POV-Ray : Newsgroups : povray.off-topic : Curious C / C++ defined behavior question Server Time
17 Oct 2026 12:06:33 EDT (-0400)
  Curious C / C++ defined behavior question (Message 1 to 20 of 20)
Subject: Curious C / C++ defined behavior question
Date: 22 Jun 2011 15:50:43
Message: <4e024793$1@news.povray.org>
Does the standard say anything about how deeply nested calls can recurse?  I
would imagine this is one of those things that's really difficult to
standardize. Or is this one of those "implementation defined" things, which
would also seem very difficult to control via the compiler on a modern OS.
   "Coding without comments is like
    driving without turn signals."
Subject: Re: Curious C / C++ defined behavior question
Date: 22 Jun 2011 16:07:39
Message: <4e024b8a@news.povray.org>
  That's an interesting question. I don't have the standard here (after all,
it's commercial, so you either have to pay for it, get a free pre-standard
draft, or pirate it), but if I had to guess, it's most probably implementation
defined (the standard *might* recommend a lower limit, but I don't know if
it does).
  In practice you can run out of stack space if you allocate too much on
the stack, and especially if you then recurse deeply. I don't remember now
what kind of error you get in that case (but the end result is probably an
abort()). In many systems the size of the stack can actually be defined from
the outside (iow. the you tell the OS how much stack space it should reserve
for the program you are going to run).
Date: 22 Jun 2011 17:04:04
Message: <4e0258c4$1@news.povray.org>
On 6/22/2011 13:07, Warp wrote:
> (but the end result is probably an abort()).
I would be very, very surprised if it wasn't undefined behavior to violate
the limits of the stack space.  There's just no good efficient portable way
of checking on hardware that doesn't do per-access checks (i.e., like a Z80
or something).
And that's why I'm thinking it can't really be implementation-defined,
unless the implementation is allowed to define it as "ask the OS."
Date: 22 Jun 2011 17:32:07
Message: <4e025f56@news.povray.org>
> or something).
  You can violate any space by poking with pointers and offset at wild,
but the question was what happens if a function recurses too much and the
function calls run out of stack space.
  The official standard probably defines it as either undefined behavior
or implementation defined, but in practice what happens in most systems
is that the C runtime asks the OS to increase the stack space for that
process, the OS says nope, and then the C runtime aborts with some message.
  AFAIK in most systems the C runtime does indeed ask the OS to increase
the stack space as needed (in a similar way as it asks the OS to increase
heap space as needed).
Date: 22 Jun 2011 18:16:44
Message: <4e0269cc$1@news.povray.org>
>> or something).
I was aware of what question I asked, yes. :)
In most multitasking systems with virtual memory running user-space
applications, yes. And my point is that I don't think there's anything in
the standard that's going to restrict C to that sort of machine.
In practice, under UNIX and Windows and such, yes, that's what happens. On
the Amiga 1000? On a Z-80 or 68000 or 8086? No, that's not what happens.
Again, assuming you're talking about a multi-user virtual-memory-based
operating system with demand paging, implying the hardware has per-access
memory checking.  On systems without per-access memory checking, you don't
get that, and it would be odd to include in the standard something that
would have egregious overhead to enforce on low-end hardware.
Am I missing something?  Was I unclear, or were you just not paying as much
attention as you usually do?  (Serious question, not intended as a
criticism. I'm just trying to improve my communication skills.)
Date: 22 Jun 2011 19:31:57
Message: <4e027b6d$1@news.povray.org>
Am 22.06.2011 21:50, schrieb Darren New:
> recurse? I would imagine this is one of those things that's really
> difficult to standardize. Or is this one of those "implementation
> defined" things, which would also seem very difficult to control via the
Such a limit wouldn't make much sense, as the nesting of calls is
typically limited by stack size, the use of which highly depends on the
number of parameters and local variables in a function call.
Consequently, according to the standard it's not even "implementation
defined", nor is the behaviour explicitly "undefined" or "unspecified"
if such limitations are exceeded.
In a typical software production for embedded systems, the maximum
required stack size will be determined as part as the build process (by
examining the call tree), and recursive function calls avoided wherever
possible. An alternative is to run dedicated tests to determine stack
(and heap) usage, and makes sure it does not reach the device's limits
minus a safety margin.
In safety critical applications (e.g. car electronics), dedicated memory
space might be set aside for a separate "high safety" task with limited
functionality but well-analyzed requirements, which might in turn watch
the stack usage of any "convenience" parts of the software at run-time
(e.g. by filling some safety margin just before that software parts'
stack limit with a predefined pattern and repeatedly checking whether
that region remains unchanged). If the expected stack size is ever found
to have been exceeded, the high safety task would then usually try to
re-start the convenience tasks (to make sure they're not operating on
corrupt data), and in case of repeated failure disable them entirely,
possibly reducing the device's functionality to shutting down safely.
Date: 22 Jun 2011 23:24:45
Message: <4e02b1fd@news.povray.org>
On 6/22/2011 16:31, clipka wrote:
> it's not even "implementation defined", nor is the behaviour
> explicitly "undefined" or "unspecified" if such limitations are exceeded.
It seems odd that a standard wouldn't describe what happens, even if only by
describing it as "undefined what happens if you exceed a limit that the
standard also doesn't specify." Because if you don't point out "hey,
function calls may fail in undefined ways", then it would seem you're
guaranteeing they'll obey the semantics the standard gives them.
Sure, I understand how the things work. Thanks for the description. I just
wondered what the standard had to say, if anything.  (But I don't wonder
intensely enough to try to find it in the draft standards. :-)
Date: 23 Jun 2011 02:38:31
Message: <4e02df67@news.povray.org>
  I'm not understanding what you are not understanding.
  I said that I don't know for certain what the standard says (because I don't
have a copy) but that I would guess it's implementation defined. Then I
commented on how it works in practice in many systems.
Date: 23 Jun 2011 02:54:54
Message: <4e02e33e$1@news.povray.org>
Oh, OK. I understood what you were saying, indeed. Since you basically
rephrased in your answer the parts I explained I already knew, I thought
perhaps I hadn't explained it clearly. But you were just rephrasing to
clarify anything I might have said that sounded right but was actually not
understood by me. Cool. Thanks!
Date: 28 Jun 2011 08:26:34
Message: <4e09c87a@news.povray.org>
> recurse?
Partially: At least 2, because it says that functions can be called
recursively. :-)
there are a lot of limits and other limitations where "no diagnostic is
required". But I cannot find anything about a maximum of function call
nesting levels, neither in C++ 2003 nor in C 99.
Lars R.
Date: 28 Jun 2011 12:30:38
Message: <4e0a01ae$1@news.povray.org>
>> recurse?
> recursively. :-)
Heh heh heh. That's a point.
See, that bothers me. Because it implies a function call will always
succeed, because they didn't say it might fail but they do tell you the
semantics of it succeeding.  That's why I wondered what kind of wording they
were using.
Date: 29 Jun 2011 03:44:09
Message: <4e0ad7c9@news.povray.org>
>>> recurse?
>> recursively. :-)
Me too.
> they were using.
Indeed.
I'd suggest something like “A recursion depth of at least 5 must be
supported by the platform. The actual limit might be higher and can be
determined by ...”
But such guarantee is not easily definable because the size of the
function parameters is not limited (only their number). On most
platforms the function parameters live on the CPU stack (when the
registers that are used for parameter transfer are exhausted). That
stack is on most platforms much smaller than the available memory, but
its size cannot be determined in a ISO-C++-compliant way.
So even a recursion “depth” of 1 might fail in such pathetic cases.
But statements like “Every function call might fail due to reasons that
are out of scope of this standard“ are also not sensible, I think.
Any other options or opinions? –.–
Lars R.
Date: 29 Jun 2011 12:49:19
Message: <4e0b578f@news.povray.org>
t be
> determined by ...”
Well, it's not even *recursion* depth, but just call stack depth.
Not any more. In the original version of C, you couldn't pass structs by
value, so it would have been easier to figure out how big your arguments
are.
hetic cases.
If you don't have actual *recursive* functions, you don't need to allocat
e
locals or arguments on the stack at all. On a machine with limited hardwa
re
stack (like a 6502 say), you might very well generate code that will
allocate bigger items in the heap and clean them up when you return, for
example.
I've used Pascal compilers (on a Z-80 for example) that stored all local
variables at fixed addresses. I don't remember how it handled recursion,
but
since I was writing a B-Tree library, I'm pretty sure it recursed OK.
ons that
nk.
I think you could require a minimum amount of stack space to be available
if you wanted. The standard could guarantee that the number of bytes of a
uto
and parameter values passed not exceeding a particular value could be
specified, if they wanted. It's not like the concept of "size of memory
occupied" isn't common in C.
Date: 29 Jun 2011 15:55:47
Message: <4e0b8343@news.povray.org>
Lars R. <rou### [at] gmxnet> wrote:
> I'd suggest something like ???A recursion depth of at least 5 must be
  They can't do that because then all compilers would become non-standard
in this regard.
  You can't impose a minimum amount of recursions because it depend on the
size of the stack and how much stuff is allocated on it. You can allocate
such a huge array on the stack that you might not be able to recurse even
once without running out of stack space, regardless of how large the stack
is.
Date: 29 Jun 2011 21:37:12
Message: <4e0bd348$1@news.povray.org>
> is.
That's why I thought maybe imposing a minimum stack size in bytes would work
out better. Of course, compilers wouldn't become non-standard to support
this - they'd just have to allocate big locals somewhere other than the
stack, which is of course a bad idea for any reason other than compatibility
with lame requirements. :-)
Date: 29 Jun 2011 23:40:46
Message: <4e0bf03e$1@news.povray.org>
Am 29.06.2011 18:49, schrieb Darren New:
> allocate locals or arguments on the stack at all. On a machine with
> limited hardware stack (like a 6502 say), you might very well generate
> code that will allocate bigger items in the heap and clean them up when
> you return, for example.
... which does not prevent you from failure due to hitting the memory limit.
> but since I was writing a B-Tree library, I'm pretty sure it recursed OK.
In that case it either can't have placed all local variables at fixed
addresses, or must have placed a hard limit on recursions.
Either way, there /always/ is a limit on recursion depth, and AFAIK
determining at compile-time whether an arbitrary program ever hits that
depth is as hard as solving the halting problem.
Date: 30 Jun 2011 00:25:48
Message: <4e0bfacc$1@news.povray.org>
Of course.  I wasn't trying to imply there might not be a recursion limit.
Of course anything that allocates memory might fail, and a function call
that's going to allocate a large chunk of memory for a parameter could fail.
I honestly don't remember. I remember I had to switch to a C compiler
because I didn't have enough memory for all local variables at once.
Right.  Sorry if what I wrote implied I thought that wasn't the case.
Date: 30 Jun 2011 03:46:48
Message: <4e0c29e8$1@news.povray.org>
> in this regard.
Hence I wrote: "I would". And in the next sentence I explained why this
whish is not realizable.
L.
Subject: Partially agree
Date: 30 Jun 2011 03:54:43
Message: <4e0c2bc3$1@news.povray.org>
>> determined by ...”
If a language allows recursion you need some kind of stack. If a
language only allows non-recursive function calls you can hold the local
variables at fix addresses, as you also wrote below.
Some tricks like tail recursion optimization allows such fix addresses
also for a limited kind of recursive functions, though...
> are.
Outdated non-standard versions don't interest me. ^^
> available, if you wanted.
If you require that (non-recursive) function calls use a "stack" at all.
That's why both the C and C++ standards avoid to use the term "stack" in
this context.
> of bytes of auto and parameter values passed not exceeding a particular
> value could be specified, if they wanted.
Sounds better. So it doesn't matter whether parameters are passed on
some kind of "stack" (in memory or CPU registers) or on fixed locations
(im memory or fixed CPU registers).
		Lars R.
Subject: Re: Partially agree
Date: 30 Jun 2011 13:15:57
Message: <4e0caf4d$1@news.povray.org>
ust be
e
>>> determined by ...”
l
Sure. I was just saying that supporting a call stack depth of at least fi
ve
is more precise than supporting a recursion depth of at least five. I.e.,
it's possible to run out of stack space even if there's no recursion
involved, assuming you're allocating locals on a stack.
And it's possible for each function to have its own stack, so it can get
really messy.
n
> this context.
Right. But you could still phrase it as requiring a minimum amount of spa
ce
for arguments and auto variables.  I.e., you could express it as adding u
p
the value of sizeof() for each argument in the call chain and each auto
local in the call chain and have a minimum number there. That doesn't mea
n
you can't implement it differently, but it does give some guarantees abou
t
how much space you have to provide for user variables.
Exactly. It has to be written in terms of the semantics of the language,
not
in terms of an implementation.
