POV-Ray : Newsgroups : povray.off-topic : Another day of failure Server Time
17 Oct 2026 05:56:08 EDT (-0400)
  Another day of failure (Message 1 to 50 of 59)
Goto Latest 50 Messages Next 9 Messages >>>
Subject: Another day of failure
Date: 14 Feb 2012 10:20:56
Message: <4f3a7bd8$1@news.povray.org>
OK, so I knew I was unfit. But by the time I go pick my car up, I will
have travelled approximately 8 miles on foot today. Turns out I'm not
unfit - I am a fat useless sack of **** who probably doesn't deserve to
live. >_<
First I drove my car to the garage, and then I walked home. Apparently
that's about 1.25 miles. (According to the wibbly wobbly line I drew in
Google Earth anyway.) Then I wanted to go visit a friend, but she said
she was going out shortly. I attempted to jog over there - yeah, that
didn't happen. I /was/ fairly wet by the time I arrived though (bearing
in mind that it's currently +3°C outside). And then I walked home again.
Apparently the trip is about 2.75 miles each way.
My legs hurt now. To be fair, I think it was probably the jogging that
did that. The impact of hitting the ground did feel fairly extreme.
(Sure, I jump around all the time at dance class, but that's on a sprung
dance floor, not a concrete footpath.) So yeah, I may have slightly
strained the tendons. I'm sure it'll stop hurting in a while.
Of course, while I was actually walking, it was the front of my legs
that hurt. That wore off after a few minutes of sitting down. Now only
the backs of my legs hurt.
Subject: Re: Another day of failure
Date: 14 Feb 2012 10:48:54
Message: <4f3a8266$1@news.povray.org>
Safety of your knees : no jogging once you are past 80 kg. No athletic
running either.
Reduce your weight first, then you could jump.
Dancing is ok, you do not hurt the knee so much with brutal impact: one
foot is usually kept on the floor all time when dancing.
Date: 15 Feb 2012 06:42:06
Message: <4f3b9a0e$1@news.povray.org>
> running either.
I used to be 80 Kg.
4 years ago. :'{
It's an amusing coincidence that my weight gain just happens to coincide
with my starting dance classes...
Date: 15 Feb 2012 08:00:28
Message: <4f3bac6c$1@news.povray.org>
Nope, muscles are more dense than fat.
If you exercise, you gain weight.
Dance is a real physical exhaustion.
At best, you can expect a loss of circumference between torso and legs,
not a loss of weight. At least not in the first stage.
Once a part of fat has been replaced by muscle in your volume, you can
reduce your weight either:
 * stop the exercise : the muscles will disappear first and very easily
(and the skin will be flappy)
 * continue the exercise with a constant diet: if the diet is a bit
under the need, the fat will be consumed. If the diet is far under the
need, the body will "remember" and at all next occasion will store far
more fat (you loose).
Date: 15 Feb 2012 08:08:17
Message: <4f3bae41$1@news.povray.org>
Hah! As if there's any muscle on me...
More like, I started dancing just around the time I turned 30, when my
waistline suddenly began massively enlarging.
I'm fairly sure dancing doesn't give you a huge gut.
Hell yes! >_< I literally do not have the stamina for this... :-(
Date: 15 Feb 2012 08:38:02
Message: <4f3bb53a$1@news.povray.org>
Once again, confusion between weight & volume!
"Huge" apply to volume.
What is heavier: a litre of gold or ten litre of water ?
Which one take more place ?
Same happen for muscle / fat.
1. You can be heavy & big. (muscle+fat or just lot of fat)
2. You can be heavy & smaller. (muscle but no fat)
3. You can be light & big (fat but no muscle)
4. You can be light & smaller (less fat, still no muscle: only bones & skin)
Typical #4 is anorexic girl (an apple is 4 complete meals! May be I can
save the pips for some extra)
#3 is often sedentary people.
#2 is marathon runner and the like.
#1 is yo mama and Mick Tyson.
(no offence intended to either, I need my life)
You should measure your "health" with a ribbon meter, not a weighting
scale. It's the small/big part which influence most behaviour, not the
heavy/light.
Date: 15 Feb 2012 09:23:08
Message: <4f3bbfcc@news.povray.org>
> heavy/light.
Well, I don't know about a tape measure, but around the time I started
dancing, all my trousers stopped fitting any more. :-(
Date: 15 Feb 2012 15:02:52
Message: <4f3c0f6c$1@news.povray.org>
On 2012-02-15 05:42, Invisible wrote:
> I used to be 80 Kg.
...but then I took an arrow in my knee.
Date: 15 Feb 2012 16:09:32
Message: <4f3c1f0c$1@news.povray.org>
>> I used to be 80 Kg.
What the hell does that even *mean*?!
Date: 15 Feb 2012 16:12:43
Message: <4f3c1fcb$1@news.povray.org>
>>> I used to be 80 Kg.
http://knowyourmeme.com/memes/i-took-an-arrow-in-the-knee
Date: 16 Feb 2012 13:59:47
Message: <4f3d5223$1@news.povray.org>
Suddenly it makes /so much/ more sense...
http://www.cad-comic.com/cad/20111209
Also: Due to a brain malfunction, every time I see "Skyrim" I read it as
"scrim". (Similarly, normally => tourmaline.)
Date: 17 Feb 2012 10:37:49
Message: <4f3e744d$1@news.povray.org>
That sounds reasonable from what you describe your normal activity to
be.  You just used a lot of muscle groups in ways that you don't
normally use them.
Expect to be sore and in some pain if you have not been jogging and then
you try to do 5 miles.  Do pay attention to what may just be muscle
soreness and what may be actual injury forming.
But the best part is that if you take a couple of days off from running
and then do it again you will eventually feel better and not be in so
much pain.
A good pair of running shoes can help lessen the impact and pain.  If
you want to run regularly then you should reserve your running shoes for
just that - running and not wear them for just going out.
Also, running on concrete can be pretty hard on the body - running on
asphalt can make a big difference.
Tom
Date: 25 Feb 2012 11:05:00
Message: <web.4f49064d3265ef95343b23870@news.povray.org>
Orchid Win7 v1 <voi### [at] devnull> wrote:
Walking only burns a few hundred calories an hour. You need to burn (and not
replace) about 3500 calories (more than a days worth) to lose one pound of fat.
To make matters worse, you can't do any of this too quickly or your body will
rebel against you. Walking won't increase your bmr. Eat a piece of pie and all
of your suffering will have been for nothing.
Get in shape as I described in the fitness thread. Learn about tabata. Do
push-ups. Start counting calories.
ALSO:
Wow! Things are different over there. I weight over 90 kg, and I'm considered
trim in Texas.
Date: 25 Feb 2012 13:30:29
Message: <4f4928c5@news.povray.org>
  Leisure walking might not, but vigorous walking certainly will. It's
almost as efficient as jogging, but much more suitable for an unfit
person.
Date: 25 Feb 2012 16:35:20
Message: <4f495418$1@news.povray.org>
Yeah, I wasn't actually attempting to lose weight. I just didn't have a
car and needed to go places. I'm actually surprised I managed it without
dying, to be honest.
As I say, at school we went on a 5 mile walk, and it took about 8 hours.
That gives an average walking speed of about just over 1 MPH. At that
speed, walking 4 miles should have taken almost 4 hours...
> ALSO:
> trim in Texas.
I used to be 80 Kg. Now I'm 90. :-{ Isn't that the best part about old
age? Now all I have to look forward to in life is progressively getting
worse...
Date: 25 Feb 2012 22:11:20
Message: <4f49a2d8$1@news.povray.org>
Uh, worse news. Turns out, when you do burn them, your body responds by
converting you "speed" muscle to "strength" muscle, which is roughly 10%
more efficient, so to "keep burning" those 3500 calories, you have to
drastically increase how much time, and work, you apply to doing so, to
keep off the original loss. In effect, once you have it, its harder to
keep it off again, than if you never had it.
Also. A thing about BMI. The man that invented it stated, clearly, "This
is not intended to be a metric of health." It became such via comity,
not via science. In reality, it cannot tell you if you are healthy, your
organs are functioning, or you will end up suffering diseases, as a
result of your weight. Its nonsense, but it is nonsense that can be used
to sell you expensive "fixes" for the same nonsense, like new diet pills.
https://www.youtube.com/watch?v=GlXxoG98urc&list=UUJm5yR1KFcysl_0I3x-iReg&index=5&feature=plcp
Date: 27 Feb 2012 10:17:05
Message: <4f4b9e71$1@news.povray.org>
Absolutely! Andrew should forget about his BMI and worry about his BMR.
Walking is good exercise. So are the bike riding, running, weight
lifting, hammer swinging, ladder climbing, kettle bell work, and
calisthenics that I do. But I wouldn't recommend any of these to Andrew
because none are the shortest path to what he wants.
 -Shay
Date: 28 Feb 2012 04:43:15
Message: <4f4ca1b3$1@news.povray.org>
>   -Shay
Interesting note. A study done a while back showed that merely knowing
how much you burned, somehow, may result in increased loss. The study
was conducted with two groups working basically identical jobs, under
basically identical conditions, where the only apparent difference was
that one group had a chart to consult, telling them how much they
burned, for every single thing they did during the day, while the other
didn't.
Still.. I seem to remember that they was someone looking into trying
to.. retrain their body for "fast" action, like sprinting. One major
improvement in BMR would literally be to trigger such a change, since if
you could get your muscles to re-organize for speed, it would drop their
efficiency 10%+, and thus burn that much more energy, during the same
duration of exercise. Not sure if this is possible though.
Unfortunately, pretty much *all* types of exercise used to drop weight
does the exact opposite, triggering an "increase" in efficiency, and
making it harder to lose/keep off the weight.
Date: 28 Feb 2012 07:59:07
Message: <4f4ccf9b@news.povray.org>
Sounds like something similar to the placebo effect. (Note: The placebo
effect is /not/ imaginary. It is real. It can be measured.) It's no
secret that both happiness and stress release a whole host of hormones
which make various organs function differently - so it's hardly
implausible that knowing how well your exercise is going could affect
how well your exercise goes.
Date: 28 Feb 2012 21:49:17
Message: <4f4d922d$1@news.povray.org>
It's also the case that your metabolism is regulated based on how much food
is available, how likely you are to be eaten by a tiger, etc. I've seen
studies where people imagined being in danger and (over time) lost weight,
and the doctors doing the study figured it was because your mind was
preparing you to run away.
   People tell me I am the counter-example.
Date: 28 Feb 2012 21:52:23
Message: <4f4d92e7$1@news.povray.org>
To optimise your muscles for speed, you need low load, repetitive,
sustained and fast exercises.
Doing the classic biscep building routine WITHOUT weight at about 50 to
60 flexions/extentions per minutes would be a nice example.
Then, whatever you do that use your muscles, will initialy burn fat.
Then, in the long term, you'll start to gain weight as you build up
muscle mass faster that you burn fat. And remember: muscle dencity is
larger than 1 (sink in water) while fat dencity is less than 1 (float in
water). That's why I don't float, I don't have enough body fat and my
muscles and bones have a somewhat above average dencity. It makes it
prety hard to learn to swim...
Date: 29 Feb 2012 04:11:42
Message: <4f4debce$1@news.povray.org>
> food is available, how likely you are to be eaten by a tiger, etc. I've
> seen studies where people imagined being in danger and (over time) lost
> weight, and the doctors doing the study figured it was because your mind
> was preparing you to run away.
Seems reasonable.
Note that stress makes you ill. (I'm not talking about having a naff day
at work. I'm talking about being /really/ stressed out.) Thing is, when
humans evolved, the only reason for being "stressed" was that you're
about to be attacked by something, and you should either kill it or run
away from it, really fast. So either the threat would be killed, or
you'd escape, or you'd die. Either way, the situation would be resolved
pretty quickly.
So the stress reaction is only supposed to be used for a short time. But
today, a "threat" isn't necessarily something you can resolve in a few
minutes. It can go on and on for months. Meanwhile, your body is
prepared for imminent physical conflict 24/7. Gradually that screws
everything up.
I'm wondering whether stressing yourself to try to provoke weight loss
is actually a good idea. I suppose it depends on the degree. And hey, if
you only need to do that until you reach your target weight, maybe
that's not so bad...
Date: 29 Feb 2012 04:14:07
Message: <4f4dec5f$1@news.povray.org>
Ironically, I can't swim for the opposite reason: After about 2 meters
or so, I'm too exhausted to continue.
Date: 2 Mar 2012 00:44:00
Message: <4f505e20@news.povray.org>
On 2/29/2012 1:14, Invisible wrote:
> Ironically, I can't swim for the opposite reason: After about 2 meters or
You're doing it wrong, is all. It's really, really easy to learn how to swim
however far you want to go.
http://www.totalimmersion.net/
It's really super-super easy.
Date: 2 Mar 2012 01:59:42
Message: <4f506fde@news.povray.org>
  How to learn to swim properly:
1) Buy swimming goggles. They are *essential*. Don't bother trying without
them. (When you buy them, it's extremely important that you check that they
are watertight and don't leak water when on. They should act like suction
cups.)
2) In the pool, before starting any swimming, learn to immerse yourself
under water and exhale air from your nose at a normal breathing rate
(ie. not too fast, not too slow, just the normal rate of breathing).
Do this repeatedly over and over (iow. when above water, inhale, then go
underwater, exhale air from your nose at a normal pace, come up, repeat).
3) Look up some pros swimming using breaststrokes. (There are some
animations in wikipedia as well.) This is by far the easiest form of
swimming. Swim like that. Pace your breathing with the swimming strokes,
just like in step 2: When your head is above water, inhale, when it's
underwater, exhale from your nose. Try to maximize the time your head
is underwater and minimize the time above (no need to exaggerate, of
course).
  Don't rush to other swimming styles. Breaststrokes are by far the
easiest and most economical.
Date: 2 Mar 2012 04:00:05
Message: <4f508c15@news.povray.org>
> cups.)
In all the years that I've been alive on this Earth, I have never, ever,
even once, found a pair of goggles that don't leak like a sieve. As far
as I can tell, goggles just flat-out don't work. (Or maybe it's that
only the incredibly expensive ones work, I don't know.) Every pair of
goggles I've ever owned has been a total waste of money.
Also: People who open their eyes underwater. OUCH! >_<
Date: 2 Mar 2012 04:28:10
Message: <4f5092aa@news.povray.org>
  You just have to search. Go to the shop and try every one of them
(as said, try them on, and if they act like suction cups and don't fall
off even without the strap, they will probably work). If you can't find
good ones in one shop, try another.
Date: 2 Mar 2012 05:27:53
Message: <4f50a0a9@news.povray.org>
>> without them. (When you buy them, it's extremely important that you
>> check that they are watertight and don't leak water when on. They
>> should act like suction cups.)
I used to speed swim - never had a problem with inexpensive goggles
leaking - but the problem that I did tend to have was that they fogged
up.  Even the anti-fogging ones would give me trouble.
I'm with you on that.  Especially chlorinated water.  That just stings,
and I never could get used to it.
Jim
Date: 2 Mar 2012 14:10:01
Message: <4f511b09@news.povray.org>
  There's a lesser-known trick to help that: Before starting to swim,
spit on the inside of the goggles (and rub the spit on the inner surface).
It's not as gross as it sounds, and it helps surprisingly well. In my
experience you might still get a slight amount of fogging, but considerably
less.
  (I'm assuming human spit creates a protective "layer" that stops
fogging.)
Date: 2 Mar 2012 14:42:40
Message: <4f5122b0$1@news.povray.org>
> surface). It's not as gross as it sounds, and it helps surprisingly
> well. In my experience you might still get a slight amount of fogging,
> but considerably less.
> fogging.)
ISTR having tried that with limited success - but  it does make sense.
Sadly, I've not been in shape to swim for some time - it's hard to pick
up something you were once good at and have to start over from the
beginning - ie, learning to breathe again with the water pressure on your
chest - I have a very hard time doing that these days, and I know it just
takes time to get acclimated to it.  I tried getting back into it about a
year ago, but when you've done speed swimming, distance swimming, and
springboard diving (never anything crazy there, and never diving off the
higher boards), it's hard to just get in the water and bob up and down,
even though it's absolutely necessary.
Just like (for me) playing the violin - I'd love to get back into it, but
I have no callouses on my fingers, and I don't have the patience to build
them up again.
Jim
Date: 2 Mar 2012 15:55:28
Message: <4f5133c0$1@news.povray.org>
>> fogging.)
certified diver (navy days) and it worked just fine for me ... matter of
fact that's what everyone else did as well
Date: 2 Mar 2012 16:36:12
Message: <4f513d4c$1@news.povray.org>
Le 02/03/2012 21:56, James Holsenback nous fit lire :
>>> fogging.)
Not a protective layer, just a wet liquid layer. Fog in goggle is opaque
because it's a distributed noise of liquid points over a dry surface.
Spitting will create a thick film that "glue" to the glass (work better
on glass than on plastic) and that film collects the points of fog.
Being dissolved in the thicker film, humidity does not become
diffracting/white.
Issue of spitting: goggle accumulate a lot of proteins which make the
goggle more opaque. You need to use a bit of dish-washing product with
clear water after usage to get ride of the proteins. (So, it's "spit
before, wash with tension-active after"; Washing with only clear water
is a failure)
Date: 2 Mar 2012 16:54:06
Message: <4f51417e@news.povray.org>
>>>> fogging.)
> diffracting/white.
> is a failure)
well, salt water diving will rot your equipment, so yes washing with
something like dish-washing soap is a definite must ... on "The Hawk" we
used to just throw everything in this big tub and someone else did the
"dirty work"
Date: 2 Mar 2012 17:23:51
Message: <4f514877$1@news.povray.org>
>>>> fogged up.  Even the anti-fogging ones would give me trouble.
>>> fogging.)
Cool, good to know. :)
SCUBA is something I'd always wanted to try, but unfortunately I
perforated my eardrum when I was 14 (diving accident - off the board and
slapped the side of my head on the water - I was able to whistle through
my ear afterwards, but then the pain it...Oh, the pain was *awful*), and
never went any further with it.  I'd done snorkeling a few times and
enjoyed that quite a lot.
Jim
Date: 2 Mar 2012 21:17:59
Message: <4f517f57@news.povray.org>
>> without
>> they
>> cups.)
Opening your eyes underwater... I've never put my head under water with
my eyes closed. In a swiming pool, in a lake, at sea... all the same and
no problem and no pain at all.
Leting air out underwater, also a natural thing for me.
My only problem with swiming is that I float like a brick!
Date: 2 Mar 2012 21:20:12
Message: <4f517fdc@news.povray.org>
>> Also: People who open their eyes underwater. OUCH!>_<
> Jim
A very simple anti fogging tip:
Rub some saliva on the inside and do a quick rinse, put on and no fogging.
Date: 2 Mar 2012 23:41:05
Message: <4f51a0e1$1@news.povray.org>
I disagree. Freestyle I find is much easier, because you can pause at any
stroke and just coast and breathe and float. With breaststroke, if you want
to stop, you have to actually stop swimming. I.e., you have to swim hard
enough to lift your face from the water with breaststroke.
For the "total immersion", you basically just have to get into a position in
the water where you're floating properly. You turn your head, and your face
is out of the water, and you can just glide like that until you stop. You
roll to the other side while drawing your arm back, and you go forward, and
coast to a stop with your face out of the water. Very relaxing if that's how
you want to swim.
Date: 2 Mar 2012 23:42:04
Message: <4f51a11c@news.povray.org>
Much worse is when your mask fills while you're doing SCUBA. It's not like
you can stop and rub the salt-water out of your eyes.
Date: 2 Mar 2012 23:47:17
Message: <4f51a255$1@news.povray.org>
> fogging.)
It's a chemical in your saliva. It doesn't work with other fluids.
Baby oil works too, btw.
Date: 2 Mar 2012 23:48:24
Message: <4f51a298$1@news.povray.org>
> "dirty work"
I suspect that they didn't necessarily consider that part the "dirty work." :-)
Date: 3 Mar 2012 02:49:45
Message: <4f51cd19@news.povray.org>
  Maybe if you are fit. In my experience it's more demanding, while
breaststroke is way more leisurely.
Date: 3 Mar 2012 04:25:05
Message: <4f51e371$1@news.povray.org>
Might be related to the fact that I'm allergic to chlorine...
LOL!
Date: 3 Mar 2012 15:40:47
Message: <4f5281cf@news.povray.org>
I'm far from fit. I find freestyle is more relaxing because basically you
can go as slowly as you like.  I think in breaststroke your face is
basically underwater if you stop, right? Or am I confused about which strokes?
In any case, once you know how to float, the actual swimming part becomes
pretty easy.
Date: 3 Mar 2012 16:34:41
Message: <4f528e71@news.povray.org>
> you can go as slowly as you like.  I think in breaststroke your face is
> strokes?
It's fairly easy when doing breaststroke to just coast and kick and keep
your head above the water.  Indeed, when I used to swim laps, I'd see a
fair number of retirees swimming and they'd do this and never actually
put their faces in the water.
Jim
Date: 3 Mar 2012 16:35:22
Message: <4f528e9a$1@news.povray.org>
> like you can stop and rub the salt-water out of your eyes.
I'd believe that.
Jim
Date: 3 Mar 2012 19:02:18
Message: <4f52b10a@news.povray.org>
I take it back, then. I never got good enough at breast-stroke to do that.
Date: 4 Mar 2012 01:16:37
Message: <4f5308c4@news.povray.org>
  That's not the most efficient way of swimming, though. (Else it would
make sense to swim breastsroke "properly", ie. going underwater.) Your
head is heavy.
Date: 4 Mar 2012 02:12:43
Message: <4f5315eb$1@news.povray.org>
>> keep your head above the water.  Indeed, when I used to swim laps, I'd
>> see a fair number of retirees swimming and they'd do this and never
>> actually put their faces in the water.
> head is heavy.
Nobody really said it was the most efficient way to swim, just that this
is a way to handle it when you need a break.
You're not going to be Michael Phelps doing it this way - but nobody
claimed you would be.
Jim
Date: 4 Mar 2012 02:41:22
Message: <4f531ca2@news.povray.org>
  It's not about speed, but about efficiency. "Taking a break" by swimming
in a less efficient (and hence more tiring) way sounds counterproductive.
If you need to take a break, then just stop at the end of the pool.
Date: 4 Mar 2012 06:58:45
Message: <4f5358f5$1@news.povray.org>
Am 04.03.2012 08:41, schrieb Warp:
I personally prefer swimming on my back to take a break. Not recommended
in rough sea of course.
