A few of you may know what I was in the IDTA Freestyle / Rock & Roll
National Dance Finals on Saturday. (No, we didn't win anything. Are you
surprised? Because I'm not...)
The IDTA website itself will tell you nothing unless you are an IDTA
member (i.e., a dance teacher). However, the website belonging to the
company that makes the score management software has results listings
for major tournaments using their software.
That's the good news. The bad news is that this website is completely
awful. Quite apart from the site being ugly as hell, it uses JavaScript
hyperlinks, seemingly just to prevent tabbed browsing from working properly.
If you want to look up the results to event 23 in a specific tournament,
that's easy enough. But if you want to look through all the events
trying to find competitor's names that you recognise... good luck with
that. No, there isn't a search function. No, Google does not appear to
have indexed any of the content. (Presumably Google doesn't follow
stupid JS links.)
That being the case, I set about writing some software to solve this
problem.
Step 1: Work out how to download the results tables.
It appears that the results index has a hidden HTML form on it, and
clicking on a hyperlink runs a small JavaScript function which looks up
some data from a giant table in the script, and shuffles the data into
the hidden fields of the hidden form. It then POSTs this form to a Perl
CGI script, which sends back a badly-formatted HTML page containing the
data I want.
Mercifully, it turns out the CGI script works perfectly well if you GET
the form parameters rather than POSTing them. And you don't even need
/all/ of the parameters, just three main ones.
Step 2: Write a program to download the HTML.
Given the information laboriously reverse-engineered above, I was able
to quickly throw together some code that generates the URL to fetch an
HTML page containing the results of each individual contest.
That's the easy bit. I then quickly threw together a trivial HTTP
client. (Note that a trivial HTTP client is significantly less trivial
than you might imagine... I suspect mine will break if they reconfigure
the web server sufficiently!) Now just loop over all the details I want,
and dump them into HTML files on disk.
(It took me a while to figure out how to turn off persistent
connections. Using EOF to find the end of the content doesn't work if
the server leaves the connection open. No, there isn't a content-length
header from the server.)
Step 3: Write a program to extract meaningful data from the mangled HTML.
This is the "really fun" part. Essentially it takes text and chops it
where hard-coded search strings appear. If the server admins decide to
change their markup, the whole thing will break hopelessly.
Fortunately, most of the data is in a big HTML table. Just got to grab
the columns you want (remembering to skip the empty width=10 column
that's only there for spacing reasons).
Unfortunately, column 3 contains multiple separate items of data,
combined by hand into a flat string. And *because* it's formatted by
hand, 99% of the values in this field follow a simple pattern, and a
further 1% of them violate this pattern, screwing up the code and
leading to lots of special-casing.
For the solo events, column 3 contains a 1- or 2-letter area code plus a
person's name. For the pairs events, it's an area code plus two names
separated by an ampersand [except on one single row where they are
separated by the word "and" rather than by "&"]. And for the team
events, it's the [arbitrary] name of the team. Yes, there is a team
called "Mammas & Pappas". No, there isn't a reliable way to tell which
events are team events.
Note also that 99% of the time, there is a space on either side of the
"&". The other 1% of the time, there isn't. There is also one single row
which reads "Kate & & John Smith". There is also one person who's name
is apparently "/laura". Roughly 1% of the time, the person's name is
followed by "WITHDRAWN". Also, some tables have all the rows padded with
spaces to constant width, and other tables don't.
In short, this stuff has been keyed in by hand, inconsistently. Which
makes trying to automatically process it rather fiddly, to say the
least. Every time you adjust the program, it will process 99% of the
dataset and then do something stupid with 1% of the records, or maybe
just one single record. Spotting these mistakes isn't very easy.
Still, in spite of all the problems, I finally ended up writing about
4KB of Haskell code which manages to produce mostly sane CSV output from
this crock of junk.
Step 4: Convert the dozens of files into one giant file.
We started with one URL for each event. That became one HTML file for
each event, and after cooking that's one CSV file for each event. Now we
loop over all the files, gathering the event titles into one CSV file
and the table rows into another CSV file. The latter file needs an event
ID prepended to each table row.
Having done all that, I can import both CSV files into MS Access,
creating two tables - one mapping event IDs to event titles, and the
other giving the results for each event. Now I just need to go through
and correct any final mistakes which remain.
(Somewhere in this process, several people have ended up with obscure
characters in their names. For example, Mr John - Davis has somehow
become Mr John û Davis. I have no idea why; the CSV files look fine, but
the text is wrong in Access.)
Finally, after all this effort, I can *finally* search the complete
results for all the competitions of interest by just issuing a few SQL
statements.
Sheesh... You know there are people who do this kind of crap for a living??
You think that's bad? Imagine the same thing for the iTunes metadata
database, with like 6 million rows.
It got to the point where I could tell you how many people worked on each
day's updates, and how many of them were the same person as last time.
Especially fun, since you want "Beatles", "The Beatles", and "Beatles, The"
to be the same band, while "Alan Parsons" and "Alan Parsons Project" are two
different bands, and "Synergy" and "Synergy" are also two different bands,
for example.
Not even counting classical music.
People tell me I am the counter-example.
As near as I can tell this problem is solved by not bothering to get it
right.
>> living??
If it's anything like CDDB, then that would be why I never use CDDB. :-P
> right.
Ah yes, the Wikipedia approach.
Required XKCD quote: http://www.xkcd.com/978/
Without labouring the point too much, this is one of the reasons why I
use Haskell and not C++. It took me about 5 minutes to write a working
HTTP client, totalling 906 bytes of source code. I shudder to think how
much time I would have wasted trying to do such a task in C. String
management becomes vastly easier in C++, but I still wouldn't have a
clue how to, say, open a socket. [Is there even a portable way of doing
that? Or would you have to ask the native OS?]
The Haskell code I wrote isn't optimised in the slightest. I could
easily make it a lot faster, but it's not slow enough to be worth
bothering. The fact that C or C++ would be faster is a complete non-issue.
Then again, this program is quite atypical of what I write. It's a
one-off, quick and dirty hack to get me some information. All it really
does is push data from A to B. So many it's not such a great example to
hold up.
(If this was something that I wanted to "work properly", I would of
course have used a real HTTP library, and a real HTML parser library,
and so on. As it is, quickly throwing something together that has the
limited functions that I need right now was easier than trying to learn
how to use a new library.)
Of course, now somebody is going to point out that in Perl, the entire
program would have been 3 lines. But I'm not using Perl unless somebody
pays me. :-P
> pays me. :-P
Good you at least know that! :)
Besides builtin http clients being pretty much a given in any modern programming
environment (including C++ boost if I'm not wrong), there's also command-line
tools such as wget. No need to write a half-baked unoptmized attempt these
days. :)
It appears you're wrong. Boost doesn't seem to include any HTTP
functionality that I can see.
> there's also command-line tools such as wget.
Amusingly, Haskell actually has a libcurl binding. Guess what? Doesn't
work on Windows. :-P
I hadn't thought about trying wget though - that probably wouldn't be
too hard. (The tricky part is running an external OS process and then
trying to figure out whether the **** it actually worked OK or not.)
Given that all I want to do is generate 30 URLs and have each one
downloaded to a file, that probably wouldn't be too hard.
> No need to write a half-baked unoptmized attempt these days. :)
Downloading 30 files, of 2KB each, is not exactly something that
requires "optimising".
The text processing that happens after that? I could have made it a lot
faster. But since I only need to run it once, I didn't bother.
Trust me, that ship has sailed.
I meant more that this *specific* example perhaps isn't the best one.
[Which is why I'm not going to go on about it too much.]
Woohoo! The results have been released! :-D
There were 13 couples entered in our event. In round 1, the judges
select the 6 best couples.
2 couples were chosen by all 7 judges. (Couples #453 and #459.)
1 couple was chosen by 5 of the judges.
3 couples were chosen by 4 of the judges.
Together, that makes 6 couples. They all went through to the next (and
final) round.
1 couple got only 3 recommendations.
2 couples got picked by 2 judges.
2 couples got only 1 recommendation.
2 couples were picked by absolutely nobody.
Me and Lynn were picked by only a single judge. (Who, I notice, is the
only judge on the list with a masculine-sounding name. Also, the only
judge who picked 4 couples, not 6 like everybody else...) That puts us
in joint 10th place, just above the two unfortunate couples whom
*nobody* wanted to see any more of. (They share joint 12th place.)
In round 2 (the final round), each judge assigns each couple a number
between 1 and 6. And here's where it gets interesting...
As I say, two couples were voted for by all 7 judges - couples #453 and
#459. Now #459 are in my dance class. Apparently they've won this event
God knows how many times over - and naturally, everyone expected them to
win again this year. But actually, they got 2nd place, with
recommendations of 1122234.
And what of #453? Well, they came 4th. Their recommendations were
3345556. Go figure!
So, uh, who won? Well, it was #446, who only got a piffling 4
recommendations in round 1 and nearly went home. But in the final round,
they got 1112236.
Read that again: Three judges thought they should be 1st, two judges
said 2nd, one judge said 3rd, AND ONE JUDGE SAID 6th?!? (As in, last
place.) How can 6 judges place them in the top 3, and the final one
place them last? That's pretty random...
Remember couple #453? One of the two that got 7 recommendations in round
1? In round two, they got 1455666, and therefore came last. Again,
everyone thought they should be bottom, except for ONE judge. THE SAME
ONE, incidentally. I wonder what the hell *she* was watching?
[I can only imagine she was standing at the other end of the room or
something, and so she did see #453 and nobody else did, and she didn't
see #466 and everyone else did. But man, that's some weird stats...]
> 3345556. Go figure!
Urm... no they didn't. Ignore that line. :-P
>>> living??
Actually, CDDB was *way* better for me. The main problem there was poor
consistency, not downright inaccuracy. :-)
On 11/16/2011 6:11, Invisible wrote:
> Downloading 30 files, of 2KB each, is not exactly something that requires
> "optimising".
It's not a question of optimizing speed, but of making it work right at all.
OK, so this one needs a cookie set, that one needs the right referrer, this
other gives you a redirect to a home page offering you to download IE or
firefox if it doesn't see a User-agent header, etc.
>> "optimising".
> all. OK, so this one needs a cookie set, that one needs the right
> referrer, this other gives you a redirect to a home page offering you to
> download IE or firefox if it doesn't see a User-agent header, etc.
Fortunately, in this instance, none of that was a problem. (This web
site seems to be stuck in 1997.) Which is very, very fortunate, because
trying to sort that lot out would probably have driven me insane! >_<
Welcome to the world of subjective points attribution...
Maybe it was an arrangement with the russian judge...
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
I hate those with a passion. "IE and Firefox don't work on my
BlackBerry, you moron! Now, let me see the page and deal with the fact
that I can't see most of your nifty CSS tricks!"
(Rant not addressed to you personally)
>> right.
Isn't that also the Fox News way of working?
BTW from a friend I heard that it is almost impossible nowadays to add
something to wikipedia. Everything you do as a new contributor is
flagged for deletion almost automatically.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
I think there was an actual case of exactly that. Apparently a wikivandal
had added an additional name to a person's biografy in wikipedia. It was one
of those people who had a really long list of names (like eg. Picasso,
although I'm pretty sure it was not him in this case). Some magazine or
newspaper then copied the entire name, the fake one included, verbatim from
wikipedia. Then someone added the reference to wikipedia.
Of course in this case checking the fact is relatively simple, as long as
someone notices it and bothers to check: Since wikipedia keeps a log of the
entire history of the page, check if the ostensibly fake name was added
before or after the name's appearance in the referenced magazine. If the
magazine is newer than the date that the name was added, it's immediately
suspect.
I think that should be a rule in wikipedia: All references *must* be older
than the page which includes the (purported) fact being referenced. If it's
newer, then it's not reliable.
One of the major criticisms against wikipedia is that it's basically a
jungle, where actual experts have to compete with egoistic laymen and
outright vandals.
For example, a physicist criticized wikipedia because he read one of its
physics pages (damned if I remember which one) and spotted several errors
and omissions, and proceeded to make lengthy corrections and tidying-up of
the page (probably spending hours on it). The original author of the page
reverted all is changes with the press of a button. The physicist gave up.
> >> right.
Paid nazi moderators working for big corps like Pixar. They need to protect
their IP and rewriting history has never been easier.
>>>> right.
In this case it was about famous cardiologists in the netherlands and
some cardiology institutions. Not really IP related I would say.
citizen per day.
