POV-Ray : Newsgroups : povray.off-topic : All your radix are belong to us! Server Time
12 Oct 2026 08:16:16 EDT (-0400)
  All your radix are belong to us! (Message 21 to 27 of 27)
<<< Previous 20 Messages Goto Initial 27 Messages
Subject: Re: All your radix are belong to us!
Date: 1 Aug 2011 15:19:25
Message: <4e36fc3d@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> On 8/1/2011 10:50, Warp wrote:
> >    Maybe it's a question of complexity vs. demand, or something.
> Also compatibility, I think. To check whether you're using a stray pointer,
> you'd have to store more than the pointer, which means void* might change
> size, which breaks anything precompiled you link to.
  There may indeed be situations where debugging code could become
completely incompatible with a third-party precompiled library. However,
at the very least it would be nice if C/C++ compilers had a debug mode
which makes the compiler program behave like if it was run using a tool
like valgrind. Valgrind can do it even without the help of a compiler,
so there's nothing stopping the compiler itself just embedding some kind
of "valgrind" into the program itself. (And, as said, since the compiler
has the source code of the program being tested to work with, it can
probably add even more checks than what valgrind alone can.)
  Visual C++ has a decent debug mode, but I wish it did more. It would be
nice if gcc had a significantly expanded debug mode. It's not like it
would be impossible.
  On a different note, gcc and many other C/C++ compilers have a mode
which tries to profile the code as accurately as possible in terms of
how much time is spent on which parts of the code (in linux this is
used in conjunction with gprof to get the results). This can sometimes
be quite useful to find bottlenecks. I wonder if other programming
languages have similar tools.
Date: 1 Aug 2011 17:04:17
Message: <4e3714d1$1@news.povray.org>
Back when Pascal was popular, I did an enhancement to the Pascal compiler
used at my university for teaching. Each allocation bumped a global counter
and put the result in both the pointer and the block of allocated data. It
also chained together all the data blocks.
Then, every time you used a pointer, it would walk the blocks of allocated
memory to make sure the pointer was still on the list, then check that the
counter values were the same. The former kept you from using dangling
pointers, and the latter kept you from using a pointer that was dangling but
happened to get reallocated later.
Obviously, performance sucked, but it was only turned on for teaching
purposes, so that's OK.  And of course you can't do this (as easily) in a
language that supports pointer arithmetic; you'd have to treat allocations
as base+index.
I would think anything where you say "we can rely on undefined behavior not
happening in order to improve this", you could simply define the behavior as
"we check for this, and drop into the debugger (or whatever) if we find it."
But to be fair, gcc and other compilers have come a long way. They warn you
if you use variables that may be uninitialized, they warn you if you pass
the wrong types to printf with a literal formatting argument (which is why
the iostream argument that it's better because it's strongly typed never
made much sense to me), and so on.
It would probably be really complicated to check even more stuff.
> I wonder if other programming languages have similar tools.
Stuff that's interpreted (or bytecoded) generally has tools like this, but
they tell you more what's happening (i.e., "lots of iterations of this
line") rather than the actual microseconds taken precisely, in part because
the precision isn't as repeatable in such environments. You can usually see
what lines were run, how much memory was allocated to particular types, and
how long individual lines took, but I don't think they tend to go to
exceptional effort to do better than what you'd get from the straightforward
"read the CPU performance counter" type of thing.
   How come I never get only one kudo?
Date: 1 Aug 2011 17:50:20
Message: <4e371f9c@news.povray.org>
  It depends on the compiler. Some compilers, especially the slightly older
ones, don't make such checks.
  Of course the major problem with the printf-style of I/O is that it breaks
abstraction, even in C. You just have to do something this to get a problem:
typedef int MySpecialInt;
void foo(MySpecialInt i)
    printf("The parameter was: %???\n", i);
  What to put as a format? Even if you put "%i" and have it work ok, it
breaks the abstraction of MySpecialInt because now you can't change it
without breaking the printf. Obviously the C++ streams have no such
problem.
Date: 1 Aug 2011 18:21:10
Message: <4e3726d6$1@news.povray.org>
gcc has been doing it for ages. (Since I haven't used gcc to do a printf in
ages, and I remember doing it... :-)  But yeah, I meant more that it's
theoretically pretty easy to cover that case.
Yeah, I guess "breaks abstraction" is more precise than "typesafe".  More
like "type change safe."  I remember being annoyed when there were no printf
codes for things like size_t and diff_t and so on.
I think C# actually came up with quite a sweet compromise. (Well, maybe not
came up with, maybe "stole", but it's pretty good anyway.)  You put in
something like
    output.write("blah {0:x} blah {2:y} blah {1:0,000.00}", a, b, c);
that calls a.ToString("x") then c.ToString("0,000.00") then b.ToString("y")
and inserts the results in the appropriate place. That way you don't have
problems like cout<<hex maybe leaving the stream screwed up, and each custom
type can configure its own meaning for formatting strings. It's typesafe and
abstraction safe, *and* it lets you put the formatting strings in a database
for internationalization.
Of course, C# turns each thing into a string and then outputs it, instead of
outputting them bit by bit, but one could work the same sort of API with a
stream interface instead of a string interface.
There's also a slightly weird thing where something different gets called
depending on whether it's one letter after the colon, multiple letters after
the colon, multiple colons, or something like that. I don't remember the
details at this point.
There's also an implicit locale passed in, so you can seamlessly have
multiple concurrent locales and have all the formatting stuff do the right
thing, pick the right date and comma format, pick the right character
encoding, etc. The trick is the locale goes in as another argument to
ToString(), so you can use as many different locales as you want. I never
really learned it well enough to understand all the combinations possible, tho.
Last time I had to do something like that, I used
#define MySpecialIntFmt "%i"
and then
printf("Here are " MySpecialIntFmt " integers", i);
But yeah, that was way uglier than it needed to be, especially if you needed
to start putting the strings in an localization file, which is the point to
start with. :-)
Date: 2 Aug 2011 04:16:37
Message: <4e37b265@news.povray.org>
On 08/01/11 17:58, Darren New wrote:
> On 8/1/2011 4:13, Lars R. wrote:
>> It is not surprising if you _know_ C.
>> i.o.w. if it is surprising for you, your C knowledge are incomplete. ^^
> Sure. It's also surprising when your leg disappears, simply because
> while you know you're in a minefield, your knowledge of that minefield
> is incomplete.
ACK.
The spirit of C is: "trust the programmer" because the programmer knows
what (s)he does. If that premise is wrong, anything goes.
Ex falso sequitur quodlibet. :-D
> That doesn't mean it's a *good* thing. Yes, it can be surprising even to
> those who know C well enough to write an operating system kernel in it.
AFAIK most "kernel hackers" knows a lot about their topic, e.g. their
hardware, their data structures (file systems) and so on. But most of
them are not academic C language evangelists who can quote every
paragraph of the ISO C language standard.
> The whole "it's only surprising if you don't know it'll happen"
> tautology is silly. The problem is that composing two perfectly valid
> statements makes an invalid program that behaves completely differently
> than how you would expect from each of those two statements separately.
Crossing the street on foot is fine.
Driving on the streat by car is also fine.
But crossing the street while someone else is driving on can be
disastrous. :-)
L.
Date: 2 Aug 2011 14:03:47
Message: <4e383c02@news.povray.org>
> something like
  In C++ you could use the boost format library, which allows you to do
things like this:
    std::cout << boost::format("writing %1%, x=%2% : %3%-th try")
                 % "toto" % 40.23 % 50;
  (OTOH I'm guessing this is less efficient than the direct approach.)
> and then
  Which is inconvenient if you need to use some format specifiers (such
as printing at least 5 digits, with leading zeros).
Date: 2 Aug 2011 14:20:24
Message: <4e383fe8$1@news.povray.org>
On 8/2/2011 11:03, Warp wrote:
>      std::cout<<  boost::format("writing %1%, x=%2% : %3%-th try")
I'm guessing boost::format has to return something that overloads % in the
same way that cout overloads <<. I'm not sure from your example whether it
supports the flexible formatting stuff either, which was more my point in
the example.
Yeah. I never needed to, but I suppose you could use just "i" instead of
"%i". In any case, it's clearly not flexible enough to handle things the way
you'd like.
