POV-Ray : Newsgroups : povray.off-topic : This is, in part, why many Windows updates require reboots Server Time
17 Oct 2026 09:57:50 EDT (-0400)
  This is, in part, why many Windows updates require reboots (Message 1 to 21 of 21)
Subject: This is, in part, why many Windows updates require reboots
Date: 4 Aug 2011 21:45:24
Message: <4e3b4b34$1@news.povray.org>
http://neugierig.org/software/chromium/notes/2011/08/zygote.html
Check out the third paragraph.
   How come I never get only one kudo?
Subject: Re: This is, in part, why many Windows updates require reboots
Date: 5 Aug 2011 00:17:33
Message: <4e3b6edd$1@news.povray.org>
It's a shame he doesn't get the Linux pieces down very well.
The package manager, for example, doesn't control whether files are
replaced or deleted - what he's seeing is part of the standard filesystem
behaviour.  I could just as easily cause the problems he describes by
deleting necessary files while a program is running.
Similarly, his assertion in the last paragraph is laughably funny - ask
any user of Slackware whether the apps they use are 'lame ports of
Windows apps" because they're all installed through tgz files.
And what he asserts about Chrome and Chromium not working well together
shows a lack of understanding of packaging dependencies for RPM and DEB
packages.  They *could* well set up a dependency that says not to install
if Chromium is installed (or to identify the packages as non-compatible).
Jim
Date: 5 Aug 2011 11:12:28
Message: <4e3c085c@news.povray.org>
  If the program is keeping the file open, then deleting the file won't
affect it. However, if it's a file that the program opens and closes
repeatedly during its execution, then that's indeed the case.
Date: 5 Aug 2011 14:37:38
Message: <4e3c3872$1@news.povray.org>
>> I could just as easily cause the problems he describes by deleting
Yes, and that's the case regardless of whether it's the user at the
console doing it or a package manager doing it. :)
Jim
Date: 5 Aug 2011 16:31:11
Message: <4e3c530f$1@news.povray.org>
> behaviour.
Nah. I can overwrite a config file, or I can write a new file and rename it
to be the config file, and these are entirely different things on Linux. The
package manager just happens to do the latter.
The whole story is basically:
1) We can't just fork, because glib and other libraries might have locks
open, and in that case things with threads break, and we use threads.
2) We can't just fork+exec, because if we exec, we get the new version of
the executable which expects the new versions of files and it might not
communicate well with the existing running processes.
3) So instead we start a helper process to hold open all the old versions of
files because that's the only way to keep them from being deleted once
they're unlinked, and the package manager unlinks old versions of files. And
stuff often breaks if we forget to make sure every file we might need gets
versioned this way.
Date: 5 Aug 2011 16:35:14
Message: <4e3c5402$1@news.povray.org>
>> what he's seeing is part of the standard filesystem behaviour.
> it to be the config file, and these are entirely different things on
> Linux. The package manager just happens to do the latter.
Sure, but he's describing the behaviour as a package manager behaviour,
when in fact it's an OS/filesystem behaviour.
> of the executable which expects the new versions of files and it might
> not communicate well with the existing running processes.
> versions of files because that's the only way to keep them from being
> deleted once they're unlinked, and the package manager unlinks old
> versions of files. And stuff often breaks if we forget to make sure
> every file we might need gets versioned this way.
But that's not what he wrote, and in writing it the way he did, he got
some things wrong.  <shrug>  It happens, but it's important to understand
how he got them wrong so the above makes sense.
Jim
Date: 5 Aug 2011 16:46:57
Message: <4e3c56c1$1@news.povray.org>
What "behavior" do you think is enforced by the file system that isn't a
choice of the package manager?
> some things wrong.<shrug>   It happens, but it's important to understand
I think that's pretty much exactly what he wrote. I didn't see anything he
actually got wrong.
Date: 5 Aug 2011 17:19:33
Message: <4e3c5e65$1@news.povray.org>
> behaviour.
Or, to put it another way...
% echo alpha > alpha ; echo beta > beta
% (sleep 20 ; cat ) < alpha &
% sleep 3 ; cp beta alpha
What does "cat" print?
% sleep 3 ; mv beta alpha
They're both standard file system behaviors. It's the choice of the package
manager to use one technique over the other, not the choice of the file system.
Date: 5 Aug 2011 21:59:30
Message: <4e3ca002@news.povray.org>
That of allowing files to be deleted while they're open.  I don't "think"
that's a choice of the package manager, because it is in fact how *nix
filesystems work, regardless of what the app thinks about it.
>> understand how he got them wrong so the above makes sense.
> he actually got wrong.
I guess we'll have to disagree on it.  I read his description and found
that it made no sense at all, and I'm not exactly a newbie to Linux....
Jim
Date: 5 Aug 2011 22:00:43
Message: <4e3ca04b@news.povray.org>
> package manager to use one technique over the other, not the choice of
> the file system.
Yes, it's a choice of whether to rename the file or delete it.  That's
not really my point.
Jim
Date: 5 Aug 2011 22:01:02
Message: <4e3ca05e$1@news.povray.org>
Agh, rename or copy.
Jim
Date: 5 Aug 2011 23:24:42
Message: <4e3cb3fa$1@news.povray.org>
Well, yes, it allows files to be deleted while they're open.
"thankfully, package updates write a new file and rename it over the old
name, leaving our open copy the only remaining reference to the old name."
That's the only place where he makes a distinction, and that's what I'm
talking about. As I demonstrated elsewhere, it's a choice of the package
manager whether to write a new file and rename it, or overwrite the old
file, which is what he's talking about here.
OK. It made perfect sense to me, and I'm not exactly a newbie to Linux *or*
Unix.
Date: 5 Aug 2011 23:26:01
Message: <4e3cb449$1@news.povray.org>
>> the file system.
OK. Then I'm not seeing your point. What statement do you think is actually
incorrect?  I must be missing something, because you're not the only person
who has told me there are incorrect assertions in the article, but I've not
gotten anyone else to actually say what they are either, other than arguing
that Linux's package management isn't "inferior".
Date: 5 Aug 2011 23:26:48
Message: <4e3cb478@news.povray.org>
Or, more technically, unlinked. The files obviously don't get deleted.
Date: 6 Aug 2011 00:20:10
Message: <4e3cc0fa$1@news.povray.org>
>>> the file system.
> actually incorrect?  I must be missing something, because you're not the
> only person who has told me there are incorrect assertions in the
> article, but I've not gotten anyone else to actually say what they are
> either, other than arguing that Linux's package management isn't
> "inferior".
"one distinction between "lame port of a Windows app" and "real Linux
software" is exactly whether you distribute as a tarball or as a package."
Factually incorrect, as I said, ask anyone using Slackware what they
think of that statement and they'll laugh you out of the room.
"Secondly, and more importantly, we knew that regardless of what we did
for Google Chrome the Linux distros would attempt to stuff Chromium into
their package manager even when they know it breaks the app, much like
they've done to Firefox."
Factually incorrect, since package management systems that use RPM or DEB
allow for the creation of packages that won't install if a conflicting
package is installed.
"Now that I've summarized it in these terms it sounds a little
depressing, but there it is"
Factually incorrect, because he got the previous two statements
completely wrong.
Jim
Date: 6 Aug 2011 01:20:12
Message: <4e3ccf0c$1@news.povray.org>
Does a tarball on Slackware actually track dependencies? I think any general
statement you make about Linux is going to be wrong in at least one
distribution. Plus, that's one distinction. He's obviously talking about the
distros that actually have packages.
I think making a Chrome update package that won't install if Chrome is
already present would be counterproductive.  What do you think the
"conflicting package" would be?
Date: 6 Aug 2011 01:39:32
Message: <4e3cd394$1@news.povray.org>
Le 06/08/2011 07:20, Darren New nous fit lire :
well, it won't compile if the dependencies is not already installed. ;-)
I remember trying to compile gnome on a slackware (old gnome, old
slackware,... old time). It was a bit a game of "try and error/again" as
there was a lot of modules, with no clear order described.
Gentoo is also source-based, and it does track dependencies in its
packages system. It's easier that slackware, as long as you are ok to
follow their option/use system.
(but it can be complex if you want option A for some packages and not-A
for some others... which have a common package!)
Date: 6 Aug 2011 11:19:47
Message: <4e3d5b93$1@news.povray.org>
Well, yes. The trick is (A) keeping things up to date, and (B) not
uninstalling dependencies for code that's installed. :-)
I mean, there were lots of UNIX systems without any sort of package manager.
That's what RedHat fixed.  So I'd say, yes, sure, a "real" Linux program is
available as a package.  If your Linux doesn't use packages, then obviously
you don't use the package version of the program.
That was always the problem I ran into, yes. Or conflicting versions of DLLs
both referenced without version numbers.
Date: 6 Aug 2011 15:29:00
Message: <4e3d95fc@news.povray.org>
>  > package."
> general statement you make about Linux is going to be wrong in at least
> one distribution. Plus, that's one distinction. He's obviously talking
> about the distros that actually have packages.
It's been a long time since I installed a package on Slack, so I don't
know how they track dependencies.  But my point is that he says that
distributing a tarball doesn't make it "real Linux software", but a "Lame
port of a Windows app".  There are plenty of software packages for Linux
that are only distributed as a tarball.  Truecrypt comes to mind,
actually.  One might argue that there is also a Windows version of
Truecrypt so it might qualify as a "lame port of a Windows app" until one
realizes that architecturally, the Linux version is quite different
(doesn't require a system-level device driver on Linux, but it does on
Windows - for example).
If he's "obviously talking about the distros that actually have
packages", then the point becomes meaningless because it's self-
referential.
>  > DEB allow for the creation of packages that won't install if a
>  > conflicting package is installed.
Chromium, which is what he's talking about.  Chromium is different from
Chrome.
Jim
Date: 6 Aug 2011 23:17:56
Message: <4e3e03e4$1@news.povray.org>
No he doesn't. He says that's one way you can tell. And obviously he's not
speaking technically. I.e., I think you're reading way too much into the
part that talks about the motivation for making it work with Linux package
managers.
> referential.
I disagree. There are lots of lame ports of Windows software that's
distributed as a tarball for Ubuntu, for example.
Date: 6 Aug 2011 23:20:45
Message: <4e3e048d@news.povray.org>
> not speaking technically. I.e., I think you're reading way too much into
> the part that talks about the motivation for making it work with Linux
> package managers.
>> referential.
Like I said, we'll have to agree to disagree.
Jim
