POV-Ray : Newsgroups : povray.off-topic : Three guesses why Server Time
1 Nov 2026 10:13:17 EST (-0500)
  Three guesses why (Message 1 to 22 of 22)
Subject: Three guesses why
Date: 16 Jun 2011 14:54:49
Message: <4dfa5179$1@news.povray.org>
http://www.economist.com/node/18750706?story_id=18750706
http://blog.orphi.me.uk/
Subject: Re: Three guesses why
Date: 16 Jun 2011 17:40:19
Message: <4dfa7843@news.povray.org>
  One thing I thought of:
  A programming language/compiler cannot automatically parallelize all
possible programs given to it in the most optimal way (iow. so that it
maximizes, or at least gets very close to maximizing the efficiency of
the program in a multiprocessor architecture). Some problems are more
easily parallelized in an automatic way, while others are much harder
(they can be really hard to parallelize even for an expert programmer,
not to talk about parallelizing it automatically). This is just a fact
(and I wouldn't be surprised if such an optimization problem would be
at the very least in the NP category, if not in the "impossible" category
in the general case; in fact, if you think about it, distributing code
optimally among processors sounds a lot like the knapsack problem; only
it's probably even harder than that).
  So if we have a programming language and/or compiler that automatically
parallelizes a program, in many cases it will make a pretty lousy job
compared to am expert programmer doing it.
  One would hastily think "well, better *some* speedup by distributing
the task among processors than just running it in one core in the old
fashioned way, with no speedup at all".
  That may be so if you are running that program only. However, in many
cases in many situations that will not be the only program running in the
system. The problem is that this "lousily" parallelized program will be
hogging all the cores for itself, and in a rather inefficient way at that,
and thus other processes will get a smaller share.
  It may even be that in some situation you might even want just the
program using one core if it can't use the others efficiently, so that
you can run something else on the others, than the one program hogging
everything for itself, making other programs run more slowly than they
would have to.
  This automatic parallelization may be also give the false illusion of
efficiency, when in fact it's far from it. After all, you will see the
program using 100% of all the cores. That's pretty efficient, isn't it?
Of course this is just an illusion. CPU usage percentage doesn't necessarily
directly translate to efficiency. One program using two cores at 100% each
might be running just eg. 20% faster than when running on one single core.
(And in fact, I think there are examples of programs which actually run
*slower* on multiple cores than on one core, even though they are using
100% of CPU time on each, as contradictory as that might sound.)
Date: 17 Jun 2011 04:12:02
Message: <4dfb0c52@news.povray.org>
> possible programs given to it in the most optimal way.
Sure. But parallelism doesn't necessarily have to be "automatic". Doing
it manually is OK, so long as you make it really easy to specify what
you actually want. That works.
> easily parallelized in an automatic way, while others are much harder.
Quite. GPUs have been merrily parallising a large class of important
algorithms for decades now. It's no secret that only certain algorithms
fit the GPU model, but when they do, boy do they go fast!
On the other hand, how do you make your word processor go faster? Hell,
*can* you make your word processor go faster? From what I've seen, the
thing that usually slows these down is I/O latency (possibly due to lack
of RAM forcing you to use virtual memory). Adding more CPU power is
going to do nothing about that.
> This is just a fact
It took me a moment to think about this one. My initial reaction was
"isn't the NP category only defined for *sequential* algorithms?" And
then I realised that the process of transforming a program could very
well be a sequential algorithm, and hence amenable to classification.
OOC, how many problems can you name for which there is no known optimal
algorithm? How many problems provably cannot be solved optimally?
> would have to.
Even for programs which do run faster in parallel, due to Amdahl's law,
there's usually a point at which adding more cores does not improve
performance. So you probably don't ever want to say "use as many cores
as I have", because that tends to be pessimal. You probably want to
choose the optimal number of cores for each particular program.
Quite.
This is not a theoretical idea. This is something which commonly happens
in the real world.
Spawn two threads. Have one thread compute the odd-numbered elements of
an array, and the other thread compute the even-numbered elements. This
way, the work is split in half, right?
Except now each CPU core continuously invalidates the other core's L1
cache lines, causing constant memory traffic and hence very high
latency. It's probably vastly slower than just doing all the work in one
thread.
Of course, the solution here is pretty trivial; rather than interleave
the elements, split the array in the middle and have one thread process
each half. If the elements really are independent, you should now see a
50% speedup.
In case this sounds like the kind of mistake only a novice would make,
consider GHC's new parallel garbage collector. Initially they programmed
it to use all available cores. But they quickly discovered that due to
locality issues, performance was rubbish. It turns out to be *faster* to
let cores sit idle rather than generate lots of cache traffic sometimes.
(The solution they eventually implemented was that each core has its own
heap, and garbage-collects it in parallel. At least, for the first
generation. The second generation has a shared heap, which is still
split into "chunks" and collected in parallel.)
Date: 17 Jun 2011 16:50:07
Message: <4dfbbdff$1@news.povray.org>
Is your word processor really not fast enough?
Spell check in one thread, layout of pages you haven't looked at in another
thread, etc.  I think they're already making it faster, if you actually
watch Word or Reader open a big document, for example.
> From what I've seen, the thing
I find that's almost all of the slow-down, actually. Have you seen the video
of the SSD RAID array? Where they open all four office programs with
documents in about half a second?  Where they open every program installed
on the computer in about 10 seconds?
>> This is just a fact
> It took me a moment to think about this one. My initial reaction was "isn't
Sort of. A NDTM isn't exactly a sequential machine.
If it's NP, it's going to be NP on any fixed number of processors. Only if
you let the number of processors scale with the size of the problem does it
come into question. (Granted, that's how a lot of SIMD theory is defined.)
Certainly all the problems that can't be solved can't be solved optimally.
Otherwise, you can always brute force all possible answers and pick out the
optimal one, assuming you have a way of generating answers and evaluating
their relative merits.  I think your question is too ill-specified to be
answered clearly, tho.
> performance.
Certainly having more cores than the number of instructions the program
executes is going to be pointless, so mathematically speaking, the law
*always* applies, even if it's silly in practice to take it to that
exaggeration.
> Except now each CPU core continuously invalidates the other core's L1 cache
> lines, causing constant memory traffic and hence very high latency. It's
> probably vastly slower than just doing all the work in one thread.
And for people who don't have a technical background:
http://blogs.msdn.com/b/ericlippert/archive/2011/06/16/atomicity-volatility-and-immutability-are-different-part-three.aspx
> generation. The second generation has a shared heap, which is still split
GC is definitely one of the harder problems out there. :-) One of those "in
theory it's easy, in practice getting good performance is really hard."
   "Coding without comments is like
    driving without turn signals."
Date: 18 Jun 2011 07:49:53
Message: <4dfc90e1@news.povray.org>
> exaggeration.
  I don't think it works like that. Of course each CPU runs the *same* code,
but each on different input data (or partially different, as some of the
input data may well be shared among the threads, only some parameters being
different; POV-Ray 3.7 would be a perfect example of this).
  Perhaps you meant that having more cores than the amount of generated data
would be useless (because each processor has to output at least one bit of
data to be useful). Since generated data typically has quite many bits, it's
not like you would hit this limit any time soon.
Date: 18 Jun 2011 07:55:20
Message: <4dfc9227@news.povray.org>
  I wonder what gives you that impression.
  The first GPU to support programmable shaders was the GeForce 3 Series,
released in 2001. Back then support for implementing more-or-less generic
algorithms with these shaders was very limited.
  As programmable shader languages were improved, the possibilities
increased, and there were quite many "hacks" to make programmable shaders
do something else than to paint pixels, but it probably was not until CUDA
was published that there was "official" support for generic algorithm
programming on GPUs. The first GPU supporting CUDA was the GeForce 8800
Series, released in 2006.
Date: 18 Jun 2011 15:56:54
Message: <4dfd0306$1@news.povray.org>
>> exaggeration.
I was speaking entirely theoretically. Amahl's law says you only get so much
speed-up, no matter how many CPUs you throw at it. If the sequential program
executes 100 billion instructions over the course of solving the problem,
giving it more than 100 billion processors cannot possibly speed it up any
farther.
Sort of like an O(n) question ignoring the constant factor sort of discussion.
Exactly. That's why I said "mathematically speaking."
When I studied SIMD algorithms in school, the assumption was that you always
had N processors, where N was the same number you were giving to O(N) sorts
of calculations.
Date: 21 Jun 2011 03:55:44
Message: <4e004e80$1@news.povray.org>
> released in 2001.
OK. So the early ones were entirely hard-wired. They're still using
parallel processing to solve a real-world problem. My point was that
some kinds of algorithms are very easy to solve with parallel processing.
Date: 21 Jun 2011 04:31:13
Message: <4e0056d1$1@news.povray.org>
Sometimes. (Depending on which one I'm using.)
> another thread, etc. I think they're already making it faster, if you
> actually watch Word or Reader open a big document, for example.
I wonder if anybody has fixed that thing where closing the CD drive
causes the entire Windows OS to lock up for 30 seconds yet?
I'm just bitter because our document management system requires you to
open a Word document that lives on a Windows share at HQ. Of course, for
all the people at HQ, that's just a subnet away. But for everyone
else... SMB over a WAN is not fast. 5 Mbit/sec bandwidth and 105 ms
latency is not fun with such a chatty protocol.
> Have you seen the
> video of the SSD RAID array? Where they open all four office programs
> with documents in about half a second? Where they open every program
> installed on the computer in about 10 seconds?
I do remember configuring my Amiga 1200 to boot from a RAM disk. Jesus,
that was fast...
> optimally. Otherwise, you can always brute force all possible answers
> and pick out the optimal one, assuming you have a way of generating
> answers and evaluating their relative merits. I think your question is
> too ill-specified to be answered clearly, tho.
OK, so a problem would be provably impossible to solve if the search
space is infinite or if there's no way to enumerate all possible solutions?
>> performance.
> exaggeration.
Sure. My point was that for some programs, adding more cores yields more
speed, at least until you reach ridiculous limits. For other programs,
adding just one or two cores means you already reach that point.
> "in theory it's easy, in practice getting good performance is really hard."
I think the fundamental thing is that GC wants to traverse pointers
backwards, but the heap structure only allows you to traverse them forwards.
Other than that, we keep getting processors with more and more cores,
but exactly the same amount of memory bandwidth. This seems very
unsustainable.
Date: 21 Jun 2011 13:41:44
Message: <4e00d7d8@news.povray.org>
  Scanline rendering is easy to parallelize because all the pixels can be
rendered independently of each other (not unlike raytracing).
Date: 21 Jun 2011 13:55:45
Message: <4e00db21$1@news.povray.org>
On 6/21/2011 1:31, Invisible wrote:
> I wonder if anybody has fixed that thing where closing the CD drive causes
Yes. They call it "NT".  Your flaw is thinking the entire OS is locked up,
when it's really just explorer waiting to read the disk.
> WAN is not fast. 5 Mbit/sec bandwidth and 105 ms latency is not fun with
Yeah. Try starting up SunOS and X Windows on a 4-meg sparcstation with no
internal disk paging over the 10Mbps ethernet.  Ninety seconds to switch
window focus?
> I do remember configuring my Amiga 1200 to boot from a RAM disk. Jesus, that
> was fast...
Amazing how when you get rid of the moving parts and the simulation of
moving parts it goes really fast.
> OK, so a problem would be provably impossible to solve if the search space
It would be provably impossible to solve via brute force, sure. That's
exactly what keeps the halting problem from being solved, in at least some
sense.
Beyond that, you'll have to say what you mean by "solving optimally". We
know the optimal Big-O for a number of problems. Is that what you're talking
about?
Right. My comment was more of an aside.
I also realized yesterday, when driving past the building I tried to model
for my game that slowed the frame rate to a crawl when I actually drew it,
that the reason the universe doesn't have trouble keeping up with the
frame-rate is that it really does have N processors for a problem of size N.
How do you calculate in real time exactly what it would look like to have
light reflecting off that building built out of all those atoms?  Give each
atom the ability to process its contribution to the reflected light in
parallel.  How do you do the clipping and shadow casting in real time? Have
each atom doing the clipping and shadow casting in parallel for all the
pixels it affects. Etc.
(Yes, maybe obvious, but it kind of twinged with this conversation.)
I don't think GC wants to traverse backwards, except perhaps in purely
functional languages/heaps. GC works by starting at the roots and seeing
what's still reachable, so that's all forward pointers.
> Other than that, we keep getting processors with more and more cores, but
> exactly the same amount of memory bandwidth. This seems very unsustainable.
Yep.  That's why NUMA is getting more popular and such.
Date: 22 Jun 2011 04:07:13
Message: <4e01a2b1$1@news.povray.org>
Indeed, a great many graphical tasks parallise very well. For example,
image scaling (whether bilinear or trilinear or anisotropic or
whatever). Or DCT / inverse DCT operations [on independent pixel blocks].
Other tasks don't parallise so well.
Date: 22 Jun 2011 04:35:48
Message: <4e01a964$1@news.povray.org>
>> causes
> up, when it's really just explorer waiting to read the disk.
Sure. It's not the whole OS. It's just the entire GUI. Subtle difference
there.
Same thing happens if the OS is expecting to configure a NIC via DHCP
but there's no server. It waits quite a long time - which is fine - but
the entire GUI again locks up while it does so (which isn't fine). No
reason, just poor design. (I think in XP it at least doesn't sit around
waiting if there's no cable plugged in.)
> no internal disk paging over the 10Mbps ethernet. Ninety seconds to
> switch window focus?
Running X Windows on an Amiga 1200 is almost as slow as that. Which is
daft really; the native OS is trippy-fast. More responsive than some of
the [massively more powerful] PCs I look after at work. And here I was
thinking Linux was fast...
>> Jesus, that was fast...
Back in those days, people were talking about PCMCIA RAM cards and how
they were going to replace HDs. Never happened, did it?
Then again, SSDs are here now, and gradually becoming actually popular.
I guess history repeats itself, eh?
>> space
> some sense.
> talking about?
Warp's original comment was that partitioning an arbitrary problem such
that you gain parallel speedup is probably impossible "in practise".
Intuitively, I was wondering how many real-world problems are
"impossible" to solve in the real world. (Here "solve" doesn't
necessarily mean deriving an /optimal/ solution, just a solution that's
"useable".)
I guess that *is* way too vague to answer.
> model for my game that slowed the frame rate to a crawl when I actually
> drew it, that the reason the universe doesn't have trouble keeping up
> with the frame-rate is that it really does have N processors for a
> problem of size N.
> have light reflecting off that building built out of all those atoms?
> Give each atom the ability to process its contribution to the reflected
> light in parallel. How do you do the clipping and shadow casting in real
> time? Have each atom doing the clipping and shadow casting in parallel
> for all the pixels it affects. Etc.
Heheh, yeah. Didn't somebody say a few months back "we need advanced
quantum computers *now*!", to which somebody else replied "we already
have that; we call it 'the real world'". ;-)
>> forwards.
Ideally you want to find out whether a given object is pointed to by
anything - which is a reverse pointer traversal. But of course, that's
impossible, so we do forward traversal to compute the same information.
Except that's not true of course. It's possible for two dead objects to
point to each other. (Which is why reference counting will never work.)
The other option is to put the liveliness testing into pointer
manipulation operations (since this is the only place where the
information can change), but that's going to heap tonnes of overhead
onto very common operations.
The other thing I've thought about is having multiple heap areas and
tracking pointers between them. If you could arrange it so that all the
garbage is in one heap chunk, you can just drop the whole chunk rather
than doing complex processing over it. However, that's not easy to
achieve in general.
>> unsustainable.
Only for supercomputers.
I wonder how long it will take for desktops to catch up?
Speaking of which, take a look at this:
http://tinyurl.com/64bfdmv
The interesting bit is slides #3 and #4. I've often wondered why all the
books about supercomputers talk a lot about parallel processing, but
[until recently] it's never seen in normal computers. Now I know, I guess...
Date: 22 Jun 2011 11:44:45
Message: <4e020ded$1@news.povray.org>
On 6/22/2011 1:35, Invisible wrote:
> Sure. It's not the whole OS. It's just the entire GUI. Subtle difference there.
Not the entire GUI. One program running the file manager.
Your email client still works. Your background processes still work.
Programs trying to open files might get stuck.
> Same thing happens if the OS is expecting to configure a NIC via DHCP but
> there's no server. It waits quite a long time - which is fine - but the
Never had that problem that I remember. On the other hand, yes, since Vista
or so, network I/O requests can be canceled, which is what you're
experiencing there.
> No reason, just poor design.
More like "insufficient engineering time given to edge cases to make them
efficient."
> Then again, SSDs are here now, and gradually becoming actually popular. I
Yeah. Sadly, it has to actually *look* like a disk, so you still get a lot
of the overhead.
> Warp's original comment was that partitioning an arbitrary problem such that
I wouldn't be surprised if it was mathematically impossible in theory, either.
For the general case, yeah.
> Heheh, yeah. Didn't somebody say a few months back "we need advanced quantum
> computers *now*!", to which somebody else replied "we already have that; we
I think that was me, yes. :-)
> anything
Um, no, not really. You want the collection of live objects. Or the
collection of dead objects. You don't do GC one object at a time, unless
you're doing reference counting.
http://en.wikipedia.org/wiki/Garbage_collection_%28computer_science%29#Tri-colour_marking
> point to each other. (Which is why reference counting will never work.) The
> other option is to put the liveliness testing into pointer manipulation
> operations (since this is the only place where the information can change),
> but that's going to heap tonnes of overhead onto very common operations.
Yes, that's reference counting, and that's why people avoid that in GC when
they can.
> garbage is in one heap chunk, you can just drop the whole chunk rather than
> doing complex processing over it. However, that's not easy to achieve in
> general.
That's called semi-space garbage collection.
>>> unsustainable.
The Opteron is a supercomputer?
You're probably already running it.
Comic Saaaaaaaaaaans!
> books about supercomputers talk a lot about parallel processing, but [until
Because until recently (like, the last 10 years), putting multiple CPUs in
something was very expensive.
Date: 22 Jun 2011 11:45:51
Message: <4e020e2f@news.povray.org>
Pretty much anything computed by atoms parallelzixes well. Sound algorithms,
video algorithms, image algorithms, mapping algorithms, etc.
Date: 22 Jun 2011 12:07:11
Message: <4e02132f$1@news.povray.org>
Actually, I suspect what's happening is that you put the CD in, and Windows
immediately generates a message saying "hey, your list of valid disks may
have changed." At which point Explorer (and maybe others) goes out over the
list of disks, but Windows is still spinning up the CD and all that, not yet
having determined which file system it is and mounted it, so processes that
do that hang waiting for the disk to mount.
You *could* make a separate thread to handle this one case, but it's
probably not worth it, esp. since you're the only person in my entire career
I've heard complain about it.
Date: 22 Jun 2011 16:31:48
Message: <4e025134$1@news.povray.org>
> career I've heard complain about it.
The other fun one is clicking on A: by mistake. It takes an absurdly
long time to figure out that there's no disk there. (That's possibly a
limitation of the hardware, but some sort of status indication wouldn't
hurt.)
Still, apparently only people like me actually *care* that the design is
flawed. Normal people just assume "it's a computer, it's not supposed to
work properly". So why does M$ have any incentive to fix it? It's not
like it affects their profits...
Date: 22 Jun 2011 16:51:36
Message: <4e0255d8$1@news.povray.org>
> algorithms, video algorithms, image algorithms, mapping algorithms, etc.
Not sure what the difference between "video algorithms" and "image
algorithms" is, but you can add "kinetic simulations" to the list...
Date: 22 Jun 2011 17:05:40
Message: <4e025924$1@news.povray.org>
> flawed.
I'd say confusing "flaw" with "intentional design trade-off" is your problem
there.
Date: 22 Jun 2011 17:06:42
Message: <4e025962$1@news.povray.org>
> algorithms" is,
If you have an image operation that convolves the entire image in a way that
can't be para;lelized, you can still paralellize it between different frames.
Yeah, probably true.
Date: 22 Jun 2011 17:09:35
Message: <4e025a0f$1@news.povray.org>
>> difference there.
The Start menu stops working, all open Explorer windows stop working,
the task bar stops working, the system tray stops working, windows stop
repainting, Alt+Tab stops working, and even Ctrl+Alt+Del becomes very
slow. And for what? Because of a piffling hardware event which I might
not even care about? Great...
> them efficient."
I'm not sure "the entire PC stops working every time you touch the CD
drive" is what I'd call an "edge case", but whatever...
> lot of the overhead.
I did see a flash device that's a PCI card. It requires special device
drivers and stuff, but apparently it goes stupidly fast.
Then again, the advantage of a vanilla SSD is that it works with
everything. A bit like the way 30 years after the original IBM PC was
released, almost every desktop computer on Earth still pretends to have
a 20-bit address space until you twiddle one of the control registers on
the keyboard controller (!?!) to enable access to all of the installed RAM.
>> such that
> either.
Well, no, the search space is presumably finite (although absurdly
vast), so theoretically it's trivial.
>> than
>> general.
Wikipedia's description of "semi-space GC" seems to be "2-space GC".
How many desktop PCs contain an Opteron?
Desktop PCs have had non-uniform memory access times for decades now.
But currently, they all *pretend* to have uniform memory. NUMA is about
explicitly admitting that there are different pools of memory, with
different properties.
Yeah, well, I didn't write it...
> in something was very expensive.
Putting multiple chip in is *still* very expensive. ;-)
Date: 22 Jun 2011 18:12:23
Message: <4e0268c7$1@news.povray.org>
On 6/22/2011 14:09, Orchid XP v8 wrote:
> windows stop repainting,
All of them? Or just explorer windows?  Because none of that stuff happens
with me.  Maybe you have something installed that goes compute-bound or
something when you mount a disk.
> I'm not sure "the entire PC stops working every time you touch the CD drive"
Clearly it doesn't "stop working."  Try opening the task manager and
watching the chart scroll when you put something in the CD drive.
> Then again, the advantage of a vanilla SSD is that it works with everything.
Exactly, yes.
>>> such that
>> either.
> Well, no, the search space is presumably finite (although absurdly vast), so
Hmmm. Maybe, yeah, if you tried every possible rearrangement of opcodes sort
of thing. But that assumes you can tell that the rearranged opcodes will
have the same effect, which again is impossible.
I.e., the number of ways you can chop up the problem is finite, but the
number of *wrong* ways to chop up the problem is non-zero.
>>> than
>>> general.
Well, you're either talking about generational heaps, semi-space heaps, or
separate heaps that might have roots in other heaps, in which case it's the
same as a generational heap technologically-speaking.
http://sites.amd.com/us/business/products/desktop/Pages/hp.aspx
Come on now. That wasn't even difficult.
> Desktop PCs have had non-uniform memory access times for decades now. But
Well, except to the OS.  Applications pretend they all have contiguous
memory addresses, too.
