http://www.ebuyer.com/179913-feser-aqua-ultra-pure-coolant-1l-fa-0054
"...is extremely pure water..."
"PH: 2.0 - 3.0"
http://blog.orphi.me.uk/
Pure water is non-conductive. Water with contaminants is conductive.
> "PH: 2.0 - 3.0"
They have also filtered out the dissolved carbon dioxide from the air which
would tend to make the water acidic.
How come I never get only one kudo?
Le 28/07/2011 21:24, Orchid XP v8 nous fit lire :
> "PH: 2.0 - 3.0"
more interesting: 1000ml ... 1,100g !
They also tuned the gravity field.
(ok, maybe it's bottle+water)
And what is PH ? pH yes, but PH ?
Also, notice, once open, any floating dirt in the air will contaminate
the water... in a fraction of second.
In fact, the air inside the bottle is not clean enough... they should go
the tires way: have it filled with 100% nitrogen (gas) instead of air.
Oh, btw, what about dissolved gas into the water after a storage of a
few weeks ? (closed bottled)
>> "PH: 2.0 - 3.0"
Um, yeah.
Perhaps. But don't bet on it!
Well, ebuyer is very bad at formatting product descriptions properly.
Most of them look like they blindly copy/pasted from the manufacturer's
website. Hell, whoever did this probably thought that "pH" was a typo
and helpfully "corrected" it.
OK, well I work for a lab company, and we really do use chemically pure
water, so this is a subject I know a little bit about.
Nitrogen dissolves in water. Not as readily as some gasses, but it does
dissolve. Apparently helium is the thing to use. (Indeed, we have
degassing equipment that works by merely bubbling helium through the
liquid. Any dissolved gasses tend to precipitate into the helium bubbles
and leave with them.) Helium is very, very insoluble in liquids. I don't
know why.
For this application (i.e., liquid cooling a computer), dissolved gas is
unlikely to be important. Also, while dissolved CO2 might make the water
very slightly acidic, pH 2 is *very* acidic. Either they got their
measurements hopelessly wrong, or this "very pure water" actually
contains some kind of additive (perhaps to limit corrosion or something).
I'm aware of that. (Although apparently many people aren't.) Our lab
water purification system (which really *does* produce "very pure
water") measures water purity in mega-Ohms - which is amusing, given
that it's the /non/-ionic containments which we're worried about!
>> "PH: 2.0 - 3.0"
> which would tend to make the water acidic.
Um, what?
pH 2 is *very* acidic. Pure water should be pH 7.0. Things having a pH
of 2.0 include lemon juice and vinegar. (Stomach acid is pH 1.0.)
By contrast, Wikipedia quotes a pH of about 5.65 for a solution of CO2
in water - much higher than 3 as quoted on the bottle. (Even fizzy water
as found in fizzy drinks is only about pH 4.)
> "PH: 2.0 - 3.0"
Today's WTF is rather unusual in that it requires a degree in chemistry
rather than in computer science (which is the usual norm here). I for one
don't know what you are talking about and, for once, am too lazy to do some
google-based research. :P
(Ok, the "requires a degree" part is an exaggeration, but you know what
I mean.)
The product description looks like it was written by Google's
Translation tool. "Through a reverse osmosis and mixed bed facility is
also demineralized water. " WAT????
Actually, it would be. Gas bubbles have a very different heat transfer
coeeficient and will act as an insulator, instead of a conductor.
If it contains an additive, is it still "very pure"? Also, the bottle
says that it is NOT an anti-corrosive agent, and that it should be mixed
with one, preferably their own, of course.
Overall, I'm getting a bad-vibe from this product. Just like when
reading the description of audiophile gear. Especially when you factor
in the deep barytone voice that says "Feser aquaaa. Ultra puuurrrre
Waterrrr" when you visit their web site.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
lolrus.
Have you ever tried reading the user manual for a motherboard? I'm sure
those things are translated from Korean. Also love the way they say
things like "option shadow video ram: causes shadowing of video ram".
Gee, like, I couldn't figure that out. WHAT IS SHADOWING?! :-P
This only matters if the gas comes out of solution. While it is /in/
solution, it is unimportant. Given the typical dimensions of the various
water-cooling components, you'd have to have pretty damned big bubbles
for it to matter.
To put it another way: Car engines are water-cooled. Typically not with
especially pure water either...
Exactly.
Didn't the Coca-Cola company at one time try selling "extremely pure
water" which was "triple-filtered" with "added minerals for extra purity"?
> Also, the bottle
You can READ that?? o_O
Heh, yeah. If I ever really /need/ very pure water... we lab has a
£8,000 water purification system? Maybe I should just use that? :-P
Le 29/07/2011 16:05, Invisible nous fit lire :
If you needed very pure water, you would go the enterprise way: ask for
allowance to pump the very old water table. Not the easy one, the very
old and very slow to fill one. Deep. Very deep. Not centuries of
filtering. Not even millenium... far more time!
Only available on continents, away from beaches.
Otherwise, use a simple cloth dryer with condensation, or just buy the
distilled water for iron.
> "PH: 2.0 - 3.0"
What about: 'Feser Aqua Ultra Pure Water is extremely pure water. This
is largely removed by a double distillation process of salts, ions,
trace elements and impurities'?
So you have pure water, then you remove it, and then you sell it?
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Oh, I got that backwards.
More like "requires remembering the first day of high-school chemistry
class, that you've never touched since." :-)
LOL! Gotta love broken translations...
> "PH: 2.0 - 3.0"
I'ts also absolutey germ-free, suppose that it will keep virus away from your
pc.
B Gimeno
>> Also, the bottle
Sure.
http://image.ebuyer.com/UK/P800-0179913-01.jpg
while fuzzy, it's big enough to read.
> Sure.
Barely...
Did I mention that my dad's a professional chemist and that I work for a
lab company? Or that I scored 98% on my GCSE science exam? Or that my
sister has an MSc in chemistry? Or that I personally own a chemistry
set? :-P
> pc.
It's not the RNA viruses I'm worried about!
On 01/08/2011 8:59 AM, Invisible wrote:
> Or that I personally own a chemistry set? :-P
Trust me, I own a chemistry set. ;-)
LOL
Regards
Seriously. Everybody knows that water freezes at 0°C (actually no, it
doesn't) and boils at 100°C. I've yet to meet anybody who didn't know
that. Similarly, I was under the impression that knowing that water is
pH 7 was common knowledge...
It also doesn't always boil at 100C - reduce the atmospheric pressure and
see when it boils.
Jim
> see when it boils.
Or increase it. Or add impurities. Or whatever.
Yes, but under /normal/ circumstances, it boils at 100°C, which is why
it's defined that way. :-P
>> see when it boils.
Pure water at average sea level presure boils/condense at 100°C and
melt/freeze at 0°C at the same presure level. Both by definition. In
fact, it's the definition of 0°C and 100°C.
(0°F is defined as the freezing poing of sea water and 100°F as the body
temperature of a "healthy" human male, but the "healthy" human male who
was used for the original mesure was somewhat feverish at the time, and
had the flue the next day...)
Change the presure and you also change freezing temperature.
So, does water freeze or melt at exactly 0 degrees celsius?
why it's
No it doesn't. At 100°C, it's in equilibrium. Just like at 0°C,
it's neither
getting more frozen or less frozen.
>> and see when it boils.
Not here at 4,000 feet - "normal" circumstances here have it boiling at a
slightly lower temperature. :P
IOW, it all depends on how you define "normal". (Hence my suggestion of
reducing the atmospheric pressure, because here, lower pressure is
'normal').
Jim
Yes, at some altitudes, it does.
Jim
96.2°C, a piffling 3.8° lower.
> 'normal').
This is why the /actual/ specification is far more complicated. But for
any sane real-world purpose, you can more or less ignore such
technicallities.
>> it's
> No it doesn't. At 100°C, it's in equilibrium. Just like at 0°C, it's
> neither getting more frozen or less frozen.
Worse than that, in certain conditions you can "hyper-heat" water, and,
I assume, probably super cool it, without changing state. In the former
case you just need a container that has "no" places for bubbles to form.
Not sure what you would need to do in the later case to make it happen,
if you could.
At sea level, yes. Melt if you add energy, freeze if it looses energy,
but stay at 0°C as long as there is still ice and liquid water.
As you climb or reduce presure, the freezing point slowly climb, but not
much.
As you go lower or increase presure, the freezing point goes into the
negative.
>>> it's
> if you could.
You can have water that stay liquid down to -10°C and possibly even
less. You need a container with very smooth surface and no particles in
suspention. In this state, a vibration can be just enough to cause
almost instant crystalisation.
If you slowly heat very pure water, it can bet a good bit warmer that
100°C before it start to boil. There will be vapour escaping from the
surface, but no ebulition, even in a open container. It's a dangerous
situation, as any disturbance can cause explosive ebulition projecting
scalding water everywhere.
If you slowly cool down steam and don't give it any nucleation point,
that steam may stay totaly gaseous at relatively low temperature. You
get hyper-saturated steam. It appens in, and around, clouds. Again, it's
an unstable situation and even a very faint sound, or a dust particle
can cause almost instant condensation.
But you can't prevent ice from melting as you slowly heat it.
Which is actually quite cool to see - I've seen it done with beer before.
Jim
>> a slightly lower temperature. :P
Which is still not 100C no matter how you slice it. The difference in
humidity, altitude, and other things makes cooking things that require
precise measurements (usually baked goods) slightly different than at
other altitudes and in other conditions.
>> of reducing the atmospheric pressure, because here, lower pressure is
>> 'normal').
> technicallities.
Baking is a real-world purpose. An awareness of the 'normal' as well as
'current' environment are, for some things, absolutely *critical* in
order to be successful.
Jim
I see what you did there.
I've got a box of hand warmers at home. They contain a super-saturated
solution (of what I don't know). Once you provide a nucleation point,
the whole lot crystallises within a few seconds. It also gets quite warm
in the process. (This is what makes it good for warming your hands.)
I would suggest that the wild variations in oven temperatures have a
vastly bigger impact than a 4% difference in the boiling point of water.
Or, very fast, by heating it all more or less at the same time (i.e.,
with something like a microwave oven.
Legend has it that boiling water in a microwave oven has this effect. I
don't know of an authoritative source which can confirm or refute that...
Seen those. There is also some expensive shirt that was made for
joggers, which uses a similar principle, though, in that case, I get the
impression they formulated the material so it crystalized faster than
normal in cold temperatures, releasing heat, but softening faster than
normal too, absorbing it, thus keeping you cooler, or warmer, depending
on conditions.
Always wondered, in the case of the whole "heat pack" thing though if
you couldn't make one that did the reverse, and was "recoolable", or
whatever. The principle being, of course, than it is rechargable, so
long as the solution doesn't change (often the plastic is
semi-permiable, so loses moister over time, and stops working), so when
you let it cool slowly, it "holds" the excess energy. When you apply
kinetic energy to it, it instantly starts losing all of what it
retained, and crystallizes. You would basically need to do the reverse,
somehow, for a "cold pack", crystallizing it, so as to "lose" more heat
than it needs in a stable state, then.. there comes the rub. Other than
that it would liquify as it absorbed the heat, instead of crystallizing,
like the supersaturation, I am not clear how you would manage to make it
so it could recharge effectively.
Uh.. Mythbusters? They tried it, and it did. lol
> whatever.
Hmm. Plausibly.
I would imagine, like with other refrigeration technologies, the key is
to find a material which has a phase change at the right temperature.
Normal hand warmers become super-saturated solutions at very high
temperatures. If you wanted to make something cold, you'd need something
that becomes super-saturated at a low temperature.
I'm also not completely sure of the kinetics: a hand warmer releases
heat quickly, and absorbs it slowly. That may or may not be useful for
cooling purposes.
Unrelated, but I note that dissolving ammonia in water is an endothermic
reaction. That, apparently, is how Victorian icecream was made. So I
guess the question is, WOULD YOU EAT IT? ;-)
>> that...
I've also had it happen to me.
Jim
>>>>> why it's defined that way. :-P
>>>> at a slightly lower temperature. :P
My point is that 4% is still 4%.
Jim
>>> in suspention. In this state, a vibration can be just enough to cause
Wow, *completely* unintentional, that one. Honest. :)
Jim
Me too.
> Me too.
Put a pinch of croase sand in the container. It provide some angular
surfaces that will stimulate the bubble formation as the liquid reatch
the ebulition point. It will allow a gradual transition.
You can also rub the inside bottom of a container with fine sand paper.
About any rough surfaced material will do the trick.
>>> 'normal').
>> technicallities.
> Jim
That's why, in some areas, you have cook books that gives several
cooking times sorted by altitude ranges.
Yep, indeed it is.
Jim
>> Me too.
Yeah, because Croase sand goes so well with tea.
Personally, I put sugar in it...
I just stick a spoon in it.
