POV-Ray : Newsgroups : povray.off-topic : A retro moment Server Time
1 Nov 2026 10:11:42 EST (-0500)
  A retro moment (Message 1 to 50 of 50)
Subject: A retro moment
Date: 7 Jun 2011 06:58:24
Message: <4dee0450$1@news.povray.org>
Question: How long does it take to copy 1.0 MB of data onto a 3" floppy
disk?
Answer: I gave up after waiting about 25 minutes.
Of course, actually formatting the whole disk only takes about 30
seconds, so there's no way copying the data to it should take that long.
Is there?
Well, in this instance, there is. You see, for whatever reason, there's
an issue with putting many small files onto such a disk. I don't know
whether the issue is with the file system design or just the OS
implementation, but it appears that every file creation operation
involves writing the file's data to one block, and updating the file
listing in another block. The result is that if you create many hundred
tiny files, the [extremely slow] R/W heads spend forever repeatedly
tracking back and forth, once per file. In this instance, copy time is
proportional to the /number/ of files, not their /size/.
Quite why Windows can't just write the final listing to the directory
block and then write all the file data blocks sequentially is beyond me,
but anyway...
Fortunately, copying said files /off/ the disk again is slightly
quicker. But only slightly.
But why do I know all this? I'll tell you why. Last week one of the
ancient PCs in our lab stopped working. As in, you turn it on, all the
lights come on, all the fans spin... and nothing else happens. The
lights are on, but nobody's home.
Now, the PC was pretty damned warm. I came back the next day and it
suddenly decided to work again. But each time it works for a while and
then stops working once it gets warm. I removed several throw rugs'
worth of dust, hair and fluff from the inside of the thing, but it's
still not working reliably.
I suppose I could try to repair it. But... are you kidding me? Let's
look at the spec sheet here:
Motherboard: Gigabyte GA-5AX
Processor: AMD K6 II with 3DNow!, 500 MHz
Memory: 128MB DDR1
Harddrive: 4.2 GB PATA
Graphics: S3 Trio3D/2X APG
Sound: None
Optical drive: None
Network: SMC 1211TX
Can you see why the inside might be a little dusty? Still, we only use
this thing to run an old 16-bit Windows 3 program that controls some
gear via a serial port. (Astonishingly, this works with Windows XP. Go
figure...)
Anyway, at one time /all/ our PCs were to this exact spec. We bought a
big batch of them so they would all be identical. Nice idea, but that
was a few years ago now. (!) So I had a hunt around, and managed to find
an 800 MHz Intel Celeron brick. So I installed the software on that,
managed to get the failing PC to work for long enough to upload all the
configuration files to a network share, unplugged the failing PC, moved
the replacement into place, and...
...now the integrated NIC on the replacement PC doesn't work. No reason.
It just doesn't. No matter how much I poke and prod it, I can't get any
activity lights out of it. Not interested. Won't work.
Both PCs had perfectly OK network access before I started (as evidenced
by the many network operations performed just prior to the move). If I
unplug the network cable and plug it into any other device, it works.
But it *refuses* to work when plugged into the replacement PC. For no
reason other than to spite me.
Needless to say, I was extremely angry by the time I went home yesterday...
Subject: Re: A retro moment
Date: 7 Jun 2011 07:34:47
Message: <4dee0cd7@news.povray.org>
> disk?
  Don't you mean a 3.5-inch floppy disk? I think 3-inch floppy disks
existed at some point, but they were really rare.
  That's how FAT works.
Date: 7 Jun 2011 08:00:18
Message: <4dee12d2$1@news.povray.org>
On 07/06/2011 12:34 PM, Warp wrote:
>> disk?
I can never remember whether it's 3.5 or 3.25 inch.
>> I don't know
Probably.
Still, why it can't build an image of what the final disk layout will
look like in RAM and then write it all to disk in the most efficient
order, I don't know. That's how I would probably do it.
(I guess Windows NT doesn't do this because when that was new, 64 MB RAM
was considered "large". So using over 1.5% of it for the disk image was
probably unacceptable. Why Windows XP still has this limitation is
another matter...)
In the end, the resolution was to create a self-extracting archive of
all the tiny files using 7zip. Remarkably, the resulting self-extracting
file /actually works/ on Windows NT still. (As a happy side-effect, the
1MB of data becomes 202KB.)
Date: 7 Jun 2011 08:22:32
Message: <4dee1808@news.povray.org>
it's 3 & 1/2, and before 5 & 1/4.
just remember that the denominator is 1 less than the number of inches.
That's for PC. (and it does not work for 8" floppy... you do not want to
remember them!)
(3" did exist and were common on Amstrad... 3" is the width, as their
length was longer)
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 7 Jun 2011 09:40:04
Message: <4dee2a34$1@news.povray.org>
> disk?
> Is there?
> implementation,
It's FAT's fault.  This has nothing to do with the OS.
> but anyway...
What happens if the power goes out in the middle of the operation and
the file allocation table has already been written, but the actual data
has not been copied over?  This is why you have to update the FAT
everytime you use a block, and the directory everytime you write a file.
This is one of the earlier forms of transaction tracking.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 7 Jun 2011 09:45:30
Message: <4dee2b7a$1@news.povray.org>
On 6/7/2011 3:58, Invisible wrote:
> Quite why Windows can't just write the final listing to the directory block
> and then write all the file data blocks sequentially is beyond me, but
> anyway...
Read up on how FAT works. It's not seeking back to write the directory
listing. It's seeking back to read/write the FAT table.
Given modern memory sizes, it ought to be able to cache the FAT table,
especially given that one might very reasonably be having only one process
with files on the disk open to start with. But I suspect not a whole lot of
time was put into optimizing that.
Blame UNIX.  The CP/M operators were much faster.  :-)
> Can you see why the inside might be a little dusty? Still, we only use this
> thing to run an old 16-bit Windows 3 program that controls some gear via a
> serial port. (Astonishingly, this works with Windows XP. Go figure...)
Didn't you just say that security updates can be done without breaking
things? Yet here you are, amazed that a Win3 program runs under XP. ;-)
I need to learn how to not get frustrated by such things myself.
   "Coding without comments is like
    driving without turn signals."
Date: 7 Jun 2011 09:47:23
Message: <4dee2beb$1@news.povray.org>
On 6/7/2011 5:00, Invisible wrote:
> Still, why it can't build an image of what the final disk layout will look
> like in RAM and then write it all to disk in the most efficient order, I
It's a removable disk.
There were backup programs under DOS that worked this way, incidentally.
You'd just page floppies and it would write them as fast as it could, even
alternating drives. But when it was done, they were all valid files.
> (I guess Windows NT doesn't do this because when that was new, 64 MB RAM was
> considered "large". So using over 1.5% of it for the disk image was probably
> unacceptable. Why Windows XP still has this limitation is another matter...)
Why would you optimize something as slow as floppy access instead of
improving other parts of the system to start with?
Date: 7 Jun 2011 09:51:21
Message: <4dee2cd9$1@news.povray.org>
On 6/7/2011 6:39, Francois Labreque wrote:
> This is why you have to update the FAT everytime you use a
Technically, you only need to update the FAT when you close the file. If you
haven't recorded the length of the file, you don't really care if the space
is marked as used in the FAT.
I.e., if you create a zero-length file name in the directory, then start
writing the file, modifying a cached version of the FAT as you write, and
then the power goes out (or the disk gets pulled), then the FAT says the
space is unallocated and the directory says the file is unallocated, so
you're OK.
So I think (IIRC) it writes the zero-length file to the directory, then
reads the FAT, then writes the file data while updating the FAT sector, then
finishes by flushing the final changes to the FAT and then going back to
update the directory to point to the first block in the chain.
It also flushes the FAT sector whenever it moves to allocating from a
different FAT sector, which is why you'll hear it write a few tracks, then
crank back and forth, then write a few more tracks, then crank back and
forth, as you copy a large file.
Date: 7 Jun 2011 10:04:32
Message: <4dee2ff0$1@news.povray.org>
>> look
And?
> even alternating drives. But when it was done, they were all valid files.
Yeah. That seems like the most sensible way to go.
Because it's a trivially easy optimisation?
Date: 7 Jun 2011 10:05:58
Message: <4dee3046$1@news.povray.org>
>> but anyway...
OK. So do it in the opposite order. Write the directory entry last,
after all the files have been written.
It's not like anybody expects a floppy disk to actually operate
*reliably*...
Date: 7 Jun 2011 10:08:08
Message: <4dee30c8@news.povray.org>
>> block
>> anyway...
OK. So it's called a file allocation table rather than a directory
listing. Same difference.
Why would a security update break a program that only reads and writes
text files and accesses the serial port?
Date: 7 Jun 2011 10:35:19
Message: <4dee3727@news.povray.org>
>>> look
> And?
And it has to be not completely corrupted if you remove it?
Not really.  What happens if you have multiple processes writing to the disk
at the same time?  You're looking at one specific use case, and complaining
that the general tool isn't optimized for that use case.
Date: 7 Jun 2011 10:35:52
Message: <4dee3748@news.povray.org>
On 6/7/2011 7:05, Invisible wrote:
> OK. So do it in the opposite order. Write the directory entry last, after
It's not the directory entry. It's the file allocation table.
Date: 7 Jun 2011 10:37:02
Message: <4dee378e@news.povray.org>
On 6/7/2011 7:08, Invisible wrote:
> OK. So it's called a file allocation table rather than a directory listing.
> Same difference.
Um, no. These are two entirely different things.
> Why would a security update break a program that only reads and writes text
Because the serial port is hardware that many programs accessed without
going through the operating system to do so.
Date: 7 Jun 2011 10:49:41
Message: <4dee3a85@news.povray.org>
> disk at the same time? You're looking at one specific use case, and
> complaining that the general tool isn't optimized for that use case.
You know, the rest of the filesystem is cached too, and that doesn't
seem to cause any problems...
Date: 7 Jun 2011 10:50:56
Message: <4dee3ad0$1@news.povray.org>
In what way?
Ah, now *that* I would expect to fail, yes. And, indeed, one of our
other programs *does* fail on Windows XP because it actually tries to
overwrite SERIAL.SYS with its own customised version...
Date: 7 Jun 2011 10:58:45
Message: <4dee3ca5$1@news.povray.org>
Not on a removable floppy drive.
Date: 7 Jun 2011 11:02:06
Message: <4dee3d6e$1@news.povray.org>
> In what way?
The File allocation table is a MAP of sectors (which ones are free,
which ones are busy). When writing a file, not in that order:
 * allocate sectors for the file content
 * file the sectors with file content
 * update the sector of the directory content to have "name-->sector/id"
 * update the FAT.
Notice that until you update the FAT, you cannot have a concurrent
allocation for another file.
(also, the update of directory might need a new sector)
around.
it's free.
Date: 7 Jun 2011 11:02:36
Message: <4dee3d8c$1@news.povray.org>
> In what way?
http://en.wikipedia.org/wiki/FAT_file_system#Design
In the same way that a linked list is an entirely different thing from a
hashtable.
> Ah, now *that* I would expect to fail, yes. And, indeed, one of our other
> programs *does* fail on Windows XP because it actually tries to overwrite
That's another example.
Date: 7 Jun 2011 11:25:49
Message: <4dee42fd$1@news.povray.org>
Actually, it's not only that but also what granules are allocated to what
file in what order.  It's not just a free-space bitmap, but an actual
collection of linked lists.
Date: 7 Jun 2011 11:29:08
Message: <4dee43c4$1@news.povray.org>
>> In what way?
Oh, I see. So the FAT is just a map of free clusters?
I don't think that impacts what I originally said though; you could
still cache it.
> hashtable.
Conceptually, a dictionary is a dictionary, regardless of which data
structure you use to implement it.
Date: 7 Jun 2011 11:39:02
Message: <4dee4616$1@news.povray.org>
No. It's a file allocation table.
> I don't think that impacts what I originally said though; you could still
> cache it.
It is cached. It's just that the cache gets written when you close a file
after allocating space from the cache, because the system can't tell you're
going to copy more files.  Otherwirse, writing a big file would have to
slopping back and forth between three different tracks for every granule
written.
>> hashtable.
And a linked list is not a dictionary.
Date: 7 Jun 2011 11:41:39
Message: <4dee46b3@news.povray.org>
That's like saying "an open set is any set that's open". This is a
useless description.
>> cache it.
> file after allocating space from the cache, because the system can't
> tell you're going to copy more files. Otherwirse, writing a big file
> would have to slopping back and forth between three different tracks for
> every granule written.
OK. But I still don't see why you can't cache the entire disk image on a
typical modern PC. (Obviously there was a time when this would have been
impractical.)
Date: 7 Jun 2011 11:58:15
Message: <4dee4a97$1@news.povray.org>
> That's like saying "an open set is any set that's open". This is a useless
> description.
You're sitting in front of google. And wikipedia.
> impractical.)
You can. But if you want to make it safe to remove the disk when it's
consistent, you still have to write it out after you make changes. I'm not
sure why you're not getting this point.  Floppy disks don't have a "remove
safely" feature. They have a hardware button on the front.
Date: 7 Jun 2011 13:13:04
Message: <4dee5c20$1@news.povray.org>
So, essentially, your entire argument is "the user can eject the disk at
any time, therefore it's unsafe to cache anything".
Correct me if I'm wrong, but wouldn't the contents of the disk be
irrepairably corrupted *anyway*? That's why there's a disk activity
light; so you don't hit eject while it's still writing stuff.
http://blog.orphi.me.uk/
Date: 7 Jun 2011 13:21:07
Message: <4dee5e03@news.povray.org>
Standard sizes are/were 3.5", 5.25", and 8".
Jim
Date: 7 Jun 2011 13:23:19
Message: <4dee5e87$1@news.povray.org>
Having actually done this at several points in the past, I can assure you
that Darren is correct.  Caching removable devices tends to be *very* bad
for data integrity.
That's why, for example, in Windows (and on Linux), you need to "safely
remove" USB flash drives - they are cached for performance reasons.
Jim
Date: 7 Jun 2011 13:24:31
Message: <4dee5ecf$1@news.povray.org>
Random fact: I'm ancient enough to *remember* 5.25" floppy disks. (They
were noteable in that they were actually *floppy*.)
Date: 7 Jun 2011 13:26:35
Message: <4dee5f4b@news.povray.org>
> for data integrity.
In which way is suddenly removing a USB flash drive different from
suddenly ejecting a floppy disk?
So why is it perfectly OK to cache a USB flash drive, but completely
unthinkable to cache a floppy disk?
(Also, I'm sure I saw somewhere a setting in Windows to select whether
the "safely remove hardware" thing is optional or not. The default
setting is worse performance in exchange for pulling the drive /not/
completely screwing the filesystem. I'm guessing M$ found that too many
people actually did this...)
Date: 7 Jun 2011 13:28:49
Message: <4dee5fd1$1@news.povray.org>
>>> at any time, therefore it's unsafe to cache anything".
>> you that Darren is correct.  Caching removable devices tends to be
>> *very* bad for data integrity.
Because people are used to ejecting a diskette when they've finished
writing to it.  Sometimes you have to keep an old method around because
of the habits people form.
See above.
Performance vs. reliability.  Traditional tradeoff.
Jim
Date: 7 Jun 2011 13:29:14
Message: <4dee5fea$1@news.povray.org>
You do realise that 30 is *not* "ancient", right?
Jim
Date: 7 Jun 2011 13:38:58
Message: <4dee6232$1@news.povray.org>
Are you kidding me? I was obsolete technology, like, 20 years ago...
Date: 7 Jun 2011 13:40:03
Message: <4dee6273$1@news.povray.org>
Yes. That makes sense. Turn it on if you want more speed, turn if off if
reliability is more important.
What doesn't really make sense is that for a floppy disk, there's no
option to turn it on.
Still, hopefully I will never have to access a floppy disk again for the
rest of my natural life, so it won't actually *matter* or anything...
Date: 7 Jun 2011 14:31:00
Message: <4dee6e64$1@news.povray.org>
On 6/7/2011 10:13, Orchid XP v8 wrote:
> So, essentially, your entire argument is "the user can eject the disk at any
No. It's unsafe to cache data structures that have interrelationships. It's
unsafe to cache the data a pointer points to in RAM while writing the
pointer back to disk.
The FAT *is* cached. It's just *also* flushed when you close each file.
How would you tell the machine it's time to write the cache to the floppy?
No. That's the point. You write things in the order that makes the files not
corrupted if you remove them. That's why if you chkdsk a floppy after
writing files but not closing them, you get "CHKDSK.001" type files.
Date: 7 Jun 2011 14:32:30
Message: <4dee6ebe$1@news.povray.org>
On 6/7/2011 10:26, Orchid XP v8 wrote:
> In which way is suddenly removing a USB flash drive different from suddenly
It's not. It'll screw up your USB drive also if you remove it without
flushing the buffers.
Because people have learned they can't just yank out a USB disk and think
it'll be OK.  Whereas the old versions of DOS said "once you come back to
the command prompt, it's safe to take out the disk."
> (Also, I'm sure I saw somewhere a setting in Windows to select whether the
> "safely remove hardware" thing is optional or not. The default setting is
> worse performance in exchange for pulling the drive /not/ completely
> screwing the filesystem. I'm guessing M$ found that too many people actually
> did this...)
There ya go.
Date: 7 Jun 2011 14:33:26
Message: <4dee6ef6$1@news.povray.org>
Which is why MS isn't investing a whole ton of effort into optimizing this case.
Date: 7 Jun 2011 16:35:08
Message: <4dee8b7c$1@news.povray.org>
>>> many people actually did this...)
People form habits, and rather than deal with people saying "Hey, you
never told me I would lose data by doing this" (no matter how many
warnings there are, someone will claim that and will sue over lost data
as a result), they decided to leave it alone.
I was a bit surprised about 6 weeks ago when I had to.
Jim
Date: 7 Jun 2011 16:36:10
Message: <4dee8bba@news.povray.org>
>>> (They were noteable in that they were actually *floppy*.)
Pardon me while I go bang my head against a brick wall for 20 minutes.
I'm 40, so what does that make me?
You still learn (hell, you go out of your way to learn new stuff).  30 is
nothing.  Talk to your grandparents if you think *you're* old.
Jim
Date: 7 Jun 2011 18:05:00
Message: <web.4dee9fc71931e63d773c9a3e0@news.povray.org>
a relic? :p
Date: 7 Jun 2011 18:14:12
Message: <4deea2b4$1@news.povray.org>
> a relic? :p
LOL
Date: 8 Jun 2011 08:55:15
Message: <4def7133@news.povray.org>
  It's not, which is the point. If you remove a USB drive without flushing,
you will probably get data loss.
  Why should operating systems switch to a less safe method of writing to
floppy disks than in the past? And why even bother changing anything given
that floppy disks are a dead medium?
Date: 8 Jun 2011 09:22:51
Message: <4def77ab$1@news.povray.org>
Actually, no.  The activity light is to prevent you from physically
damaging the RW head by pulling on the diskette while the head is still
in harm's way.  5.25" and 8" drives actually locked the door while the
head was moving.
Date: 8 Jun 2011 09:38:35
Message: <4def7b5b@news.povray.org>
> head was moving.
  Ah, the time when disks were actually physically pulled out of the drive
via manual force, rather than being ejected by a spring mechanism...
  Would you believe I'm too young to have ever used such disk drives?
I grew up with 3.5-inch hard-covered "floppy" disks. The luxury.
Date: 8 Jun 2011 09:59:07
Message: <4def802b@news.povray.org>
On 08/06/2011 02:38 PM, Warp wrote:
>> head was moving.
My memory is that on the 5.25" drive I saw, you turned a little knob
(which blocks the slot where the disk goes in). Until you turn this
knob, the drive won't acknowledge the media.
Let me see if I can find an image...
...there we go:
http://en.wikipedia.org/wiki/Commodore_1541
As you can see, with the knob turned, you physically can't move the
disk, because the knob is in the way.
Date: 8 Jun 2011 13:43:34
Message: <4defb4c6$1@news.povray.org>
On 6/8/2011 6:22, Francois Labreque wrote:
>  5.25" and 8" drives actually locked the door while the head was moving.
More precisely, on every model I saw, the door-open was a latch (i.e.,
something you turn like a doorknob or such rather than a push button), and
the heads were attached to that. So moving the blocking bar out of the way
of the drive slot also lifted the heads off the disk.
Date: 8 Jun 2011 13:44:22
Message: <4defb4f6@news.povray.org>
On 6/8/2011 6:59, Invisible wrote:
> As you can see, with the knob turned, you physically can't move the disk,
And the heads were attached to the knob, yes. (Or at least lifted when you
turned it.)
Date: 9 Jun 2011 04:21:37
Message: <4df08291@news.povray.org>
> you turned it.)
Really? I didn't know that...
Date: 9 Jun 2011 06:55:03
Message: <4df0a687$1@news.povray.org>
Am 07.06.2011 12:58, schrieb Invisible:
> but anyway...
Keeping things as consistent as FAT allows at any one time, as a
safeguard agains the user ejecting a disk during operation?
Date: 9 Jun 2011 15:36:30
Message: <4df120be@news.povray.org>
>> block
>> anyway...
> process with files on the disk open to start with. But I suspect not a
> whole lot of time was put into optimizing that.
First off, for storage media, you don't want to do it that way in the
bloody first place. You want to make sure the data is actually there
*first*, so that when you point the file table to it, its not pointing
at empty disk space. But, to do that, you have to go back to where the
directory data is located, and update it to point at the now *actually
there* data.
Personally, I never *quite* understood how you get more reliability,
with something like storing what you are doing, so you can replay it, if
the disk gets unmounted. You still need to have the shit you did *on*
the disk, so you can replay it. Which means that the only thing you
might be saving is some seek time, if you have your session data stored
at the start of the disk, and the final write/replay goes to a bunch of
different places. Its basically writing to a swap file, then using that
to generate the data, if the power goes out. But, you have to write the
data, then read it, then write it again, to finalize the changes. Sure
it makes sense to someone, and works, but, unless you are storing that
shit of flash ram, or something, then writing it out to slower media,
you are doubling the amount of stuff you are doing, probably wearing out
the disk faster, since you are rewriting your transaction record to the
same swap area over and over, and so on. The whole, "write once, update
the table saying where the data is, and you are done", seems to me to
make a lot of damn sense, if you want to be *sure* it gets written. All
the rest is done for speed, not reliability. So.. Which is more
important to you, actually having the data, when you need it, or being
able to load/change it very very fast? You don't get to have both.
Date: 9 Jun 2011 16:32:43
Message: <4df12deb$1@news.povray.org>
On 6/9/2011 12:36, Patrick Elliott wrote:
> But, to do that, you have to go back to where the directory data is
> located, and update it to point at the now *actually there* data.
This is FAT. The directory data only points to the first granule. You have
to go back to the file allocation table for anything else. Which is exactly
why it's slow when you have lots of small files.
> Personally, I never *quite* understood how you get more reliability, with
> something like storing what you are doing, so you can replay it, if the disk
> gets unmounted.
The reliability comes from the fact that you're basically keeping both
copies around until you finish, and marking it as "finished" is atomic.
So you write a file. You have to update the directory, the allocation map
for what blocks the file occupied, and you have to clear the bits out of the
bitmap that says those blocks are free. Those three items might be in three
different places on the disk.  What happens if you record where the file is
stored, then mark those as used in the bitmap, and someone pulls out the
disk between those two steps?
With a journal, you'd record those two operations in the journal, then you'd
perform those two operations, then you'd record in the journal that you
completed them. Anything missing that last step gets rolled back, just like
in any other database system.
> You still need to have the shit you did *on* the disk, so
> you can replay it.
Right. But you don't overwrite the old version until *all* parts of the new
version are recorded. Just like in a database transaction, you don't
overwrite the balance of the account you're taking money out of before
you're recorded that you want to put money into the other account.
You basically wind up recording your intention, then executing your
intention, then recording that you've finished executing your intention. The
journal isn't really for efficiency as much as it is for reliability.
Of course, in this particular case, it serves as both, specifically
*because* you wind up being able to stage storing a bunch of files, *then*
doing a bunch of updates to areas of the disk that are far apart.
 > "write once, update the table saying where the data is, and you are
> done", seems to me to make a lot of damn sense,
That's how a lot of systems work, except you still eventually need to get
rid of the old stuff.
