta-format, in the sense that the
content of the individual data fields needs to be agreed upon separately.
Date: 23 Feb 2012 14:06:27
Message: <4f468e32@news.povray.org>
  It's verbose, but it has one advantage over most other formats: It's
standardized and pretty well supported.
  It has many advantages over many other formats. One example is character
encoding. With all types of character encodings out there, and support
for them in different file formats and programs being what they are, a
*standardized* form for representing special characters can be really
useful. Also, any program that reads XML ought to support it regardless
of which character encoding it uses (at least if the program uses a
generic XML parser internally).
  Compare this to, for example, just a simple raw .txt file. Which encoding
does it use? ISO-Latin-1? ISO-Latin-9? UTF-8? Shift JIS? EUC-JP? ISO-2022-JP?
Something else completely? Impossible to say. With an XML file you don't have
to care. (As said, if your program uses a generic XML parser, the character
encoding used in the input XML file becomes a non-issue.)
  Not that this exact same thing wouldn't be possible with a less verbose
format, but as said, XML is widely supported so it has this implicit
Date: 23 Feb 2012 15:08:11
Message: <4f469cab@news.povray.org>
Le 23/02/2012 20:06, Warp nous fit lire :
Well, XML is a container. The problem is lack of intelligent design for
the inside. It is too often the Excel sheet of today: A bunch of
entries, without consistency.
Indeed, with a bit of base64 encapsulation, you could put an BINARY
excel sheet file into a XML document. And advertise that you output XML.
And to make matter more interesting, some find it enterprisey to have
xml inside xml... and other old CSV into XML too (without reinterpreting
the data, so it's just a formatting. A dumb formatting).
Read it, yes. Understand it, that's another whole story!
Same as: I can read latin or japanese in katakana, with few error on
sound. That does not means I get the meaning. At least I can edit it
like a monkey.
XML is interesting when exchanging documents/data, once the big bosses
and their technical staffs have agreed on a XSD. But whenever you add a
third company, you need to negociate another XSD (with a totally
different approach of the data, not even compatible with the first one).
Date: 23 Feb 2012 16:14:21
Message: <4f46ac2d@news.povray.org>
Isn't that what the HTML encoding tag is for? Or the XML encoding
declaration?
Date: 23 Feb 2012 20:49:10
Message: <4f46ec96$1@news.povray.org>
Am 23.02.2012 22:14, schrieb Orchid Win7 v1:
> declaration?
You can't read those until you know at least some basics about the
encoding :-P
That's /one/ reason why XML requires UTF-16 files to start with a byte
order mark: If the file starts with "FE FF" or "FF FE", it's either
UTF-16, malformed XML (not starting with optional whitespace followed by
"<?"), or indeed garbish, so UTF-16 is a safe bet in that case.
Otherwise rely on the file format being backward compatible with ASCII,
and treat it as UTF-8 (which is ASCII-compatible as well) until an
encoding declaration tells you otherwise.
Date: 23 Feb 2012 22:43:51
Message: <4f470777@news.povray.org>
It also has an advantage in that it's a *markup language*. That's what it's
for. Just as it sucks for passing around arrays of floats or passing pov-ray
data objects between clusters of renderers or encoding routing table
updates, it does pretty darn good at things like writing help pages, user
manuals, and so on.
Bitching that XML is poorly suited for something it was never designed to do
is just pointless.
It's only verbose if you're not using it to pass around human-readable prose.
   People tell me I am the counter-example.
Date: 24 Feb 2012 04:02:15
Message: <4f475217$1@news.povray.org>
>> declaration?
> encoding :-P
Yeah. Isn't that fun? :-D
Date: 24 Feb 2012 04:10:09
Message: <4f4753f1$1@news.povray.org>
Well, it was that or JSON.
In my case, XML has XSLT. JSON does not possess anything comparable.
What that means is that just by outputting my data as XML, I can easily
transform it into something usable later. And I don't have to implement
the transformation engine myself - just the actual transformation rules.
(Which is still pretty non-trivial, mind you.)
(The other possibility is the unspeakably awful YAML...)
Some people /do/ use XML in some pretty inappropriate ways. (E.g., "if
we store all our data as XML, we won't have to ask the DB admin to
change the DB schema for us, and we can just run all the queries on the
client-side instead".) Just because people do stupid things with XML,
does not mean that XML is stupid.
That said, it /does/ seem overly complicated for the simple problem it's
supposed to solve...
Date: 24 Feb 2012 07:09:45
Message: <4f477e09@news.povray.org>
  OTOH, it would be quite trivial to guess that a HTML/XML file is
UTF-16-encoded: If each other byte is 0 and each other form valid
HTML/XML (at least up to the header section that specifies the encoding),
then it's a safe bet that it's UTF16-encoded.
Date: 24 Feb 2012 09:40:40
Message: <4f47a168$1@news.povray.org>
Darren New escreveu:
> it's for. Just as it sucks for passing around arrays of floats or
> passing pov-ray data objects between clusters of renderers or encoding
> routing table updates, it does pretty darn good at things like writing
> help pages, user manuals, and so on.
> to do is just pointless.
Precisely so, like implementing validators or transformers for xml docs.
  How recursive and verbose you can get?  "Hey, Darren, have you already
wrote that xml document to validate the xml document validator that
validates our client xml document?"
I can't actually believe a typeful haskell supporter (I'm looking at
Orchid) is here advocating an xml document rather than writing a typeful
haskell program to validate data marshalling.
Date: 25 Feb 2012 01:04:12
Message: <4f4879dc$1@news.povray.org>
What simple problem do you think it was supposed to solve?
Date: 25 Feb 2012 05:37:21
Message: <4f48b9e1@news.povray.org>
The problem of marking up textual data.
A lot of people seem to think that if you just write some stuff in angle
brackets, that's XML. But it' actually far more complicated than that.
(As an aside, those aren't angle brackets. They're inequality signs. :-P
But I digress...)
For example, to say "this XML file actually contains XHTML", you're
supposed to add something like 5 separate headers, each about 25 million
miles long, to the top of the file. Why? Would one header not be sufficient?
Then there's all that stupidity with character entities. It should be
possible to include character entities in /all/ XML documents, not just
XHTML. But to this day, I have never discovered a way of doing this.
One of the nice ideas of XML is that you can use namespaces to include
one sort of XML document inside enought - e.g., you could put an SVG
file inside an XHTML file. But nooo, apparently you need a specialised
DTD to do that. In fact, you need one DTD for XHTML + SVG, another,
different DTD for XHTML + MathML, a third, different DTD for XHTML +
MathML + SVG, and... ARE YOU PEOPLE INSANE?!
In short, most people just end up sticking stuff in angle brackets and
calling that XML. /Actual/ XML is far too complicated.
Date: 25 Feb 2012 19:35:48
Message: <4f497e64@news.povray.org>
On 2/25/2012 2:37, Orchid Win7 v1 wrote:
> For example, to say "this XML file actually contains XHTML", you're supposed
> to add something like 5 separate headers, each about 25 million miles long,
Really? What do you have to add? I suspect you exaggerate a bit.
You have to declare the entities. Otherwise, you run across &frump; and
don't know what it means. That's what DTDs are for.
> One of the nice ideas of XML is that you can use namespaces to include one
> sort of XML document inside enought - e.g., you could put an SVG file inside
> an XHTML file. But nooo, apparently you need a specialised DTD to do that.
You can. Of course, your various processors have to know what the various
namespaces *mean*, so you have to declare them and you have to have a
processor that understands them (which is where the DTDs come in).
Date: 27 Feb 2012 04:15:06
Message: <4f4b499a$1@news.povray.org>
>> supposed
>> long,
First, you must say
<?xml version="1.0" encoding="ISO-8859-1" ?>
Which is fair enough, although the 5-digit ISO code number isn't exactly
easy to remember. Then you have to say
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
Yeah, I'm really going to remember that without looking it up. :-P No,
you can't just say "this is XHTML". You really do have to write all that
crap. And after /that/, you still have to say
<html xmlns="http://www.w3.org/1999/xhtml">
Um, didn't I just declare this as XHTML already? At least this URL is a
bit shorter, I guess...
In short, that's a /hell/ of a lot of typing, before I've even written
my document. It's also a lot of typing that I have to go look up on
three different websites every single damned time I want to write XHTML.
So why isn't there a DTD somewhere that contains all the entities that
everybody uses, which I can just link to? More to the point, since
everybody uses the same set of entities, why aren't they built in?
>> one
>> inside
>> that.
> various namespaces *mean*, so you have to declare them and you have to
> have a processor that understands them (which is where the DTDs come in).
You would /think/ you could just say "hey, this stuff here is in the
XHTML namespace, this stuff here is in the SVG namespace", and that
would work. But it doesn't. You need to use a DTD specially written for
the exact combination of XHTML+SVG. To me, this indicates that the
system is fundamentally broken. It should not be necessary to write a
separate DTD for every possible combination of XML documents imaginable.
You should just be able to refer to the DTD for XHTML and the DTD for
SVG and have it work.
