POV-Ray : Newsgroups : povray.off-topic : PRNG Server Time
1 Nov 2026 10:10:02 EST (-0500)
  PRNG (Message 1 to 8 of 8)
Subject: PRNG
Date: 22 Jun 2011 08:52:17
Message: <4e01e581@news.povray.org>
There are several types of "psuedo-random number generators" out there.
Most of them work by having some sort of "seed", and a function that
takes the seed and generates a new random number and a new seed.
This is great if you just want to produce a really long stream of random
numbers. But are there any PRNGs out there which offer random (!) access
to the stream of numbers? In other words, the ability to compute the Nth
random number without needing to compute any of the preceding ones?
Subject: Re: PRNG
Date: 22 Jun 2011 10:04:32
Message: <4e01f670@news.povray.org>
Am 22.06.2011 14:52, schrieb Invisible:
(Would that be a Random Access Pseudo-Random Number Generator then? :-))
Depends on what properties you need the PRNs to have.
For instance, if what you really want is to generate a sequence of
numbers with a low discrepancy distribution (and be able to pick
individual ones from the sequence), a Halton sequence would be a good
option.
Then again, if all you want is a value that does not depend on the seed
in any obvious fashion, you might want to look at some cryptographic
hashing algorithms.
Subject: Re: PRNG
Date: 22 Jun 2011 12:01:47
Message: <4e0211eb$1@news.povray.org>
On 6/22/2011 5:52, Invisible wrote:
> But are there any PRNGs out there which offer random (!) access to
Take a look at eliptical curve cryptography.
Otherwise, yes, sure.
SHA(concat("mysecret", myseed, myindex))
   "Coding without comments is like
    driving without turn signals."
Subject: Re: PRNG
Date: 22 Jun 2011 13:50:37
Message: <4e022b6d@news.povray.org>
  You could use a hashing function to convert N to a pseudorandom number,
and it should work exactly as you describe.
Subject: Re: PRNG
Date: 22 Jun 2011 16:23:03
Message: <4e024f27$1@news.povray.org>
Yeah, that's about what I figured.
You could use a cryptographic hash function, but these usually provide
strong guarantees about secrecy, etc. which aren't required if you just
want psuedo-random numbers for simulation purposes. I'm wondering if
anybody has looked specifically at functions which are cheap to compute
but still look "reasonably random".
http://blog.orphi.me.uk/
Subject: Re: PRNG
Date: 22 Jun 2011 17:04:34
Message: <4e0258e2$1@news.povray.org>
On 6/22/2011 13:23, Orchid XP v8 wrote:
> looked specifically at functions which are cheap to compute but still look
Yes. They're called "non-cryptographic hashes". ;-)
Subject: Re: PRNG
Date: 22 Jun 2011 18:24:27
Message: <4e026b9b@news.povray.org>
Am 22.06.2011 23:04, schrieb Darren New:
>> look
... but beware - there are some pretty simple algorithms out there that
probably don't suit your needs. E.g., "hash(data) := data mod N"
qualifies as a hash function, but probably not as "reasonably random".
Subject: Re: PRNG
Date: 23 Jun 2011 04:08:23
Message: <4e02f477@news.povray.org>
>>> look
Yeah, a hash function for a hash table just needs to avoid collisions if
possible. The results don't need to "look random" at all.
