POV-Ray : Newsgroups : povray.off-topic : That looks ....... Unsafe Server Time
6 Mar 2026 04:13:09 EST (-0500)
  That looks ....... Unsafe (Message 1 to 8 of 8)
Subject: That looks ....... Unsafe
Date: 23 Sep 2011 12:59:18
Message: <4e7cbae6$1@news.povray.org>
Found while reading the article on transformers on Wikipedia.
http://www.zen40166.zen.co.uk/image006.jpg
~Mike
Subject: Re: That looks ....... Unsafe
Date: 23 Sep 2011 19:27:03
Message: <4e7d15c7@news.povray.org>
... as long as you don't actualy touch it while it's powered up, you
should be safe...
Manipulating that, I'd be more concerned with geting a scratch and
needing a tetanos shot.
Date: 24 Sep 2011 02:10:22
Message: <4e7d744e@news.povray.org>
  Isn't it a bit too late if you get the shot afterwards?
  And besides, isn't being vaccinated against tetanus kind of standard
almost everywhere?
Date: 24 Sep 2011 11:43:37
Message: <4e7dfaa9@news.povray.org>
Actually, it's not.
> almost everywhere?
There's a tetanus vaccine, but also a tetanus cure.  You can basically get
the tetanus in you and supress it before it causes ill effects like lock-jaw.
   How come I never get only one kudo?
Date: 24 Sep 2011 15:11:53
Message: <4e7e2b79$1@news.povray.org>
Le 24/09/2011 17:43, Darren New nous fit lire :
Well, the vaccine is easy.
The cure is a way to hell: removal of healthy parts around the wounds
(up to 2 cm of clean parts after the wound... what was the size of your
finger ?), heavy medication and continual analysis (nearly: every 4
hours...). It might turns the shortest way is using curare and
mechanical ventilator when it start to contract a lot.
Also, during the 4 to 6 weeks of cure, the intake must be raised to
3500/4000 calories per day... (remember an healty women would take 2000
on average, 2500 for a man and IIRC, something like 3000+ is for working
outside and moving charges), not something easy in the dangerous
countries which already lack the vaccine.
Date: 25 Sep 2011 00:59:36
Message: <4e7eb538$1@news.povray.org>
Well, there's a shot you can get after you've been poked with a rusty nail
and before the symptoms set in. I wouldn't imagine a vaccine at that point
helps. Once the symptoms set in, yes, it's much harder to fix.
Date: 25 Sep 2011 08:53:45
Message: <4e7f2459$1@news.povray.org>
Am 25.09.2011 06:59, schrieb Darren New:
> nail and before the symptoms set in. I wouldn't imagine a vaccine at
> that point helps.
It's actually a shot combining both a vaccine (intended to "jump-start"
an immune response ASAP) and antibodies (intended to keep the infection
under control until the immune response sets in).
Date: 25 Sep 2011 12:24:45
Message: <4e7f55cd$1@news.povray.org>
>> that point helps.
> It's actually a shot combining both a vaccine (intended to "jump-start" an
> immune response ASAP) and antibodies (intended to keep the infection under
Interesting! Thanks!
