POV-Ray : Newsgroups : povray.off-topic : Zip cracking Server Time
17 Oct 2026 09:57:23 EDT (-0400)
  Zip cracking (Message 1 to 3 of 3)
Subject: Zip cracking
Date: 1 Sep 2011 05:37:34
Message: <4e5f525e$1@news.povray.org>
http://math.ucr.edu/~mike/zipattacks.pdf
If I'm reading this right, it says that Zip files using the default
DEFLATE compression and the default password-protect mechanism can be
decrypted on a 500MHz Pentium-II in a few hours. (In particular, that
you can use flaws in the algorithm to figure out the decryption key,
*without* needing to run a password cracker.)
If that's true... is there some software somewhere which implements this??
Subject: Re: Zip cracking
Date: 1 Sep 2011 11:42:27
Message: <4e5fa7e3@news.povray.org>
  Ever heard of this thing called "google"?
Date: 2 Sep 2011 04:10:10
Message: <4e608f62$1@news.povray.org>
Google finds plenty of password crackers for Zip files.
(Actually, that's a lie. It finds exactly two: "fzc", an ancient MS-DOS
program which I can't convince to work at all, and "fcrackzip", a
somewhat less kludgy thing which has very limited cracking abilities.
Basically, it can use brute-force, or a dictionary [not supplied], and
in the latter case it *only* matches exact dictionary words, not any
variations.)
The link, however, indicates that due to the laughably weak cipher used
for Zip files, you can crack the cipher itself without ever needing the
password.
This is significant, since the time required to crack a password depends
on how strong the password is, but the time required to crack the cipher
itself is constant. And given that the paper is talking about "a few
hours" with a P2, that might perhaps translate into only a few minutes
with a modern PC.
If you really can decrypt any Zip file, regardless of password strength,
within just a few minutes, that would be a Big Deal.
(On the other hand, *real* Zip tools now support AES encryption, which
presumably isn't so trivially crackable...)
Unfortunately, I can't find any off-the-shelf software that performs
this type of analysis. In fact, the vast majority of Google hits for any
search term remotely related to password cracking are from sites
promising miracles in exchange for very large sums of money. (There
should be a name for that... suckerware?)
