POV-Ray : Newsgroups : povray.off-topic : Core, look at that... Server Time
17 Oct 2026 12:06:00 EDT (-0400)
  Core, look at that... (Message 1 to 21 of 21)
Subject: Core, look at that...
Date: 23 Jun 2011 10:57:30
Message: <4e03545a$1@news.povray.org>
http://en.wikipedia.org/wiki/Magnetic_core_memory
Oh. I hadn't realised it was this small. I was thinking that the "cores"
were the same sort of size as the RF filters you still find on some
cables. (I.e., about 3cm across.) I had therefore imagined that a
complete core memory would fill an entire rack. (I also read somewhere
that it was housed in a vat of heated oil to keep the temperature
constant, and therefore reduce the need to recalibrate.)
 From the look of this photograph, they actually put the stuff on
"chips" of a sort...
Subject: Re: Core, look at that...
Date: 23 Jun 2011 11:19:53
Message: <4e035999@news.povray.org>
http://en.wikipedia.org/wiki/Percussive_maintenance
Best euphemism ever! :-D
Date: 23 Jun 2011 13:04:35
Message: <4e037223$1@news.povray.org>
Am 23.06.2011 16:57, schrieb Invisible:
"Memory modules" is probably closer to the mark. 10x10 cm is not what
I'd call a "chip". (Though this is a pretty small example; the core
memory I once had the opportunity to see (and touch) was more like
20x25, probably with a similar capacity.
My favorite memory type is Core Rope Memory though - a type of ROM used
in the Apollo Guidance Computer, to be programmed with a sowing needle.
Bit by bit. Manually, not with an automaton.
Date: 23 Jun 2011 14:36:54
Message: <4e0387c6$1@news.povray.org>
> were the same sort of size as the RF filters you still find on some cables.
Not really. Draw a circle as small as you can with a fine mechanical pencil,
and you get something the size of a core.
>  From the look of this photograph, they actually put the stuff on "chips" of
> a sort...
Boards. That picture is a 10cm x 10cm board. 8K was about as big as you
could hold in one hand, stretching your fingers.
   "Coding without comments is like
    driving without turn signals."
Date: 23 Jun 2011 21:22:45
Message: <4e03e6e5@news.povray.org>
In the day. A 1K of Honeywell 316 memory was about 1.25" wide, 4" deep
and about a foot long. The cores were strung by hand.
Regards
Date: 24 Jun 2011 04:24:30
Message: <4e0449be$1@news.povray.org>
By unemployed dress makers, apparently.
Also: My dad has a Honeywell central heating system. WTF?
Date: 24 Jun 2011 20:10:28
Message: <4e052774$1@news.povray.org>
Why WTF??
Regards
Date: 25 Jun 2011 07:56:29
Message: <4e05cced$1@news.povray.org>
> Why WTF??
That's like... that's like a company that manufactures motorbikes also
manufacturing pianos!
...oh, wait...
http://blog.orphi.me.uk/
Date: 25 Jun 2011 08:54:39
Message: <4e05da8f$1@news.povray.org>
>> Why WTF??
> ....oh, wait...
Indeed :-D
Regards
Date: 25 Jun 2011 09:28:23
Message: <4e05e277$1@news.povray.org>
I worked on a piece of avionics gear that was used to identify submarine
acoustic signatures ... it was loaded with mag core memory
LOL now that I'm strolling down memory lane ... there was also a dipping
sonar that had a tray of FULL of capacitors about the size of a soda pop
can ... they were bussed together with aluminum bars. There was an
eyebrow raising admonishment on the case "Warning: 3000V Unlimited
Current" ... working on that would make the hair on my arm stand up from
the field!
Did anyone see the articles about IBM turning 100 ... it was full of
examples about "back in the day" technology?
Date: 25 Jun 2011 13:44:40
Message: <4e061e88$1@news.povray.org>
I knew someone who worked on modern military helicopters, at least some of
which also have mag core memory.  The thing is, it's non-volatile. You can
lose power without wiping out your mission or having to reboot or whatever.
When I was in college, I was working on a big assembly program on a
mainframe. 20 minutes into a 30 minute compile, all the lights go out. I
think "Well, so much for getting this done before lunch."  Three minutes
later, the lights come back on, I start getting messages on the terminal
about disks being inaccessible, and then ten minutes later I get "compile
completed."  So, yeah, there was enough voltage in the capacitors to save
the registers out to memory when the power-fail interrupt came along.
Date: 25 Jun 2011 20:34:52
Message: <4e067eac$1@news.povray.org>
>> Why WTF??
> ...oh, wait...
It's rather a piano maker that also make motorbikes. There where Yamaha
pianos long before the first Yamaha bike...
Date: 26 Jun 2011 05:20:29
Message: <4e06f9dd@news.povray.org>
> of which also have mag core memory. The thing is, it's non-volatile. You
> can lose power without wiping out your mission or having to reboot or
> whatever.
I wonder how well the power consumption of core compares to flash.
Because, let's face it, flash is available in densities that core will
never match.
Also, I was under the impression that core requires constant temperature
operating conditions, or you have to recalibrate it.
Date: 26 Jun 2011 06:07:36
Message: <4e0704e8$1@news.povray.org>
Am 25.06.2011 19:44, schrieb Darren New:
> whatever.
Flash memory would do that, too. But I guess when the military does such
things, they know what they want. Robustness against gamma rays or EMP
or some such might be a reason.
Date: 26 Jun 2011 14:37:23
Message: <4e077c63$1@news.povray.org>
>> whatever.
> things, they know what they want. Robustness against gamma rays or EMP or
Well, to be fair, by "modern" I meant "not 1960's", I didn't necessarily
mean "2011". :-) This was... let's see... 1990 or so?  So maybe they're
using flash now.
Another restriction is that you have to be able to actually erase the memory
completely, such as in the event of landing in enemy territory. I don't know
how well flash erases.
Date: 26 Jun 2011 14:51:52
Message: <4e077fc8@news.povray.org>
Le 26/06/2011 20:37, Darren New nous fit lire :
> using flash now.
Flash have a limited number of write, not something you want to deal
with in a desert year long operation.
(military helicopters have such a long live time, mechanical maintenance
is ok on field, but electronic maintenance is always long, expensive &
tricky (i.e. not for the sergent)
> memory completely, such as in the event of landing in enemy territory. I
> don't know how well flash erases.
Usually a little explosive if all they need... as long as it is not
triggered by the EMP. If the information is really sensitive.
Usually it is not: the main target (or secondary ones) is just
coordinates for that mission. And nowadays, everyone has maps.
The Friend-or-Foe identifiers will be changed by the next day/hour, no
problem either.
Date: 26 Jun 2011 15:00:38
Message: <4e0781d6$1@news.povray.org>
It's also easy to plug in and out, compared to core. :-)
I think the idea was you erase it when you park the vehicle, maybe? I was
under the impression they didn't want to actually destroy the thing, but
rather that this was a normal part of operations.
I wasn't sure what he was trying to erase, of course.
Date: 26 Jun 2011 16:12:13
Message: <4e07929d$1@news.povray.org>
>> whatever.
Core against an EMP? An EMP can very easily whipe out any magnetic core
at an intensity that would not affect any consumer grade flash unit.
Then, you can have military grade hardened flash memory that's shielded
against such agressions.
As for gamma rays... a simple redudency system will do.
Date: 27 Jun 2011 08:51:56
Message: <4e087cec$1@news.povray.org>
But, is that the same Yamaha?
~Mike
Date: 27 Jun 2011 09:02:55
Message: <4e087f7f@news.povray.org>
yep ... same logo anyways
Date: 27 Jun 2011 22:01:49
Message: <4e09360d$1@news.povray.org>
Absolutely!
The logo you see on a Yamaha bike, tree tuning forks, comes from the one
made for the piano.
After WWII, Japan discovered the motorbikes and the piano business was
stagnating.
