Le 2011-07-29 10:05, Invisible a écrit :
> On 29/07/2011 02:51 PM, Francois Labreque wrote:
>> Also, the bottle
>> says that it is NOT an anti-corrosive agent, and that it should be mixed
>> with one, preferably their own, of course.
> You can READ that?? o_O
Sure.
http://image.ebuyer.com/UK/P800-0179913-01.jpg
while fuzzy, it's big enough to read.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* gmail.com */}camera{orthographic location<6,1.25,-6>look_at a }
> Sure.
Barely...
http://blog.orphi.me.uk/
On 29/07/2011 05:51 PM, Darren New wrote:
> On 7/29/2011 1:26, Invisible wrote:
>> pH 2 is *very* acidic.
> Oh, I got that backwards.
Did I mention that my dad's a professional chemist and that I work for a
lab company? Or that I scored 98% on my GCSE science exam? Or that my
sister has an MSc in chemistry? Or that I personally own a chemistry
set? :-P
On 29/07/2011 06:15 PM, B. Gimeno wrote:
> I'ts also absolutey germ-free, suppose that it will keep virus away from your
> pc.
It's not the RNA viruses I'm worried about!
On 01/08/2011 8:59 AM, Invisible wrote:
> Or that I personally own a chemistry set? :-P
Trust me, I own a chemistry set. ;-)
LOL
Regards
On 29/07/2011 05:54 PM, Darren New wrote:
> On 7/29/2011 3:07, Warp wrote:
>> the "requires a degree" part is an exaggeration
> More like "requires remembering the first day of high-school chemistry
> class, that you've never touched since." :-)
Seriously. Everybody knows that water freezes at 0°C (actually no, it
doesn't) and boils at 100°C. I've yet to meet anybody who didn't know
that. Similarly, I was under the impression that knowing that water is
pH 7 was common knowledge...
It also doesn't always boil at 100C - reduce the atmospheric pressure and
see when it boils.
Jim
> see when it boils.
Or increase it. Or add impurities. Or whatever.
Yes, but under /normal/ circumstances, it boils at 100°C, which is why
it's defined that way. :-P
>> see when it boils.
Pure water at average sea level presure boils/condense at 100°C and
melt/freeze at 0°C at the same presure level. Both by definition. In
fact, it's the definition of 0°C and 100°C.
(0°F is defined as the freezing poing of sea water and 100°F as the body
temperature of a "healthy" human male, but the "healthy" human male who
was used for the original mesure was somewhat feverish at the time, and
had the flue the next day...)
Change the presure and you also change freezing temperature.
So, does water freeze or melt at exactly 0 degrees celsius?
why it's
No it doesn't. At 100°C, it's in equilibrium. Just like at 0°C,
it's neither
getting more frozen or less frozen.
How come I never get only one kudo?
>> and see when it boils.
Not here at 4,000 feet - "normal" circumstances here have it boiling at a
slightly lower temperature. :P
IOW, it all depends on how you define "normal". (Hence my suggestion of
reducing the atmospheric pressure, because here, lower pressure is
'normal').
Jim
Yes, at some altitudes, it does.
Jim
96.2°C, a piffling 3.8° lower.
> 'normal').
This is why the /actual/ specification is far more complicated. But for
any sane real-world purpose, you can more or less ignore such
technicallities.
>> it's
> No it doesn't. At 100°C, it's in equilibrium. Just like at 0°C, it's
> neither getting more frozen or less frozen.
Worse than that, in certain conditions you can "hyper-heat" water, and,
I assume, probably super cool it, without changing state. In the former
case you just need a container that has "no" places for bubbles to form.
Not sure what you would need to do in the later case to make it happen,
if you could.
At sea level, yes. Melt if you add energy, freeze if it looses energy,
but stay at 0°C as long as there is still ice and liquid water.
As you climb or reduce presure, the freezing point slowly climb, but not
much.
As you go lower or increase presure, the freezing point goes into the
negative.
>>> it's
> if you could.
You can have water that stay liquid down to -10°C and possibly even
less. You need a container with very smooth surface and no particles in
suspention. In this state, a vibration can be just enough to cause
almost instant crystalisation.
If you slowly heat very pure water, it can bet a good bit warmer that
100°C before it start to boil. There will be vapour escaping from the
surface, but no ebulition, even in a open container. It's a dangerous
situation, as any disturbance can cause explosive ebulition projecting
scalding water everywhere.
If you slowly cool down steam and don't give it any nucleation point,
that steam may stay totaly gaseous at relatively low temperature. You
get hyper-saturated steam. It appens in, and around, clouds. Again, it's
an unstable situation and even a very faint sound, or a dust particle
can cause almost instant condensation.
But you can't prevent ice from melting as you slowly heat it.
Which is actually quite cool to see - I've seen it done with beer before.
Jim
>> a slightly lower temperature. :P
Which is still not 100C no matter how you slice it. The difference in
humidity, altitude, and other things makes cooking things that require
precise measurements (usually baked goods) slightly different than at
other altitudes and in other conditions.
>> of reducing the atmospheric pressure, because here, lower pressure is
>> 'normal').
> technicallities.
Baking is a real-world purpose. An awareness of the 'normal' as well as
'current' environment are, for some things, absolutely *critical* in
order to be successful.
Jim
I see what you did there.
I've got a box of hand warmers at home. They contain a super-saturated
solution (of what I don't know). Once you provide a nucleation point,
the whole lot crystallises within a few seconds. It also gets quite warm
in the process. (This is what makes it good for warming your hands.)
I would suggest that the wild variations in oven temperatures have a
vastly bigger impact than a 4% difference in the boiling point of water.
Or, very fast, by heating it all more or less at the same time (i.e.,
with something like a microwave oven.
Legend has it that boiling water in a microwave oven has this effect. I
don't know of an authoritative source which can confirm or refute that...
Seen those. There is also some expensive shirt that was made for
joggers, which uses a similar principle, though, in that case, I get the
impression they formulated the material so it crystalized faster than
normal in cold temperatures, releasing heat, but softening faster than
normal too, absorbing it, thus keeping you cooler, or warmer, depending
on conditions.
Always wondered, in the case of the whole "heat pack" thing though if
you couldn't make one that did the reverse, and was "recoolable", or
whatever. The principle being, of course, than it is rechargable, so
long as the solution doesn't change (often the plastic is
semi-permiable, so loses moister over time, and stops working), so when
you let it cool slowly, it "holds" the excess energy. When you apply
kinetic energy to it, it instantly starts losing all of what it
retained, and crystallizes. You would basically need to do the reverse,
somehow, for a "cold pack", crystallizing it, so as to "lose" more heat
than it needs in a stable state, then.. there comes the rub. Other than
that it would liquify as it absorbed the heat, instead of crystallizing,
like the supersaturation, I am not clear how you would manage to make it
so it could recharge effectively.
Uh.. Mythbusters? They tried it, and it did. lol
> whatever.
Hmm. Plausibly.
I would imagine, like with other refrigeration technologies, the key is
to find a material which has a phase change at the right temperature.
Normal hand warmers become super-saturated solutions at very high
temperatures. If you wanted to make something cold, you'd need something
that becomes super-saturated at a low temperature.
I'm also not completely sure of the kinetics: a hand warmer releases
heat quickly, and absorbs it slowly. That may or may not be useful for
cooling purposes.
Unrelated, but I note that dissolving ammonia in water is an endothermic
reaction. That, apparently, is how Victorian icecream was made. So I
guess the question is, WOULD YOU EAT IT? ;-)
>> that...
I've also had it happen to me.
Jim
>>>>> why it's defined that way. :-P
>>>> at a slightly lower temperature. :P
My point is that 4% is still 4%.
Jim
>>> in suspention. In this state, a vibration can be just enough to cause
Wow, *completely* unintentional, that one. Honest. :)
Jim
Me too.
> Me too.
Put a pinch of croase sand in the container. It provide some angular
surfaces that will stimulate the bubble formation as the liquid reatch
the ebulition point. It will allow a gradual transition.
You can also rub the inside bottom of a container with fine sand paper.
About any rough surfaced material will do the trick.
>>> 'normal').
>> technicallities.
> Jim
That's why, in some areas, you have cook books that gives several
cooking times sorted by altitude ranges.
Yep, indeed it is.
Jim
>> Me too.
Yeah, because Croase sand goes so well with tea.
Personally, I put sugar in it...
I just stick a spoon in it.
Not while it's in the oven, I hope...
I find a chopstick works well.
Jim
And get it under the right condition and ice sublimates. Even more
interesting at certain temperature/pressure combinations water can be
kind of a liquid that's almost a gas, and can smoothly change phases
between the two.
~Mike
Actually, an interesting question: does water's liquid-solid phase
change at standard atmospheric pressure exhibit hysteresis?
~Mike
> if you could.
You can super-cool water. Fun trick:
Get some bottled water, leave it in the freezer for approximately 30
minutes (some experimentation will be needed to determine the exact
amount of time needed for the best effect) remove it from the freezer,
note that it is still liquid, bang it against something to get a crystal
to nucleate, then watch the ice form right in front of you. Enjoy your
slushy, cold water.
~Mike
Sodium acetate. I've made my own countless times in my life. And
recently made a big enough batch to create the super-saturated solution
(actually melted crystals) to crystallize. Very cool to watch. Drop a
tiny sodium acetate crystal in, and it grows out from that and warms the
container nicely.
~Mike
There is a certain type of candy or treat (Finnish, I believe?) that is
seasoned with ammonium chloride ....) They eat it, though ammonia
solution I think I would avoid.
~Mike
> container nicely.
And here I was thinking it was sodium thiosulphate...
>>> Me too.
It adds a nice crunch.
~Mike
Hydration of common salt is endothermic. The fusion temperature of the
mix is usually lower than the fusion of clear water.
(For road usage: Hydration of CaCl2 is exothermic, but the one of NaCl
is endothermic; CaCl2 is used in countries with very low temperatures on
their road)
For the preparation of ice-cream (well, rather sorbet (water-based
ice-cream, using fruit juice, water), than the rich ice-cream with cream
of milk, eggs and other stuff), you only have to cool the recipient and
the preparation a bit below 0°C (which can take a lot, as freezing water
has a lot of joules to expel): using a recipient with an internal
container and an external container, you prepare the sorbet in the
internal container, and have the water+ammoniac mixed in the external
container.
(If you remember your chemistry about mixing acid and water (you drop
one in the other, but avoid the other way round), can you guess what
must be added to what (ammoniac is a base)) ?
Nothing related to the fancy preparation of ice-cream with liquid
Nitrogen (pour liquid nitrogen over the preparation, and mix with energy
and a wood spatula (and some goggles, and some heavy gloves)!).
I would be interested in a preparation with liquid Oxygen, served at a
table of smoking people... well, soon-ex-people. I'm just afraid the
reaction with liquid Oxygen would also change the taste too much.
(oxidation power is very strong)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Am 20.09.2011 15:11, schrieb Mike Raiford:
> slushy, cold water.
NOT recommended with glass bottles >_<
>> slushy, cold water.
Just don't bang it too hard... ;)
~Mike
Am 21.09.2011 14:41, schrieb Mike Raiford:
>>> slushy, cold water.
Well, bang as softly as you might - I wouldn't want to be close to /any/
glass bottle in which water is busy crystallizing.
(Hint: The specific density of ice is only about 92% that of ice-cold
water.)
> water.)
Oh, right... Water expands when freezing.
So long as there's sufficient air at the top, and the glass bottle is
thick enough....
~Mike
