POV-Ray : Newsgroups : povray.off-topic : Encrypted storage Server Time
1 Nov 2026 08:22:15 EST (-0500)
  Encrypted storage (Message 1 to 39 of 39)
Subject: Encrypted storage
Date: 17 Aug 2011 11:57:31
Message: <4e4be4eb@news.povray.org>
I ordered some office supplied, and as usual they arrived with a flyer
telling me about all the fabulous stuff I could be buying. (E.g.,
apparently you can now buy computer monitors for less than £100, which
is impressive...)
One thing that caught my eye was a USB flash drivewith "AES 256-bit
hardware encryption" and "high strength password enforcement".
Obviously, my first assumption was that this is snake oil. For example,
I read a while back about a HD with "hardware AES-256 encryption", where
all it actually did was XOR all the data with a fixed 32-bit mask, and
then AES-encrypt that mask. So the /mask/ is encrypted with powerful
encryption, but the actual /data/ is trivially XOR-encrypted.
The little "FIPS 140-2" tag is a nice touch. Presumably that's just the
code number of the document that formally specifies the AES algorithm or
something.
Obviously the supplier's website contains no technical data at all. Like
most products, it's quite clearly been copied and pasted from somewhere
else (complete with mis-encoded special symbols). Eventually I tracked
down the product on the manufacturer's website. Apparently it /really
has/ been sent to an independent lab for conformance testing, and
there's actually a FIPS certificate number. I was eventually able to dig
this up on the FIPS website.
It's unclear to me what was actually tested. (E.g., I'm almost certain
they /didn't/ get professional cryptographers to try to crack the
encryption and retried data out of it.) Probably they just tested that
it implements AES correctly or something by comparing it against some
known test vectors.
 From what technical details I can find, it appears that it stores the
SHA-1 hash of a user-supplied password, and uses that for
authentication. The AES encryption keys are apparently stored
unencrypted inside the unit. Actual data is encrypted with these keys,
running the cipher in CBC mode. (Not the strongest, but not the weakest
either.) It uses a hardware RNG together with the ANSI X9.31 PRNG
algorithm. And it sounds like physically it's fairly hard to get into
the device.
The documents confirm that the device is certified to FIPS 140-2 level 2
compliance. (The highest level is level 4, and it looks like it wouldn't
be applicable to portable devices, only to complete systems.) It's using
a sensible-looking set of algorithms, and it's been through some kind of
verification process. So I'm reasonably confident that this device isn't
/trivially/ hackable.
(I was, however, amused by the manufacturer's product advert. "This
product is routinely used by the hospitals, banks, the police and the
armed forces." Well, yes, technically that's probably true. And
unencrypted floppy disks are also almost certainly used by the same
people. Does that make unencrypted floppy disks count as "secure"? For
that appears to be what they're trying to imply...)
My next step was to go to my supplier of choice and see what kinds of
encrypted USB devices they could sell me, at what prices.
Prices start at £4 for a no-name 2GB flash drive. The cheapest
"protected" device I could find was £6 for a drive with "optional
password protection for added security". No word on how it's
implemented. I imagine it isn't especially secure, it just stops curious
individuals nosing through your files.
All of the cheapest "secure" drives mention the keyword "software". In
other words, it's a normal USB drive, with some [probably Windows-only]
software on it which asks you for a password, and won't let you access
any files unless you type in the correct password. I severely doubt that
any data is actually encrypted; instead, the supplied software merely
refuses to let you look without the password. It's probably trivially
easy to defeat such software. (Perhaps it's as simple as installing
Linux...)
The first product to actually talk about /encryption/ comes in at £9
(which is by no means "expensive" compared to the other products in the
list). The fact that the system requirements claim that "2 unused drive
letters" are required suggests that once again, this is a software
solution. In other words, when you insert the thing, it runs some
[Windows] software that transparently encrypts and decrypts data as it
is transferred. Still, that's a small step up in security. Even if the
software doesn't function, you can't get at the data. (Assuming it does
something sensible with the encryption keys.)
Going up the price list, all the "secured" devices still talk about
hardware (although they gradually shout louder and louder about AES).
The cheapest product I could find which is definitely using /hardware/
encryption was £20. (Still not actually that much more expensive than
other big-brand devices.) "Includes XYZ software to access the encrypted
data." So you still need Windows to access it.
At £24 is an apparently rather popular device that has a 5-digit keypad
on the casing that allows you to enter a PIN (from 4 to 10 digits).
Apparently the LEDs change colour after you've unlocked it. When you
unplug it from the PC, it locks again. It definitely uses AES-256, and
it's probably implemented in hardware. 5^10 is roughly 10 million, and
hence the PIN must be entered by hand, you aren't going to crack this
too easily. (No word on whether the device disables itself given a
number of access attempts.)
The cheapest device I could find that is actually FIPS 140-2 certified
(again, at level 2) was for £36. That's for a 4GB drive which is also
physically quite rugged. Now, £36 is a lot more than the £5 for the
cheapest 4GB drive. On the other hand, it's not drastically more than
you'd pay for a 32GB drive (those start at £30). Sure, it *is* quite a
lot more expensive. But it's not /drastically/ expensive, really. I
would have expected to pay maybe £150 for a device with hardware AES
encryption.
It's not so much that the encrypted drives are "expensive", more than
the unencrypted ones are jaw-droppingly cheap. If you actually /needed/
encryption, £36 isn't really all that pricey.
On the other hand, for £0 you can download a copy of GPG and manually
encrypt all your files before putting them onto an external storage
device. Then you know /exactly/ which way it's been encrypted, and
further more you can arrange it so that (for example) it's protected by
a certificate rather than a password...
Subject: Re: Encrypted storage
Date: 17 Aug 2011 13:05:04
Message: <4e4bf4c0@news.povray.org>
> device.
Of course, file by file encryption makes the encryption obvious.  Try
truecrypt instead. :)
Jim
Date: 17 Aug 2011 13:57:30
Message: <4e4c010a$1@news.povray.org>
>> device.
Oh, GPG is quite capable of taking /multiple/ files and encrypting the
entire lot as one binary blob. So all you know is that it's encrypted,
and how big it is. You can't tell how many files are inside, nor what
their uncompressed size is...
http://blog.orphi.me.uk/
Date: 17 Aug 2011 14:28:08
Message: <4e4c0838$1@news.povray.org>
 code
> number of the document that formally specifies the AES algorithm or som
ething.
No, it describes the algorithms and how hard it is to break into the devi
ce
and so on. The trick is it's a standard, so the guy in charge of ordering
office supplies can say "Is it FIPS 140-2 compliant?" without having to
understand how to evaluate that himself. Wikipedia is your friend in this
 case.
2
t be
> applicable to portable devices, only to complete systems.) It's using a
t
Which device was this? I could use something to stick my passwords on.
eypad on
> the casing that allows you to enter a PIN (from 4 to 10 digits). Appare
ntly
> the LEDs change colour after you've unlocked it. When you unplug it fro
m the
> PC, it locks again.
Kewl. And what was this one?
> It definitely uses AES-256, and it's probably
Note that AES in hardware just means they added a trivial processor core
to
the same core that runs the USB protocol. It's not like it's hard to do.
It's just more transistors on the silicon that's already there.
   How come I never get only one kudo?
Date: 17 Aug 2011 15:24:57
Message: <4e4c1589$1@news.povray.org>
>>> device.
I haven't looked at GPG in a while, but didn't know it could do that.
I'll have to have another look at it.
But with Truecrypt, you can encrypt the entire device and there's no
indication of anything on it other than just random data.
Jim
Date: 18 Aug 2011 04:09:53
Message: <4e4cc8d1$1@news.povray.org>
PGP can encrypt a bunch of files as a self-decrypting executable file.
Then again, PGP [now] costs money. AFAIK, GPG doesn't have this feature.
Sure. There is that. In fact, I'm told there's a number of freeware
whole-drive encryption products. They're usually applied to HDs, but I
suppose they should apply equally to portable ones.
I also imagine that such products have to be /installed/ on any machine
before they can be used. GPG has the advantage that it's just a single
executable. I mean, the whole point of portable storage is to be, you
know, /portable/. If I encrypt all my stuff and put it on a flash drive,
and put a copy of GPG on there as well, I can decrypt on any PC I might
visit. (Especially if I include a Linux binary as well as a Windows
one.) If I use Truecrypt or similar, any time I visit another PC I have
to spend time installing and configuring software before I can access my
data.
The same advantages apply to drives with hardware encryption, of course...
Date: 18 Aug 2011 04:29:59
Message: <4e4ccd87@news.povray.org>
>> the code
>> something.
> device and so on. The trick is it's a standard, so the guy in charge of
> ordering office supplies can say "Is it FIPS 140-2 compliant?" without
> having to understand how to evaluate that himself. Wikipedia is your
> friend in this case.
Oh yeah, I know what FIPS 140-2 is *now*. I meant before I looked it up
I assumed it was going to be the designation for AES or something.
...the irony... it burns...
>> keypad on
>> Apparently
>> from the
>> PC, it locks again.
OK, for anyone else wanting to duplicate my results:
http://www.ebuyer.com/223405-extra-value-2gb-usb-flash-drive-ev-usb2gb
Cheapest drive. (2GB, £4)
http://www.ebuyer.com/132692-fujifilm-2gb-usb-2-0-secure-and-splash-memory-card-n079050a
Cheapest drive with "security" features. (2GB, £6, trivial password
protection.)
http://www.ebuyer.com/180530-kingston-datatraveler-locker-4gb-usb-flash-drive-with-encryption-100-privacy-dtl-4gb
Cheapest drive which mentions "encryption". (4GB Kingston-branded, £9,
appears to use Windows software to do the encryption.)
http://www.ebuyer.com/159024-kingston-2gb-datatraveler-vault-usb-flash-drive-hi-speed-with-dtv-2gb
Cheapest drive with "hardware encryption". (2GB Kingston-branded, £20,
uses Windows software to access the drive.)
http://www.ebuyer.com/196586-corsair-flash-padlock-2-8gb-usb-flash-drive-with-256-bit-aes-cmfpla8gb
The drive with a physical keypad. (8GB Corsair-branded, £24, uses a 4 to
10 digit PIN to, 5 unique digits, lights up when unlocked, locks when
unplugged. Claims to be AES-256 encrypted.)
http://www.ebuyer.com/159010-kingston-datatraveler-blackbox-4gb-usb-flash-drive-dtbb-4gb
Cheapest FIPS certified drive. (4GB Kingston-branded, £36, FIPS 140-2
level 2 certified.)
Some of the even more expensive drives boast about using AES in XTS
mode, which is stronger than CBC. Well, whatever...
> to the same core that runs the USB protocol. It's not like it's hard to
> do. It's just more transistors on the silicon that's already there.
Not necessarily. I'm pretty sure you can buy off-the-shelf components
that run crypto primitives like AES.
(Also, doesn't the USB protocol require a processor core already? In
which case, all you have to add is firmware for performing AES.)
Fundamentally though, it doesn't matter whether AES is in special
hardware or in firmware. The point is, the encryption is transparent to
the host PC. And *that* means that the host PC can't screw it up! ;-) It
also means you can't actually access the ciphertext at all, without
taking the device apart.
Subject: Re: Encrypted storage - sensitive data on non-trustworthy computers
Date: 18 Aug 2011 05:08:06
Message: <4e4cd676$1@news.povray.org>
GPG and Truecrypt don't have to be “installed” but can be used directly
from USB drive, sure.
But: If you have sensitive data on your USB drive you never ever should
decrypt them on a foreign PC, in an Internet café etc. because you
cannot trust them at all (keylogger, spyware etc.)
Call me paranoid but I distrust any Windows PC (and any other PC that is
under control of a talented Linux guy) and I would never enter any
sensitive password on them (neither web mail nor ssh nor crypted USB
drives etc.)
Lars R.
Date: 18 Aug 2011 05:27:11
Message: <4e4cdaef$1@news.povray.org>
GPG, yes. (I've done it.) Truecrypt, I couldn't say. Never tried it.
This is of course a valid point. If your drive actually contains
anything "sensitive" then no, you really don't want to be decrypting
that for arbitrary PCs.
If, on the other hand, the drive just contains your holiday photos that
you'd prefer random strangers to /not/ be able to access, then
encrypting the data will prevent that, and I wouldn't be too worried
about decrypting it in an Internet cafe.
As with everything security-wise, it depends how much security you need.
1. I keep all my favourite program installers on a flash drive. None of
it is encrypted, but then again, none of it is secret either. I don't
really care who can see it. Security is not an issue.
2. If I had, say, my holiday photos or something on there, which I don't
want random strangers looking at, I could encrypt it in various ways. If
the drive gets lost or stolen, nobody can access the contents. But
decrypting it on an untrusted PC is no big deal, really.
3. If I had something like my bank details on there, I would /not/ be
decrypting that stuff on any system except one that I set up myself. But
then, really, WTF would that be on a portable drive for anyway? I would
probably GPG encrypt, using public key cryptography rather than a mere
password to secure it. Since presumably only trusted systems have a copy
of my private key, I /can't/ decrypt the data from anywhere else, even
if I want to.
Date: 18 Aug 2011 10:58:00
Message: <4e4d2878$1@news.povray.org>
What's ironic about wanting to put passwords or private keys on an encrypted
portable medium?
Thank you!
> Not necessarily. I'm pretty sure you can buy off-the-shelf components that
I was thinking it would likely be a core, not a component as such.
> (Also, doesn't the USB protocol require a processor core already? In which
That was my point, yes. :-)
> Fundamentally though, it doesn't matter whether AES is in special hardware
> or in firmware. The point is, the encryption is transparent to the host PC.
Right.
Date: 18 Aug 2011 11:03:59
Message: <4e4d29df@news.povray.org>
> encrypted portable medium?
You want to password-protect your passwords? That's just crazy. (The
idea of a password is that you're supposed to /remember/ it. Which makes
it impossible to ever steal.)
Password protecting private key files is another matter. Having the
keyfile on a portable device means it's always with you, you can use it
like a physical key, but if you lose it, the password should stop
anybody else pretending to be you.
> Thank you!
No problem. There's no charge for this service. ;-)
(Just waiting for you to complain that you can't order from the USA now...)
>> that
I'm not so sure about AES, but its predecessor DES is very, very easy to
implement in hardware. Literally *all* you have to do is a few XOR
operations, rearrange the bits slightly, and implement a few S-boxes.
Each S-box is probably a dozen logic gates. That's really very, very
little hardware at all. An 8-segment display driver probably has more
transistors in it than that. And it's probably very much faster than
doing this in software, where things like complicated bit permutations
are fairly expensive.
(My recollection is that AES involves finite field arithmetic that's
quite fiddly in software, but probably very simple in hardware. I don't
remember a great amount of detail though.)
>> hardware
>> host PC.
> Right.
Mmm, I wonder if it's immune to side-channel attacks? >:-D
Date: 18 Aug 2011 13:15:35
Message: <4e4d48b7$1@news.povray.org>
Of course, that executable file would probably only run on Windows,
natch. ;)
> data.
Actually, using Truecrypt on Linux doesn't require system-level access,
and you just run a single executable.  The Windows version does use a
filesystem driver, though, so on Windows you do need to install it before
you can use it.
> course...
True.
Jim
Date: 18 Aug 2011 13:18:47
Message: <4e4d4977$1@news.povray.org>
Certainly, though you can get a certain degree of security if you also
have a bootable OS, say a Linux LiveCD or LiveUSB.  That doesn't remove
hardware keyloggers, of course, but it does remove the software threats.
> drives etc.)
Using ssh - easy way would be to use public key authentication from a
removable storage device, though I would prefer to boot my own media for
something like that on a public system.
Of course, if you do this in the public library, the staff sometimes can
tend to get a bit testy about it (here in the SLC library, they have
software to restrict your usage to a particular period of time, obviously
that doesn't run if you use your own OS).
Jim
Date: 18 Aug 2011 13:21:40
Message: <4e4d4a24$1@news.povray.org>
On 8/18/2011 8:03, Invisible wrote:
> You want to password-protect your passwords? That's just crazy. (The idea of
> a password is that you're supposed to /remember/ it. Which makes it
You're also supposed to use a different, long password for every site. It's
basically a key locker.
Plus, of course, it has the advantage of being able to store actual
sensitive files in a mildly secure way.
Unlike some here, I have learned how to use google to find such things are
reviews and local retailers. ;-)
AES (and, really, almost all the modern block cyphers) are designed that
way. They're all designed to run on smart cards and stuff like that, except
for the "fish" ciphers (blowfish, twofish, etc), iirc, which are
specifically designed to be fast in software.
Well, first you have to get to the chip in its encrypted state or something.
I'm (personally) not so worried about it that I think someone's going to
crack the case open and hit it with a logic probe. Indeed, I haven't found
any review that actually says it's encrypting the data on the chip itself.
If it can change the password instantly, I'd doubt the actual data is
encrypted. I did read one review where they cracked it open, took out the
battery for a couple weeks, put it back together, and the PIN was still enabled.
Date: 18 Aug 2011 13:47:40
Message: <4e4d503c$1@news.povray.org>
> natch. ;)
Yeah, I should think so. It also has a nice GUI. ;-)
> you can use it.
That's what I figured, yes.
Date: 18 Aug 2011 13:58:06
Message: <4e4d52ae$1@news.povray.org>
> except for the "fish" ciphers (blowfish, twofish, etc), iirc, which are
Well, there's "easy" and there's "really easy". DES is really easy. AES
I'm not so sure about, off the top of my head.
But sure. None of these ciphers are "hard" to implement in hardare.
> something. I'm (personally) not so worried about it that I think
> someone's going to crack the case open and hit it with a logic probe.
You don't have to open the case for side-channel attacks to be effective.
Maybe if you sent certain requests, the timing of the responce varies in
a way that tells you something about the encryption key or the password
hash or the PRNG state. Maybe you can measure power consuption and find
out useful info. Heck, maybe the temperature varies, or it leaks RF signals.
Come to think of it, /that/ is the kind of thing I would expect FIPS
certification to be testing for. Anyone can implement AES correctly.
It's not hard to run a few test vectors and confirm that you get the
correct numbers. Making sure that the assembled system is actually
secure is a whole other matter...
> Indeed, I haven't found any review that actually says it's encrypting
> the data on the chip itself. If it can change the password instantly,
> I'd doubt the actual data is encrypted. I did read one review where they
> cracked it open, took out the battery for a couple weeks, put it back
I looked at the FIPS documentation for one of the drives. (Not the one
in the list I gave you, but something similar.) It actually describes,
in vague detail, how the encryption works. It seems it stores the
encryption keys in the clear (?!), and also stores the SHA-1 hash of the
password. So presumably when you change the password, it just updates
the SHA-1 hash.
To me, that seems like a very strange way to implement. However, there's
no particular reason why you can't use the SHA-1 hash of the password to
AES-encrypt the main AES encryption key. And then changing the password
is /still/ instant, without having to re-encrypt any data.
Date: 18 Aug 2011 14:39:42
Message: <4e4d5c6e$1@news.povray.org>
On 8/18/2011 10:57, Orchid XP v8 wrote:
> Maybe if you sent certain requests, the timing of the responce varies in a
> way that tells you something about the encryption key or the password hash
> or the PRNG state. Maybe you can measure power consuption and find out
If it doesn't even respond to USB signals until you've unlocked it, it would
seem to pretty much eliminate side-channel attacks.
> To me, that seems like a very strange way to implement. However, there's no
> AES-encrypt the main AES encryption key. And then changing the password is
Well, yes, that's true.  In any case, by the time you've taken that apart,
you can probably brute-force the thing pretty easily. You don't have to
brute-force the entire 160 bit SHA-1 key if you can brute-force the possible
hashes of 5^10 (9 million) possible combinations.
Date: 18 Aug 2011 17:49:13
Message: <4e4d88d9@news.povray.org>
>>> feature.
>> natch. ;)
>> before you can use it.
What I wish they had for the Linux version was the option for a hidden OS
like they do with Windows.  I may have to image this laptop and see if I
can figure out a way to bodge it together to do that (but I wouldn't be
surprised if it required a special driver in the OS)
Jim
Date: 18 Aug 2011 19:24:17
Message: <4e4d9f21$1@news.povray.org>
What does that even mean? That you can boot off the trucrypt partition?
Date: 18 Aug 2011 19:40:13
Message: <4e4da2dd$1@news.povray.org>
>> OS like they do with Windows.
Yep.  They've got a special bootloader that's installed (can be made to
present something that looks like there's nothing installed, but you type
your password in), and then it boots the hidden OS.  You can combine that
with a non-hidden OS (though hidden partitions with regular encrypted
partitions can be dangerous - unless you mount the outer volume so it
protects the inner volume, you risk overwriting data in the inner volume)
so the sensitive data is completely hidden from view.
It's an interesting concept.
Jim
Date: 19 Aug 2011 04:00:56
Message: <4e4e1838@news.povray.org>
>> in a
>> hash
> would seem to pretty much eliminate side-channel attacks.
Oh, well, if you're talking about the one with the combination lock
(which *isn't* FIPS certified) then yeah. The most you could worry about
is RF leakage, or maybe heat. (But you would need some damned sensitive
thermometers to measure that.) I would imagine RF output is both very
easy to check for and shield against.
I was thinking more about the ones where you insert the USB drive and it
asks for a password before it will let you see the encrypted partition.
>> there's no
>> password is
> apart, you can probably brute-force the thing pretty easily. You don't
> have to brute-force the entire 160 bit SHA-1 key if you can brute-force
> the possible hashes of 5^10 (9 million) possible combinations.
Oh, sure, the password or PIN or whatever is *clearly* the weakest point
in the system. (Assuming the RNG isn't broken...)
Date: 19 Aug 2011 11:03:58
Message: <4e4e7b5e$1@news.povray.org>
Yeah.  I wasn't interested in one I couldn't use on multiple OSes.
Yup, agreed.
> Oh, sure, the password or PIN or whatever is *clearly* the weakest point in
I think I'm OK with storing things on there that can only be extraced by
someone willing to break it open, extract the actual flash chip, and insert
that chip into a new controller. :-)
Date: 19 Aug 2011 11:09:32
Message: <4e4e7cac@news.povray.org>
I can see why that wouldn't appeal.
It's a pity there isn't a standard, portable way of doing this really.
>> point in
> insert that chip into a new controller. :-)
It depends on the level of security you want, really.
If you're anything like me, you don't particularly need ultra-security.
Date: 20 Aug 2011 06:15:08
Message: <4e4f892c$1@news.povray.org>
Please tell me how to remember passwords for half a dozen systems each
with two or three clients that force you to change your password
regularly. Along with accounts for umpteen different company websites
and personal logons?
Regards
Date: 20 Aug 2011 06:28:11
Message: <4e4f8c3b$1@news.povray.org>
Damn. You have even more passwords than I do!
Date: 20 Aug 2011 06:34:04
Message: <4e4f8d9c$1@news.povray.org>
Then I move to the next job and start again.
Regards
Date: 20 Aug 2011 06:40:33
Message: <4e4f8f21$1@news.povray.org>
Le 20/08/2011 12:15, Stephen nous fit lire :
Have a small black book with the passwords, one page per system.
For the changing systems, using a rotation of 3 entries should do it
(they are weak, badly managed... they usually check only against the
previous one; I only once encountered a really painful one which stored
the 10 lasts)
Date: 20 Aug 2011 06:44:40
Message: <4e4f9018$1@news.povray.org>
> the 10 lasts)
Our network stores the last 12 passwords. Stupidly, it enforces a
*minimum* password age of 1 day. So, like, if your password is
compromised the day you change it, you cannot change it until tomorrow. WTF?
The idea, of course, is that you can't enter 12 passwords and then go
back to your original password. As if *anybody* dumb enough to work here
would realise they could do that.
What it /does/ mean is that if I reset somebody's password, I can't
reset it, let them log back in, and then have them change it again. They
have to wait until tomorrow (by which time they WILL have forgotten). So
they end up with a weak password for a month. (Or I reset the password
to something strong, and they whine at me for a month.)
Date: 20 Aug 2011 07:03:36
Message: <4e4f9488@news.povray.org>
  The solution to both problems is really obvious: Make the waiting time
progressive rather than fixed. In other words, you can change your password
a second time immediately, but the third time requires something like a
minute before you can do it, the fourth time 5 minutes, and so on, until
the 12th time requires a few days or whatever.
  This both prevents potential abuse *and* allows you to immediately change
your password again for whatever reason (eg. because it was reset or
because it was compromised or whatever).
  Why do not developers understand trivial solutions like this?
Date: 20 Aug 2011 07:14:25
Message: <4e4f9711$1@news.povray.org>
> the 10 lasts)
Since I generally access the systems from the same laptop. I have a
small black spreadsheet which is password protected and the entries are
in ROT13 so I can tell where in my sequence of passwords I am at a
glance but someone looking over my shoulder cannot. The laptop itself is
encrypted.
BTW That was a "Tell me about it?" type of question. I did not expect a
literal answer. ;-)
Regards
Date: 20 Aug 2011 08:20:33
Message: <4e4fa691$1@news.povray.org>
That would work.
Myself I'd probably just follow the Keep It Simple principle; no minimum
password age at all. As I say, very few people are smart enough to
realise that the system can be abused this way. Heck, most people just
/assume/ that the system keeps all passwords forever. They don't know
that 12 is our magic number.
Date: 20 Aug 2011 08:34:54
Message: <4e4fa9ed@news.povray.org>
  Security by non-disclosement isn't a good strategy either. It would be
like arguing "nobody is going to hack our password database if we don't
tell anybody in which directory it's located".
  (Yes, I know this is not a question of hacking or the users being
malicious and potentially causing mayhem. However, I see no reason to
not prevent even "innocent" abuse of the system.)
Date: 20 Aug 2011 10:39:22
Message: <4e4fc71a$1@news.povray.org>
On 8/20/2011 3:44, Orchid XP v8 wrote:
> As if *anybody* dumb enough to work here would realise they could do that.
Uh.... you work there?
> What it /does/ mean is that if I reset somebody's password, I can't reset
You're doing it wrong. Assuming you're talking Windows, I believe there's a
checkbox that says "Must change password on next login".
Date: 20 Aug 2011 14:07:02
Message: <4e4ff7c6$1@news.povray.org>
>> that.
And what does that make me?
> there's a checkbox that says "Must change password on next login".
...and that checkbox is frequently the *reason* I'm having to manually
reset the password in the first place. If the user's password expires,
and they only access our network via the VPN, they don't get the warning
to change password. They just get silently locked out.
Date: 20 Aug 2011 14:30:09
Message: <4e4ffd31$1@news.povray.org>
>>> that.
Employed. :)
I'm about ready to be done with the "not currently employed" status -
it's been a quiet summer, but I'd rather actually be making an income
(been doing a little contract work, but not having health coverage is a
bit of an issue).
Jim
Date: 20 Aug 2011 17:29:51
Message: <4e50274f@news.povray.org>
Some post-it on your monitor ;P
After all, it's prety common practice almost everywhere...
Date: 21 Aug 2011 03:17:21
Message: <4e50b101@news.povray.org>
Written in mirror writing? :-)
Regards
Date: 21 Aug 2011 06:20:38
Message: <4e50dbf6$1@news.povray.org>
In fairness, this is probably OK for the PC in your house. If
unauthorised people are in your house, you have *way* bigger problems
than passwords...
In an office though, DO NOT DO THIS! >_<
Date: 21 Aug 2011 12:58:22
Message: <4e51392e@news.povray.org>
> than passwords...
It's a common sight in many offices, especialy when the passwords are
numerous and change often.
They usualy read similar to:
Site/acount
User name - password
The password can be under the user name.
Some only list the user name and password, or only the password for the
main password the user need to start his work day. In that later case,
you only have to look at the office/desk to figure the user name.
I know, it's realy no good, but common...
