POV-Ray : Newsgroups : povray.off-topic : PCs vs consoles Server Time
1 Nov 2026 06:00:04 EST (-0500)
  PCs vs consoles (Message 1 to 13 of 13)
Subject: PCs vs consoles
Date: 6 Feb 2012 01:33:09
Message: <4f2f7425$1@news.povray.org>
One thing I don't understand is why games that target consoles don't do
infrastructure-type improvements on PCs. For example, Portal has, at the end
of each level, an elevator ride, that freezes in the middle as a loading
screen, then resumes. Well, my XBox has half a gig of RAM, and my PC has 6.
Or 16, depending which one you're talking about. Would it really be so hard
to have a low-priority thread loading the next level into a second block of
RAM during the current level, or even during the elevator ride? (I'm
assuming it doesn't actually take several seconds to copy textures from RAM
to video card, does it?)
Batman did such a sweet job of this, even on consoles, that I surprised a
few friends by pointing out where the loading screens were that they hadn't
noticed. :-)  That really was a technically-awesome game.
   People tell me I am the counter-example.
Subject: Re: PCs vs consoles
Date: 6 Feb 2012 04:11:31
Message: <4f2f9943$1@news.povray.org>
> a few friends by pointing out where the loading screens were that they
> hadn't noticed. :-) That really was a technically-awesome game.
My old PC can run Crysis, but it can't run Batman: Arkham Asylum at
playable frame rates, despite the former having infinitely superior
graphics to the latter. I'm not sure if that counts as "technically
awesome"...
Date: 6 Feb 2012 05:30:00
Message: <web.4f2fab8a9668629edbb0a6fe0@news.povray.org>
They don't want people to realize current consoles are so obsolete already.
This generation was not fair to PC gamers at all.
God of War also got technically smooth 0-time loading times well-hid between
level chunks, even on the PS2.  It seemed to begin to load as you were close to
get to the entry for the next section, which usually coincided with some narrow
corridor.
Date: 8 Feb 2012 00:38:53
Message: <4f320a6d@news.povray.org>
> corridor.
That's how batman did it. Crawling thru airways, or waiting for the security
doors to scan you.  I noticed because I went back through the wrong door in
the jail at one point and the door took about 3 times as long to scan me,
and I realied that's because it predicted me going thru the door that
progressed the game. And that's on an xbox.
Date: 8 Feb 2012 11:12:40
Message: <4f329ef8@news.povray.org>
  Laziness.
Date: 8 Feb 2012 11:41:12
Message: <4f32a5a8$1@news.povray.org>
>    Laziness.
Laziness???  Given how hard the games industry is known on working its
employees, and that I figure you're aware of this too, I'm not even sure
what you actually mean when you say "laziness" in this context.  I'd
think that something like "other things have higher priority" would be
far more accurate.
Date: 9 Feb 2012 04:41:34
Message: <4f3394ce@news.povray.org>
> far more accurate.
The games industry is home to some visionary designers and very
hard-working, productive programmers, who produce cutting-edge content.
It is /also/ home to developers who put out some decidedly lazy
offerings. Short games with gratuitous padding to make them longer.
Games which are blatantly identical to existing successful products.
Hastily produced sequels with large sections of identical or minimally
modified content. Oh, I'm sure some of these companies still whip their
developers pretty hard. But the end product is still "lazy", IMHO.
I suppose it's just like any other industry, really. How many great
films have had sequels hastily thrown together which turned out to be
awful? Whilst I'm sure even a hasty sequel is quite a lot of work to
produce, the result can still rightly be called "lazy".
Date: 11 Feb 2012 22:38:53
Message: <4f37344d$1@news.povray.org>
> I'd think that something like "other things have higher priority"
would be far more accurate.
To put this another way: I'm sure that through the development of Portal
2, the programmers had a lot of things to work on. It's very likely that
they were aware of the loading screens, and were forced to answer the
question, "Should we spend programmer time eliminating loading screens,
or should we spend that time, say, implementing light bridges?" If you
would prefer the game without loading screens, you should suggest what
feature you would have liked to trade that for.
The other option is to push back the release date. However, even if they
had done that, I guarantee you they would have said, "Should we use this
extra time to eliminate loading screens, or should we implement <cool
gameplay feature the designers thought of but was cut for lack of time>?"
You can see how the only way that loading screens are going to go away
is if they push back the release so much that there's really nothing
better to work on. The list of things that have a higher payoff than
eliminating loading screens is long, especially when you're suggesting
it will only work on one of the target platforms.
Laziness doesn't really factor into it. It's a matter of priorities.
  - Slime
Date: 11 Feb 2012 22:43:41
Message: <4f37356d$1@news.povray.org>
> Would it really be so hard to have a low-priority thread loading the
next level into a second block of RAM during the current level, or even
In a word, yes. It's only (relatively) easy under the assumption that a
level can be "loaded into a block of RAM," which is probably not the
case. There are probably many different things in a level that are
loaded into many different places that interact with many different
systems, all of which would need to be updated to make that possible.
This comes with new bugs that take time to track down and fix.
Obviously, some games do manage to do this, but that doesn't mean it's
an easy feature to add to an engine that doesn't support it.
  - Slime
Date: 13 Feb 2012 11:34:24
Message: <4f393b90$1@news.povray.org>
> level can be "loaded into a block of RAM," which is probably not the case.
Actually, since most of the time seems to be spent pulling the level off the
HD or DVD, I would think you could pre-buffer the files at least. *That*
should be pretty trivial to implement, even if unpacking the levels into
individual objects and such can't be done easily. I'd imagine that would
reduce loading times a bunch.
 > If you would prefer the game without loading screens, you should suggest
what feature you would have liked to trade that for.
That's a good question. Portal2 is pretty tight. On the other hand, if the
loading screens took 5 minutes each, I'd bet people would balance the
priorities differently, or even hire an extra developer to work on it, so
it's not like I'm asking for something absurd. :-)  Plus, of course, it's
the Source engine, so it's not like the work wouldn't be amortized over
numerous games.
Date: 13 Feb 2012 12:02:06
Message: <4f39420e@news.povray.org>
  I'm not so intimately acquainted with the PC architecture to know for
sure, but how much can disk-to-RAM data transfer be made in parallel
with everything else a game can do, in terms of memory bus usage (iow.
does disk I/O have to share, and hence compete for, the same memory
bus as the CPU and, more significantly, the GPU, when transferring data
from the main RAM to it)?
  I know that the DMA chip allows transferring data between RAM and the
different devices without the need for the CPU to do anything (other
than launching the transfer), so things like pre-loading data from disk
to memory takes zero CPU time. However, I'm thinking how much congestion
it causes on the memory bus, and if it could have a negative impact on
data transfer performance in other critical areas (such as transferring
data from the main RAM to the GPU, which happens all the time).
  Of course there are many games, especially the open sandbox type ones,
which are specifically *designed* to load data on the fly, avoiding any
loading pauses completely. However, can speeding up level data loading by
pre-loading data on the background using available free memory be done
without the game engine having been specifically designed to do so?
Date: 13 Feb 2012 22:50:52
Message: <4f39da1c$1@news.povray.org>
> bus as the CPU
On modern desktop type machines, I think the disk probably steals memory
cycles from the CPU. That's a good point. On the other hand, what's the
transfer rate of even a fast disk? 120MBps?
I wouldn't think the disk's DMA would affect CPU->GPU at all, since AGP bus
and later, but I'm not sure. Of course, the CPU has to read from the RAM as
well, so it's hard to say.
An excellent point I hadn't considered. Honestly, I haven't really thought
about this stuff since the generations of machines where RAM is faster than
CPUs. :-)
That said, given that a level in Portal (say) can take a couple minutes to
go through, and a level takes maybe 15 seconds to load, keeping the transfer
rate down to 1M/s or something might even speed things up there. Especially
when you're talking about loading it off a DVD instead of a HD, where the
seek times will still dominate.
Date: 14 Feb 2012 09:24:04
Message: <4f3a6e84$1@news.povray.org>
> thought about this stuff since the generations of machines where RAM is
> faster than CPUs. :-)
My graphics card has just under 1GB of on-board RAM. I would expect that
once all the textures and meshes and so forth have been uploaded over
the AGP bus (or PCI-X or whatever you're using today), the GPU probably
requires minimal bandwidth from main memory. Certainly not enough that
the piffling transfer rate of the disk drive would affect it in the
slightest.
