POV-Ray : Newsgroups : povray.off-topic : More Net Questions Server Time
1 Nov 2026 06:00:20 EST (-0500)
  More Net Questions (Message 1 to 17 of 17)
Subject: More Net Questions
Date: 21 Dec 2011 09:25:29
Message: <4ef1ec59$1@news.povray.org>
OK, So I am still on the hunt for the network delays I am seeing - so
some questions about network throughput.
My Hardware
Windows Domain Server - (1) 1 GB ethernet
File Server - (2) 1GB ethernet (bonded to share load into the same switch)
Patch panel and patch cords are CAT5e
In Wall wiring is combination of CAT5 and CAT5e
Switch is DELL PowerConnect 2724 running in a non-managed mode
about 10 users on the network
What slowdowns might this kind of setup cause?
Thanks
Subject: Re: More Net Questions
Date: 21 Dec 2011 10:23:16
Message: <4ef1f9e4$1@news.povray.org>
> My Hardware
How are the lights blinking on the Dell 2724 ?
(if it's a storm or a huge requesting of network resource, some should
blink very fast).
Now, there is other thing that storm in the network to cause a slowdown:
trying to reach/find inaccessible resource and awaiting time-out before
resorting to another solution. In such case the network is rather calm.
(and the light blinks slowly)
In theory Cat5 cable are not suitable for 1G. (cat5e is ok, but not
strict 5)
Have you tested "unloaded network" ? (Keep the WDS & fileserver, as well
as the switch, 1 user only (all other users are disconnected from the
switch). Does it work better ? or same ? or worse ?
Adding 1 user at a time ?
Putting back the Internet connection ?
Date: 21 Dec 2011 11:45:01
Message: <4ef20d0d@news.povray.org>
>> My Hardware
> blink very fast).
Just making sure - a storm is bad
I'll keep an eye on the switch lights and try to have a look when
someone reports a problem.
Good idea.
So, I should label each 'computer' on the switch and look at everything
when there is a problem and pay attention to the 'problem' computer as well.
> strict 5)
right - that's what I thought.  The CAT5 is baked into the building so
it will be hard to replace.
But we can run a test with long patch cables to see if that helps.
> Have you tested "unloaded network" ? (Keep the WDS&  fileserver, as well
We are going to try this next week when the office is pretty empty.
The main problem is not a small delay in getting a file - 10-15 seconds
can happen from time to time.  But 5+ minutes is pretty bad.
Thanks for the tips.
Merry Christmas!
Date: 21 Dec 2011 12:00:42
Message: <4ef210ba$1@news.povray.org>
On 12/21/2011 8:45, Tom Austin wrote:
> The main problem is not a small delay in getting a file - 10-15 seconds can
On a gigabit network, that sounds like a long time to load a 5M file.
Do you do a lot of updates on the Linux server, like creating and deleting
thousands of files at a time? It's possible that the Linux server is just
locking up flushing its buffers if it has a lot of RAM. Sadly, I don't know
any sort of monitor that would actually tell you what's going on inside the
kernel of a Linux machine. (Anyone know what the equivalent of Performance
Monitor on Linux is?)  If your file server has RAID, maybe there's a bad
spot on one of the disks and it retries a while before falling over to the
other disk? Maybe check through syslog records to see?
Check the domain server's event logs around the time of a problem, and see
if it's an authorization problem or something, where maybe you're waiting
for a new kerberos key to access the remote file and the domain server is
slow giving it out for some reason?
   People tell me I am the counter-example.
Date: 21 Dec 2011 12:38:16
Message: <4ef21988$1@news.povray.org>
Le 21/12/2011 18:00, Darren New nous fit lire :
>> seconds can
On gigabit network, a 5M file which should transfer in about 4000
frames, should take less than 10s even at 1% of network usage, including
an acknowledge of each frame.
(1% of network: which means that even on a 10mbits, 10s is already large)
> deleting thousands of files at a time? It's possible that the Linux
> server is just locking up flushing its buffers if it has a lot of RAM.
> Sadly, I don't know any sort of monitor that would actually tell you
> what's going on inside the kernel of a Linux machine. (Anyone know what
> the equivalent of Performance Monitor on Linux is?)
there is:
 * text mode: top
 * gnome : gnome-system-monitor
 * kde : ksysguard
Date: 21 Dec 2011 15:57:30
Message: <4ef2483a$1@news.povray.org>
>> seconds can
Agreed, but the occasional 'glitch' of 10-15 seconds is acceptable.
> the equivalent of Performance Monitor on Linux is?) If your file server
> has RAID, maybe there's a bad spot on one of the disks and it retries a
> while before falling over to the other disk? Maybe check through syslog
> records to see?
No updates, but a lot of large (5 MB) image files are being transferred
to and around the file system.
It is 32 bit - so only 4GB of physical ram with some extra swap just in
case.
It does have RAID - OS is RAID 1 on the software level, file drives are
RAID 1 on a 3Ware controller 2 mirrored sets as a logical volume.
> see if it's an authorization problem or something, where maybe you're
> waiting for a new kerberos key to access the remote file and the domain
> server is slow giving it out for some reason?
That could be a very real possibility - and would bring our crappy
Windows domain server into question - like we want it to be :-)
This is good food for thought.  I'll set up some tests that might help
flush some of this out.
Thanks
Date: 21 Dec 2011 15:59:36
Message: <4ef248b8$1@news.povray.org>
yes, agreed - but an occasional hiccup is tolerable so we didn't worry
about it.  Now with more users and data maybe that hiccup 'error' is
being compounded.
Date: 22 Dec 2011 10:13:29
Message: <4ef34919$1@news.povray.org>
> My Hardware
Make sure the server NICs are hard-coded for 1 Gbps Full-duplex.
Gigabitethernet left in auto-detect mode can lead to funky things...
Make sure the switch ports facing the servers also have their speed and
duplex hardcoded, if possible.
How?  Depending on the way it's set up, it can cause major problems with
the switch.  Disconnect one of the patch cords and see if performance
improves.  If it does, you had a loop between the two switch ports, and
the two NICs in your server.  Either reconfigure your NICs to use
fail-over, or make sure "spanning-tree" is enabled on the switch ports
facing the server.  Keep in mind that by doing that you will lose your
2Gbps aggregation speed and the second NIC will only be there to provide
a host-stanby.
Length?  CAT5e specification says that desks-side patch cords must not
be longer than 3m (10ft), and that switch-side patch cords can not be
longer than 7m (25ft), while the total length of the premises cabling
(in the wall) must not exceed 90m (300ft).  See below to know how to do
this.
Do you have lots of internediary patch panel connections (e.g.: desk to
wiring closet.  Wiring closet to server room main wall.  Server room
wall to rack patch panel)
According to TFM (which you should R), there are cable-testing functions
in the switch.  Check to see if you have faulty cabling, exceed the
length of the standards, or if the premises cabling can really sustain
1Gbps.  If not, downgrade the user ports to 100 Mbps.
Check, if possible, for rogue user activity (Is anyone running a
streaming app?  Is anyone acting as a Counterstrike server?  Does anyone
have NetBEUI turned on by mistake? etc...)
Apart from the risk of having a spanning-tree loop between the switch
and the dual-homed server, there's nothing inherently bad about this
setup. By default it should run fine.
> Thanks
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 23 Dec 2011 08:12:31
Message: <4ef47e3f@news.povray.org>
> a host-stanby.
And by that, I mean "hot-standby".  I Should have proof-read...
Date: 23 Dec 2011 18:57:17
Message: <4ef5155d@news.povray.org>
> My Hardware
> Thanks
I know someone who had slow network. He discovered that he was
configured as peer to peer instead of on a domain. This can realy slow
things down.
Check for crushed or otherwise damaged cables. Any work on a wall
containint cabling? It could have damaged some cabling.
I think that, at least sometimes, a faulty network adaptor on one
computer may cause erratic trafic over the network.
Date: 3 Jan 2012 07:47:35
Message: <4f02f8e7$1@news.povray.org>
>> My Hardware
I will look into this.
>> switch)
> a host-stanby.
Hmmm - something to look at.  I'll try to run a test in the near future.
It has run like this for 4 years without a visible issue - but that
could be due to a light load.
> Length? CAT5e specification says that desks-side patch cords must not be
> this.
desk-side -   5-10 ft typical - a very few longer - < 15 ft
switch-side - < 3 ft
in wall  -    < 100 ft  (building is 100' long and net room is in the
middle.
> wiring closet. Wiring closet to server room main wall. Server room wall
server patch directly switch
switch patch to panel
panel run to wall outlet
wall outlet patch to computer
Working on RTFM - as time allows.
Just set the switch to 'managed mode' while nobody was in the office.
Now to figure out how to 'use' it.
We do have people running streaming music and video - and even a small
minecraft server for local use (guys like to lunch it)
My thought is that the bandwidth that these things use is small enough
as to not impact usability.  We have never seen things like this impact
the network before.
Our pipe to the internet is 50/10 and is pretty consistent - but that
should not overly impact server-client speeds in out office - should it?
We have been running the network like this since 2007 without noticing
any problems.  But with a few extra guys in the office it sounds like it
could cause some latent problems to crop up.
The spanning-tree loop sounds like something to look into.  I'll run
some tests with disconnecting a port to see if that may be the cause of
the problem as well as using the managed features of the switch to run
down some issues.
Thanks
Date: 3 Jan 2012 07:48:43
Message: <4f02f92b$1@news.povray.org>
>> a host-stanby.
I picked up on that - is there a 'safe' setup that would allow ganging
of ports like I have?
Date: 3 Jan 2012 07:51:06
Message: <4f02f9ba$1@news.povray.org>
>> My Hardware
>> switch)
>> Thanks
> things down.
I'll set up some monitoring to see if I can see what traffic is flowing.
I am pretty confidant that we are all running on domain.
Cabling to some offices may be suspect - but not too much to do about it
as it is in-wall.  We may run some patch cords to do some tests.
Thanks
Date: 3 Jan 2012 09:11:40
Message: <4f030c9c$1@news.povray.org>
>>> a host-stanby.
Look into LACP (IEEE 802.3ad Link Aggregation Control Protocol).  Both
your NICs and the swith need support it (and be configured for it,
obviously!)  Cisco also has proprietary equivalents (EtherChannel and
PAgP) that are sometimes supported by third party hardware.
Date: 3 Jan 2012 09:21:13
Message: <4f030ed9$1@news.povray.org>
>>> My Hardware
>>> switch)
>> a host-stanby.
>> this.
> in wall - < 100 ft (building is 100' long and net room is in the middle.
Do not assume anything.  Cabling conduits sometimes take funky routes
around (or into... but that's a big fire hazard!) ventilation ducts,
plumbing, elevator shafts, etc...  I've seen cables strung as tight as
piano wire, I've seen bundles of cables thrown under the floors because
the cabling guys were too lazy to cut them to the proper lengths, I've
seen attack ship fire off the shoulder of Orion...
> the network before.
Things have certainly improved since Doom 1.1 wrecked havoc on company
LANs in the early 90s, but it's always a good think to know what's out
there and be ready to limit extra-curricular activies, if it's
preventing people from working.
Unless someone has gotten access to your server and is running a proxy
from it, no.
> The spanning-tree loop sounds like something to look into. I'll run some
> tests with disconnecting a port to see if that may be the cause of the
> problem as well as using the managed features of the switch to run down
> some issues.
> Thanks
Date: 3 Jan 2012 13:23:02
Message: <4f034786$1@news.povray.org>
>>>> provide
>>>> a host-stanby.
I found a bit of time and put our switch into managed mode and R some of TM.
Looks like it supports "Link Aggregate Groups".
The linux box is set up with aggregation already - ethernet bonding with
round-robin - actually pretty cool setup that I figured out when I set
it up.
The switch and linux box are pre 2008 so they don't support the 802.1 -
but should do the 802.3ad.
Some reading shows that I should be able to link the 2 server ports on
the switch - don't know if it will make much difference but it seems
like it is the way it should be.
Will have to try it in the morning when no-one is in the office.
Date: 3 Jan 2012 13:29:17
Message: <4f0348fd$1@news.povray.org>
Our own guys wired the building when they moved in way back - ~1999.
While likely not the best installation it wasn't the worst either.  It
is amazing what a bunch of engineers that don't know what htey are doing
can do?
>> the network before.
Always on the mind - always keeping an eye out for it.  Conceptually it
doesn't seem top be the problem, but I am no network expert.
> from it, no.
In the office there are no worries, but from out the office - we have
always tried to have a decent firewall between us and the internet.  But
that is never a guarantee.  Doesn't seem like something weird is running
- but I am not a network/computer expert.
