POV-Ray : Newsgroups : povray.off-topic : All your radix are belong to us! Server Time
1 Nov 2026 09:23:44 EST (-0500)
  All your radix are belong to us! (Message 1 to 27 of 27)
Subject: All your radix are belong to us!
Date: 22 Jul 2011 06:50:49
Message: <4e295609$1@news.povray.org>
http://blog.llvm.org/2011/05/what-every-c-programmer-should-know.html
http://blog.llvm.org/2011/05/what-every-c-programmer-should-know_14.html
http://blog.llvm.org/2011/05/what-every-c-programmer-should-know_21.html
...OK, I'm scared. o_O
http://blog.orphi.me.uk/
Subject: Re: All your radix are belong to us!
Date: 22 Jul 2011 11:28:20
Message: <4e299713@news.povray.org>
  Why?
Date: 23 Jul 2011 06:29:55
Message: <4e2aa2a3$1@news.povray.org>
>    Why?
A language where the language spec specifically allows you to optimise
away bounds checks, null checks and so forth in the name of performance?
Yeah, sounds fairly scary to me.
Not having these things automatically is one thing. Automatically
removing them when the programmer explicitly added them is another. And
apparently even the "experts" get surprised by this behaviour, so...
Date: 23 Jul 2011 10:59:45
Message: <4e2ae1e0@news.povray.org>
> >    Why?
  If you access first and check bounds afterwards, that's kind of a bit
late, don't you think? That's the whole point. If you access before making
the bounds check, then the compiler can assume that the checking is useless.
(The check won't do anything useful because the accessing has already been
made by that point, so the check won't retroactively make it work.)
  If you make the check first, and only then access based on that, then the
compiler cannot make the assumption.
  Well, if the code is accessing out of boundaries, there's a bug. If there's
such a bug, the compiler is free to do whatever it likes. There's nothing
surprising about that.
Date: 23 Jul 2011 13:13:04
Message: <4e2b0120$1@news.povray.org>
In the first example, he reads, then checks, then writes, and it's not
unreasonable to think that he's ensuring the write isn't out of bounds
because the read is harmless.  (Yes, there are still architectures where
*NULL does not trap.)
It is to a large number of people who work with safe languages. :-) Even
more surprising to people who work with languages where having an index out
of bounds doesn't even make sense, let alone be "a bug".
   "Coding without comments is like
    driving without turn signals."
Date: 23 Jul 2011 13:36:47
Message: <4e2b06af@news.povray.org>
  But there are many architectures where dereferencing null will trap,
which is why the C standard does not want to force it either way (in
other words, it does not want to force compilers to add a check to each
dereferencing to see if it's dereferencing null, and then either cause
an abort() or some other defined behavior).
  If dereferencing null is normal in a certain architecture, then compilers
made for that architecture should take that into account (which the standard
fully allows, obviously).
  (As always, this is a compromise between efficiency and safety. If the
standard said "thou shalt not dereference null, or you'll be abort()ed",
then every single pointer and array access would become slower.)
  Then these people either have to learn C properly, or not use it.
It really is a case of "take it or leave it".
Date: 23 Jul 2011 13:40:21
Message: <4e2b0785@news.povray.org>
Yes, I know that. :-)
I didn't say it's normal. I said it's something someone who knows the
hardware might expect and thus be surprised by the compiler deleting
completely different code.
If I compiled something like that first version for a Z-80, I can easily
believe I would be surprised if that code ever wrote to the interrupt
vector.  I'm not criticizing C. I'm simply saying it's reasonable to be
surprised. :-)
Yes. I'm simply pointing out to people who know C very well why it would be
that people who don't know it very well might be surprised. Heck, code like
that wound up in the Linux kernel, so I think it's save to say "it sometimes
surprises even experts", yes?
Date: 23 Jul 2011 13:51:37
Message: <4e2b0a29@news.povray.org>
  But wasn't it a bug, rather than an intentional "trick" which the
programmers didn't realize would trigger undefined behavior?
Date: 23 Jul 2011 19:05:04
Message: <4e2b53a0@news.povray.org>
Yes. It was a bug caused by the programmer not knowing a null pointer check
would not wind up in the object code, because they accessed the pointer
first. I.e., it was pretty much exactly the contains_null_check code on the
second link.
I.e., I'm pretty sure anyone committing code to the Linux kernel "knows C
properly."  It really is a surprising language.  Saying "real programmers
never make this sort of mistake" is a no-true-scotsman argument.
I'm not saying anything is *wrong* with C or the decisions the standards
committee made. Just that expressing surprise that it's as tricky as it is
doesn't imply you're ignorant.  "Real programmers think C isn't surprising,
because if you're surprised by C, it means you're not a real programmer."
Date: 24 Jul 2011 06:22:44
Message: <4e2bf274@news.povray.org>
  We are probably using a slightly different meaning for "surprised".
  Everybody makes errors, and sometimes those errors happen because you
don't know the language well enough. The error would be a surprise if you
make that latter kind of error, and you have never heard of that feature
before, so it catches you by surprise. It's not a surprise if you already
knew about that language feature, but didn't realize it comes into play in
a complex piece of code. (The difference would be that after you resolve
the situation you think "ah, true, it indeed is that language feature
kicking in", so it's doesn't surprise you, rather than "I didn't know that
feature even existed".)
Date: 24 Jul 2011 13:59:18
Message: <4e2c5d76@news.povray.org>
Probably.
Date: 24 Jul 2011 22:24:26
Message: <4e2cd3da$1@news.povray.org>
Actually, I'm more thinking this:
http://en.wikipedia.org/wiki/Principle_of_least_astonishment
Date: 1 Aug 2011 04:08:11
Message: <4e365eeb$1@news.povray.org>
> I said it's something someone who knows the hardware might […]
If you make assumptions about the hardware your program is running on
you're out of scope of C language.
Either you realy _know_ what your hardware _and_ your compiler do in the
current and will do in all future versions, or you better rely only on
the C language standard.
It is your choice. I prefere almost always the latter, except I have to
wirte platform-dependend code/optimizations etc.
L.
Date: 1 Aug 2011 04:14:19
Message: <4e36605b@news.povray.org>
More to the point, according to the C spec, NULL is not /required/ to
trap. Ever. The compiler is 100% free to make it do whatever it likes.
Which isn't especially surprising. The surprising thing is that you've
got code there explicitly to check for a null pointer, and the optimiser
may or may not end up removing it for you.
Date: 1 Aug 2011 07:13:26
Message: <4e368a56$1@news.povray.org>
It is not surprising if you _know_ C.
i.o.w. if it is surprising for you, your C knowledge are incomplete. ^^
L.
Date: 1 Aug 2011 11:58:17
Message: <4e36cd19$1@news.povray.org>
Sure. It's also surprising when your leg disappears, simply because while
you know you're in a minefield, your knowledge of that minefield is incomplete.
That doesn't mean it's a *good* thing. Yes, it can be surprising even to
those who know C well enough to write an operating system kernel in it. The
whole "it's only surprising if you don't know it'll happen" tautology is
silly. The problem is that composing two perfectly valid statements makes an
invalid program that behaves completely differently than how you would
expect from each of those two statements separately.
   How come I never get only one kudo?
Date: 1 Aug 2011 12:30:17
Message: <4e36d499@news.povray.org>
  Nobody claimed it is. It's just something you have to live with if you
program in C (or its close variants).
  But you *can't* expect something specific to happen if you dereference
null (even if you do it "separately"). If you dereference null, *anything*
can happen (including the following code doing something completely different
than what you expect).
  If you want derefercing null to do something special (which cannot be
written in C itself), you'll have to use some custom extension of the
programming language.
Date: 1 Aug 2011 13:22:47
Message: <4e36e0e7$1@news.povray.org>
Yes, I understand that.
I know that too. I really do completely understand the problem. It's exactly
why I'd say that maybe C or its close variants aren't good for a new user.
I'm merely pointing out that "it isn't surprising if you already know it's
going to happen" combined with "you should know it's going to happen because
you need to understand the detailed rules of every single operation possible
to write a program that silently doesn't do something good" combines to make
"I only know a little bit" a bad choice.
And it's not just dereferencing null. It's any of the undefined behaviors
which can lead to the compiler doing very unintuitive things if you're not
aware of the rule.
Date: 1 Aug 2011 13:50:17
Message: <4e36e759@news.povray.org>
> aware of the rule.
  OTOH "undefined behavior" also allows for the compiler to, for example,
add sanity checks and issue clear runtime errors when these kinds of errors
happen.
  Some compilers actually do this with a bunch of undefined behavior
situations when compiling in debug mode. However, it's a rather curiously
rare thing to do. I have been wondering why C/C++ compilers don't have a
"super-debug mode" where *everything* that can possibly go wrong is checked
(if it can be physically checked), completely regardless of how slow the
program becomes. A bit like a "builtin valgrind" (but which adds even more
checks which the compiler can do because it can see the source code). Only
few C/C++ compilers have anything even resembling this, and usually in a
relatively limited form (ie. the debugging mode doesn't even do all the
same checks as valgrind does).
  Maybe it's a question of complexity vs. demand, or something.
Date: 1 Aug 2011 14:53:22
Message: <4e36f622$1@news.povray.org>
Also compatibility, I think. To check whether you're using a stray pointer,
you'd have to store more than the pointer, which means void* might change
size, which breaks anything precompiled you link to.
Interestingly, too, I read that Microsoft has an "Application Verifier" that
does things like intentionally initializing stack frames to random garbage
(rather than leaving whatever's there), and they find many people don't test
under the "application verifier" because it breaks too much of their code.
(For example, a lot of the "application compatibility shims" fix stuff the
application verifier would have detected had they used it.)
There used to be lint, which would seem to address the complaint that "it
would slow down the compiler."  I guess it's easier to just make it flags
nowadays rather than maintain a separate program, tho.
I suspect 99% of the people writing code are writing code that doesn't get
used in any application but their own, so they write it, test it, it seems
to work well, they release the executable. It's a lot harder to get
libraries like boost or openssl or whatever working on every compiler in
every environment.
Date: 1 Aug 2011 15:19:25
Message: <4e36fc3d@news.povray.org>
  There may indeed be situations where debugging code could become
completely incompatible with a third-party precompiled library. However,
at the very least it would be nice if C/C++ compilers had a debug mode
which makes the compiler program behave like if it was run using a tool
like valgrind. Valgrind can do it even without the help of a compiler,
so there's nothing stopping the compiler itself just embedding some kind
of "valgrind" into the program itself. (And, as said, since the compiler
has the source code of the program being tested to work with, it can
probably add even more checks than what valgrind alone can.)
  Visual C++ has a decent debug mode, but I wish it did more. It would be
nice if gcc had a significantly expanded debug mode. It's not like it
would be impossible.
  On a different note, gcc and many other C/C++ compilers have a mode
which tries to profile the code as accurately as possible in terms of
how much time is spent on which parts of the code (in linux this is
used in conjunction with gprof to get the results). This can sometimes
be quite useful to find bottlenecks. I wonder if other programming
languages have similar tools.
Date: 1 Aug 2011 17:04:17
Message: <4e3714d1$1@news.povray.org>
Back when Pascal was popular, I did an enhancement to the Pascal compiler
used at my university for teaching. Each allocation bumped a global counter
and put the result in both the pointer and the block of allocated data. It
also chained together all the data blocks.
Then, every time you used a pointer, it would walk the blocks of allocated
memory to make sure the pointer was still on the list, then check that the
counter values were the same. The former kept you from using dangling
pointers, and the latter kept you from using a pointer that was dangling but
happened to get reallocated later.
Obviously, performance sucked, but it was only turned on for teaching
purposes, so that's OK.  And of course you can't do this (as easily) in a
language that supports pointer arithmetic; you'd have to treat allocations
as base+index.
I would think anything where you say "we can rely on undefined behavior not
happening in order to improve this", you could simply define the behavior as
"we check for this, and drop into the debugger (or whatever) if we find it."
But to be fair, gcc and other compilers have come a long way. They warn you
if you use variables that may be uninitialized, they warn you if you pass
the wrong types to printf with a literal formatting argument (which is why
the iostream argument that it's better because it's strongly typed never
made much sense to me), and so on.
It would probably be really complicated to check even more stuff.
> I wonder if other programming languages have similar tools.
Stuff that's interpreted (or bytecoded) generally has tools like this, but
they tell you more what's happening (i.e., "lots of iterations of this
line") rather than the actual microseconds taken precisely, in part because
the precision isn't as repeatable in such environments. You can usually see
what lines were run, how much memory was allocated to particular types, and
how long individual lines took, but I don't think they tend to go to
exceptional effort to do better than what you'd get from the straightforward
"read the CPU performance counter" type of thing.
Date: 1 Aug 2011 17:50:20
Message: <4e371f9c@news.povray.org>
  It depends on the compiler. Some compilers, especially the slightly older
ones, don't make such checks.
  Of course the major problem with the printf-style of I/O is that it breaks
abstraction, even in C. You just have to do something this to get a problem:
typedef int MySpecialInt;
void foo(MySpecialInt i)
    printf("The parameter was: %???\n", i);
  What to put as a format? Even if you put "%i" and have it work ok, it
breaks the abstraction of MySpecialInt because now you can't change it
without breaking the printf. Obviously the C++ streams have no such
problem.
Date: 1 Aug 2011 18:21:10
Message: <4e3726d6$1@news.povray.org>
gcc has been doing it for ages. (Since I haven't used gcc to do a printf in
ages, and I remember doing it... :-)  But yeah, I meant more that it's
theoretically pretty easy to cover that case.
Yeah, I guess "breaks abstraction" is more precise than "typesafe".  More
like "type change safe."  I remember being annoyed when there were no printf
codes for things like size_t and diff_t and so on.
I think C# actually came up with quite a sweet compromise. (Well, maybe not
came up with, maybe "stole", but it's pretty good anyway.)  You put in
something like
    output.write("blah {0:x} blah {2:y} blah {1:0,000.00}", a, b, c);
that calls a.ToString("x") then c.ToString("0,000.00") then b.ToString("y")
and inserts the results in the appropriate place. That way you don't have
problems like cout<<hex maybe leaving the stream screwed up, and each custom
type can configure its own meaning for formatting strings. It's typesafe and
abstraction safe, *and* it lets you put the formatting strings in a database
for internationalization.
Of course, C# turns each thing into a string and then outputs it, instead of
outputting them bit by bit, but one could work the same sort of API with a
stream interface instead of a string interface.
There's also a slightly weird thing where something different gets called
depending on whether it's one letter after the colon, multiple letters after
the colon, multiple colons, or something like that. I don't remember the
details at this point.
There's also an implicit locale passed in, so you can seamlessly have
multiple concurrent locales and have all the formatting stuff do the right
thing, pick the right date and comma format, pick the right character
encoding, etc. The trick is the locale goes in as another argument to
ToString(), so you can use as many different locales as you want. I never
really learned it well enough to understand all the combinations possible, tho.
Last time I had to do something like that, I used
#define MySpecialIntFmt "%i"
and then
printf("Here are " MySpecialIntFmt " integers", i);
But yeah, that was way uglier than it needed to be, especially if you needed
to start putting the strings in an localization file, which is the point to
start with. :-)
Date: 2 Aug 2011 04:16:37
Message: <4e37b265@news.povray.org>
> while you know you're in a minefield, your knowledge of that minefield
> is incomplete.
ACK.
The spirit of C is: "trust the programmer" because the programmer knows
what (s)he does. If that premise is wrong, anything goes.
Ex falso sequitur quodlibet. :-D
AFAIK most "kernel hackers" knows a lot about their topic, e.g. their
hardware, their data structures (file systems) and so on. But most of
them are not academic C language evangelists who can quote every
paragraph of the ISO C language standard.
> The whole "it's only surprising if you don't know it'll happen"
> tautology is silly. The problem is that composing two perfectly valid
> statements makes an invalid program that behaves completely differently
> than how you would expect from each of those two statements separately.
Crossing the street on foot is fine.
Driving on the streat by car is also fine.
But crossing the street while someone else is driving on can be
disastrous. :-)
L.
Date: 2 Aug 2011 14:03:47
Message: <4e383c02@news.povray.org>
> something like
  In C++ you could use the boost format library, which allows you to do
things like this:
    std::cout << boost::format("writing %1%, x=%2% : %3%-th try")
                 % "toto" % 40.23 % 50;
  (OTOH I'm guessing this is less efficient than the direct approach.)
> and then
  Which is inconvenient if you need to use some format specifiers (such
as printing at least 5 digits, with leading zeros).
Date: 2 Aug 2011 14:20:24
Message: <4e383fe8$1@news.povray.org>
On 8/2/2011 11:03, Warp wrote:
>      std::cout<<  boost::format("writing %1%, x=%2% : %3%-th try")
I'm guessing boost::format has to return something that overloads % in the
same way that cout overloads <<. I'm not sure from your example whether it
supports the flexible formatting stuff either, which was more my point in
the example.
Yeah. I never needed to, but I suppose you could use just "i" instead of
"%i". In any case, it's clearly not flexible enough to handle things the way
you'd like.
