POV-Ray : Newsgroups : povray.off-topic : Moray & POV-Ray 64-bit problem Server Time
17 Oct 2026 06:58:45 EDT (-0400)
  Moray & POV-Ray 64-bit problem (Message 1 to 11 of 11)
Subject: Moray & POV-Ray 64-bit problem
Date: 26 Jan 2012 03:03:06
Message: <4f2108ba$1@news.povray.org>
I know this is probably the wrong section but looks like nobody watches
moray.win anymore.
I have the latest Moray and POV-Ray 3.7 RC3 64-bit. I wanted to ask if
there are any updates to Moray or nightly build I can use to make it
work? I'm willing to use Alpha Moray versions.
I get this:
Preset INI file is 'H:\Saul\POV-Ray\v3.7\ini\quickres.ini', section is
'[512x384, No AA]'.
Preset source file is 'C:\Program Files (x86)\Moray For
Windows\POVScn\CoffeeCup.ini'.
Rendering using command line '-q9'.
"C:\Program Files (x86)\Moray For Windows\POVScn\CoffeeCup.ini" line 5:
INI option 'Buffer_Output' is no longer used and will result in an error
in future versions of POV-Ray.
"C:\Program Files (x86)\Moray For Windows\POVScn\CoffeeCup.ini" line 6:
INI option 'Buffer_Size' is no longer used and will result in an error
"C:\Program Files (x86)\Moray For Windows\POVScn\CoffeeCup.ini" line 24:
INI option 'Histogram_Name' is no longer used and will result in an
error in future versions of POV-Ray.
"C:\Program Files (x86)\Moray For Windows\POVScn\CoffeeCup.ini" line 25:
INI option 'Histogram_Grid_Size' is no longer used and will result in an
"C:\Program Files (x86)\Moray For Windows\POVScn\CoffeeCup.ini" line 26:
INI option 'Histogram_Type' is no longer used and will result in an
"C:\Program Files (x86)\Moray For Windows\POVScn\CoffeeCup.ini" line 63:
Unknown key 'Radiosity' in INI file.
Cannot continue to process INI file 'C:\Program Files (x86)\Moray For
Windows\POVScn\CoffeeCup.ini' due to a parse
error in line 63.
This is not a valid INI file. Check the file for syntax errors, correct
them, and try again!
Valid options in INI files are explained in detail in the reference part
of the documentation.
Failed to start render: Failed to parse INI file
So, this means I need POV-Ray 3.6 32-bit?
(news://news.povray.org:119/web.4ca9900cd96a259b561919e10@news.povray.org)
Subject: Re: Moray & POV-Ray 64-bit problem
Date: 26 Jan 2012 03:10:19
Message: <4f210a6b$1@news.povray.org>
I'd like a 64-bit version of Moray because I use Win7 64-bit.
The error messages in OP are POV-Ray 3.7 specific?
ANy help would be appreciated.
Date: 26 Jan 2012 09:31:23
Message: <4f2163bb$1@news.povray.org>
If you can do some coding yourself, I'd suggest a small utility that
strips the offending lines from the .INI.  Pipe Moray to that utility,
and the utility to PovRay.
John
Date: 26 Jan 2012 10:15:23
Message: <4f216e0b$1@news.povray.org>
Thanks for the suggestion John but I don't code much. Regards.
Date: 13 Feb 2012 14:02:09
Message: <4f395e31$1@news.povray.org>
This is, unfortunately, a known issue; Moray simply doesn't work with
newer than POV...3.5, actually, in my experience.  We just have to
muddle along, manually exporting and loading into POV 3.7 by hand until
the powers that be take pity on us and get Moray up to speed.
I haven't even touched 3D with any seriousness in a long time, now...  :(
Tim Cook
http://empyrean.sjcook.com
http://www.lifemax.net/TimCook
Date: 13 Feb 2012 21:43:20
Message: <4f39ca48$1@news.povray.org>
I'm gonna use blender then.
Well unfortunately POV-Ray development is really slow compared to other
open source freeware, maybe a reason Megapov and other POV-Ray based
renderers exist, forking the code, instead of team up helping 1 single
cause to get stronger but well, thank God there are good replacements
for POV-Ray, I'll still have it as a reference but as someone else
pointed out 3.7 versions in 10+ years is not a good ritm and I don't
think I'll ever use POV-Ray as my main raytracer that I had intended.
Is my sentiment that many feel the same and are doing the same as I
will, too bad POV-Ray deserved better because I think it had potential.
It is what it is.
Cheers.
Date: 14 Feb 2012 06:35:16
Message: <4f3a46f4@news.povray.org>
I remember, that by chance I visited Blender website (it was tech news
at the time) when it first got released as open-source freeware, it had
less features than POV-Ray, they were calling for webmasters, developers
to get involved and people to help them get organized, pretty much
starting from almost scratch in many ways; I honestly felt sorry for
them they were really pathetic and I was sorry I could lend a had at
all. Of course POV-Ray looked pretty solid in comparison.
Look at them now...
Roles are opposite now, at least to me.
As I wrote, POV-Ray could have gone a similar destiny, but well, things
happen for a reason as they say, reasons that can't be helped I suppose
since I doubt the developers are letting POV-Ray fall back like that
intentionally.
I'm worried that this path POV-Ray has taken is one of a long and slow
death. It could take another 10 years, unless they reorganize as Blender
did.
Because I recently made a Google search for photo-realistic renderers
and I was surprised how many they are, and "Yet Another [fill here}"
open-source freeware/share projects are spreading.
I have realized that people has a lot of fixed ideas and they don't
accept suggestions easily, so I think this is 1 big obstacle when trying
to do this open-source freeware projects, pride and and stubbornness
mostly, people prefer the long way instead of coordinate and cooperate
with other people, selfishness of creativity, etc. You need your
creative space but this is childish... really sad...
For example I as people in FS SCP (www.hard-light.net) to consult
POV-Ray developers since POV-Ray is already on the other side of the
fence of multi-thread and 64-bit, but no sir, "we have our own
resources" crap, fine so be it...
Cheers.
Date: 14 Feb 2012 06:43:10
Message: <4f3a48ce$1@news.povray.org>
Saul Luizaga wrote:
Correction:
> For example I *asked* people...
PS: Is a shame you can't correct your messages in a newsgroup.
Date: 14 Feb 2012 10:32:23
Message: <4f3a7e87$1@news.povray.org>
> did.
The transition to 3.7 is taking more than expected, as it run so far on
only a few people with small free time. It is a needed larva stage, to
adapt to modern world.
Once out, you can probably expect some replay of the megapov series (or
whatever name, it started as superpatch... ). This uncontrolled sandbox
might be the fertile ground for selecting new features in official line.
(as It happened from 3.1 to 3.5 and 3.6...)
If you have extra energy right now, it would be good to revive the IRTC
(not dedicated to povray but Cheepa is not the same good name), but it's
a long and tiring dedication (setting the website, computing result and
so on). Maybe you can regroup with a few interested people.
Why is there no fertile jungle right now: because 3.7 was such a major
rewrite (in term of internal coding) that making patches while the 3.7
was not stable is kind of a waste of energy.
About the cited site: yet another website that assume that the reader
know what they are all about. It took me a few real minutes to find
something which explain FS, at least at the outer level. In a world of
google search, more than 15 seconds of reading for search is far too long!
Date: 14 Feb 2012 13:44:53
Message: <4f3aaba5$1@news.povray.org>
On Tue, 14 Feb 2012 07:42:58 -0400, Saul Luizaga wrote:
> Saul Luizaga wrote:
> Correction:
You can, cancel and repost.
Jim
Date: 15 Feb 2012 08:52:01
Message: <4f3bb881$1@news.povray.org>
>> did.
As I wrote instead of uniting forking, Blender made the opposite and it
was better, a lot. Also I feel is only a handful of people actually
doing POV-Ray coding, 1 more thing forking is not helping with and since
"foreign" coders are making improvements that later will integrated the
official version seems redundant and inefficient.
I wish I had the time, IRTC is mostly dead, POV-Ray is no longer a
reference to test performance, etc; is falling behind...
I understand but again, wasn't carried out the best way IMO, I think the
devs are about 5 if so, the rest of POV-Ray effort is forked out.
Dude, you complain without pain, if you could only see the website I
have been, you wouldn't complain for a few seconds even a few minutes.
They use custom Google search so it shouldn't be difficult and their
forums is pretty organized and you can easily know what they're about.
