POV-Ray : Newsgroups : povray.off-topic : Java Server Time
17 Jul 2025 10:07:39 EDT (-0400)
  Java (Message 1 to 10 of 23)
Subject: Java
Date: 22 Sep 2011 13:56:35
Message: <4e7b76d3$1@news.povray.org>
I will say, I'm only back into Java for a week, and even in spite of Java
generics and inner classes and all that, I'm already much more appreciative
of how much crap MS fixed in C#. :-)  Stuff that's taking me 4 or 5 lines,
with the types repeated three times each, is a one-liner in C#, even without
LINQ.
   How come I never get only one kudo?
Subject: Re: Java
Date: 22 Sep 2011 14:42:14
Message: <4e7b8186@news.povray.org>
Darren New escreveu:
> Java generics and inner classes and all that, I'm already much more
> appreciative of how much crap MS fixed in C#. :-)  Stuff that's taking
> me 4 or 5 lines, with the types repeated three times each, is a
> one-liner in C#, even without LINQ.
yeah, I like it how MS took ideas from Python and Haskell too.
a game sig: http://tinyurl.com/d3rxz9
Subject: Re: Java
Date: 23 Sep 2011 05:42:16
Message: <4e7c5478@news.povray.org>
> appreciative of how much crap MS fixed in C#. :-) Stuff that's taking me
> 4 or 5 lines, with the types repeated three times each, is a one-liner
Now you know why I dislike using languages which aren't Haskell...
Subject: Re: Java
Date: 23 Sep 2011 11:28:20
Message: <4e7ca594$1@news.povray.org>
Last time I used Java, we did a little dance. It went like this:
"Object-oriented programming allows you to use facilities such as
subclassing to extend the application in ways the original designers
never anticipated."
"By declaring your class 'final', you can prevent anybody subclassing it."
"Multiple inheritance is EVIL! We support only single inheritance."
"We support multiple inheritance using 'interfaces'. They're like
classes, but not as good."
"For receiving input, use the InputStream classes. For output, use the
OutputStream classes."
"For receiving input, use the Reader classes. For output, use the Writer
classes. The InputStream and OutputStream classes are now formally
deprecated. (Even though System.in, System.out and System.err mention
them explicitly.)"
"We will never deprecate the AWT."
"The AWT is now deprecated. Please use Swing in new applications."
"To create a horizontal scrollbar, create a Scrollbar object passing the
SCROLLBAR_AXIS_HORIZONTAL static constant. To create a vertical
scrollbar, create a Scrollbar object passing the SCROLLBAR_AXIS_VERTICAL
static constant. To determine whether a given scrollbar is horizontal or
vertical, call getAxis() and compare against these static constants. Do
not hard-code the numerical values, as more may be added in future."
"The 'int' type is not a class."
"If you want 'int' to be a class, you must wrap it using the 'Int' class."
"The int[] type is a class."
"For structuring complex applications, use the ApplicationFactory class."
"The ApplicationFactory class is now deprecated. Please use
ApplicationCenter for new."
"The ApplicationCenter class is now deprecated. The ApplicationFactory
class has been formally UNdeprecated. Please use ApplicationFactory for
new applications."
Basically, the language is loaded with hypocrisy, and the libraries were
huge, bloated, overly complex, insufficiently documented, and prone to
radical alterations every minor point release. (In fact, I gather that
these days, they don't even call it Java 1.5.x any more. They just call
it 5.x...)
Last time I checked, java.awt.Component has about 80+ methods. Every
single AWT widget inherits these 80+ methods. Any guesses what the hell
the difference between widget.init(), widget.start() and widget.begin()
is? The documentation helpfully fails to say. (E.g., "start() - starts
the widget." Yeah, thanks for that. I gathered.)
It still amuses me how almost every statically-typed programming
language lacks parametric types, /except/ for arrays, which are
hard-wired into the language.
(It still makes me cry that Haskell to this day still doesn't support
parametric unboxed arrays - you know, like what almost every programming
language known to man /does/ provide, out of the box...)
In Java, "int" is not a class. But "int[]" is. In fact, every array is a
class. And you cannot ever subclass it.
I love the way that with the JDK, compiling a class compiles every class
it depends on, but declaring two mutually-dependent classes is enough to
break the compiler. I wonder if they fixed that yet?
I love how you run your Java applet in IE and it works perfectly, and
when you run it in Netscape it dies with java.lang.NullPointerException.
I love how we have System.err (because System.error would be far too
verbose), and yet we have java.lang.ArrayIndexOutOfBoundsException.
Because, say, java.language.exception.ArrayIndex would be too hard?
I still think that Java is a great /idea/ - you specify a programming
language and a library of classes which is guaranteed to work the same
on *all* platforms. That's a very neat idea.
I also still think that the actual Java /design/ and /implementation/
utterly suck. Nice idea, too bad it went so drastically wrong from
thereon in.
(I suppose you could argue that C# is the same. You know, if it actually
worked on more than one platform...)
Subject: Re: Java
Date: 23 Sep 2011 12:43:42
Message: <4e7cb73e@news.povray.org>
Mono.
~Mike
Subject: Re: Java
Date: 23 Sep 2011 13:25:07
Message: <4e7cc0f3$1@news.povray.org>
> Mono.
Does Mono support more than 0.2% of what .NET supports yet?
http://blog.orphi.me.uk/
Subject: Re: Java
Date: 23 Sep 2011 14:20:42
Message: <4e7ccdfa$1@news.povray.org>
>>> actually worked on more than one platform...)
>> Mono.
Yes.  Go read the mono page and see what compatibility is.
Jim
Subject: Re: Java
Date: 24 Sep 2011 00:54:55
Message: <4e7d629f$1@news.povray.org>
I agree with every one of these rants.
Now, throw in Eclipse, as well as code that generates java code, which the
IDE doesn't know about.
> deprecated. (Even though System.in, System.out and System.err mention them
> explicitly.)"
And now there's a third set, NIO, or "New I/O".  I wonder what they'll call
the fourth set.
Yeah, I remember that one.
> "The ApplicationCenter class is now deprecated. The ApplicationFactory class
> has been formally UNdeprecated. Please use ApplicationFactory for new
> applications."
Oh, wait until you use some "dependency injection". Then you'll have *no*
idea how your code is structured. You not only get the indirection of
factories making other factories, but the factories you're depending on
aren't even compiled at the same time as everything else. Good luck figuring
out what you're trying to instantiate.
> documentation helpfully fails to say. (E.g., "start() - starts the widget."
Yep, yep. Altho MS has been starting to do that sort of crap lately too,
I've noticed.  The first release of Java had identical documentation for
StreamReader and StreamWriter, because they did the cut-and-paste and forgot
to change "read" to "write" everywhere.
> I love the way that with the JDK, compiling a class compiles every class it
> depends on, but declaring two mutually-dependent classes is enough to break
Nope.
> verbose), and yet we have java.lang.ArrayIndexOutOfBoundsException. Because,
I did some code yesterday where I had to break one type name over multiple
lines to keep within the 80-character line limit standard. It doesn't help
when you have stuff like
   FastPersistentLinearCollection<OrganizationIndividualRelationshipEntity>
I kid you not.
Subject: Re: Java
Date: 24 Sep 2011 09:33:24
Message: <4e7ddc24@news.povray.org>
>> them
>> explicitly.)"
> call the fourth set.
*facepalm*
Was it you that said something about "committing to backwards
compatibility way too early"?
>> class
>> applications."
> *no* idea how your code is structured. You not only get the indirection
> of factories making other factories, but the factories you're depending
> on aren't even compiled at the same time as everything else. Good luck
> figuring out what you're trying to instantiate.
It just amuses me that they thought the current design was bad, so they
deprecated it and build a better replacement. And then they decided the
repliacement was worse than the original, so they UNdeprecated it. I
mean, WTF?
> I've noticed.
I notice Office no longer comes with any documentation at all, just a
link to an online forum. (So if you have no Internet access, there's no
documentation AT ALL.) That's a nice touch... Why pay for experts to
write correct documentation when you can get your users to spread
erroneous twiddle for free?
> forgot to change "read" to "write" everywhere.
Yep. That's the great thing about embedding documentation in the source
code; it keeps the two in sync.
Oh, wait...
> Nope.
LOL. At least VisualStudio J++ got that right... (Oh, wait, Sun sued
Microsoft to make them discontinue that product.)
> multiple lines to keep within the 80-character line limit standard. It
> doesn't help when you have stuff like
> I kid you not.
That's just silly...
Subject: Re: Java
Date: 24 Sep 2011 11:37:28
Message: <4e7df938$1@news.povray.org>
On 9/24/2011 6:33, Orchid XP v8 wrote:
> Was it you that said something about "committing to backwards compatibility
> way too early"?
Yep. That was the fundamental failure, caused by the whole "write once"
marketing campaign.
> I notice Office no longer comes with any documentation at all, just a link
> to an online forum.
It has documentation. It just mixes it in with the online forum. I think you
have to chose to install it locally, tho, which is what you might be seeing.
>> I kid you not.
It makes perfect sense in context. It's just absurdly verbose.
What would be in C#
   var z = from y select z where z.id = myID
in java becomes
   List<OrganizationIndividualRelationshipEntity> z =
     Lists.ImmutableCopyOf(
       Lists.filter(y, new
Predicate<List<OrganizationIndividualRelationshipEntity>() {
      @override boolean apply(OrganizationIndividualRelationshipEntity x) {
      return x.id = myID;
I've lost track of closing braces....
